I’m having trouble getting image frames out of my camera sensor. I have a camera connected via an FPDLink SerDes pair to a MIPI CSI-2 expansion board. When I run
v4l2-ctl -d /dev/video0 --set-fmt-video=width=2880,height=1860,pixelformat=RG12 --stream-count=1 --stream-mmap --stream-to=csi.raw --verbose
I get this message repeatedly in dmesg:
[ 1069.830932] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1069.880950] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1069.930950] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1069.980930] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1070.030924] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1070.080936] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1070.130937] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1070.180956] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1070.230913] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1070.280904] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 1070.330903] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
and these messages in trace
kworker/0:0-9101 [000] .... 5758.777954: rtcpu_vinotify_event: tstamp:180394103235 tag:FS channel:0x00 frame:146 vi_tstamp:180393711999 data:0x00000010
kworker/0:0-9101 [000] .... 5758.777955: rtcpu_vinotify_event: tstamp:180394103363 tag:ATOMP_FS channel:0x00 frame:146 vi_tstamp:180393712002 data:0x00000000
kworker/0:0-9101 [000] .... 5758.777955: rtcpu_vinotify_event: tstamp:180394103506 tag:CHANSEL_FAULT channel:0x23 frame:146 vi_tstamp:180393713149 data:0x00004004
kworker/0:0-9101 [000] .... 5758.777955: rtcpu_vinotify_event: tstamp:180394103628 tag:RESERVED_19 channel:0x23 frame:146 vi_tstamp:180551408448 data:0x01020581
kworker/0:0-9101 [000] .... 5758.777956: rtcpu_vinotify_event: tstamp:180394103765 tag:CHANSEL_NOMATCH channel:0x01 frame:146 vi_tstamp:180393713931 data:0x000006e9
kworker/0:0-9101 [000] .... 5758.777956: rtcpu_vinotify_event: tstamp:180394103887 tag:CHANSEL_FAULT channel:0x23 frame:146 vi_tstamp:180393723306 data:0x00004001
kworker/0:0-9101 [000] .... 5758.777956: rtcpu_vinotify_event: tstamp:180394104027 tag:RESERVED_19 channel:0x23 frame:146 vi_tstamp:180551733472 data:0x01020581
kworker/0:0-9101 [000] .... 5758.833947: rtcpu_vinotify_event: tstamp:180395178424 tag:CHANSEL_FAULT channel:0x23 frame:146 vi_tstamp:180395175891 data:0x07434002
kworker/0:0-9101 [000] .... 5758.833947: rtcpu_vinotify_event: tstamp:180395178576 tag:RESERVED_19 channel:0x23 frame:146 vi_tstamp:180598216160 data:0x01020581
kworker/0:0-9101 [000] .... 5758.833948: rtcpu_vinotify_event: tstamp:180395178707 tag:ATOMP_FRAME_DONE channel:0x23 frame:146 vi_tstamp:180395175910 data:0x00000000
kworker/0:0-9101 [000] .... 5758.833948: rtos_queue_send_from_isr_failed: tstamp:180395288874 queue:0x0bcb41f8
kworker/0:0-9101 [000] .... 5758.833949: rtos_queue_send_from_isr_failed: tstamp:180395289014 queue:0x0bcb8a60
kworker/0:0-9101 [000] .... 5758.833950: rtos_queue_send_from_isr_failed: tstamp:180395289154 queue:0x0bcba5e0
kworker/0:0-9101 [000] .... 5758.833951: rtos_queue_send_from_isr_failed: tstamp:180395289288 queue:0x0bcbb3a0
kworker/0:0-9101 [000] .... 5758.833951: rtos_queue_send_from_isr_failed: tstamp:180395289433 queue:0x0bcbc160
