I tried to capture an image that assuming the size is “1280x483”, but it failed.
Image size definition of my module is below :
- image width : 1280
- image height : 480
- embedded line data width : 128
- embedded line data height : 3
V4L2 command log is below :
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height : 1280/483
Pixel Format : 'RG12'
Field : None
Bytes per Line : 2560
Size Image : 1236480
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
^C
Device tree is below :
mode0 {
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1280";
active_h = "483";
embedded_metadata_height = "3";
Trace log is below :
# tracer: nop
# entries-in-buffer/entries-written: 331/331 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-23216 [000] .... 5378.074835: rtos_queue_peek_from_isr_failed: tstamp:168346871931 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5378.242894: rtos_queue_peek_from_isr_failed: tstamp:168351871926 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5378.410884: rtos_queue_peek_from_isr_failed: tstamp:168356871934 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5378.578906: rtos_queue_peek_from_isr_failed: tstamp:168361871947 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5378.746811: rtos_queue_peek_from_isr_failed: tstamp:168366871955 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5378.914829: rtos_queue_peek_from_isr_failed: tstamp:168371871983 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5379.082876: rtos_queue_peek_from_isr_failed: tstamp:168376871987 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5379.194897: rtos_queue_peek_from_isr_failed: tstamp:168381871966 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5379.362876: rtos_queue_peek_from_isr_failed: tstamp:168386871977 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5379.530895: rtos_queue_peek_from_isr_failed: tstamp:168391872008 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5379.698888: rtos_queue_peek_from_isr_failed: tstamp:168396872012 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5379.866872: rtos_queue_peek_from_isr_failed: tstamp:168401872005 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5380.034928: rtos_queue_peek_from_isr_failed: tstamp:168406872002 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5380.202891: rtos_queue_peek_from_isr_failed: tstamp:168411872034 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5380.314887: rtos_queue_peek_from_isr_failed: tstamp:168416872014 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5380.482896: rtos_queue_peek_from_isr_failed: tstamp:168421872023 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5380.650930: rtos_queue_peek_from_isr_failed: tstamp:168426872055 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5380.818867: rtos_queue_peek_from_isr_failed: tstamp:168431872035 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5380.986922: rtos_queue_peek_from_isr_failed: tstamp:168436872042 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5381.154900: rtos_queue_peek_from_isr_failed: tstamp:168441872049 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5381.270873: rtos_queue_peek_from_isr_failed: tstamp:168446872057 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5381.438880: rtos_queue_peek_from_isr_failed: tstamp:168451872064 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5381.606811: rtos_queue_peek_from_isr_failed: tstamp:168456872071 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5381.774891: rtos_queue_peek_from_isr_failed: tstamp:168461872104 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5381.942891: rtos_queue_peek_from_isr_failed: tstamp:168466872082 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5382.110912: rtos_queue_peek_from_isr_failed: tstamp:168471872090 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5382.278886: rtos_queue_peek_from_isr_failed: tstamp:168476872095 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5382.390932: rtos_queue_peek_from_isr_failed: tstamp:168481872105 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5382.558873: rtos_queue_peek_from_isr_failed: tstamp:168486872110 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5382.726927: rtos_queue_peek_from_isr_failed: tstamp:168491872117 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5382.894909: rtos_queue_peek_from_isr_failed: tstamp:168496872122 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5383.006837: rtos_queue_peek_from_isr_failed: tstamp:168500479402 queue:0x0b4b4500
v4l2-ctl-23451 [003] .... 5402.242314: tegra_channel_open: vi-output, imx516 2-0010
v4l2-ctl-23451 [000] .... 5402.245250: tegra_channel_set_power: imx516 2-0010 : 0x1
v4l2-ctl-23451 [000] .... 5402.245261: camera_common_s_power: status : 0x1
v4l2-ctl-23451 [000] .... 5402.251719: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-23451 [000] .... 5402.251747: csi_s_power: enable : 0x1
