I am doing an LT6911UXC (HDMI to MIPI/CSI) chip based board with the Xavier NX Dev Kit.
I am trying to capture som frames usgin v4l2 ctl like below,
v4l2-ctl --device /dev/video0 --stream-mmap --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-to=frame.raw --stream-count=10 --verbose
But I got this error.
Do you have any ideas on how we could handle this situation?
Thanks,
Looks like unable capture data from sensor cause the error and make kernel crash.
Have check the trace log.
https://elinux.org/Jetson/l4t/Camera_BringUp
The previous error has become no problem now.
I modified some code and works well.
However, if I capture and save it as jpeg using below command
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=UYUY --stream-mmap --stream-count=10 --stream-skip=3 --stream-to=test.jpeg
the ‘test.jpeg’ file was generated but when I open it nothing shows up.
I have checked the trace log.
k@k-desktop:~$ sudo su
[sudo] password for k:
root@k-desktop:/home/k# echo 1 > /sys/kernel/debug/tracing/tracing_on
root@k-desktop:/home/k# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
root@k-desktop:/home/k# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
root@k-desktop:/home/k# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
root@k-desktop:/home/k# echo 2 > /sys/kernel/debug/camrtc/log-level
root@k-desktop:/home/k# echo > /sys/kernel/debug/tracing/trace
root@k-desktop:/home/k# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 313/313 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/1:5-1924 [001] .... 153.970663: rtos_queue_peek_from_isr_failed: tstamp:5242790334 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 153.970669: rtcpu_start: tstamp:5242792214
kworker/1:5-1924 [001] .... 153.970671: rtos_queue_send_from_isr_failed: tstamp:5242805948 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 153.970672: rtos_queue_send_from_isr_failed: tstamp:5242806100 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 153.970673: rtos_queue_send_from_isr_failed: tstamp:5242806249 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 153.970674: rtos_queue_send_from_isr_failed: tstamp:5242806398 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 153.970675: rtos_queue_send_from_isr_failed: tstamp:5242806546 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 153.970676: rtcpu_string: tstamp:5242806988 id:0x04010000 str:"Configuring VI GoS.
kworker/1:5-1924 [001] .... 153.970704: rtcpu_string: tstamp:5242807188 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/1:5-1924 [001] .... 153.970712: rtcpu_string: tstamp:5242807442 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/1:5-1924 [001] .... 153.970719: rtcpu_string: tstamp:5242807702 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/1:5-1924 [001] .... 153.970725: rtcpu_string: tstamp:5242807934 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/1:5-1924 [001] .... 153.970732: rtcpu_string: tstamp:5242808183 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/1:5-1924 [001] .... 153.970738: rtcpu_string: tstamp:5242808416 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/1:5-1924 [001] .... 153.970744: rtcpu_string: tstamp:5242817178 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/1:5-1924 [001] .... 153.970749: rtcpu_string: tstamp:5242817297 id:0x04010000 str:"on 2.2
kworker/1:5-1924 [001] .... 153.970756: rtos_queue_send_from_isr_failed: tstamp:5242832551 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 153.970757: rtos_queue_send_from_isr_failed: tstamp:5242832717 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 153.970758: rtos_queue_send_from_isr_failed: tstamp:5242832870 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 153.970759: rtos_queue_send_from_isr_failed: tstamp:5242833015 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 153.970760: rtos_queue_send_from_isr_failed: tstamp:5242833161 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 153.970761: rtcpu_string: tstamp:5242834119 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/1:5-1924 [001] .... 153.970769: rtos_queue_send_from_isr_failed: tstamp:5242932891 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 153.970770: rtos_queue_send_from_isr_failed: tstamp:5242933044 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 153.970771: rtos_queue_send_from_isr_failed: tstamp:5242933198 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 153.970772: rtos_queue_send_from_isr_failed: tstamp:5242933345 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 153.970773: rtos_queue_send_from_isr_failed: tstamp:5242933491 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 153.970775: rtcpu_vinotify_error: tstamp:5242941868 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:5242939027 data:0x00000001
kworker/1:5-1924 [001] .... 153.970779: rtcpu_vinotify_event: tstamp:5243349081 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4561972064 data:0x10000000
kworker/1:5-1924 [001] .... 153.970780: rtcpu_vinotify_event: tstamp:5243349225 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4561980288 data:0x31000001
kworker/1:5-1924 [001] .... 153.970781: rtcpu_vinotify_event: tstamp:5243349386 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4561982432 data:0x07020001
kworker/1:5-1924 [001] .... 153.970782: rtcpu_vinotify_event: tstamp:5243349522 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4562016224 data:0x10000000
kworker/1:5-1924 [001] .... 153.970783: rtcpu_vinotify_event: tstamp:5243349679 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4562024480 data:0x31000002
kworker/1:5-1924 [001] .... 153.970784: rtcpu_vinotify_event: tstamp:5243349823 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:5242939027 data:0x00000001
kworker/1:5-1924 [001] .... 153.970785: rtcpu_vinotify_event: tstamp:5243349981 tag:FS channel:0x00 frame:1 vi_tstamp:5242978418 data:0x00000010
kworker/1:5-1924 [001] .... 153.970786: rtcpu_vinotify_event: tstamp:5243350121 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5242978420 data:0x00000000
kworker/1:5-1924 [001] .... 153.970787: rtcpu_vinotify_event: tstamp:5243350279 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5242978883 data:0x00000001
kworker/1:5-1924 [001] .... 153.970788: rtcpu_vinotify_event: tstamp:5243350414 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4566571232 data:0x08020001
kworker/1:5-1924 [001] .... 153.970789: rtcpu_vinotify_event: tstamp:5243484217 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5243479318 data:0x04370002
kworker/1:5-1924 [001] .... 153.970792: rtcpu_vinotify_event: tstamp:5243484356 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5243479346 data:0x00000000
kworker/1:5-1924 [001] .... 153.970793: rtcpu_vinotify_event: tstamp:5243484513 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4582588768 data:0x02020001
kworker/1:5-1924 [001] .... 153.970794: rtcpu_vinotify_event: tstamp:5243484649 tag:FE channel:0x00 frame:1 vi_tstamp:5243479383 data:0x00000020
kworker/1:5-1924 [001] .... 153.970795: rtcpu_vinotify_event: tstamp:5243484807 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5243479385 data:0x00000000
kworker/1:5-1924 [001] .... 153.970796: rtcpu_vinotify_event: tstamp:5243484945 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4582613888 data:0x00020001
kworker/1:5-1924 [001] .... 153.970797: rtos_queue_send_from_isr_failed: tstamp:5243490218 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 153.970798: rtos_queue_send_from_isr_failed: tstamp:5243490374 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 153.970799: rtos_queue_send_from_isr_failed: tstamp:5243490527 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 153.970800: rtos_queue_send_from_isr_failed: tstamp:5243490672 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 153.970801: rtos_queue_send_from_isr_failed: tstamp:5243490817 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.026724: rtcpu_vinotify_event: tstamp:5243999645 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4582642304 data:0x07020002
kworker/1:5-1924 [001] .... 154.026729: rtcpu_vinotify_event: tstamp:5243999793 tag:FS channel:0x00 frame:1 vi_tstamp:5243499774 data:0x00000010
kworker/1:5-1924 [001] .... 154.026730: rtcpu_vinotify_event: tstamp:5243999955 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5243499777 data:0x00000000
kworker/1:5-1924 [001] .... 154.026731: rtcpu_vinotify_event: tstamp:5244000093 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5243500239 data:0x00000001
kworker/1:5-1924 [001] .... 154.026732: rtcpu_vinotify_event: tstamp:5244000252 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4583254688 data:0x08020002
kworker/1:5-1924 [001] .... 154.026733: rtcpu_vinotify_event: tstamp:5244000387 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4583435008 data:0x10000000
kworker/1:5-1924 [001] .... 154.026734: rtcpu_vinotify_event: tstamp:5244000544 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4583464128 data:0x31000003
kworker/1:5-1924 [001] .... 154.026741: rtos_queue_send_from_isr_failed: tstamp:5244009360 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.026743: rtos_queue_send_from_isr_failed: tstamp:5244009517 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.026744: rtos_queue_send_from_isr_failed: tstamp:5244009668 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.026745: rtos_queue_send_from_isr_failed: tstamp:5244009815 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.026746: rtos_queue_send_from_isr_failed: tstamp:5244009960 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.026747: rtcpu_vinotify_event: tstamp:5244025300 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5244000675 data:0x04370002
kworker/1:5-1924 [001] .... 154.026748: rtcpu_vinotify_event: tstamp:5244025462 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5244000702 data:0x00000000
kworker/1:5-1924 [001] .... 154.026749: rtcpu_vinotify_event: tstamp:5244025600 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4599272160 data:0x02020002
kworker/1:5-1924 [001] .... 154.026749: rtcpu_vinotify_event: tstamp:5244025759 tag:FE channel:0x00 frame:1 vi_tstamp:5244000740 data:0x00000020
kworker/1:5-1924 [001] .... 154.026750: rtcpu_vinotify_event: tstamp:5244025912 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5244000742 data:0x00000000
kworker/1:5-1924 [001] .... 154.026751: rtcpu_vinotify_event: tstamp:5244026069 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4599297248 data:0x00020002
kworker/1:5-1924 [001] .... 154.026752: rtcpu_vinotify_event: tstamp:5244026203 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4599319040 data:0x07020003
kworker/1:5-1924 [001] .... 154.026753: rtcpu_vinotify_event: tstamp:5244026359 tag:FS channel:0x00 frame:1 vi_tstamp:5244021131 data:0x00000010
kworker/1:5-1924 [001] .... 154.026754: rtcpu_vinotify_event: tstamp:5244026500 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5244021134 data:0x00000000
kworker/1:5-1924 [001] .... 154.026756: rtos_queue_send_from_isr_failed: tstamp:5244529365 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.026757: rtos_queue_send_from_isr_failed: tstamp:5244529521 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.026758: rtos_queue_send_from_isr_failed: tstamp:5244529674 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.026759: rtos_queue_send_from_isr_failed: tstamp:5244529820 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.026759: rtos_queue_send_from_isr_failed: tstamp:5244529966 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.026760: rtcpu_vinotify_event: tstamp:5244542577 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5244021596 data:0x00000001