kworker/0:0-9101 [000] .... 5758.833952: rtcpu_vinotify_event: tstamp:180395664991 tag:RESERVED_19 channel:0x23 frame:146 vi_tstamp:180598225888 data:0x02020581
kworker/0:0-9101 [000] .... 5758.833952: rtcpu_vinotify_event: tstamp:180395665123 tag:FE channel:0x00 frame:146 vi_tstamp:180395186853 data:0x00000020
kworker/0:0-9101 [000] .... 5758.833952: rtcpu_vinotify_event: tstamp:180395665264 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:146 vi_tstamp:180395186853 data:0x00000000
kworker/0:0-9101 [000] .... 5758.833953: rtcpu_vinotify_event: tstamp:180395665390 tag:RESERVED_19 channel:0x23 frame:146 vi_tstamp:180598577440 data:0x01020581
kworker/0:0-9101 [000] .... 5758.833953: rtcpu_vinotify_event: tstamp:180395665534 tag:ATOMP_FE channel:0x00 frame:146 vi_tstamp:180395186854 data:0x00000000
kworker/0:0-9101 [000] .... 5758.833953: rtcpu_vinotify_event: tstamp:180395665657 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:180598590720 data:0x07020582
kworker/0:0-9101 [000] .... 5758.833953: rtcpu_vinotify_event: tstamp:180395665798 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180598635360 data:0x10000000
kworker/0:0-9101 [000] .... 5758.833954: rtcpu_vinotify_event: tstamp:180395665920 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180598662112 data:0x31000583
kworker/0:0-9101 [000] .... 5758.833954: rtcpu_vinotify_event: tstamp:180395666063 tag:FS channel:0x00 frame:147 vi_tstamp:180395274397 data:0x00000010
kworker/0:0-9101 [000] .... 5758.833954: rtcpu_vinotify_event: tstamp:180395666190 tag:ATOMP_FS channel:0x00 frame:147 vi_tstamp:180395274400 data:0x00000000
kworker/0:0-9101 [000] .... 5758.833954: rtcpu_vinotify_event: tstamp:180395666330 tag:CHANSEL_FAULT channel:0x23 frame:147 vi_tstamp:180395275548 data:0x00004004
kworker/0:0-9101 [000] .... 5758.833955: rtcpu_vinotify_event: tstamp:180395666452 tag:RESERVED_19 channel:0x23 frame:147 vi_tstamp:180601405184 data:0x01020582
kworker/0:0-9101 [000] .... 5758.833955: rtcpu_vinotify_event: tstamp:180395666588 tag:CHANSEL_NOMATCH channel:0x01 frame:147 vi_tstamp:180395276328 data:0x000006e9
kworker/0:0-9101 [000] .... 5758.833955: rtcpu_vinotify_event: tstamp:180395666711 tag:CHANSEL_FAULT channel:0x23 frame:147 vi_tstamp:180395285703 data:0x00004001
kworker/0:0-9101 [000] .... 5758.833955: rtcpu_vinotify_event: tstamp:180395666854 tag:RESERVED_19 channel:0x23 frame:147 vi_tstamp:180601730144 data:0x01020582
kworker/0:0-9101 [000] .... 5758.889943: rtcpu_vinotify_event: tstamp:180396740823 tag:CHANSEL_FAULT channel:0x23 frame:147 vi_tstamp:180396738285 data:0x07434002
kworker/0:0-9101 [000] .... 5758.889944: rtcpu_vinotify_event: tstamp:180396850489 tag:RESERVED_19 channel:0x23 frame:147 vi_tstamp:180648218144 data:0x01020582
kworker/0:0-9101 [000] .... 5758.889944: rtcpu_vinotify_event: tstamp:180396850631 tag:ATOMP_FRAME_DONE channel:0x23 frame:147 vi_tstamp:180396738305 data:0x00000000
kworker/0:0-9101 [000] .... 5758.889944: rtcpu_vinotify_event: tstamp:180396850778 tag:RESERVED_19 channel:0x23 frame:147 vi_tstamp:180648222560 data:0x02020582
kworker/0:0-9101 [000] .... 5758.889944: rtcpu_vinotify_event: tstamp:180396850902 tag:FE channel:0x00 frame:147 vi_tstamp:180396749248 data:0x00000020