v4l2-ctl-23451 [000] .... 5402.260115: tegra_channel_capture_setup: vnc_id 0 W 1280 H 483 fmt 20
vi-output, imx5-23452 [005] .... 5402.260263: tegra_channel_set_stream: enable : 0x1
vi-output, imx5-23452 [000] .... 5402.261691: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx5-23452 [000] .... 5402.261694: csi_s_stream: enable : 0x1
vi-output, imx5-23452 [000] .... 5402.261720: tegra_channel_set_stream: imx516 2-0010 : 0x1
kworker/0:2-23216 [000] .... 5402.278805: rtos_queue_peek_from_isr_failed: tstamp:169102876322 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5402.278810: rtcpu_start: tstamp:169102877292
kworker/0:2-23216 [000] .... 5402.278812: rtos_queue_send_from_isr_failed: tstamp:169102885920 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.278814: rtos_queue_send_from_isr_failed: tstamp:169102886026 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5402.278814: rtos_queue_send_from_isr_failed: tstamp:169102886134 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5402.278815: rtos_queue_send_from_isr_failed: tstamp:169102886240 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5402.278816: rtos_queue_send_from_isr_failed: tstamp:169102886345 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5402.278816: rtos_queue_send_from_isr_failed: tstamp:169102886450 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5402.278817: rtos_queue_send_from_isr_failed: tstamp:169102886554 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5402.278818: rtos_queue_send_from_isr_failed: tstamp:169102886671 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5402.278820: rtos_queue_send_failed: tstamp:169102887166 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.278820: rtos_queue_send_from_isr_failed: tstamp:169102889096 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.278821: rtos_queue_send_from_isr_failed: tstamp:169102889210 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5402.278822: rtos_queue_send_from_isr_failed: tstamp:169102889315 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5402.278822: rtos_queue_send_from_isr_failed: tstamp:169102889420 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5402.278823: rtos_queue_send_from_isr_failed: tstamp:169102889525 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5402.278824: rtos_queue_send_from_isr_failed: tstamp:169102889630 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5402.278824: rtos_queue_send_from_isr_failed: tstamp:169102889735 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5402.278825: rtos_queue_send_from_isr_failed: tstamp:169102889841 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5402.278826: rtos_queue_send_failed: tstamp:169102890758 queue:0x0b4a7258
vi-output, imx5-23452 [003] .... 5402.404060: tegra_channel_capture_frame: sof:5402.297085809
kworker/0:2-23216 [000] .... 5402.446890: rtcpu_vinotify_event: tstamp:169107384275 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:169107383741 data:0x00000001
kworker/0:2-23216 [000] .... 5402.446899: rtcpu_vinotify_event: tstamp:169107384472 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:169107383754 data:0x00000000
kworker/0:2-23216 [000] .... 5402.446902: rtcpu_vinotify_event: tstamp:169107393646 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:1 vi_tstamp:169107393277 data:0x08000000
kworker/0:2-23216 [000] .... 5402.446905: rtcpu_vinotify_event: tstamp:169107745920 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:169107745338 data:0x00000001
kworker/0:2-23216 [000] .... 5402.446907: rtcpu_vinotify_event: tstamp:169107746138 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:169107745339 data:0x00000000
kworker/0:2-23216 [000] .... 5402.446913: rtos_queue_peek_from_isr_failed: tstamp:169107876687 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5402.614850: rtos_queue_peek_from_isr_failed: tstamp:169112876684 queue:0x0b4b4500
vi-output, imx5-23452 [003] .... 5402.623994: tegra_channel_capture_setup: vnc_id 0 W 1280 H 483 fmt 20
vi-output, imx5-23452 [003] .... 5402.624058: tegra_channel_capture_frame: sof:5402.297085809
vi-output, imx5-23452 [000] .... 5402.640588: tegra_channel_capture_frame: sof:5402.533635714
kworker/0:3-23024 [000] .... 5402.670975: rtos_queue_send_from_isr_failed: tstamp:169114236020 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.670981: rtos_queue_send_from_isr_failed: tstamp:169114236147 queue:0x0b4aad68
kworker/0:3-23024 [000] .... 5402.670983: rtos_queue_send_from_isr_failed: tstamp:169114236267 queue:0x0b4ac998
kworker/0:3-23024 [000] .... 5402.670985: rtos_queue_send_from_isr_failed: tstamp:169114236385 queue:0x0b4ae518
kworker/0:3-23024 [000] .... 5402.670988: rtos_queue_send_from_isr_failed: tstamp:169114236501 queue:0x0b4af2d8
kworker/0:3-23024 [000] .... 5402.670990: rtos_queue_send_from_isr_failed: tstamp:169114236620 queue:0x0b4b0098
kworker/0:3-23024 [000] .... 5402.671016: rtos_queue_send_from_isr_failed: tstamp:169114236738 queue:0x0b4b0e58