kworker/1:5-1924 [001] .... 154.026761: rtcpu_vinotify_event: tstamp:5244542717 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4599941920 data:0x08020003
kworker/1:5-1924 [001] .... 154.026762: rtcpu_vinotify_event: tstamp:5244542875 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4600204128 data:0x10000000
kworker/1:5-1924 [001] .... 154.026763: rtcpu_vinotify_event: tstamp:5244543010 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4600233280 data:0x31000004
kworker/1:5-1924 [001] .... 154.026763: rtcpu_vinotify_event: tstamp:5244543168 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5244522031 data:0x04370002
kworker/1:5-1924 [001] .... 154.026764: rtcpu_vinotify_event: tstamp:5244543303 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5244522059 data:0x00000000
kworker/1:5-1924 [001] .... 154.026765: rtcpu_vinotify_event: tstamp:5244543460 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4615955584 data:0x02020003
kworker/1:5-1924 [001] .... 154.026766: rtcpu_vinotify_event: tstamp:5244543596 tag:FE channel:0x00 frame:1 vi_tstamp:5244522096 data:0x00000020
kworker/1:5-1924 [001] .... 154.026767: rtcpu_vinotify_event: tstamp:5244545615 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5244522099 data:0x00000000
kworker/1:5-1924 [001] .... 154.026767: rtcpu_vinotify_event: tstamp:5244545750 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4615980736 data:0x00020003
kworker/1:5-1924 [001] .... 154.026768: rtcpu_vinotify_event: tstamp:5244545906 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4616002496 data:0x07020004
kworker/1:5-1924 [001] .... 154.026769: rtcpu_vinotify_event: tstamp:5244551278 tag:FS channel:0x00 frame:1 vi_tstamp:5244542487 data:0x00000010
kworker/1:5-1924 [001] .... 154.026770: rtcpu_vinotify_event: tstamp:5244551437 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5244542489 data:0x00000000
kworker/1:5-1924 [001] .... 154.026771: rtcpu_vinotify_event: tstamp:5244551575 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5244542952 data:0x00000001
kworker/1:5-1924 [001] .... 154.026772: rtcpu_vinotify_event: tstamp:5244551733 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4616621472 data:0x08020004
kworker/1:5-1924 [001] .... 154.026772: rtcpu_vinotify_event: tstamp:5244551868 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4616808704 data:0x10000000
kworker/1:5-1924 [001] .... 154.026774: rtcpu_vinotify_event: tstamp:5245085353 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4616926240 data:0x31000005
kworker/1:5-1924 [001] .... 154.026774: rtcpu_vinotify_event: tstamp:5245085496 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5245043388 data:0x04370002
kworker/1:5-1924 [001] .... 154.026775: rtcpu_vinotify_event: tstamp:5245085658 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5245043416 data:0x00000000
kworker/1:5-1924 [001] .... 154.026776: rtcpu_vinotify_event: tstamp:5245085795 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4632639008 data:0x02020004
kworker/1:5-1924 [001] .... 154.026777: rtcpu_vinotify_event: tstamp:5245085952 tag:FE channel:0x00 frame:1 vi_tstamp:5245043453 data:0x00000020
kworker/1:5-1924 [001] .... 154.026777: rtcpu_vinotify_event: tstamp:5245086095 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5245043455 data:0x00000000
kworker/1:5-1924 [001] .... 154.026779: rtcpu_vinotify_event: tstamp:5245086266 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4632664128 data:0x00020004
kworker/1:5-1924 [001] .... 154.026780: rtcpu_vinotify_event: tstamp:5245086401 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4632685888 data:0x07020005
kworker/1:5-1924 [001] .... 154.026781: rtcpu_vinotify_event: tstamp:5245086557 tag:FS channel:0x00 frame:1 vi_tstamp:5245063843 data:0x00000010
kworker/1:5-1924 [001] .... 154.026781: rtcpu_vinotify_event: tstamp:5245086697 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5245063846 data:0x00000000
kworker/1:5-1924 [001] .... 154.026782: rtcpu_vinotify_event: tstamp:5245086852 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5245064309 data:0x00000001
kworker/1:5-1924 [001] .... 154.026783: rtcpu_vinotify_event: tstamp:5245086986 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4633304928 data:0x08020005
kworker/1:5-1924 [001] .... 154.026784: rtcpu_vinotify_event: tstamp:5245087141 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4633478560 data:0x10000000
kworker/1:5-1924 [001] .... 154.026784: rtcpu_vinotify_event: tstamp:5245087276 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4633507648 data:0x31000006
kworker/1:5-1924 [001] .... 154.082705: rtcpu_vinotify_event: tstamp:5245569639 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5245564744 data:0x04370002
kworker/1:5-1924 [001] .... 154.082710: rtcpu_vinotify_event: tstamp:5245569775 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5245564773 data:0x00000000
kworker/1:5-1924 [001] .... 154.082717: rtcpu_vinotify_event: tstamp:5246061489 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4649328352 data:0x02020005
kworker/1:5-1924 [001] .... 154.082718: rtcpu_vinotify_event: tstamp:5246061630 tag:FE channel:0x00 frame:1 vi_tstamp:5245564809 data:0x00000020
kworker/1:5-1924 [001] .... 154.082719: rtcpu_vinotify_event: tstamp:5246061795 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5245564812 data:0x00000000
kworker/1:5-1924 [001] .... 154.082719: rtcpu_vinotify_event: tstamp:5246061931 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4649353824 data:0x00020005
kworker/1:5-1924 [001] .... 154.082720: rtcpu_vinotify_event: tstamp:5246062088 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4649376064 data:0x07020006
kworker/1:5-1924 [001] .... 154.082721: rtcpu_vinotify_event: tstamp:5246062222 tag:FS channel:0x00 frame:1 vi_tstamp:5245585200 data:0x00000010
kworker/1:5-1924 [001] .... 154.082722: rtcpu_vinotify_event: tstamp:5246062380 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5245585203 data:0x00000000
kworker/1:5-1924 [001] .... 154.082723: rtcpu_vinotify_event: tstamp:5246062514 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5245585666 data:0x00000001
kworker/1:5-1924 [001] .... 154.082723: rtcpu_vinotify_event: tstamp:5246062672 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4649988288 data:0x08020006
kworker/1:5-1924 [001] .... 154.082749: rtcpu_vinotify_event: tstamp:5246062808 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4650173856 data:0x10000000
kworker/1:5-1924 [001] .... 154.082749: rtcpu_vinotify_event: tstamp:5246062965 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4650202976 data:0x31000007
kworker/1:5-1924 [001] .... 154.082750: rtcpu_vinotify_event: tstamp:5246090995 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5246086101 data:0x04370002
kworker/1:5-1924 [001] .... 154.082751: rtcpu_vinotify_event: tstamp:5246091153 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5246086129 data:0x00000000
kworker/1:5-1924 [001] .... 154.082752: rtcpu_vinotify_event: tstamp:5246091288 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4666005824 data:0x02020006
kworker/1:5-1924 [001] .... 154.082753: rtcpu_vinotify_event: tstamp:5246091442 tag:FE channel:0x00 frame:1 vi_tstamp:5246086165 data:0x00000020
kworker/1:5-1924 [001] .... 154.082754: rtcpu_vinotify_event: tstamp:5246091580 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5246086169 data:0x00000000
kworker/1:5-1924 [001] .... 154.082755: rtcpu_vinotify_event: tstamp:5246603957 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4666037120 data:0x00020006
kworker/1:5-1924 [001] .... 154.082756: rtcpu_vinotify_event: tstamp:5246604095 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4666059392 data:0x07020007
kworker/1:5-1924 [001] .... 154.082757: rtcpu_vinotify_event: tstamp:5246604256 tag:FS channel:0x00 frame:1 vi_tstamp:5246106557 data:0x00000010
kworker/1:5-1924 [001] .... 154.082758: rtcpu_vinotify_event: tstamp:5246604394 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5246106559 data:0x00000000
kworker/1:5-1924 [001] .... 154.082758: rtcpu_vinotify_event: tstamp:5246604552 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5246107023 data:0x00000001
kworker/1:5-1924 [001] .... 154.082778: rtcpu_vinotify_event: tstamp:5246604688 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4666671744 data:0x08020007
kworker/1:5-1924 [001] .... 154.082780: rtcpu_vinotify_error: tstamp:5246631175 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:5246628378 data:0x000003c9
kworker/1:5-1924 [001] .... 154.082782: rtos_queue_send_from_isr_failed: tstamp:5246749128 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.082783: rtos_queue_send_from_isr_failed: tstamp:5246749282 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.082784: rtos_queue_send_from_isr_failed: tstamp:5246749438 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.082785: rtos_queue_send_from_isr_failed: tstamp:5246749586 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.082786: rtos_queue_send_from_isr_failed: tstamp:5246749733 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.082787: rtcpu_vinotify_event: tstamp:5246756375 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5246607457 data:0x04370002
kworker/1:5-1924 [001] .... 154.082787: rtcpu_vinotify_event: tstamp:5246756516 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5246607485 data:0x00000000
kworker/1:5-1924 [001] .... 154.082788: rtcpu_vinotify_event: tstamp:5246756677 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4682689248 data:0x02020007
kworker/1:5-1924 [001] .... 154.082789: rtcpu_vinotify_event: tstamp:5246756815 tag:FE channel:0x00 frame:1 vi_tstamp:5246607522 data:0x00000020
kworker/1:5-1924 [001] .... 154.082790: rtcpu_vinotify_event: tstamp:5246756974 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5246607524 data:0x00000000
kworker/1:5-1924 [001] .... 154.082791: rtcpu_vinotify_event: tstamp:5246757106 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4682714400 data:0x00020007
kworker/1:5-1924 [001] .... 154.082792: rtcpu_vinotify_event: tstamp:5246757264 tag:FS channel:0x00 frame:1 vi_tstamp:5246627913 data:0x00000010
kworker/1:5-1924 [001] .... 154.082792: rtcpu_vinotify_event: tstamp:5246757402 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:5246628378 data:0x000003c9
kworker/1:5-1924 [001] .... 154.082793: rtcpu_vinotify_event: tstamp:5246757556 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4687342752 data:0x10000000
kworker/1:5-1924 [001] .... 154.082794: rtcpu_vinotify_event: tstamp:5246757691 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4687371520 data:0x31000008
kworker/1:5-1924 [001] .... 154.138706: rtos_queue_send_from_isr_failed: tstamp:5247137677 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.138711: rtos_queue_send_from_isr_failed: tstamp:5247137827 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.138712: rtos_queue_send_from_isr_failed: tstamp:5247137979 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.138713: rtos_queue_send_from_isr_failed: tstamp:5247138124 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.138714: rtos_queue_send_from_isr_failed: tstamp:5247138269 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.138722: rtcpu_vinotify_event: tstamp:5247255478 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4687445248 data:0x07020008
kworker/1:5-1924 [001] .... 154.138723: rtcpu_vinotify_event: tstamp:5247255622 tag:FE channel:0x00 frame:1 vi_tstamp:5247128878 data:0x00000020
kworker/1:5-1924 [001] .... 154.138724: rtcpu_vinotify_event: tstamp:5247255784 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4699772640 data:0x10000000
