When I use the cmd show below, I cannot get image.
cmd: v4l2-ctl --set-fmt-video=width=1280,height=768,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 -d /dev/video0
dmesg:
[ 502.072933] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 128, err_data 131072
[ 504.698948] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 504.699088] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
the message print by rtcpu is show below. I want to know “CHANSEL_NOMATCH” means what, and “data:0x00000549” means what. Thank you.
tracer: nop
entries-in-buffer/entries-written: 2467/2467 #P:8
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/1:2-1776 [001] .... 465.644845: rtos_queue_peek_from_isr_failed: tstamp:14738625317 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 465.644851: rtcpu_start: tstamp:14738626444
kworker/1:2-1776 [001] .... 465.644853: rtos_queue_send_from_isr_failed: tstamp:14738647952 queue:0x0bcb41f8
kworker/1:2-1776 [001] .... 465.644854: rtos_queue_send_from_isr_failed: tstamp:14738648091 queue:0x0bcb8a60
kworker/1:2-1776 [001] .... 465.644884: rtos_queue_send_from_isr_failed: tstamp:14738648229 queue:0x0bcba5e0
kworker/1:2-1776 [001] .... 465.644885: rtos_queue_send_from_isr_failed: tstamp:14738648363 queue:0x0bcbb3a0
kworker/1:2-1776 [001] .... 465.644886: rtos_queue_send_from_isr_failed: tstamp:14738648497 queue:0x0bcbc160
kworker/1:2-1776 [001] .... 465.644889: rtcpu_dbg_set_loglevel: tstamp:14738649879 old:0 new:2
kworker/1:2-1776 [001] .... 465.644890: rtos_queue_send_from_isr_failed: tstamp:14738652152 queue:0x0bcb41f8
kworker/1:2-1776 [001] .... 465.644891: rtos_queue_send_from_isr_failed: tstamp:14738652287 queue:0x0bcb8a60
kworker/1:2-1776 [001] .... 465.644891: rtos_queue_send_from_isr_failed: tstamp:14738652426 queue:0x0bcba5e0
kworker/1:2-1776 [001] .... 465.644892: rtos_queue_send_from_isr_failed: tstamp:14738652558 queue:0x0bcbb3a0
kworker/1:2-1776 [001] .... 465.644893: rtos_queue_send_from_isr_failed: tstamp:14738652690 queue:0x0bcbc160
kworker/1:2-1776 [001] .... 465.812836: rtos_queue_peek_from_isr_failed: tstamp:14743625681 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 465.980861: rtos_queue_peek_from_isr_failed: tstamp:14748625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 466.152844: rtos_queue_peek_from_isr_failed: tstamp:14753625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 466.268847: rtos_queue_peek_from_isr_failed: tstamp:14758625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 466.436852: rtos_queue_peek_from_isr_failed: tstamp:14763625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 466.608828: rtos_queue_peek_from_isr_failed: tstamp:14768625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 466.776843: rtos_queue_peek_from_isr_failed: tstamp:14773625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 466.944841: rtos_queue_peek_from_isr_failed: tstamp:14778625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 467.120837: rtos_queue_peek_from_isr_failed: tstamp:14783625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 467.232839: rtos_queue_peek_from_isr_failed: tstamp:14788625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 467.404820: rtos_queue_peek_from_isr_failed: tstamp:14793625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 467.576815: rtos_queue_peek_from_isr_failed: tstamp:14798625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 467.744830: rtos_queue_peek_from_isr_failed: tstamp:14803625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 467.912838: rtos_queue_peek_from_isr_failed: tstamp:14808625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 468.024848: rtos_queue_peek_from_isr_failed: tstamp:14813625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 468.192815: rtos_queue_peek_from_isr_failed: tstamp:14818625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 468.364831: rtos_queue_peek_from_isr_failed: tstamp:14823625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 468.540839: rtos_queue_peek_from_isr_failed: tstamp:14828625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 468.716846: rtos_queue_peek_from_isr_failed: tstamp:14833625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 468.828815: rtos_queue_peek_from_isr_failed: tstamp:14838625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 469.004792: rtos_queue_peek_from_isr_failed: tstamp:14843625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 469.176803: rtos_queue_peek_from_isr_failed: tstamp:14848625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 469.352842: rtos_queue_peek_from_isr_failed: tstamp:14853625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 469.464833: rtos_queue_peek_from_isr_failed: tstamp:14858625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 469.632819: rtos_queue_peek_from_isr_failed: tstamp:14863625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 469.800787: rtos_queue_peek_from_isr_failed: tstamp:14868625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 469.968804: rtos_queue_peek_from_isr_failed: tstamp:14873625679 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 470.140828: rtos_queue_peek_from_isr_failed: tstamp:14878625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 470.312824: rtos_queue_peek_from_isr_failed: tstamp:14883625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 470.424814: rtos_queue_peek_from_isr_failed: tstamp:14888625679 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 470.592806: rtos_queue_peek_from_isr_failed: tstamp:14893625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 470.760804: rtos_queue_peek_from_isr_failed: tstamp:14898625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 470.936785: rtos_queue_peek_from_isr_failed: tstamp:14903625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 471.108823: rtos_queue_peek_from_isr_failed: tstamp:14908625677 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 471.224822: rtos_queue_peek_from_isr_failed: tstamp:14913625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 471.396817: rtos_queue_peek_from_isr_failed: tstamp:14918625678 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 471.456815: rtos_queue_peek_from_isr_failed: tstamp:14919824926 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 502.063170: rtos_queue_peek_from_isr_failed: tstamp:15876434004 queue:0x0bcbcf78
kworker/1:2-1776 [001] .... 502.063175: rtcpu_start: tstamp:15876435135
kworker/1:2-1776 [001] .... 502.063199: rtos_queue_send_from_isr_failed: tstamp:15876445229 queue:0x0bcb41f8
kworker/1:2-1776 [001] .... 502.063200: rtos_queue_send_from_isr_failed: tstamp:15876445368 queue:0x0bcb8a60
kworker/1:2-1776 [001] .... 502.063201: rtos_queue_send_from_isr_failed: tstamp:15876445504 queue:0x0bcba5e0
kworker/1:2-1776 [001] .... 502.063201: rtos_queue_send_from_isr_failed: tstamp:15876445646 queue:0x0bcbb3a0
kworker/1:2-1776 [001] .... 502.063202: rtos_queue_send_from_isr_failed: tstamp:15876445780 queue:0x0bcbc160
kworker/1:2-1776 [001] .... 502.063204: rtcpu_string: tstamp:15876446181 id:0x04010000 str:"Configuring VI GoS.
kworker/1:2-1776 [001] … 502.063309: rtcpu_string: tstamp:15876446356 id:0x04010000 str:"VM GOS[#0] addr=0xb4900000
kworker/1:2-1776 [001] … 502.063390: rtcpu_string: tstamp:15876446597 id:0x04010000 str:"VM GOS[#1] addr=0xb4901000
kworker/1:2-1776 [001] … 502.063475: rtcpu_string: tstamp:15876446870 id:0x04010000 str:"VM GOS[#2] addr=0xb4902000
kworker/1:2-1776 [001] … 502.063554: rtcpu_string: tstamp:15876447090 id:0x04010000 str:"VM GOS[#3] addr=0xb4903000
kworker/1:2-1776 [001] … 502.063629: rtcpu_string: tstamp:15876447309 id:0x04010000 str:"VM GOS[#4] addr=0xb4904000
kworker/1:2-1776 [001] … 502.063707: rtcpu_string: tstamp:15876447528 id:0x04010000 str:"VM GOS[#5] addr=0xb4905000
kworker/1:2-1776 [001] … 502.063781: rtcpu_string: tstamp:15876455193 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/1:2-1776 [001] … 502.063783: rtcpu_string: tstamp:15876455316 id:0x04010000 str:"on 2.2
kworker/1:2-1776 [001] … 502.063896: rtos_queue_send_from_isr_failed: tstamp:15876468258 queue:0x0bcb41f8
kworker/1:2-1776 [001] … 502.063898: rtos_queue_send_from_isr_failed: tstamp:15876468411 queue:0x0bcb8a60
kworker/1:2-1776 [001] … 502.063898: rtos_queue_send_from_isr_failed: tstamp:15876468553 queue:0x0bcba5e0
kworker/1:2-1776 [001] … 502.063899: rtos_queue_send_from_isr_failed: tstamp:15876468686 queue:0x0bcbb3a0
kworker/1:2-1776 [001] … 502.063900: rtos_queue_send_from_isr_failed: tstamp:15876468818 queue:0x0bcbc160
kworker/1:2-1776 [001] … 502.063901: rtcpu_string: tstamp:15876469634 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xb4904000