kworker/0:3-23024 [000] .... 5402.671020: rtos_queue_send_from_isr_failed: tstamp:169114236855 queue:0x0b4b1c18
kworker/0:3-23024 [000] .... 5402.671023: rtos_queue_send_failed: tstamp:169114237473 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.671026: rtos_queue_send_from_isr_failed: tstamp:169114245235 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.671028: rtos_queue_send_from_isr_failed: tstamp:169114245355 queue:0x0b4aad68
kworker/0:3-23024 [000] .... 5402.671030: rtos_queue_send_from_isr_failed: tstamp:169114245473 queue:0x0b4ac998
kworker/0:3-23024 [000] .... 5402.671033: rtos_queue_send_from_isr_failed: tstamp:169114245592 queue:0x0b4ae518
kworker/0:3-23024 [000] .... 5402.671035: rtos_queue_send_from_isr_failed: tstamp:169114245709 queue:0x0b4af2d8
kworker/0:3-23024 [000] .... 5402.671037: rtos_queue_send_from_isr_failed: tstamp:169114245838 queue:0x0b4b0098
kworker/0:3-23024 [000] .... 5402.671039: rtos_queue_send_from_isr_failed: tstamp:169114245958 queue:0x0b4b0e58
kworker/0:3-23024 [000] .... 5402.671042: rtos_queue_send_from_isr_failed: tstamp:169114246074 queue:0x0b4b1c18
kworker/0:3-23024 [000] .... 5402.671044: rtos_queue_send_failed: tstamp:169114246554 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.671046: rtos_queue_send_from_isr_failed: tstamp:169114254053 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.671048: rtos_queue_send_from_isr_failed: tstamp:169114254173 queue:0x0b4aad68
kworker/0:3-23024 [000] .... 5402.671051: rtos_queue_send_from_isr_failed: tstamp:169114254306 queue:0x0b4ac998
kworker/0:3-23024 [000] .... 5402.671053: rtos_queue_send_from_isr_failed: tstamp:169114254425 queue:0x0b4ae518
kworker/0:3-23024 [000] .... 5402.671055: rtos_queue_send_from_isr_failed: tstamp:169114254542 queue:0x0b4af2d8
kworker/0:3-23024 [000] .... 5402.671057: rtos_queue_send_from_isr_failed: tstamp:169114254658 queue:0x0b4b0098
kworker/0:3-23024 [000] .... 5402.671060: rtos_queue_send_from_isr_failed: tstamp:169114254775 queue:0x0b4b0e58
kworker/0:3-23024 [000] .... 5402.671062: rtos_queue_send_from_isr_failed: tstamp:169114254892 queue:0x0b4b1c18
kworker/0:3-23024 [000] .... 5402.671064: rtos_queue_send_failed: tstamp:169114255400 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.671067: rtos_queue_send_from_isr_failed: tstamp:169114258718 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.671069: rtos_queue_send_from_isr_failed: tstamp:169114258854 queue:0x0b4aad68
kworker/0:3-23024 [000] .... 5402.671071: rtos_queue_send_from_isr_failed: tstamp:169114258972 queue:0x0b4ac998
kworker/0:3-23024 [000] .... 5402.671073: rtos_queue_send_from_isr_failed: tstamp:169114259092 queue:0x0b4ae518
kworker/0:3-23024 [000] .... 5402.671076: rtos_queue_send_from_isr_failed: tstamp:169114259212 queue:0x0b4af2d8
kworker/0:3-23024 [000] .... 5402.671078: rtos_queue_send_from_isr_failed: tstamp:169114259329 queue:0x0b4b0098
kworker/0:3-23024 [000] .... 5402.671080: rtos_queue_send_from_isr_failed: tstamp:169114259447 queue:0x0b4b0e58
kworker/0:3-23024 [000] .... 5402.671082: rtos_queue_send_from_isr_failed: tstamp:169114259565 queue:0x0b4b1c18
kworker/0:3-23024 [000] .... 5402.671085: rtos_queue_send_failed: tstamp:169114260674 queue:0x0b4a7258
kworker/0:3-23024 [000] .... 5402.671089: rtcpu_vinotify_event: tstamp:169114327879 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:169114327496 data:0x00000001
kworker/0:3-23024 [000] .... 5402.671091: rtcpu_vinotify_event: tstamp:169114776443 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:169114775933 data:0x00000001
kworker/0:3-23024 [000] .... 5402.671093: rtcpu_vinotify_event: tstamp:169114776624 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:169114775945 data:0x00000000
kworker/0:3-23024 [000] .... 5402.671095: rtcpu_vinotify_event: tstamp:169114784970 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:16 vi_tstamp:169114784603 data:0x08000000
kworker/0:3-23024 [000] .... 5402.671097: rtcpu_vinotify_event: tstamp:169115138116 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:16 vi_tstamp:169115137535 data:0x00000001
kworker/0:3-23024 [000] .... 5402.671099: rtcpu_vinotify_event: tstamp:169115138334 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:169115137537 data:0x00000000
kworker/0:2-23216 [000] .... 5402.782924: rtos_queue_peek_from_isr_failed: tstamp:169117876725 queue:0x0b4b4500
vi-output, imx5-23452 [000] .... 5402.860018: tegra_channel_capture_setup: vnc_id 0 W 1280 H 483 fmt 20
vi-output, imx5-23452 [000] .... 5402.860065: tegra_channel_capture_frame: sof:5402.533635714
vi-output, imx5-23452 [000] .... 5402.869634: tegra_channel_capture_frame: sof:5402.762765976