kworker/1:5-1924 [001] .... 154.138725: rtcpu_vinotify_event: tstamp:5247255921 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4699801728 data:0x31000009
kworker/1:5-1924 [001] .... 154.138725: rtcpu_vinotify_event: tstamp:5247256078 tag:FS channel:0x00 frame:1 vi_tstamp:5247149269 data:0x00000010
kworker/1:5-1924 [001] .... 154.138726: rtcpu_vinotify_event: tstamp:5247256218 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5247149272 data:0x00000000
kworker/1:5-1924 [001] .... 154.138727: rtcpu_vinotify_event: tstamp:5247256375 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5247149735 data:0x00000001
kworker/1:5-1924 [001] .... 154.138728: rtcpu_vinotify_event: tstamp:5247256509 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4700038560 data:0x08020008
kworker/1:5-1924 [001] .... 154.138729: rtos_queue_send_from_isr_failed: tstamp:5247465967 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.138730: rtos_queue_send_from_isr_failed: tstamp:5247466122 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.138730: rtos_queue_send_from_isr_failed: tstamp:5247466274 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.138731: rtos_queue_send_from_isr_failed: tstamp:5247466419 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.138732: rtos_queue_send_from_isr_failed: tstamp:5247466566 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.138733: rtcpu_vinotify_event: tstamp:5247674793 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5247650170 data:0x04370002
kworker/1:5-1924 [001] .... 154.138734: rtcpu_vinotify_event: tstamp:5247674933 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5247650198 data:0x00000000
kworker/1:5-1924 [001] .... 154.138735: rtcpu_vinotify_event: tstamp:5247675094 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4716056032 data:0x02020008
kworker/1:5-1924 [001] .... 154.138736: rtcpu_vinotify_event: tstamp:5247675231 tag:FE channel:0x00 frame:1 vi_tstamp:5247650235 data:0x00000020
kworker/1:5-1924 [001] .... 154.138736: rtcpu_vinotify_event: tstamp:5247675395 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5247650238 data:0x00000000
kworker/1:5-1924 [001] .... 154.138737: rtcpu_vinotify_event: tstamp:5247675532 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4716081152 data:0x00020008
kworker/1:5-1924 [001] .... 154.138738: rtcpu_vinotify_event: tstamp:5247675689 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4716102912 data:0x07020009
kworker/1:5-1924 [001] .... 154.138739: rtcpu_vinotify_event: tstamp:5247675825 tag:FS channel:0x00 frame:1 vi_tstamp:5247670626 data:0x00000010
kworker/1:5-1924 [001] .... 154.138741: rtos_queue_peek_from_isr_failed: tstamp:5247790711 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 154.138742: rtos_queue_send_from_isr_failed: tstamp:5247831688 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.138743: rtos_queue_send_from_isr_failed: tstamp:5247831839 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.138743: rtos_queue_send_from_isr_failed: tstamp:5247831991 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.138744: rtos_queue_send_from_isr_failed: tstamp:5247832136 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.138745: rtos_queue_send_from_isr_failed: tstamp:5247832281 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.138746: rtos_queue_send_from_isr_failed: tstamp:5248147918 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.138747: rtos_queue_send_from_isr_failed: tstamp:5248148067 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.138748: rtos_queue_send_from_isr_failed: tstamp:5248148216 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.138748: rtos_queue_send_from_isr_failed: tstamp:5248148363 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.138749: rtos_queue_send_from_isr_failed: tstamp:5248148509 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.138750: rtcpu_vinotify_event: tstamp:5248178150 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5247670629 data:0x00000000
kworker/1:5-1924 [001] .... 154.138751: rtcpu_vinotify_event: tstamp:5248178294 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5247671091 data:0x00000001
kworker/1:5-1924 [001] .... 154.138752: rtcpu_vinotify_event: tstamp:5248178455 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4716725728 data:0x08020009
kworker/1:5-1924 [001] .... 154.138753: rtcpu_vinotify_event: tstamp:5248178590 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4716970368 data:0x10000000
kworker/1:5-1924 [001] .... 154.138754: rtcpu_vinotify_event: tstamp:5248178748 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4716999456 data:0x3100000a
kworker/1:5-1924 [001] .... 154.138754: rtcpu_vinotify_event: tstamp:5248178880 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5248171527 data:0x04370002
kworker/1:5-1924 [001] .... 154.138755: rtcpu_vinotify_event: tstamp:5248179037 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5248171555 data:0x00000000
kworker/1:5-1924 [001] .... 154.138756: rtcpu_vinotify_event: tstamp:5248179173 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4732739456 data:0x02020009
kworker/1:5-1924 [001] .... 154.138757: rtcpu_vinotify_event: tstamp:5248179331 tag:FE channel:0x00 frame:1 vi_tstamp:5248171592 data:0x00000020
kworker/1:5-1924 [001] .... 154.138758: rtcpu_vinotify_event: tstamp:5248179474 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5248171595 data:0x00000000
kworker/1:5-1924 [001] .... 154.138758: rtcpu_vinotify_event: tstamp:5248179630 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4732764576 data:0x00020009
kworker/1:5-1924 [001] .... 154.138759: rtcpu_vinotify_event: tstamp:5248179765 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4732786336 data:0x0702000a
kworker/1:5-1924 [001] .... 154.138760: rtcpu_vinotify_event: tstamp:5248196206 tag:FS channel:0x00 frame:1 vi_tstamp:5248191982 data:0x00000010
kworker/1:5-1924 [001] .... 154.138761: rtcpu_vinotify_event: tstamp:5248196345 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5248191985 data:0x00000000
kworker/1:5-1924 [001] .... 154.138762: rtcpu_vinotify_event: tstamp:5248196501 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5248192448 data:0x00000001
kworker/1:5-1924 [001] .... 154.138762: rtcpu_vinotify_event: tstamp:5248196636 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4733405344 data:0x0802000a
kworker/1:5-1924 [001] .... 154.138764: rtos_queue_send_from_isr_failed: tstamp:5248510890 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.138765: rtos_queue_send_from_isr_failed: tstamp:5248511044 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.138766: rtos_queue_send_from_isr_failed: tstamp:5248511197 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.138767: rtos_queue_send_from_isr_failed: tstamp:5248511344 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.138768: rtos_queue_send_from_isr_failed: tstamp:5248511489 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.138770: rtcpu_vinotify_event: tstamp:5248720173 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4733640384 data:0x10000000
kworker/1:5-1924 [001] .... 154.138770: rtcpu_vinotify_event: tstamp:5248720314 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4733669504 data:0x3100000b
kworker/1:5-1924 [001] .... 154.138794: rtcpu_vinotify_event: tstamp:5248720475 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5248692883 data:0x04370002
kworker/1:5-1924 [001] .... 154.138795: rtcpu_vinotify_event: tstamp:5248720610 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5248692912 data:0x00000000
kworker/1:5-1924 [001] .... 154.138796: rtcpu_vinotify_event: tstamp:5248720766 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4749422848 data:0x0202000a
kworker/1:5-1924 [001] .... 154.138796: rtcpu_vinotify_event: tstamp:5248720904 tag:FE channel:0x00 frame:1 vi_tstamp:5248692948 data:0x00000020
kworker/1:5-1924 [001] .... 154.138797: rtcpu_vinotify_event: tstamp:5248721065 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5248692952 data:0x00000000
kworker/1:5-1924 [001] .... 154.138798: rtcpu_vinotify_event: tstamp:5248721200 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4749448032 data:0x0002000a
kworker/1:5-1924 [001] .... 154.138799: rtcpu_vinotify_event: tstamp:5248721356 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4749469824 data:0x0702000b
kworker/1:5-1924 [001] .... 154.138800: rtcpu_vinotify_event: tstamp:5248721494 tag:FS channel:0x00 frame:1 vi_tstamp:5248713339 data:0x00000010
kworker/1:5-1924 [001] .... 154.138801: rtcpu_vinotify_event: tstamp:5248721651 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5248713342 data:0x00000000
kworker/1:5-1924 [001] .... 154.138801: rtcpu_vinotify_event: tstamp:5248721786 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5248713805 data:0x00000001
kworker/1:5-1924 [001] .... 154.138802: rtcpu_vinotify_event: tstamp:5248721940 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4750088768 data:0x0802000b
kworker/1:5-1924 [001] .... 154.194687: rtos_queue_send_from_isr_failed: tstamp:5248969906 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.194692: rtos_queue_send_from_isr_failed: tstamp:5248970060 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.194693: rtos_queue_send_from_isr_failed: tstamp:5248970212 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.194693: rtos_queue_send_from_isr_failed: tstamp:5248970358 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.194694: rtos_queue_send_from_isr_failed: tstamp:5248970505 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.194696: rtcpu_vinotify_event: tstamp:5249219134 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4750320416 data:0x10000000
kworker/1:5-1924 [001] .... 154.194697: rtcpu_vinotify_event: tstamp:5249219296 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4750349504 data:0x3100000c
kworker/1:5-1924 [001] .... 154.194698: rtcpu_vinotify_event: tstamp:5249219435 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5249214241 data:0x04370002
kworker/1:5-1924 [001] .... 154.194703: rtos_queue_send_from_isr_failed: tstamp:5249473896 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.194704: rtos_queue_send_from_isr_failed: tstamp:5249474049 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.194704: rtos_queue_send_from_isr_failed: tstamp:5249474201 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.194705: rtos_queue_send_from_isr_failed: tstamp:5249474348 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.194706: rtos_queue_send_from_isr_failed: tstamp:5249474496 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.194707: rtcpu_vinotify_event: tstamp:5249740493 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5249214268 data:0x00000000
kworker/1:5-1924 [001] .... 154.194708: rtcpu_vinotify_event: tstamp:5249740636 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4766112192 data:0x0202000b
kworker/1:5-1924 [001] .... 154.194709: rtcpu_vinotify_event: tstamp:5249740798 tag:FE channel:0x00 frame:1 vi_tstamp:5249214305 data:0x00000020
kworker/1:5-1924 [001] .... 154.194728: rtcpu_vinotify_event: tstamp:5249740939 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5249214308 data:0x00000000
kworker/1:5-1924 [001] .... 154.194729: rtcpu_vinotify_event: tstamp:5249741096 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4766137632 data:0x0002000b
kworker/1:5-1924 [001] .... 154.194730: rtcpu_vinotify_event: tstamp:5249741231 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4766159840 data:0x0702000c
kworker/1:5-1924 [001] .... 154.194731: rtcpu_vinotify_event: tstamp:5249741387 tag:FS channel:0x00 frame:1 vi_tstamp:5249234696 data:0x00000010