kworker/1:2-1776 [001] … 502.063996: rtos_queue_send_from_isr_failed: tstamp:15876528094 queue:0x0bcb41f8
kworker/1:2-1776 [001] … 502.063997: rtos_queue_send_from_isr_failed: tstamp:15876528231 queue:0x0bcb8a60
kworker/1:2-1776 [001] … 502.063998: rtos_queue_send_from_isr_failed: tstamp:15876528370 queue:0x0bcba5e0
kworker/1:2-1776 [001] … 502.063998: rtos_queue_send_from_isr_failed: tstamp:15876528502 queue:0x0bcbb3a0
kworker/1:2-1776 [001] … 502.063999: rtos_queue_send_from_isr_failed: tstamp:15876528634 queue:0x0bcbc160
kworker/1:2-1776 [001] … 502.064003: rtcpu_nvcsi_intr: tstamp:15876531289 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:2-1776 [001] … 502.064004: rtcpu_vinotify_event: tstamp:15876992279 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:14125815968 data:0x10000000
kworker/1:2-1776 [001] … 502.064005: rtcpu_vinotify_event: tstamp:15876992410 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:14125819840 data:0x31000001
kworker/1:2-1776 [001] … 502.064006: rtcpu_vinotify_event: tstamp:15876992572 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14125820832 data:0x07020001
kworker/1:2-1776 [001] … 502.064006: rtcpu_vinotify_event: tstamp:15876992714 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:14125857280 data:0x10000000
kworker/1:2-1776 [001] … 502.064007: rtcpu_vinotify_event: tstamp:15876992916 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:14125861184 data:0x31000002
kworker/1:2-1776 [001] … 502.123147: rtcpu_vinotify_error: tstamp:15877434602 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15877431634 data:0x00000549
kworker/1:2-1776 [001] … 502.123151: rtcpu_vinotify_event: tstamp:15877534644 tag:FS channel:0x00 frame:0 vi_tstamp:15877431364 data:0x00000010
kworker/1:2-1776 [001] … 502.123153: rtcpu_vinotify_event: tstamp:15877534790 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:15877431366 data:0x00000000
kworker/1:2-1776 [001] … 502.123153: rtcpu_vinotify_event: tstamp:15877534915 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15877431634 data:0x00000549
kworker/1:2-1776 [001] … 502.123159: rtos_queue_send_from_isr_failed: tstamp:15877710097 queue:0x0bcb41f8
kworker/1:2-1776 [001] … 502.123160: rtos_queue_send_from_isr_failed: tstamp:15877710238 queue:0x0bcb8a60
kworker/1:2-1776 [001] … 502.123161: rtos_queue_send_from_isr_failed: tstamp:15877710377 queue:0x0bcba5e0
kworker/1:2-1776 [001] … 502.123162: rtos_queue_send_from_isr_failed: tstamp:15877710509 queue:0x0bcbb3a0
kworker/1:2-1776 [001] … 502.123163: rtos_queue_send_from_isr_failed: tstamp:15877710643 queue:0x0bcbc160
kworker/1:2-1776 [001] … 502.123164: rtcpu_vinotify_event: tstamp:15878077296 tag:FE channel:0x00 frame:0 vi_tstamp:15877695121 data:0x00000020
kworker/1:2-1776 [001] … 502.123164: rtcpu_vinotify_event: tstamp:15878077426 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:15877695122 data:0x01000000
kworker/1:2-1776 [001] … 502.123165: rtcpu_vinotify_event: tstamp:15878077591 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14165022528 data:0x01020001
kworker/1:2-1776 [001] … 502.123166: rtcpu_vinotify_event: tstamp:15878077720 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:15877695124 data:0x00000000
kworker/1:2-1776 [001] … 502.123167: rtcpu_vinotify_error: tstamp:15878215202 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15878212240 data:0x00000549
kworker/1:2-1776 [001] … 502.123168: rtcpu_vinotify_event: tstamp:15878478974 tag:FS channel:0x00 frame:0 vi_tstamp:15878211970 data:0x00000010
kworker/1:2-1776 [001] … 502.123187: rtcpu_vinotify_event: tstamp:15878479101 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:15878211973 data:0x00000000
kworker/1:2-1776 [001] … 502.123188: rtcpu_vinotify_event: tstamp:15878479262 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15878212240 data:0x00000549
kworker/1:2-1776 [001] … 502.123189: rtcpu_vinotify_event: tstamp:15878479385 tag:FE channel:0x00 frame:0 vi_tstamp:15878475727 data:0x00000020
kworker/1:2-1776 [001] … 502.123190: rtcpu_vinotify_error: tstamp:15878996366 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15878993537 data:0x00000549
kworker/1:2-1776 [001] … 502.123191: rtcpu_vinotify_event: tstamp:15878999268 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:15878475728 data:0x01000000