kworker/0:2-23216 [000] .... 5402.895018: rtos_queue_send_from_isr_failed: tstamp:169121622199 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895024: rtos_queue_send_from_isr_failed: tstamp:169121622333 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5402.895027: rtos_queue_send_from_isr_failed: tstamp:169121622466 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5402.895029: rtos_queue_send_from_isr_failed: tstamp:169121622586 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5402.895032: rtos_queue_send_from_isr_failed: tstamp:169121622709 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5402.895056: rtos_queue_send_from_isr_failed: tstamp:169121622824 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5402.895058: rtos_queue_send_from_isr_failed: tstamp:169121622941 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5402.895060: rtos_queue_send_from_isr_failed: tstamp:169121623058 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5402.895064: rtos_queue_send_failed: tstamp:169121623684 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895066: rtos_queue_send_from_isr_failed: tstamp:169121626244 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895069: rtos_queue_send_from_isr_failed: tstamp:169121626363 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5402.895071: rtos_queue_send_from_isr_failed: tstamp:169121626481 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5402.895074: rtos_queue_send_from_isr_failed: tstamp:169121626599 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5402.895076: rtos_queue_send_from_isr_failed: tstamp:169121626714 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5402.895081: rtos_queue_send_from_isr_failed: tstamp:169121626831 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5402.895084: rtos_queue_send_from_isr_failed: tstamp:169121626946 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5402.895086: rtos_queue_send_from_isr_failed: tstamp:169121627062 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5402.895088: rtos_queue_send_failed: tstamp:169121627548 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895091: rtos_queue_send_from_isr_failed: tstamp:169121631952 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895093: rtos_queue_send_from_isr_failed: tstamp:169121632068 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5402.895095: rtos_queue_send_from_isr_failed: tstamp:169121632189 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5402.895098: rtos_queue_send_from_isr_failed: tstamp:169121632308 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5402.895100: rtos_queue_send_from_isr_failed: tstamp:169121632425 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5402.895102: rtos_queue_send_from_isr_failed: tstamp:169121632542 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5402.895104: rtos_queue_send_from_isr_failed: tstamp:169121632657 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5402.895106: rtos_queue_send_from_isr_failed: tstamp:169121632774 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5402.895109: rtos_queue_send_failed: tstamp:169121633260 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895111: rtos_queue_send_from_isr_failed: tstamp:169121635362 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895113: rtos_queue_send_from_isr_failed: tstamp:169121635481 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5402.895115: rtos_queue_send_from_isr_failed: tstamp:169121635599 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5402.895118: rtos_queue_send_from_isr_failed: tstamp:169121635717 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5402.895120: rtos_queue_send_from_isr_failed: tstamp:169121635834 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5402.895122: rtos_queue_send_from_isr_failed: tstamp:169121635951 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5402.895124: rtos_queue_send_from_isr_failed: tstamp:169121636066 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5402.895127: rtos_queue_send_from_isr_failed: tstamp:169121636181 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5402.895129: rtos_queue_send_failed: tstamp:169121637260 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5402.895134: rtcpu_vinotify_event: tstamp:169121936776 tag:CHANSEL_PXL_SOF channel:0x00 frame:29 vi_tstamp:169121936261 data:0x00000001
kworker/0:2-23216 [000] .... 5402.895136: rtcpu_vinotify_event: tstamp:169121936939 tag:ATOMP_FS channel:0x00 frame:29 vi_tstamp:169121936274 data:0x00000000
kworker/0:2-23216 [000] .... 5402.895156: rtcpu_vinotify_event: tstamp:169121941335 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:29 vi_tstamp:169121940972 data:0x08000000
kworker/0:2-23216 [000] .... 5402.895158: rtcpu_vinotify_event: tstamp:169122298444 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:29 vi_tstamp:169122297858 data:0x00000001
kworker/0:2-23216 [000] .... 5402.895160: rtcpu_vinotify_event: tstamp:169122298662 tag:ATOMP_FE channel:0x00 frame:29 vi_tstamp:169122297859 data:0x00000000
kworker/0:2-23216 [000] .... 5402.950984: rtos_queue_peek_from_isr_failed: tstamp:169122876699 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5403.062909: rtos_queue_peek_from_isr_failed: tstamp:169127876707 queue:0x0b4b4500