kworker/1:5-1924 [001] .... 154.194732: rtcpu_vinotify_event: tstamp:5249741528 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5249234699 data:0x00000000
kworker/1:5-1924 [001] .... 154.194733: rtcpu_vinotify_event: tstamp:5249741684 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5249235162 data:0x00000001
kworker/1:5-1924 [001] .... 154.194733: rtcpu_vinotify_event: tstamp:5249741819 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4766772160 data:0x0802000c
kworker/1:5-1924 [001] .... 154.194734: rtcpu_vinotify_event: tstamp:5249741974 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4766941760 data:0x10000000
kworker/1:5-1924 [001] .... 154.194735: rtcpu_vinotify_event: tstamp:5249742108 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4766970880 data:0x3100000d
kworker/1:5-1924 [001] .... 154.194736: rtcpu_vinotify_event: tstamp:5249742266 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5249735597 data:0x04370002
kworker/1:5-1924 [001] .... 154.194737: rtcpu_vinotify_event: tstamp:5249742401 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5249735626 data:0x00000000
kworker/1:5-1924 [001] .... 154.194738: rtcpu_vinotify_event: tstamp:5249742573 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4782789696 data:0x0202000c
kworker/1:5-1924 [001] .... 154.194738: rtcpu_vinotify_event: tstamp:5249742708 tag:FE channel:0x00 frame:1 vi_tstamp:5249735661 data:0x00000020
kworker/1:5-1924 [001] .... 154.194740: rtos_queue_send_from_isr_failed: tstamp:5249987144 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.194741: rtos_queue_send_from_isr_failed: tstamp:5249987298 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.194742: rtos_queue_send_from_isr_failed: tstamp:5249987450 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.194743: rtos_queue_send_from_isr_failed: tstamp:5249987595 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.194744: rtos_queue_send_from_isr_failed: tstamp:5249987740 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.194744: rtcpu_vinotify_event: tstamp:5250238762 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5249735664 data:0x00000000
kworker/1:5-1924 [001] .... 154.194745: rtcpu_vinotify_event: tstamp:5250238922 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4782821024 data:0x0002000c
kworker/1:5-1924 [001] .... 154.194746: rtcpu_vinotify_event: tstamp:5250239085 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4782843264 data:0x0702000d
kworker/1:5-1924 [001] .... 154.194747: rtcpu_vinotify_event: tstamp:5250239223 tag:FS channel:0x00 frame:1 vi_tstamp:5249756052 data:0x00000010
kworker/1:5-1924 [001] .... 154.194748: rtcpu_vinotify_event: tstamp:5250239382 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5249756055 data:0x00000000
kworker/1:5-1924 [001] .... 154.194749: rtcpu_vinotify_event: tstamp:5250239516 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5249756518 data:0x00000001
kworker/1:5-1924 [001] .... 154.194749: rtcpu_vinotify_event: tstamp:5250239672 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4783455584 data:0x0802000d
kworker/1:5-1924 [001] .... 154.194750: rtcpu_vinotify_event: tstamp:5250239807 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4783646464 data:0x10000000
kworker/1:5-1924 [001] .... 154.194751: rtcpu_vinotify_event: tstamp:5250239967 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4783675584 data:0x3100000e
kworker/1:5-1924 [001] .... 154.194752: rtcpu_vinotify_event: tstamp:5250261844 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5250256954 data:0x04370002
kworker/1:5-1924 [001] .... 154.194753: rtcpu_vinotify_event: tstamp:5250262004 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5250256982 data:0x00000000
kworker/1:5-1924 [001] .... 154.194754: rtcpu_vinotify_event: tstamp:5250262140 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4799473120 data:0x0202000d
kworker/1:5-1924 [001] .... 154.194754: rtcpu_vinotify_event: tstamp:5250262297 tag:FE channel:0x00 frame:1 vi_tstamp:5250257018 data:0x00000020
kworker/1:5-1924 [001] .... 154.194755: rtcpu_vinotify_event: tstamp:5250262434 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5250257021 data:0x00000000
kworker/1:5-1924 [001] .... 154.194756: rtcpu_vinotify_event: tstamp:5250262590 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4799498208 data:0x0002000d
kworker/1:5-1924 [001] .... 154.194757: rtcpu_vinotify_event: tstamp:5250262724 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4799519968 data:0x0702000e
kworker/1:5-1924 [001] .... 154.194772: rtos_queue_send_from_isr_failed: tstamp:5250515069 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.194773: rtos_queue_send_from_isr_failed: tstamp:5250515226 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.194774: rtos_queue_send_from_isr_failed: tstamp:5250515379 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.194775: rtos_queue_send_from_isr_failed: tstamp:5250515530 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.194775: rtos_queue_send_from_isr_failed: tstamp:5250515676 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.250693: rtcpu_vinotify_event: tstamp:5250785545 tag:FS channel:0x00 frame:1 vi_tstamp:5250277409 data:0x00000010
kworker/1:5-1924 [001] .... 154.250699: rtcpu_vinotify_event: tstamp:5250785693 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5250277412 data:0x00000000
kworker/1:5-1924 [001] .... 154.250700: rtcpu_vinotify_event: tstamp:5250785855 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:5250277875 data:0x00000001
kworker/1:5-1924 [001] .... 154.250702: rtcpu_vinotify_event: tstamp:5250785990 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4800139008 data:0x0802000e
kworker/1:5-1924 [001] .... 154.250703: rtcpu_vinotify_event: tstamp:5250786147 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4800333536 data:0x10000000
kworker/1:5-1924 [001] .... 154.250704: rtcpu_vinotify_event: tstamp:5250786280 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4800362688 data:0x3100000f
kworker/1:5-1924 [001] .... 154.250706: rtcpu_vinotify_event: tstamp:5250786437 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:5250778310 data:0x04370002
kworker/1:5-1924 [001] .... 154.250707: rtcpu_vinotify_event: tstamp:5250786572 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:5250778337 data:0x00000000
kworker/1:5-1924 [001] .... 154.250708: rtcpu_vinotify_event: tstamp:5250786729 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4816156544 data:0x0202000e
kworker/1:5-1924 [001] .... 154.250709: rtcpu_vinotify_event: tstamp:5250786865 tag:FE channel:0x00 frame:1 vi_tstamp:5250778375 data:0x00000020
kworker/1:5-1924 [001] .... 154.250713: rtos_queue_send_from_isr_failed: tstamp:5250786990 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.250714: rtos_queue_send_from_isr_failed: tstamp:5250787147 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.250715: rtos_queue_send_from_isr_failed: tstamp:5250787302 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.250717: rtos_queue_send_from_isr_failed: tstamp:5250787454 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.250718: rtos_queue_send_from_isr_failed: tstamp:5250787604 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.250719: rtcpu_vinotify_event: tstamp:5250787834 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5250778377 data:0x00000000
kworker/1:5-1924 [001] .... 154.250721: rtcpu_vinotify_event: tstamp:5250787970 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4816181664 data:0x0002000e
kworker/1:5-1924 [001] .... 154.250722: rtcpu_vinotify_event: tstamp:5250788127 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4816203392 data:0x0702000f
kworker/1:5-1924 [001] .... 154.250723: rtos_queue_send_from_isr_failed: tstamp:5250894954 queue:0x0bcb2e38
kworker/1:5-1924 [001] .... 154.250725: rtos_queue_send_from_isr_failed: tstamp:5250895120 queue:0x0bcb76a0
kworker/1:5-1924 [001] .... 154.250726: rtos_queue_send_from_isr_failed: tstamp:5250895273 queue:0x0bcb9220
kworker/1:5-1924 [001] .... 154.250727: rtos_queue_send_from_isr_failed: tstamp:5250895419 queue:0x0bcb9fe0
kworker/1:5-1924 [001] .... 154.250728: rtos_queue_send_from_isr_failed: tstamp:5250895566 queue:0x0bcbada0
kworker/1:5-1924 [001] .... 154.306696: rtos_queue_peek_from_isr_failed: tstamp:5252790707 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 154.474662: rtos_queue_peek_from_isr_failed: tstamp:5257790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 154.586671: rtos_queue_peek_from_isr_failed: tstamp:5262790709 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 154.754713: rtos_queue_peek_from_isr_failed: tstamp:5267790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 154.922662: rtos_queue_peek_from_isr_failed: tstamp:5272790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 155.090719: rtos_queue_peek_from_isr_failed: tstamp:5277790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 155.258717: rtos_queue_peek_from_isr_failed: tstamp:5282790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 155.426713: rtos_queue_peek_from_isr_failed: tstamp:5287790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 155.594734: rtos_queue_peek_from_isr_failed: tstamp:5292790709 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 155.706686: rtos_queue_peek_from_isr_failed: tstamp:5297790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 155.874691: rtos_queue_peek_from_isr_failed: tstamp:5302790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 156.042648: rtos_queue_peek_from_isr_failed: tstamp:5307790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 156.210660: rtos_queue_peek_from_isr_failed: tstamp:5312790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 156.378667: rtos_queue_peek_from_isr_failed: tstamp:5317790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 156.546682: rtos_queue_peek_from_isr_failed: tstamp:5322790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 156.714679: rtos_queue_peek_from_isr_failed: tstamp:5327790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 156.826654: rtos_queue_peek_from_isr_failed: tstamp:5332790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 156.994657: rtos_queue_peek_from_isr_failed: tstamp:5337790706 queue:0x0bcbbbb8
kworker/1:5-1924 [001] .... 157.162651: rtos_queue_peek_from_isr_failed: tstamp:5342790706 queue:0x0bcbbbb8
Do you have any ideas on how I could solve this errors?
Thanks,
Confirm the sensor output embedded data to define the embedded_metadata_height in device tree.
If I set the value, embedded_metadata_height, as 1, I get the same error as I mentioned at first.
On the otherhands, if I set the value, embedded_metadata_height, as 0, I get the second error.
Should it have to be set as 1?
Thanks,
Here is the trace log.
(Test1) : v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=UYUY --stream-mmap --stream-count=200 --stream-to=test0.jpeg
kworker/3:1-1149 [003] .... 136.631966: rtos_queue_peek_from_isr_failed: tstamp:4701240686 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 136.631974: rtcpu_start: tstamp:4701243365
kworker/3:1-1149 [003] .... 136.631976: rtos_queue_send_from_isr_failed: tstamp:4701278206 queue:0x0bcb2e38
kworker/3:1-1149 [003] .... 136.631978: rtos_queue_send_from_isr_failed: tstamp:4701278358 queue:0x0bcb76a0
kworker/3:1-1149 [003] .... 136.631979: rtos_queue_send_from_isr_failed: tstamp:4701278510 queue:0x0bcb9220
kworker/3:1-1149 [003] .... 136.631980: rtos_queue_send_from_isr_failed: tstamp:4701278656 queue:0x0bcb9fe0
kworker/3:1-1149 [003] .... 136.631981: rtos_queue_send_from_isr_failed: tstamp:4701278804 queue:0x0bcbada0
kworker/3:1-1149 [003] .... 136.631983: rtcpu_string: tstamp:4701279255 id:0x04010000 str:"Configuring VI GoS.