kworker/1:2-1776 [001] … 502.123191: rtcpu_vinotify_event: tstamp:15878999397 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14190007840 data:0x01020001
kworker/1:2-1776 [001] … 502.123192: rtcpu_vinotify_event: tstamp:15878999560 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:15878475730 data:0x00000000
kworker/1:2-1776 [001] … 502.123193: rtcpu_vinotify_event: tstamp:15878999703 tag:FS channel:0x00 frame:0 vi_tstamp:15878993263 data:0x00000010
kworker/1:2-1776 [001] … 502.123195: rtcpu_vinotify_event: tstamp:15878999861 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15878993537 data:0x00000549
kworker/1:2-1776 [001] … 502.179167: rtcpu_vinotify_event: tstamp:15879542086 tag:FE channel:0x00 frame:0 vi_tstamp:15879257021 data:0x00000020
kworker/1:2-1776 [001] … 502.179170: rtcpu_vinotify_error: tstamp:15879777663 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15879774830 data:0x00000549
kworker/1:2-1776 [001] … 502.179171: rtcpu_vinotify_event: tstamp:15880084327 tag:FS channel:0x00 frame:0 vi_tstamp:15879774555 data:0x00000010
kworker/1:2-1776 [001] … 502.179172: rtcpu_vinotify_event: tstamp:15880084450 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15879774830 data:0x00000549
kworker/1:2-1776 [001] … 502.179173: rtcpu_vinotify_event: tstamp:15880084608 tag:FE channel:0x00 frame:0 vi_tstamp:15880038313 data:0x00000020
kworker/1:2-1776 [001] … 502.179173: rtcpu_vinotify_error: tstamp:15880559297 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15880556468 data:0x00000549
kworker/1:2-1776 [001] … 502.179174: rtcpu_vinotify_event: tstamp:15880627261 tag:FS channel:0x00 frame:0 vi_tstamp:15880556198 data:0x00000010
kworker/1:2-1776 [001] … 502.179175: rtcpu_vinotify_event: tstamp:15880627401 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15880556468 data:0x00000549
kworker/1:2-1776 [001] … 502.235129: rtcpu_vinotify_event: tstamp:15881170072 tag:FE channel:0x00 frame:0 vi_tstamp:15880819954 data:0x00000020
kworker/1:2-1776 [001] … 502.235132: rtcpu_vinotify_error: tstamp:15881340246 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15881337417 data:0x00000549
kworker/1:2-1776 [001] … 502.235134: rtos_queue_peek_from_isr_failed: tstamp:15881434368 queue:0x0bcbcf78
kworker/1:2-1776 [001] … 502.235135: rtcpu_vinotify_event: tstamp:15881712374 tag:FS channel:0x00 frame:0 vi_tstamp:15881337146 data:0x00000010
kworker/1:2-1776 [001] … 502.235154: rtcpu_vinotify_event: tstamp:15881712498 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15881337417 data:0x00000549
kworker/1:2-1776 [001] … 502.235155: rtcpu_vinotify_event: tstamp:15881712659 tag:FE channel:0x00 frame:0 vi_tstamp:15881600905 data:0x00000020
kworker/1:2-1776 [001] … 502.235156: rtcpu_vinotify_error: tstamp:15882121150 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15882118367 data:0x00000549
kworker/1:2-1776 [001] … 502.235157: rtcpu_vinotify_event: tstamp:15882121582 tag:FS channel:0x00 frame:0 vi_tstamp:15882118097 data:0x00000010
kworker/1:2-1776 [001] … 502.235158: rtcpu_vinotify_event: tstamp:15882634402 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15882118367 data:0x00000549
kworker/1:2-1776 [001] … 502.235158: rtcpu_vinotify_event: tstamp:15882634524 tag:FE channel:0x00 frame:0 vi_tstamp:15882381854 data:0x00000020
kworker/1:2-1776 [001] … 502.291137: rtcpu_vinotify_error: tstamp:15882902469 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15882899660 data:0x00000549
kworker/1:2-1776 [001] … 502.291141: rtcpu_vinotify_event: tstamp:15883177448 tag:FS channel:0x00 frame:0 vi_tstamp:15882899389 data:0x00000010
kworker/1:2-1776 [001] … 502.291142: rtcpu_vinotify_event: tstamp:15883177570 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15882899660 data:0x00000549
kworker/1:2-1776 [001] … 502.291143: rtcpu_vinotify_event: tstamp:15883177728 tag:FE channel:0x00 frame:0 vi_tstamp:15883163147 data:0x00000020
kworker/1:2-1776 [001] … 502.291144: rtcpu_vinotify_error: tstamp:15883684136 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15883681301 data:0x00000549
kworker/1:2-1776 [001] … 502.291145: rtcpu_vinotify_event: tstamp:15883719586 tag:FS channel:0x00 frame:0 vi_tstamp:15883681027 data:0x00000010
kworker/1:2-1776 [001] … 502.291145: rtcpu_vinotify_event: tstamp:15883719726 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:15883681301 data:0x00000549