vi-output, imx5-23452 [005] .... 5403.104182: tegra_channel_capture_setup: vnc_id 0 W 1280 H 483 fmt 20
vi-output, imx5-23452 [005] .... 5403.104236: tegra_channel_capture_frame: sof:5402.762765976
vi-output, imx5-23452 [003] .... 5403.113137: tegra_channel_capture_frame: sof:5403.6236101
kworker/0:2-23216 [000] .... 5403.118840: rtos_queue_send_from_isr_failed: tstamp:169128737612 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118844: rtos_queue_send_from_isr_failed: tstamp:169128737736 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.118846: rtos_queue_send_from_isr_failed: tstamp:169128737858 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.118848: rtos_queue_send_from_isr_failed: tstamp:169128737977 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.118850: rtos_queue_send_from_isr_failed: tstamp:169128738094 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.118851: rtos_queue_send_from_isr_failed: tstamp:169128738211 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.118853: rtos_queue_send_from_isr_failed: tstamp:169128738327 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.118855: rtos_queue_send_from_isr_failed: tstamp:169128738444 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.118858: rtos_queue_send_failed: tstamp:169128739059 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118859: rtos_queue_send_from_isr_failed: tstamp:169128743111 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118861: rtos_queue_send_from_isr_failed: tstamp:169128743230 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.118863: rtos_queue_send_from_isr_failed: tstamp:169128743349 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.118865: rtos_queue_send_from_isr_failed: tstamp:169128743467 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.118866: rtos_queue_send_from_isr_failed: tstamp:169128743584 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.118868: rtos_queue_send_from_isr_failed: tstamp:169128743701 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.118869: rtos_queue_send_from_isr_failed: tstamp:169128743818 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.118871: rtos_queue_send_from_isr_failed: tstamp:169128743934 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.118873: rtos_queue_send_failed: tstamp:169128744413 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118874: rtos_queue_send_from_isr_failed: tstamp:169129258988 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118876: rtos_queue_send_from_isr_failed: tstamp:169129259108 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.118878: rtos_queue_send_from_isr_failed: tstamp:169129259228 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.118879: rtos_queue_send_from_isr_failed: tstamp:169129259347 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.118881: rtos_queue_send_from_isr_failed: tstamp:169129259464 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.118883: rtos_queue_send_from_isr_failed: tstamp:169129259593 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.118885: rtos_queue_send_from_isr_failed: tstamp:169129259714 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.118886: rtos_queue_send_from_isr_failed: tstamp:169129259837 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.118888: rtos_queue_send_failed: tstamp:169129260348 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118889: rtos_queue_send_from_isr_failed: tstamp:169129264159 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118891: rtos_queue_send_from_isr_failed: tstamp:169129264278 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.118893: rtos_queue_send_from_isr_failed: tstamp:169129264396 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.118895: rtos_queue_send_from_isr_failed: tstamp:169129264514 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.118896: rtos_queue_send_from_isr_failed: tstamp:169129264631 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.118898: rtos_queue_send_from_isr_failed: tstamp:169129264749 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.118900: rtos_queue_send_from_isr_failed: tstamp:169129264864 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.118901: rtos_queue_send_from_isr_failed: tstamp:169129264983 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.118903: rtos_queue_send_failed: tstamp:169129266091 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.118907: rtcpu_vinotify_event: tstamp:169129545216 tag:CHANSEL_PXL_SOF channel:0x00 frame:43 vi_tstamp:169129544704 data:0x00000001
kworker/0:2-23216 [000] .... 5403.118908: rtcpu_vinotify_event: tstamp:169129545396 tag:ATOMP_FS channel:0x00 frame:43 vi_tstamp:169129544717 data:0x00000000
kworker/0:2-23216 [000] .... 5403.118910: rtcpu_vinotify_event: tstamp:169129551430 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:43 vi_tstamp:169129551061 data:0x08000000