kworker/3:1-1149 [003] .... 136.632017: rtcpu_string: tstamp:4701279454 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/3:1-1149 [003] .... 136.632029: rtcpu_string: tstamp:4701279726 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/3:1-1149 [003] .... 136.632040: rtcpu_string: tstamp:4701279970 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/3:1-1149 [003] .... 136.632050: rtcpu_string: tstamp:4701280202 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/3:1-1149 [003] .... 136.632062: rtcpu_string: tstamp:4701280450 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/3:1-1149 [003] .... 136.632074: rtcpu_string: tstamp:4701280683 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/3:1-1149 [003] .... 136.632084: rtcpu_string: tstamp:4701289447 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/3:1-1149 [003] .... 136.632086: rtcpu_string: tstamp:4701289565 id:0x04010000 str:"on 2.2
kworker/3:1-1149 [003] .... 136.632097: rtos_queue_send_from_isr_failed: tstamp:4701303318 queue:0x0bcb2e38
kworker/3:1-1149 [003] .... 136.632098: rtos_queue_send_from_isr_failed: tstamp:4701303485 queue:0x0bcb76a0
kworker/3:1-1149 [003] .... 136.632100: rtos_queue_send_from_isr_failed: tstamp:4701303638 queue:0x0bcb9220
kworker/3:1-1149 [003] .... 136.632101: rtos_queue_send_from_isr_failed: tstamp:4701303783 queue:0x0bcb9fe0
kworker/3:1-1149 [003] .... 136.632102: rtos_queue_send_from_isr_failed: tstamp:4701303931 queue:0x0bcbada0
kworker/3:1-1149 [003] .... 136.632103: rtcpu_string: tstamp:4701304873 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/3:1-1149 [003] .... 136.632113: rtos_queue_send_from_isr_failed: tstamp:4701440302 queue:0x0bcb2e38
kworker/3:1-1149 [003] .... 136.632114: rtos_queue_send_from_isr_failed: tstamp:4701440452 queue:0x0bcb76a0
kworker/3:1-1149 [003] .... 136.632116: rtos_queue_send_from_isr_failed: tstamp:4701440604 queue:0x0bcb9220
kworker/3:1-1149 [003] .... 136.632117: rtos_queue_send_from_isr_failed: tstamp:4701440749 queue:0x0bcb9fe0
kworker/3:1-1149 [003] .... 136.632118: rtos_queue_send_from_isr_failed: tstamp:4701440894 queue:0x0bcbada0
kworker/3:1-1149 [003] .... 136.632120: rtcpu_vinotify_error: tstamp:4701449337 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:4701446499 data:0x00000001
kworker/3:1-1149 [003] .... 136.632127: rtcpu_vinotify_event: tstamp:4701796614 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4412904608 data:0x10000000
kworker/3:1-1149 [003] .... 136.632128: rtcpu_vinotify_event: tstamp:4701796757 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4412912800 data:0x31000001
kworker/3:1-1149 [003] .... 136.632130: rtcpu_vinotify_event: tstamp:4701796918 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4412914944 data:0x07020001
kworker/3:1-1149 [003] .... 136.632131: rtcpu_vinotify_event: tstamp:4701797055 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4412948320 data:0x10000000
kworker/3:1-1149 [003] .... 136.632132: rtcpu_vinotify_event: tstamp:4701797212 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4412956576 data:0x31000002
kworker/3:1-1149 [003] .... 136.632133: rtcpu_vinotify_event: tstamp:4701797355 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:4701446499 data:0x00000001
kworker/3:1-1149 [003] .... 136.632134: rtcpu_vinotify_event: tstamp:4701797515 tag:FS channel:0x00 frame:1 vi_tstamp:4701518791 data:0x00000010
kworker/3:1-1149 [003] .... 136.632135: rtcpu_vinotify_event: tstamp:4701797657 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:4701518794 data:0x00000000
kworker/3:1-1149 [003] .... 136.632136: rtcpu_vinotify_event: tstamp:4701797817 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:4701519257 data:0x00000001
kworker/3:1-1149 [003] .... 136.632137: rtcpu_vinotify_event: tstamp:4701797952 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4419732448 data:0x08020001
kworker/3:1-1149 [003] .... 136.687948: rtcpu_vinotify_event: tstamp:4702044311 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:4702019692 data:0x04370002
kworker/3:1-1149 [003] .... 136.687953: rtcpu_vinotify_event: tstamp:4702044450 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:4702019720 data:0x00000000
kworker/3:1-1149 [003] .... 136.687954: rtcpu_vinotify_event: tstamp:4702044608 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4435749920 data:0x02020001
kworker/3:1-1149 [003] .... 136.687956: rtcpu_vinotify_event: tstamp:4702044744 tag:FE channel:0x00 frame:1 vi_tstamp:4702019757 data:0x00000020
kworker/3:1-1149 [003] .... 136.687957: rtcpu_vinotify_event: tstamp:4702044901 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:4702019760 data:0x00000000
kworker/3:1-1149 [003] .... 136.687958: rtcpu_vinotify_event: tstamp:4702045036 tag:FS channel:0x00 frame:1 vi_tstamp:4702040149 data:0x00000010
kworker/3:1-1149 [003] .... 136.687959: rtcpu_vinotify_event: tstamp:4702556390 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:4702040151 data:0x00000000
kworker/3:1-1149 [003] .... 136.687960: rtcpu_vinotify_event: tstamp:4702556530 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:4702040613 data:0x00000001
kworker/3:1-1149 [003] .... 136.687962: rtcpu_vinotify_event: tstamp:4702556688 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4436419584 data:0x08020001
kworker/3:1-1149 [003] .... 136.687963: rtcpu_vinotify_event: tstamp:4702556822 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:4702541049 data:0x04370002
kworker/3:1-1149 [003] .... 136.687964: rtcpu_vinotify_event: tstamp:4702556978 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:4702541076 data:0x00000000
kworker/3:1-1149 [003] .... 136.687965: rtcpu_vinotify_event: tstamp:4702557113 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:4452433312 data:0x02020001
kworker/3:1-1149 [003] .... 136.687966: rtcpu_vinotify_event: tstamp:4702557269 tag:FE channel:0x00 frame:1 vi_tstamp:4702541114 data:0x00000020
kworker/3:1-1149 [003] .... 136.687968: rtcpu_vinotify_event: tstamp:4702557410 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:4702541116 data:0x00000000
kworker/3:1-1149 [003] .... 136.688002: rtcpu_vinotify_error: tstamp:4702564779 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4702561970 data:0x000003c9
kworker/3:1-1149 [003] .... 136.688004: rtcpu_vinotify_error: tstamp:4703086134 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4703083326 data:0x000003c9
kworker/3:1-1149 [003] .... 136.688005: rtcpu_vinotify_event: tstamp:4703098529 tag:FS channel:0x00 frame:1 vi_tstamp:4702561504 data:0x00000010
kworker/3:1-1149 [003] .... 136.688006: rtcpu_vinotify_event: tstamp:4703098667 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4702561970 data:0x000003c9
kworker/3:1-1149 [003] .... 136.688007: rtcpu_vinotify_event: tstamp:4703098824 tag:FE channel:0x00 frame:1 vi_tstamp:4703062470 data:0x00000020
kworker/3:1-1149 [003] .... 136.688008: rtcpu_vinotify_event: tstamp:4703098961 tag:FS channel:0x00 frame:1 vi_tstamp:4703082861 data:0x00000010
kworker/3:1-1149 [003] .... 136.688010: rtcpu_vinotify_event: tstamp:4703099118 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4703083326 data:0x000003c9
kworker/3:1-1149 [003] .... 136.688011: rtcpu_vinotify_error: tstamp:4703607623 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4703604682 data:0x000003c9
kworker/3:1-1149 [003] .... 136.688012: rtcpu_vinotify_event: tstamp:4703608007 tag:FE channel:0x00 frame:1 vi_tstamp:4703583826 data:0x00000020
kworker/3:1-1149 [003] .... 136.688013: rtcpu_vinotify_event: tstamp:4703608162 tag:FS channel:0x00 frame:1 vi_tstamp:4703604218 data:0x00000010
kworker/3:1-1149 [003] .... 136.688014: rtcpu_vinotify_event: tstamp:4703608297 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4703604682 data:0x000003c9
kworker/3:1-1149 [003] .... 136.743959: rtcpu_vinotify_error: tstamp:4704128843 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4704126039 data:0x000003c9
kworker/3:1-1149 [003] .... 136.743962: rtcpu_vinotify_event: tstamp:4704131811 tag:FE channel:0x00 frame:1 vi_tstamp:4704105183 data:0x00000020
kworker/3:1-1149 [003] .... 136.743964: rtcpu_vinotify_event: tstamp:4704131953 tag:FS channel:0x00 frame:1 vi_tstamp:4704125573 data:0x00000010
kworker/3:1-1149 [003] .... 136.743965: rtcpu_vinotify_event: tstamp:4704132112 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4704126039 data:0x000003c9
kworker/3:1-1149 [003] .... 136.743966: rtcpu_vinotify_error: tstamp:4704650212 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4704647395 data:0x000003c9
kworker/3:1-1149 [003] .... 136.743968: rtcpu_vinotify_event: tstamp:4704672131 tag:FE channel:0x00 frame:1 vi_tstamp:4704626539 data:0x00000020
kworker/3:1-1149 [003] .... 136.743969: rtcpu_vinotify_event: tstamp:4704672288 tag:FS channel:0x00 frame:1 vi_tstamp:4704646930 data:0x00000010
kworker/3:1-1149 [003] .... 136.743970: rtcpu_vinotify_event: tstamp:4704672427 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4704647395 data:0x000003c9
kworker/3:1-1149 [003] .... 136.743971: rtcpu_vinotify_error: tstamp:4705171562 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4705168751 data:0x000003c9
kworker/3:1-1149 [003] .... 136.743972: rtcpu_vinotify_event: tstamp:4705214783 tag:FE channel:0x00 frame:1 vi_tstamp:4705147895 data:0x00000020
kworker/3:1-1149 [003] .... 136.743974: rtcpu_vinotify_event: tstamp:4705214919 tag:FS channel:0x00 frame:1 vi_tstamp:4705168286 data:0x00000010
kworker/3:1-1149 [003] .... 136.743975: rtcpu_vinotify_event: tstamp:4705215076 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4705168751 data:0x000003c9
kworker/3:1-1149 [003] .... 136.799926: rtcpu_vinotify_error: tstamp:4705692916 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4705690108 data:0x000003c9
kworker/3:1-1149 [003] .... 136.799928: rtcpu_vinotify_event: tstamp:4705757440 tag:FE channel:0x00 frame:1 vi_tstamp:4705669251 data:0x00000020
kworker/3:1-1149 [003] .... 136.799930: rtcpu_vinotify_event: tstamp:4705757597 tag:FS channel:0x00 frame:1 vi_tstamp:4705689642 data:0x00000010
kworker/3:1-1149 [003] .... 136.799931: rtcpu_vinotify_event: tstamp:4705757734 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4705690108 data:0x000003c9
kworker/3:1-1149 [003] .... 136.799932: rtcpu_vinotify_error: tstamp:4706214267 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4706211464 data:0x000003c9
kworker/3:1-1149 [003] .... 136.799935: rtos_queue_peek_from_isr_failed: tstamp:4706241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 136.799936: rtcpu_vinotify_event: tstamp:4706300094 tag:FE channel:0x00 frame:1 vi_tstamp:4706190608 data:0x00000020
kworker/3:1-1149 [003] .... 136.799938: rtcpu_vinotify_event: tstamp:4706300233 tag:FS channel:0x00 frame:1 vi_tstamp:4706210999 data:0x00000010
kworker/3:1-1149 [003] .... 136.799964: rtcpu_vinotify_event: tstamp:4706300394 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4706211464 data:0x000003c9
kworker/3:1-1149 [003] .... 136.799965: rtcpu_vinotify_event: tstamp:4706714380 tag:FE channel:0x00 frame:1 vi_tstamp:4706711964 data:0x00000020
kworker/3:1-1149 [003] .... 136.799966: rtcpu_vinotify_error: tstamp:4706735618 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4706732820 data:0x000003c9