kworker/0:0-9101 [000] .... 5758.889945: rtcpu_vinotify_event: tstamp:180396851049 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:147 vi_tstamp:180396749249 data:0x00000000
kworker/0:0-9101 [000] .... 5758.889945: rtos_queue_send_from_isr_failed: tstamp:180396851194 queue:0x0bcb41f8
kworker/0:0-9101 [000] .... 5758.889946: rtos_queue_send_from_isr_failed: tstamp:180396851338 queue:0x0bcb8a60
kworker/0:0-9101 [000] .... 5758.889948: rtos_queue_send_from_isr_failed: tstamp:180396851481 queue:0x0bcba5e0
kworker/0:0-9101 [000] .... 5758.889948: rtos_queue_send_from_isr_failed: tstamp:180396851618 queue:0x0bcbb3a0
kworker/0:0-9101 [000] .... 5758.889949: rtos_queue_send_from_isr_failed: tstamp:180396851754 queue:0x0bcbc160
kworker/0:0-9101 [000] .... 5758.889950: rtcpu_vinotify_event: tstamp:180396851938 tag:RESERVED_19 channel:0x23 frame:147 vi_tstamp:180648574112 data:0x01020582
kworker/0:0-9101 [000] .... 5758.889950: rtcpu_vinotify_event: tstamp:180396852082 tag:ATOMP_FE channel:0x00 frame:147 vi_tstamp:180396749251 data:0x00000000
kworker/0:0-9101 [000] .... 5758.889950: rtcpu_vinotify_event: tstamp:180396852204 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:180648587424 data:0x07020583
kworker/0:0-9101 [000] .... 5758.889950: rtcpu_vinotify_event: tstamp:180396852344 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180648637600 data:0x10000000
kworker/0:0-9101 [000] .... 5758.889951: rtcpu_vinotify_event: tstamp:180396852465 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180648664352 data:0x31000584
kworker/0:0-9101 [000] .... 5758.889951: rtcpu_vinotify_event: tstamp:180396852607 tag:FS channel:0x00 frame:148 vi_tstamp:180396836796 data:0x00000010
kworker/0:0-9101 [000] .... 5758.889951: rtcpu_vinotify_event: tstamp:180396852733 tag:ATOMP_FS channel:0x00 frame:148 vi_tstamp:180396836798 data:0x00000000
kworker/0:0-9101 [000] .... 5758.889951: rtcpu_vinotify_event: tstamp:180396852873 tag:CHANSEL_FAULT channel:0x23 frame:148 vi_tstamp:180396837944 data:0x00004004
kworker/0:0-9101 [000] .... 5758.889952: rtcpu_vinotify_event: tstamp:180396852995 tag:RESERVED_19 channel:0x23 frame:148 vi_tstamp:180651401888 data:0x01020583
kworker/0:0-9101 [000] .... 5758.889952: rtcpu_vinotify_event: tstamp:180396853134 tag:CHANSEL_NOMATCH channel:0x01 frame:148 vi_tstamp:180396838726 data:0x000006e9
kworker/0:0-9101 [000] .... 5758.889952: rtcpu_vinotify_event: tstamp:180396853257 tag:CHANSEL_FAULT channel:0x23 frame:148 vi_tstamp:180396848101 data:0x00004001
kworker/0:0-9101 [000] .... 5758.889952: rtcpu_vinotify_event: tstamp:180397325116 tag:RESERVED_19 channel:0x23 frame:148 vi_tstamp:180651732160 data:0x01020583
kworker/0:0-9101 [000] .... 5758.889953: rtos_queue_peek_from_isr_failed: tstamp:180397428047 queue:0x0bcbcf78
kworker/0:0-9101 [000] .... 5758.945940: rtcpu_vinotify_event: tstamp:180398405088 tag:CHANSEL_FAULT channel:0x23 frame:148 vi_tstamp:180398300683 data:0x07434002
kworker/0:0-9101 [000] .... 5758.945941: rtcpu_vinotify_event: tstamp:180398405241 tag:RESERVED_19 channel:0x23 frame:148 vi_tstamp:180698209536 data:0x01020583
kworker/0:0-9101 [000] .... 5758.945941: rtcpu_vinotify_event: tstamp:180398405372 tag:ATOMP_FRAME_DONE channel:0x23 frame:148 vi_tstamp:180398300704 data:0x00000000