kworker/0:2-23216 [000] .... 5403.174890: rtcpu_vinotify_event: tstamp:169129906888 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:43 vi_tstamp:169129906306 data:0x00000001
kworker/0:2-23216 [000] .... 5403.174896: rtcpu_vinotify_event: tstamp:169129907111 tag:ATOMP_FE channel:0x00 frame:43 vi_tstamp:169129906307 data:0x00000000
kworker/0:2-23216 [000] .... 5403.230916: rtos_queue_peek_from_isr_failed: tstamp:169132876725 queue:0x0b4b4500
vi-output, imx5-23452 [003] .... 5403.347999: tegra_channel_capture_setup: vnc_id 0 W 1280 H 483 fmt 20
vi-output, imx5-23452 [003] .... 5403.348041: tegra_channel_capture_frame: sof:5403.6236101
kworker/0:2-23216 [000] .... 5403.350804: rtos_queue_send_from_isr_failed: tstamp:169136361523 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.350806: rtos_queue_send_from_isr_failed: tstamp:169136361646 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.350807: rtos_queue_send_from_isr_failed: tstamp:169136361767 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.350808: rtos_queue_send_from_isr_failed: tstamp:169136361885 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.350809: rtos_queue_send_from_isr_failed: tstamp:169136362000 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.350810: rtos_queue_send_from_isr_failed: tstamp:169136362115 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.350811: rtos_queue_send_from_isr_failed: tstamp:169136362231 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.350812: rtos_queue_send_from_isr_failed: tstamp:169136362346 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.350814: rtos_queue_send_failed: tstamp:169136362987 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.350814: rtos_queue_send_from_isr_failed: tstamp:169136369477 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.350815: rtos_queue_send_from_isr_failed: tstamp:169136369597 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.350816: rtos_queue_send_from_isr_failed: tstamp:169136369718 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.350817: rtos_queue_send_from_isr_failed: tstamp:169136369837 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.350818: rtos_queue_send_from_isr_failed: tstamp:169136369967 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.350819: rtos_queue_send_from_isr_failed: tstamp:169136370082 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.350820: rtos_queue_send_from_isr_failed: tstamp:169136370200 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.350821: rtos_queue_send_from_isr_failed: tstamp:169136370317 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.350822: rtos_queue_send_failed: tstamp:169136370811 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.350822: rtos_queue_send_from_isr_failed: tstamp:169136882463 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.350823: rtos_queue_send_from_isr_failed: tstamp:169136882584 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.350824: rtos_queue_send_from_isr_failed: tstamp:169136882703 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.350825: rtos_queue_send_from_isr_failed: tstamp:169136882822 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.350826: rtos_queue_send_from_isr_failed: tstamp:169136882939 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.350827: rtos_queue_send_from_isr_failed: tstamp:169136883057 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.350828: rtos_queue_send_from_isr_failed: tstamp:169136883174 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.350828: rtos_queue_send_from_isr_failed: tstamp:169136883289 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.350829: rtos_queue_send_failed: tstamp:169136883791 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.350830: rtos_queue_send_from_isr_failed: tstamp:169136885352 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.350831: rtos_queue_send_from_isr_failed: tstamp:169136885486 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.350832: rtos_queue_send_from_isr_failed: tstamp:169136885602 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.350833: rtos_queue_send_from_isr_failed: tstamp:169136885720 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.350834: rtos_queue_send_from_isr_failed: tstamp:169136885838 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.350834: rtos_queue_send_from_isr_failed: tstamp:169136885955 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.350835: rtos_queue_send_from_isr_failed: tstamp:169136886074 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.350836: rtos_queue_send_from_isr_failed: tstamp:169136886191 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.350837: rtos_queue_send_failed: tstamp:169136887279 queue:0x0b4a7258
vi-output, imx5-23452 [003] .... 5403.371065: tegra_channel_capture_frame: sof:5403.264066602
kworker/0:2-23216 [000] .... 5403.406917: rtcpu_vinotify_event: tstamp:169137140410 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:169137140034 data:0x00000001