kworker/3:1-1149 [003] .... 136.799967: rtcpu_vinotify_event: tstamp:4707222235 tag:FS channel:0x00 frame:1 vi_tstamp:4706732355 data:0x00000010
kworker/3:1-1149 [003] .... 136.799969: rtcpu_vinotify_event: tstamp:4707222374 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4706732820 data:0x000003c9
kworker/3:1-1149 [003] .... 136.799970: rtcpu_vinotify_error: tstamp:4707256980 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4707254178 data:0x000003c9
kworker/3:1-1149 [003] .... 136.855936: rtcpu_vinotify_event: tstamp:4707764997 tag:FE channel:0x00 frame:1 vi_tstamp:4707233320 data:0x00000020
kworker/3:1-1149 [003] .... 136.855938: rtcpu_vinotify_event: tstamp:4707765137 tag:FS channel:0x00 frame:1 vi_tstamp:4707253711 data:0x00000010
kworker/3:1-1149 [003] .... 136.855939: rtcpu_vinotify_event: tstamp:4707765295 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4707254178 data:0x000003c9
kworker/3:1-1149 [003] .... 136.855942: rtcpu_vinotify_event: tstamp:4707765435 tag:FE channel:0x00 frame:1 vi_tstamp:4707754677 data:0x00000020
kworker/3:1-1149 [003] .... 136.855943: rtcpu_vinotify_error: tstamp:4707778366 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4707775533 data:0x000003c9
kworker/3:1-1149 [003] .... 136.855944: rtcpu_vinotify_error: tstamp:4708299694 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4708296890 data:0x000003c9
kworker/3:1-1149 [003] .... 136.855973: rtcpu_vinotify_event: tstamp:4708307141 tag:FS channel:0x00 frame:1 vi_tstamp:4707775067 data:0x00000010
kworker/3:1-1149 [003] .... 136.855974: rtcpu_vinotify_event: tstamp:4708307278 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4707775533 data:0x000003c9
kworker/3:1-1149 [003] .... 136.855975: rtcpu_vinotify_event: tstamp:4708307435 tag:FE channel:0x00 frame:1 vi_tstamp:4708276032 data:0x00000020
kworker/3:1-1149 [003] .... 136.855976: rtcpu_vinotify_event: tstamp:4708307570 tag:FS channel:0x00 frame:1 vi_tstamp:4708296424 data:0x00000010
kworker/3:1-1149 [003] .... 136.855978: rtcpu_vinotify_event: tstamp:4708307729 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4708296890 data:0x000003c9
kworker/3:1-1149 [003] .... 136.855979: rtcpu_vinotify_error: tstamp:4708821051 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4708818246 data:0x000003c9
kworker/3:1-1149 [003] .... 136.855980: rtcpu_vinotify_event: tstamp:4708849801 tag:FE channel:0x00 frame:1 vi_tstamp:4708797389 data:0x00000020
kworker/3:1-1149 [003] .... 136.855981: rtcpu_vinotify_event: tstamp:4708849957 tag:FS channel:0x00 frame:1 vi_tstamp:4708817780 data:0x00000010
kworker/3:1-1149 [003] .... 136.855982: rtcpu_vinotify_event: tstamp:4708850093 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4708818246 data:0x000003c9
kworker/3:1-1149 [003] .... 136.911954: rtcpu_vinotify_event: tstamp:4709342746 tag:FE channel:0x00 frame:1 vi_tstamp:4709318746 data:0x00000020
kworker/3:1-1149 [003] .... 136.911957: rtcpu_vinotify_event: tstamp:4709342887 tag:FS channel:0x00 frame:1 vi_tstamp:4709339136 data:0x00000010
kworker/3:1-1149 [003] .... 136.911958: rtcpu_vinotify_error: tstamp:4709343953 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4709339602 data:0x000003c9
kworker/3:1-1149 [003] .... 136.911959: rtcpu_vinotify_error: tstamp:4709863761 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4709860959 data:0x000003c9
kworker/3:1-1149 [003] .... 136.911960: rtcpu_vinotify_event: tstamp:4709880403 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4709339602 data:0x000003c9
kworker/3:1-1149 [003] .... 136.911961: rtcpu_vinotify_event: tstamp:4709880539 tag:FE channel:0x00 frame:1 vi_tstamp:4709840102 data:0x00000020
kworker/3:1-1149 [003] .... 136.911963: rtcpu_vinotify_event: tstamp:4709880695 tag:FS channel:0x00 frame:1 vi_tstamp:4709860493 data:0x00000010
kworker/3:1-1149 [003] .... 136.911964: rtcpu_vinotify_event: tstamp:4709880830 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4709860959 data:0x000003c9
kworker/3:1-1149 [003] .... 136.911965: rtcpu_vinotify_error: tstamp:4710385115 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4710382315 data:0x000003c9
kworker/3:1-1149 [003] .... 136.911966: rtcpu_vinotify_event: tstamp:4710423055 tag:FE channel:0x00 frame:1 vi_tstamp:4710361459 data:0x00000020
kworker/3:1-1149 [003] .... 136.911967: rtcpu_vinotify_event: tstamp:4710423192 tag:FS channel:0x00 frame:1 vi_tstamp:4710381849 data:0x00000010
kworker/3:1-1149 [003] .... 136.911968: rtcpu_vinotify_event: tstamp:4710423352 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4710382315 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967917: rtcpu_vinotify_error: tstamp:4710906475 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4710903671 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967919: rtcpu_vinotify_event: tstamp:4710965766 tag:FE channel:0x00 frame:1 vi_tstamp:4710882815 data:0x00000020
kworker/3:1-1149 [003] .... 136.967920: rtcpu_vinotify_event: tstamp:4710965924 tag:FS channel:0x00 frame:1 vi_tstamp:4710903205 data:0x00000010
kworker/3:1-1149 [003] .... 136.967922: rtcpu_vinotify_event: tstamp:4710966063 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4710903671 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967923: rtos_queue_peek_from_isr_failed: tstamp:4711241055 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 136.967924: rtcpu_vinotify_error: tstamp:4711427834 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4711425027 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967925: rtcpu_vinotify_event: tstamp:4711508359 tag:FE channel:0x00 frame:1 vi_tstamp:4711404171 data:0x00000020
kworker/3:1-1149 [003] .... 136.967927: rtcpu_vinotify_event: tstamp:4711508498 tag:FS channel:0x00 frame:1 vi_tstamp:4711424562 data:0x00000010
kworker/3:1-1149 [003] .... 136.967928: rtcpu_vinotify_event: tstamp:4711508656 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4711425027 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967929: rtcpu_vinotify_error: tstamp:4711949327 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4711946384 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967930: rtcpu_vinotify_event: tstamp:4711949709 tag:FE channel:0x00 frame:1 vi_tstamp:4711925528 data:0x00000020
kworker/3:1-1149 [003] .... 136.967931: rtcpu_vinotify_event: tstamp:4711949866 tag:FS channel:0x00 frame:1 vi_tstamp:4711945918 data:0x00000010
kworker/3:1-1149 [003] .... 136.967932: rtcpu_vinotify_event: tstamp:4711950002 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4711946384 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967934: rtcpu_vinotify_error: tstamp:4712470546 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4712467740 data:0x000003c9
kworker/3:1-1149 [003] .... 136.967935: rtcpu_vinotify_event: tstamp:4712485037 tag:FE channel:0x00 frame:1 vi_tstamp:4712446884 data:0x00000020
kworker/3:1-1149 [003] .... 136.967936: rtcpu_vinotify_event: tstamp:4712485176 tag:FS channel:0x00 frame:1 vi_tstamp:4712467274 data:0x00000010
kworker/3:1-1149 [003] .... 136.967937: rtcpu_vinotify_event: tstamp:4712485333 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4712467740 data:0x000003c9
kworker/3:1-1149 [003] .... 137.023912: rtcpu_vinotify_error: tstamp:4712991901 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4712989096 data:0x000003c9
kworker/3:1-1149 [003] .... 137.023914: rtcpu_vinotify_event: tstamp:4713027698 tag:FE channel:0x00 frame:1 vi_tstamp:4712968240 data:0x00000020
kworker/3:1-1149 [003] .... 137.023915: rtcpu_vinotify_event: tstamp:4713027855 tag:FS channel:0x00 frame:1 vi_tstamp:4712988631 data:0x00000010
kworker/3:1-1149 [003] .... 137.023917: rtcpu_vinotify_event: tstamp:4713028037 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4712989096 data:0x000003c9
kworker/3:1-1149 [003] .... 137.023918: rtcpu_vinotify_error: tstamp:4713513309 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4713510453 data:0x000003c9
kworker/3:1-1149 [003] .... 137.023919: rtcpu_vinotify_event: tstamp:4713569568 tag:FE channel:0x00 frame:1 vi_tstamp:4713489596 data:0x00000020
kworker/3:1-1149 [003] .... 137.023920: rtcpu_vinotify_event: tstamp:4713569705 tag:FS channel:0x00 frame:1 vi_tstamp:4713509987 data:0x00000010
kworker/3:1-1149 [003] .... 137.023921: rtcpu_vinotify_event: tstamp:4713569862 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4713510453 data:0x000003c9
kworker/3:1-1149 [003] .... 137.023923: rtcpu_vinotify_error: tstamp:4714034608 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4714031809 data:0x000003c9
kworker/3:1-1149 [003] .... 137.023953: rtcpu_vinotify_event: tstamp:4714112221 tag:FE channel:0x00 frame:1 vi_tstamp:4714010953 data:0x00000020
kworker/3:1-1149 [003] .... 137.023954: rtcpu_vinotify_event: tstamp:4714112375 tag:FS channel:0x00 frame:1 vi_tstamp:4714031344 data:0x00000010
kworker/3:1-1149 [003] .... 137.023955: rtcpu_vinotify_event: tstamp:4714112511 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4714031809 data:0x000003c9
kworker/3:1-1149 [003] .... 137.079945: rtcpu_vinotify_error: tstamp:4714555972 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4714553165 data:0x000003c9
kworker/3:1-1149 [003] .... 137.079948: rtcpu_vinotify_event: tstamp:4714654888 tag:FE channel:0x00 frame:1 vi_tstamp:4714532309 data:0x00000020
kworker/3:1-1149 [003] .... 137.079949: rtcpu_vinotify_event: tstamp:4714655027 tag:FS channel:0x00 frame:1 vi_tstamp:4714552700 data:0x00000010
kworker/3:1-1149 [003] .... 137.079950: rtcpu_vinotify_event: tstamp:4714655185 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4714553165 data:0x000003c9
kworker/3:1-1149 [003] .... 137.079952: rtcpu_vinotify_event: tstamp:4715056086 tag:FE channel:0x00 frame:1 vi_tstamp:4715053665 data:0x00000020
kworker/3:1-1149 [003] .... 137.079953: rtcpu_vinotify_error: tstamp:4715077323 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4715074522 data:0x000003c9
kworker/3:1-1149 [003] .... 137.079954: rtcpu_vinotify_event: tstamp:4715577090 tag:FS channel:0x00 frame:1 vi_tstamp:4715074056 data:0x00000010
kworker/3:1-1149 [003] .... 137.079955: rtcpu_vinotify_event: tstamp:4715577226 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4715074522 data:0x000003c9
kworker/3:1-1149 [003] .... 137.079956: rtcpu_vinotify_error: tstamp:4715598682 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4715595878 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135925: rtcpu_vinotify_error: tstamp:4716120041 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4716117234 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135931: rtcpu_vinotify_event: tstamp:4716122422 tag:FE channel:0x00 frame:1 vi_tstamp:4715575022 data:0x00000020
kworker/3:1-1149 [003] .... 137.135932: rtcpu_vinotify_event: tstamp:4716122561 tag:FS channel:0x00 frame:1 vi_tstamp:4715595412 data:0x00000010
kworker/3:1-1149 [003] .... 137.135934: rtcpu_vinotify_event: tstamp:4716122720 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4715595878 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135935: rtcpu_vinotify_event: tstamp:4716122855 tag:FE channel:0x00 frame:1 vi_tstamp:4716096377 data:0x00000020
kworker/3:1-1149 [003] .... 137.135936: rtcpu_vinotify_event: tstamp:4716123009 tag:FS channel:0x00 frame:1 vi_tstamp:4716116769 data:0x00000010