kworker/0:0-9101 [000] .... 5758.945941: rtcpu_vinotify_event: tstamp:180398405516 tag:RESERVED_19 channel:0x23 frame:148 vi_tstamp:180698213952 data:0x02020583
kworker/0:0-9101 [000] .... 5758.945942: rtcpu_vinotify_event: tstamp:180398405644 tag:FE channel:0x00 frame:148 vi_tstamp:180398311648 data:0x00000020
kworker/0:0-9101 [000] .... 5758.945942: rtcpu_vinotify_event: tstamp:180398405792 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:148 vi_tstamp:180398311648 data:0x00000000
kworker/0:0-9101 [000] .... 5758.945942: rtcpu_vinotify_event: tstamp:180398405918 tag:RESERVED_19 channel:0x23 frame:148 vi_tstamp:180698570880 data:0x01020583
kworker/0:0-9101 [000] .... 5758.945943: rtcpu_vinotify_event: tstamp:180398406063 tag:ATOMP_FE channel:0x00 frame:148 vi_tstamp:180398311649 data:0x00000000
kworker/0:0-9101 [000] .... 5758.945943: rtcpu_vinotify_event: tstamp:180398406186 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:180698584192 data:0x07020584
kworker/0:0-9101 [000] .... 5758.945943: rtcpu_vinotify_event: tstamp:180398406329 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180698639136 data:0x10000000
kworker/0:0-9101 [000] .... 5758.945943: rtcpu_vinotify_event: tstamp:180398406449 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180698665888 data:0x31000585
kworker/0:0-9101 [000] .... 5758.945944: rtcpu_vinotify_event: tstamp:180398406591 tag:FS channel:0x00 frame:149 vi_tstamp:180398399192 data:0x00000010
kworker/0:0-9101 [000] .... 5758.945944: rtcpu_vinotify_event: tstamp:180398406717 tag:ATOMP_FS channel:0x00 frame:149 vi_tstamp:180398399195 data:0x00000000
kworker/0:0-9101 [000] .... 5758.945944: rtcpu_vinotify_event: tstamp:180398406863 tag:CHANSEL_FAULT channel:0x23 frame:149 vi_tstamp:180398400342 data:0x00004004
kworker/0:0-9101 [000] .... 5758.945944: rtcpu_vinotify_event: tstamp:180398406985 tag:RESERVED_19 channel:0x23 frame:149 vi_tstamp:180701398656 data:0x01020584
kworker/0:0-9101 [000] .... 5758.945945: rtos_queue_send_from_isr_failed: tstamp:180398415696 queue:0x0bcb41f8
kworker/0:0-9101 [000] .... 5758.945946: rtos_queue_send_from_isr_failed: tstamp:180398415835 queue:0x0bcb8a60
kworker/0:0-9101 [000] .... 5758.945946: rtos_queue_send_from_isr_failed: tstamp:180398415976 queue:0x0bcba5e0
kworker/0:0-9101 [000] .... 5758.945947: rtos_queue_send_from_isr_failed: tstamp:180398416108 queue:0x0bcbb3a0
kworker/0:0-9101 [000] .... 5758.945947: rtos_queue_send_from_isr_failed: tstamp:180398416242 queue:0x0bcbc160
kworker/0:0-9101 [000] .... 5758.945948: rtcpu_vinotify_event: tstamp:180398887279 tag:CHANSEL_NOMATCH channel:0x01 frame:149 vi_tstamp:180398401124 data:0x000006e9
kworker/0:0-9101 [000] .... 5758.945948: rtcpu_vinotify_event: tstamp:180398887409 tag:CHANSEL_FAULT channel:0x23 frame:149 vi_tstamp:180398410499 data:0x00004001
kworker/0:0-9101 [000] .... 5758.945948: rtcpu_vinotify_event: tstamp:180398887554 tag:RESERVED_19 channel:0x23 frame:149 vi_tstamp:180701723616 data:0x01020584
kworker/0:0-9101 [000] .... 5759.001940: rtcpu_vinotify_event: tstamp:180399967378 tag:CHANSEL_FAULT channel:0x23 frame:149 vi_tstamp:180399863084 data:0x07434002