kworker/0:2-23216 [000] .... 5403.406924: rtcpu_vinotify_event: tstamp:169137602417 tag:CHANSEL_PXL_SOF channel:0x00 frame:58 vi_tstamp:169137601905 data:0x00000001
kworker/0:2-23216 [000] .... 5403.406926: rtcpu_vinotify_event: tstamp:169137602599 tag:ATOMP_FS channel:0x00 frame:58 vi_tstamp:169137601917 data:0x00000000
kworker/0:2-23216 [000] .... 5403.406928: rtcpu_vinotify_event: tstamp:169137617504 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:58 vi_tstamp:169137617136 data:0x08000000
kworker/0:2-23216 [000] .... 5403.406933: rtos_queue_peek_from_isr_failed: tstamp:169137876722 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5403.406935: rtcpu_vinotify_event: tstamp:169137964088 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:58 vi_tstamp:169137963504 data:0x00000001
kworker/0:2-23216 [000] .... 5403.406937: rtcpu_vinotify_event: tstamp:169137964307 tag:ATOMP_FE channel:0x00 frame:58 vi_tstamp:169137963506 data:0x00000000
v4l2-ctl-23451 [000] .... 5403.533502: tegra_channel_close: vi-output, imx516 2-0010
kworker/0:2-23216 [000] .... 5403.574909: rtos_queue_peek_from_isr_failed: tstamp:169142876774 queue:0x0b4b4500
vi-output, imx5-23452 [000] .... 5403.611896: tegra_channel_capture_setup: vnc_id 0 W 1280 H 483 fmt 20
vi-output, imx5-23452 [000] .... 5403.611961: tegra_channel_capture_frame: sof:5403.264066602
v4l2-ctl-23451 [000] .... 5403.612410: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-23451 [000] .... 5403.612417: tegra_channel_set_stream: imx516 2-0010 : 0x0
v4l2-ctl-23451 [000] .... 5403.612687: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-23451 [000] .... 5403.612695: csi_s_stream: enable : 0x0
v4l2-ctl-23451 [000] .... 5403.618873: tegra_channel_set_power: imx516 2-0010 : 0x0
v4l2-ctl-23451 [000] .... 5403.618887: camera_common_s_power: status : 0x0
v4l2-ctl-23451 [000] .... 5403.621069: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-23451 [000] .... 5403.621076: csi_s_power: enable : 0x0
kworker/0:2-23216 [000] .... 5403.630816: rtos_queue_send_from_isr_failed: tstamp:169144608017 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630822: rtos_queue_send_from_isr_failed: tstamp:169144608190 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.630824: rtos_queue_send_from_isr_failed: tstamp:169144608332 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.630826: rtos_queue_send_from_isr_failed: tstamp:169144608481 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.630828: rtos_queue_send_from_isr_failed: tstamp:169144608618 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.630830: rtos_queue_send_from_isr_failed: tstamp:169144608759 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.630832: rtos_queue_send_from_isr_failed: tstamp:169144608896 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.630834: rtos_queue_send_from_isr_failed: tstamp:169144609033 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.630840: rtos_queue_send_failed: tstamp:169144609780 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630842: rtos_queue_send_from_isr_failed: tstamp:169144615527 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630844: rtos_queue_send_from_isr_failed: tstamp:169144615688 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.630846: rtos_queue_send_from_isr_failed: tstamp:169144615828 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.630848: rtos_queue_send_from_isr_failed: tstamp:169144615968 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.630850: rtos_queue_send_from_isr_failed: tstamp:169144616105 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.630852: rtos_queue_send_from_isr_failed: tstamp:169144616243 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.630854: rtos_queue_send_from_isr_failed: tstamp:169144616380 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.630855: rtos_queue_send_from_isr_failed: tstamp:169144616518 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.630857: rtos_queue_send_failed: tstamp:169144617093 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630859: rtos_queue_send_from_isr_failed: tstamp:169145128786 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630861: rtos_queue_send_from_isr_failed: tstamp:169145128906 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.630863: rtos_queue_send_from_isr_failed: tstamp:169145129014 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.630864: rtos_queue_send_from_isr_failed: tstamp:169145129120 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.630866: rtos_queue_send_from_isr_failed: tstamp:169145129224 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.630868: rtos_queue_send_from_isr_failed: tstamp:169145129328 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.630870: rtos_queue_send_from_isr_failed: tstamp:169145129433 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.630872: rtos_queue_send_from_isr_failed: tstamp:169145129539 