kworker/3:1-1149 [003] .... 137.135937: rtcpu_vinotify_event: tstamp:4716123144 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4716117234 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135940: rtos_queue_peek_from_isr_failed: tstamp:4716241055 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 137.135942: rtcpu_vinotify_error: tstamp:4716641400 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4716638590 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135943: rtcpu_vinotify_event: tstamp:4716662672 tag:FE channel:0x00 frame:1 vi_tstamp:4716617734 data:0x00000020
kworker/3:1-1149 [003] .... 137.135944: rtcpu_vinotify_event: tstamp:4716662810 tag:FS channel:0x00 frame:1 vi_tstamp:4716638125 data:0x00000010
kworker/3:1-1149 [003] .... 137.135945: rtcpu_vinotify_event: tstamp:4716662969 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4716638590 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135973: rtcpu_vinotify_error: tstamp:4717162750 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4717159948 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135974: rtcpu_vinotify_event: tstamp:4717205330 tag:FE channel:0x00 frame:1 vi_tstamp:4717139091 data:0x00000020
kworker/3:1-1149 [003] .... 137.135976: rtcpu_vinotify_event: tstamp:4717205487 tag:FS channel:0x00 frame:1 vi_tstamp:4717159481 data:0x00000010
kworker/3:1-1149 [003] .... 137.135977: rtcpu_vinotify_event: tstamp:4717205622 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4717159948 data:0x000003c9
kworker/3:1-1149 [003] .... 137.135978: rtcpu_vinotify_event: tstamp:4717684484 tag:FE channel:0x00 frame:1 vi_tstamp:4717660446 data:0x00000020
kworker/3:1-1149 [003] .... 137.135979: rtcpu_vinotify_event: tstamp:4717684621 tag:FS channel:0x00 frame:1 vi_tstamp:4717680838 data:0x00000010
kworker/3:1-1149 [003] .... 137.135980: rtcpu_vinotify_error: tstamp:4717685683 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4717681303 data:0x000003c9
kworker/3:1-1149 [003] .... 137.191917: rtcpu_vinotify_event: tstamp:4718181282 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4717681303 data:0x000003c9
kworker/3:1-1149 [003] .... 137.191923: rtcpu_vinotify_error: tstamp:4718205464 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4718202659 data:0x000003c9
kworker/3:1-1149 [003] .... 137.191924: rtcpu_vinotify_event: tstamp:4718724040 tag:FE channel:0x00 frame:1 vi_tstamp:4718181803 data:0x00000020
kworker/3:1-1149 [003] .... 137.191925: rtcpu_vinotify_event: tstamp:4718724197 tag:FS channel:0x00 frame:1 vi_tstamp:4718202194 data:0x00000010
kworker/3:1-1149 [003] .... 137.191927: rtcpu_vinotify_event: tstamp:4718725830 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4718202659 data:0x000003c9
kworker/3:1-1149 [003] .... 137.191928: rtcpu_vinotify_event: tstamp:4718725987 tag:FE channel:0x00 frame:1 vi_tstamp:4718703160 data:0x00000020
kworker/3:1-1149 [003] .... 137.191929: rtcpu_vinotify_error: tstamp:4718727047 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4718724017 data:0x000003c9
kworker/3:1-1149 [003] .... 137.191930: rtcpu_vinotify_error: tstamp:4719248231 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4719245372 data:0x000003c9
kworker/3:1-1149 [003] .... 137.191931: rtcpu_vinotify_event: tstamp:4719266920 tag:FS channel:0x00 frame:1 vi_tstamp:4718723550 data:0x00000010
kworker/3:1-1149 [003] .... 137.191932: rtcpu_vinotify_event: tstamp:4719267077 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4718724017 data:0x000003c9
kworker/3:1-1149 [003] .... 137.191934: rtcpu_vinotify_event: tstamp:4719267213 tag:FE channel:0x00 frame:1 vi_tstamp:4719224515 data:0x00000020
kworker/3:1-1149 [003] .... 137.191935: rtcpu_vinotify_event: tstamp:4719267367 tag:FS channel:0x00 frame:1 vi_tstamp:4719244907 data:0x00000010
kworker/3:1-1149 [003] .... 137.191937: rtcpu_vinotify_event: tstamp:4719267502 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4719245372 data:0x000003c9
kworker/3:1-1149 [003] .... 137.247935: rtcpu_vinotify_error: tstamp:4719769539 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4719766729 data:0x000003c9
kworker/3:1-1149 [003] .... 137.247939: rtcpu_vinotify_event: tstamp:4719808803 tag:FE channel:0x00 frame:1 vi_tstamp:4719745873 data:0x00000020
kworker/3:1-1149 [003] .... 137.247941: rtcpu_vinotify_event: tstamp:4719808940 tag:FS channel:0x00 frame:1 vi_tstamp:4719766263 data:0x00000010
kworker/3:1-1149 [003] .... 137.247942: rtcpu_vinotify_event: tstamp:4719809099 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4719766729 data:0x000003c9
kworker/3:1-1149 [003] .... 137.247943: rtcpu_vinotify_error: tstamp:4720291034 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4720288086 data:0x000003c9
kworker/3:1-1149 [003] .... 137.247944: rtcpu_vinotify_event: tstamp:4720291417 tag:FE channel:0x00 frame:1 vi_tstamp:4720267228 data:0x00000020
kworker/3:1-1149 [003] .... 137.247946: rtcpu_vinotify_event: tstamp:4720291571 tag:FS channel:0x00 frame:1 vi_tstamp:4720287619 data:0x00000010
kworker/3:1-1149 [003] .... 137.247947: rtcpu_vinotify_event: tstamp:4720291706 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4720288086 data:0x000003c9
kworker/3:1-1149 [003] .... 137.247978: rtcpu_vinotify_error: tstamp:4720812244 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4720809441 data:0x000003c9
kworker/3:1-1149 [003] .... 137.247979: rtcpu_vinotify_event: tstamp:4720839770 tag:FE channel:0x00 frame:1 vi_tstamp:4720788584 data:0x00000020
kworker/3:1-1149 [003] .... 137.247980: rtcpu_vinotify_event: tstamp:4720839908 tag:FS channel:0x00 frame:1 vi_tstamp:4720808975 data:0x00000010
kworker/3:1-1149 [003] .... 137.247981: rtcpu_vinotify_event: tstamp:4720840066 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4720809441 data:0x000003c9
kworker/3:1-1149 [003] .... 137.247984: rtos_queue_peek_from_isr_failed: tstamp:4721241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 137.303959: rtcpu_vinotify_error: tstamp:4721333606 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4721330798 data:0x000003c9
kworker/3:1-1149 [003] .... 137.303962: rtcpu_vinotify_event: tstamp:4721382432 tag:FE channel:0x00 frame:1 vi_tstamp:4721309941 data:0x00000020
kworker/3:1-1149 [003] .... 137.303963: rtcpu_vinotify_event: tstamp:4721382592 tag:FS channel:0x00 frame:1 vi_tstamp:4721330332 data:0x00000010
kworker/3:1-1149 [003] .... 137.303964: rtcpu_vinotify_event: tstamp:4721382732 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4721330798 data:0x000003c9
kworker/3:1-1149 [003] .... 137.303994: rtcpu_vinotify_error: tstamp:4721854958 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4721852154 data:0x000003c9
kworker/3:1-1149 [003] .... 137.303995: rtcpu_vinotify_event: tstamp:4721925083 tag:FE channel:0x00 frame:1 vi_tstamp:4721831298 data:0x00000020
kworker/3:1-1149 [003] .... 137.303996: rtcpu_vinotify_event: tstamp:4721925220 tag:FS channel:0x00 frame:1 vi_tstamp:4721851689 data:0x00000010
kworker/3:1-1149 [003] .... 137.303997: rtcpu_vinotify_event: tstamp:4721925377 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4721852154 data:0x000003c9
kworker/3:1-1149 [003] .... 137.303999: rtcpu_vinotify_error: tstamp:4722376317 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4722373510 data:0x000003c9
kworker/3:1-1149 [003] .... 137.304000: rtcpu_vinotify_event: tstamp:4722467737 tag:FE channel:0x00 frame:1 vi_tstamp:4722352654 data:0x00000020
kworker/3:1-1149 [003] .... 137.304001: rtcpu_vinotify_event: tstamp:4722467891 tag:FS channel:0x00 frame:1 vi_tstamp:4722373044 data:0x00000010
kworker/3:1-1149 [003] .... 137.304002: rtcpu_vinotify_event: tstamp:4722468029 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4722373510 data:0x000003c9
kworker/3:1-1149 [003] .... 137.304003: rtcpu_vinotify_error: tstamp:4722897668 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4722894867 data:0x000003c9
kworker/3:1-1149 [003] .... 137.304004: rtcpu_vinotify_event: tstamp:4723010391 tag:FE channel:0x00 frame:1 vi_tstamp:4722874010 data:0x00000020
kworker/3:1-1149 [003] .... 137.304006: rtcpu_vinotify_event: tstamp:4723010527 tag:FS channel:0x00 frame:1 vi_tstamp:4722894401 data:0x00000010
kworker/3:1-1149 [003] .... 137.304007: rtcpu_vinotify_event: tstamp:4723010684 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4722894867 data:0x000003c9
kworker/3:1-1149 [003] .... 137.359935: rtcpu_vinotify_event: tstamp:4723397786 tag:FE channel:0x00 frame:1 vi_tstamp:4723395367 data:0x00000020
kworker/3:1-1149 [003] .... 137.359938: rtcpu_vinotify_error: tstamp:4723419025 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4723416223 data:0x000003c9
kworker/3:1-1149 [003] .... 137.359939: rtcpu_vinotify_event: tstamp:4723932641 tag:FS channel:0x00 frame:1 vi_tstamp:4723415756 data:0x00000010
kworker/3:1-1149 [003] .... 137.359940: rtcpu_vinotify_event: tstamp:4723932777 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4723416223 data:0x000003c9
kworker/3:1-1149 [003] .... 137.359941: rtcpu_vinotify_event: tstamp:4723932939 tag:FE channel:0x00 frame:1 vi_tstamp:4723916723 data:0x00000020
kworker/3:1-1149 [003] .... 137.359942: rtcpu_vinotify_error: tstamp:4723940389 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4723937579 data:0x000003c9
kworker/3:1-1149 [003] .... 137.359943: rtcpu_vinotify_error: tstamp:4724461741 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4724458936 data:0x000003c9
kworker/3:1-1149 [003] .... 137.359945: rtcpu_vinotify_event: tstamp:4724474794 tag:FS channel:0x00 frame:1 vi_tstamp:4723937114 data:0x00000010
kworker/3:1-1149 [003] .... 137.359946: rtcpu_vinotify_event: tstamp:4724474953 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4723937579 data:0x000003c9
kworker/3:1-1149 [003] .... 137.359947: rtcpu_vinotify_event: tstamp:4724475088 tag:FE channel:0x00 frame:1 vi_tstamp:4724438079 data:0x00000020
kworker/3:1-1149 [003] .... 137.359948: rtcpu_vinotify_event: tstamp:4724475242 tag:FS channel:0x00 frame:1 vi_tstamp:4724458470 data:0x00000010
kworker/3:1-1149 [003] .... 137.359949: rtcpu_vinotify_event: tstamp:4724475377 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4724458936 data:0x000003c9
kworker/3:1-1149 [003] .... 137.416001: rtcpu_vinotify_error: tstamp:4724983100 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4724980292 data:0x000003c9
kworker/3:1-1149 [003] .... 137.416004: rtcpu_vinotify_event: tstamp:4725017453 tag:FE channel:0x00 frame:1 vi_tstamp:4724959436 data:0x00000020
kworker/3:1-1149 [003] .... 137.416005: rtcpu_vinotify_event: tstamp:4725017589 tag:FS channel:0x00 frame:1 vi_tstamp:4724979826 data:0x00000010
kworker/3:1-1149 [003] .... 137.416006: rtcpu_vinotify_event: tstamp:4725017749 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4724980292 data:0x000003c9
kworker/3:1-1149 [003] .... 137.416008: rtcpu_vinotify_error: tstamp:4725504454 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4725501648 data:0x000003c9
kworker/3:1-1149 [003] .... 137.416009: rtcpu_vinotify_event: tstamp:4725560159 tag:FE channel:0x00 frame:1 vi_tstamp:4725480791 data:0x00000020
kworker/3:1-1149 [003] .... 137.416010: rtcpu_vinotify_event: tstamp:4725560316 tag:FS channel:0x00 frame:1 vi_tstamp:4725501183 data:0x00000010