kworker/0:0-9101 [000] .... 5759.001940: rtcpu_vinotify_event: tstamp:180399967533 tag:RESERVED_19 channel:0x23 frame:149 vi_tstamp:180748211776 data:0x01020584
kworker/0:0-9101 [000] .... 5759.001941: rtcpu_vinotify_event: tstamp:180399967663 tag:ATOMP_FRAME_DONE channel:0x23 frame:149 vi_tstamp:180399863104 data:0x00000000
kworker/0:0-9101 [000] .... 5759.001941: rtcpu_vinotify_event: tstamp:180399967804 tag:RESERVED_19 channel:0x23 frame:149 vi_tstamp:180748216160 data:0x02020584
kworker/0:0-9101 [000] .... 5759.001941: rtcpu_vinotify_event: tstamp:180399967930 tag:FE channel:0x00 frame:149 vi_tstamp:180399874047 data:0x00000020
kworker/0:0-9101 [000] .... 5759.001941: rtcpu_vinotify_event: tstamp:180399968074 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:149 vi_tstamp:180399874047 data:0x00000000
kworker/0:0-9101 [000] .... 5759.001942: rtcpu_vinotify_event: tstamp:180399968197 tag:RESERVED_19 channel:0x23 frame:149 vi_tstamp:180748567648 data:0x01020584
kworker/0:0-9101 [000] .... 5759.001942: rtcpu_vinotify_event: tstamp:180399968345 tag:ATOMP_FE channel:0x00 frame:149 vi_tstamp:180399874050 data:0x00000000
kworker/0:0-9101 [000] .... 5759.001942: rtcpu_vinotify_event: tstamp:180399968468 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:180748580960 data:0x07020585
kworker/0:0-9101 [000] .... 5759.001943: rtcpu_vinotify_event: tstamp:180399968612 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180748628064 data:0x10000000
kworker/0:0-9101 [000] .... 5759.001943: rtcpu_vinotify_event: tstamp:180399968734 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:180748654816 data:0x31000586
kworker/0:0-9101 [000] .... 5759.001943: rtcpu_vinotify_event: tstamp:180399968874 tag:FS channel:0x00 frame:150 vi_tstamp:180399961591 data:0x00000010
kworker/0:0-9101 [000] .... 5759.001943: rtcpu_vinotify_event: tstamp:180399969001 tag:ATOMP_FS channel:0x00 frame:150 vi_tstamp:180399961593 data:0x00000000
kworker/0:0-9101 [000] .... 5759.001944: rtos_queue_send_from_isr_failed: tstamp:180399978615 queue:0x0bcb41f8
kworker/0:0-9101 [000] .... 5759.001945: rtos_queue_send_from_isr_failed: tstamp:180399978752 queue:0x0bcb8a60
kworker/0:0-9101 [000] .... 5759.001945: rtos_queue_send_from_isr_failed: tstamp:180399978892 queue:0x0bcba5e0
kworker/0:0-9101 [000] .... 5759.001946: rtos_queue_send_from_isr_failed: tstamp:180399979026 queue:0x0bcbb3a0
kworker/0:0-9101 [000] .... 5759.001946: rtos_queue_send_from_isr_failed: tstamp:180399979158 queue:0x0bcbc160
kworker/0:0-9101 [000] .... 5759.001947: rtcpu_vinotify_event: tstamp:180400450207 tag:CHANSEL_FAULT channel:0x23 frame:150 vi_tstamp:180399962741 data:0x00004004
kworker/0:0-9101 [000] .... 5759.001947: rtcpu_vinotify_event: tstamp:180400450337 tag:RESERVED_19 channel:0x23 frame:150 vi_tstamp:180751410144 data:0x01020585
kworker/0:0-9101 [000] .... 5759.001947: rtcpu_vinotify_event: tstamp:180400450481 tag:CHANSEL_NOMATCH channel:0x01 frame:150 vi_tstamp:180399963521 data:0x000006e9
kworker/0:0-9101 [000] .... 5759.001948: rtcpu_vinotify_event: tstamp:180400450605 tag:CHANSEL_FAULT channel:0x23 frame:150 vi_tstamp:180399972896 data:0x00004001
kworker/0:0-9101 [000] .... 5759.001948: rtcpu_vinotify_event: tstamp:180400450745 tag:RESERVED_19 channel:0x23 frame:150 vi_tstamp:180751720320 data:0x01020585