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.630873: rtos_queue_send_failed: tstamp:169145129986 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630875: rtos_queue_send_from_isr_failed: tstamp:169145132243 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630877: rtos_queue_send_from_isr_failed: tstamp:169145132358 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.630879: rtos_queue_send_from_isr_failed: tstamp:169145132465 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.630881: rtos_queue_send_from_isr_failed: tstamp:169145132571 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.630882: rtos_queue_send_from_isr_failed: tstamp:169145132675 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.630884: rtos_queue_send_from_isr_failed: tstamp:169145132778 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.630886: rtos_queue_send_from_isr_failed: tstamp:169145132883 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.630888: rtos_queue_send_from_isr_failed: tstamp:169145132988 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.630890: rtos_queue_send_failed: tstamp:169145133913 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630892: rtos_queue_send_from_isr_failed: tstamp:169145138392 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630914: rtos_queue_send_from_isr_failed: tstamp:169145138515 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.630916: rtos_queue_send_from_isr_failed: tstamp:169145138621 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.630918: rtos_queue_send_from_isr_failed: tstamp:169145138727 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.630920: rtos_queue_send_from_isr_failed: tstamp:169145138831 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.630922: rtos_queue_send_from_isr_failed: tstamp:169145138936 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.630924: rtos_queue_send_from_isr_failed: tstamp:169145139041 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.630926: rtos_queue_send_from_isr_failed: tstamp:169145139145 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.630927: rtos_queue_send_failed: tstamp:169145139701 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630929: rtos_queue_send_from_isr_failed: tstamp:169145142887 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.630931: rtos_queue_send_from_isr_failed: tstamp:169145142994 queue:0x0b4aad68
kworker/0:2-23216 [000] .... 5403.630933: rtos_queue_send_from_isr_failed: tstamp:169145143100 queue:0x0b4ac998
kworker/0:2-23216 [000] .... 5403.630935: rtos_queue_send_from_isr_failed: tstamp:169145143206 queue:0x0b4ae518
kworker/0:2-23216 [000] .... 5403.630937: rtos_queue_send_from_isr_failed: tstamp:169145143311 queue:0x0b4af2d8
kworker/0:2-23216 [000] .... 5403.630939: rtos_queue_send_from_isr_failed: tstamp:169145143416 queue:0x0b4b0098
kworker/0:2-23216 [000] .... 5403.630940: rtos_queue_send_from_isr_failed: tstamp:169145143523 queue:0x0b4b0e58
kworker/0:2-23216 [000] .... 5403.630942: rtos_queue_send_from_isr_failed: tstamp:169145143626 queue:0x0b4b1c18
kworker/0:2-23216 [000] .... 5403.630944: rtos_queue_send_failed: tstamp:169145144059 queue:0x0b4a7258
kworker/0:2-23216 [000] .... 5403.742928: rtos_queue_peek_from_isr_failed: tstamp:169147876762 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5403.910885: rtos_queue_peek_from_isr_failed: tstamp:169152876754 queue:0x0b4b4500
kworker/0:2-23216 [000] .... 5404.022875: rtos_queue_peek_from_isr_failed: tstamp:169157876761 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5404.190911: rtos_queue_peek_from_isr_failed: tstamp:169162876801 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5404.358895: rtos_queue_peek_from_isr_failed: tstamp:169167876772 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5404.526879: rtos_queue_peek_from_isr_failed: tstamp:169172876771 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5404.694893: rtos_queue_peek_from_isr_failed: tstamp:169177876771 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5404.862929: rtos_queue_peek_from_isr_failed: tstamp:169182876798 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5405.030888: rtos_queue_peek_from_isr_failed: tstamp:169187876839 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5405.142936: rtos_queue_peek_from_isr_failed: tstamp:169192876808 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5405.310842: rtos_queue_peek_from_isr_failed: tstamp:169197876814 queue:0x0b4b4500
kworker/0:3-23024 [000] .... 5405.478912: rtos_queue_peek_from_isr_failed: tstamp:169202876819 queue:0x0b4b4500
I think it failed because image width and embedded data line width are different.
However, I don’t know how to handle it.
My questions are :
How can I gather an image including embedded line data using v4l2 api?"
- Do I need to modify source code? or to modify some settings?
- which part do I need to check?
Should active_h value set to 480 in device tree?? (Previously I set to 483)