kworker/3:1-1149 [003] .... 137.416012: rtcpu_vinotify_event: tstamp:4725560454 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4725501648 data:0x000003c9
kworker/3:1-1149 [003] .... 137.416013: rtcpu_vinotify_event: tstamp:4726026146 tag:FE channel:0x00 frame:1 vi_tstamp:4726002148 data:0x00000020
kworker/3:1-1149 [003] .... 137.416014: rtcpu_vinotify_event: tstamp:4726026282 tag:FS channel:0x00 frame:1 vi_tstamp:4726022539 data:0x00000010
kworker/3:1-1149 [003] .... 137.416015: rtcpu_vinotify_error: tstamp:4726027347 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4726023004 data:0x000003c9
kworker/3:1-1149 [003] .... 137.416017: rtos_queue_peek_from_isr_failed: tstamp:4726241051 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 137.416019: rtcpu_vinotify_event: tstamp:4726536951 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4726023004 data:0x000003c9
kworker/3:1-1149 [003] .... 137.416048: rtcpu_vinotify_event: tstamp:4726537090 tag:FE channel:0x00 frame:1 vi_tstamp:4726523505 data:0x00000020
kworker/3:1-1149 [003] .... 137.471919: rtcpu_vinotify_error: tstamp:4726547160 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4726544361 data:0x000003c9
kworker/3:1-1149 [003] .... 137.471923: rtcpu_vinotify_error: tstamp:4727068520 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4727065717 data:0x000003c9
kworker/3:1-1149 [003] .... 137.471925: rtcpu_vinotify_event: tstamp:4727079095 tag:FS channel:0x00 frame:1 vi_tstamp:4726543895 data:0x00000010
kworker/3:1-1149 [003] .... 137.471927: rtcpu_vinotify_event: tstamp:4727079232 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4726544361 data:0x000003c9
kworker/3:1-1149 [003] .... 137.471928: rtcpu_vinotify_event: tstamp:4727079389 tag:FE channel:0x00 frame:1 vi_tstamp:4727044860 data:0x00000020
kworker/3:1-1149 [003] .... 137.471929: rtcpu_vinotify_event: tstamp:4727079525 tag:FS channel:0x00 frame:1 vi_tstamp:4727065252 data:0x00000010
kworker/3:1-1149 [003] .... 137.471931: rtcpu_vinotify_event: tstamp:4727079682 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4727065717 data:0x000003c9
kworker/3:1-1149 [003] .... 137.471932: rtcpu_vinotify_error: tstamp:4727589878 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4727587073 data:0x000003c9
kworker/3:1-1149 [003] .... 137.471933: rtcpu_vinotify_event: tstamp:4727621789 tag:FE channel:0x00 frame:1 vi_tstamp:4727566217 data:0x00000020
kworker/3:1-1149 [003] .... 137.471934: rtcpu_vinotify_event: tstamp:4727621945 tag:FS channel:0x00 frame:1 vi_tstamp:4727586608 data:0x00000010
kworker/3:1-1149 [003] .... 137.471935: rtcpu_vinotify_event: tstamp:4727622081 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4727587073 data:0x000003c9
kworker/3:1-1149 [003] .... 137.471937: rtcpu_vinotify_error: tstamp:4728111234 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4728108430 data:0x000003c9
kworker/3:1-1149 [003] .... 137.471938: rtcpu_vinotify_event: tstamp:4728164406 tag:FE channel:0x00 frame:1 vi_tstamp:4728087574 data:0x00000020
kworker/3:1-1149 [003] .... 137.471939: rtcpu_vinotify_event: tstamp:4728164542 tag:FS channel:0x00 frame:1 vi_tstamp:4728107964 data:0x00000010
kworker/3:1-1149 [003] .... 137.471969: rtcpu_vinotify_event: tstamp:4728164699 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4728108430 data:0x000003c9
kworker/3:1-1149 [003] .... 137.527911: rtcpu_vinotify_error: tstamp:4728632729 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4728629786 data:0x000003c9
kworker/3:1-1149 [003] .... 137.527916: rtcpu_vinotify_event: tstamp:4728633117 tag:FE channel:0x00 frame:1 vi_tstamp:4728608929 data:0x00000020
kworker/3:1-1149 [003] .... 137.527917: rtcpu_vinotify_event: tstamp:4728633275 tag:FS channel:0x00 frame:1 vi_tstamp:4728629320 data:0x00000010
kworker/3:1-1149 [003] .... 137.527919: rtcpu_vinotify_event: tstamp:4728633411 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4728629786 data:0x000003c9
kworker/3:1-1149 [003] .... 137.527920: rtcpu_vinotify_event: tstamp:4729140811 tag:FE channel:0x00 frame:1 vi_tstamp:4729130286 data:0x00000020
kworker/3:1-1149 [003] .... 137.527922: rtcpu_vinotify_error: tstamp:4729153978 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4729151142 data:0x000003c9
kworker/3:1-1149 [003] .... 137.527923: rtcpu_vinotify_error: tstamp:4729675303 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4729672499 data:0x000003c9
kworker/3:1-1149 [003] .... 137.527924: rtcpu_vinotify_event: tstamp:4729683738 tag:FS channel:0x00 frame:1 vi_tstamp:4729150677 data:0x00000010
kworker/3:1-1149 [003] .... 137.527925: rtcpu_vinotify_event: tstamp:4729683895 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4729151142 data:0x000003c9
kworker/3:1-1149 [003] .... 137.527956: rtcpu_vinotify_event: tstamp:4729684031 tag:FE channel:0x00 frame:1 vi_tstamp:4729651642 data:0x00000020
kworker/3:1-1149 [003] .... 137.527957: rtcpu_vinotify_event: tstamp:4729684227 tag:FS channel:0x00 frame:1 vi_tstamp:4729672033 data:0x00000010
kworker/3:1-1149 [003] .... 137.527958: rtcpu_vinotify_event: tstamp:4729684366 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4729672499 data:0x000003c9
kworker/3:1-1149 [003] .... 137.583962: rtcpu_vinotify_error: tstamp:4730196697 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4730193855 data:0x000003c9
kworker/3:1-1149 [003] .... 137.583965: rtcpu_vinotify_event: tstamp:4730225622 tag:FE channel:0x00 frame:1 vi_tstamp:4730172998 data:0x00000020
kworker/3:1-1149 [003] .... 137.583966: rtcpu_vinotify_event: tstamp:4730225758 tag:FS channel:0x00 frame:1 vi_tstamp:4730193389 data:0x00000010
kworker/3:1-1149 [003] .... 137.583968: rtcpu_vinotify_event: tstamp:4730225915 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4730193855 data:0x000003c9
kworker/3:1-1149 [003] .... 137.583969: rtcpu_vinotify_error: tstamp:4730718022 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4730715212 data:0x000003c9
kworker/3:1-1149 [003] .... 137.583970: rtcpu_vinotify_event: tstamp:4730768276 tag:FE channel:0x00 frame:1 vi_tstamp:4730694354 data:0x00000020
kworker/3:1-1149 [003] .... 137.584005: rtcpu_vinotify_event: tstamp:4730768432 tag:FS channel:0x00 frame:1 vi_tstamp:4730714746 data:0x00000010
kworker/3:1-1149 [003] .... 137.584006: rtcpu_vinotify_event: tstamp:4730768568 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4730715212 data:0x000003c9
kworker/3:1-1149 [003] .... 137.584008: rtcpu_vinotify_error: tstamp:4731239372 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4731236568 data:0x000003c9
kworker/3:1-1149 [003] .... 137.584010: rtos_queue_peek_from_isr_failed: tstamp:4731241047 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 137.584013: rtcpu_vinotify_event: tstamp:4731310939 tag:FE channel:0x00 frame:1 vi_tstamp:4731215712 data:0x00000020
kworker/3:1-1149 [003] .... 137.584014: rtcpu_vinotify_event: tstamp:4731311080 tag:FS channel:0x00 frame:1 vi_tstamp:4731236102 data:0x00000010
kworker/3:1-1149 [003] .... 137.584016: rtcpu_vinotify_event: tstamp:4731311238 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4731236568 data:0x000003c9
kworker/3:1-1149 [003] .... 137.584017: rtcpu_vinotify_event: tstamp:4731739486 tag:FE channel:0x00 frame:1 vi_tstamp:4731737068 data:0x00000020
kworker/3:1-1149 [003] .... 137.584018: rtcpu_vinotify_error: tstamp:4731760728 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4731757924 data:0x000003c9
kworker/3:1-1149 [003] .... 137.639936: rtcpu_vinotify_event: tstamp:4732233078 tag:FS channel:0x00 frame:1 vi_tstamp:4731757458 data:0x00000010
kworker/3:1-1149 [003] .... 137.639938: rtcpu_vinotify_event: tstamp:4732233218 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4731757924 data:0x000003c9
kworker/3:1-1149 [003] .... 137.639940: rtcpu_vinotify_error: tstamp:4732282082 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4732279281 data:0x000003c9
kworker/3:1-1149 [003] .... 137.639941: rtcpu_vinotify_event: tstamp:4732775731 tag:FE channel:0x00 frame:1 vi_tstamp:4732258424 data:0x00000020
kworker/3:1-1149 [003] .... 137.639942: rtcpu_vinotify_event: tstamp:4732775869 tag:FS channel:0x00 frame:1 vi_tstamp:4732278815 data:0x00000010
kworker/3:1-1149 [003] .... 137.639944: rtcpu_vinotify_event: tstamp:4732776028 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4732279281 data:0x000003c9
kworker/3:1-1149 [003] .... 137.639945: rtcpu_vinotify_error: tstamp:4732803439 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4732800637 data:0x000003c9
kworker/3:1-1149 [003] .... 137.639946: rtcpu_vinotify_event: tstamp:4733318493 tag:FE channel:0x00 frame:1 vi_tstamp:4732779781 data:0x00000020
kworker/3:1-1149 [003] .... 137.639947: rtcpu_vinotify_event: tstamp:4733318649 tag:FS channel:0x00 frame:1 vi_tstamp:4732800171 data:0x00000010
kworker/3:1-1149 [003] .... 137.639948: rtcpu_vinotify_event: tstamp:4733318786 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4732800637 data:0x000003c9
kworker/3:1-1149 [003] .... 137.639949: rtcpu_vinotify_event: tstamp:4733318942 tag:FE channel:0x00 frame:1 vi_tstamp:4733301137 data:0x00000020
kworker/3:1-1149 [003] .... 137.639951: rtcpu_vinotify_error: tstamp:4733324784 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4733321993 data:0x000003c9
kworker/3:1-1149 [003] .... 137.695944: rtcpu_vinotify_error: tstamp:4733846159 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4733843349 data:0x000003c9
kworker/3:1-1149 [003] .... 137.695947: rtcpu_vinotify_event: tstamp:4733860635 tag:FS channel:0x00 frame:1 vi_tstamp:4733321527 data:0x00000010
kworker/3:1-1149 [003] .... 137.695948: rtcpu_vinotify_event: tstamp:4733860795 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4733321993 data:0x000003c9
kworker/3:1-1149 [003] .... 137.695949: rtcpu_vinotify_event: tstamp:4733860933 tag:FE channel:0x00 frame:1 vi_tstamp:4733822493 data:0x00000020
kworker/3:1-1149 [003] .... 137.695951: rtcpu_vinotify_event: tstamp:4733861089 tag:FS channel:0x00 frame:1 vi_tstamp:4733842884 data:0x00000010
kworker/3:1-1149 [003] .... 137.695952: rtcpu_vinotify_event: tstamp:4733861224 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4733843349 data:0x000003c9
kworker/3:1-1149 [003] .... 137.695993: rtcpu_vinotify_event: tstamp:4734367843 tag:FE channel:0x00 frame:1 vi_tstamp:4734343850 data:0x00000020
kworker/3:1-1149 [003] .... 137.695994: rtcpu_vinotify_event: tstamp:4734367981 tag:FS channel:0x00 frame:1 vi_tstamp:4734364240 data:0x00000010
kworker/3:1-1149 [003] .... 137.695995: rtcpu_vinotify_error: tstamp:4734369044 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4734364706 data:0x000003c9
kworker/3:1-1149 [003] .... 137.695996: rtcpu_vinotify_error: tstamp:4734888868 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4734886062 data:0x000003c9
kworker/3:1-1149 [003] .... 137.695998: rtcpu_vinotify_event: tstamp:4734892011 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4734364706 data:0x000003c9
kworker/3:1-1149 [003] .... 137.695999: rtcpu_vinotify_event: tstamp:4734892147 tag:FE channel:0x00 frame:1 vi_tstamp:4734865206 data:0x00000020
kworker/3:1-1149 [003] .... 137.696000: rtcpu_vinotify_event: tstamp:4734892302 tag:FS channel:0x00 frame:1 vi_tstamp:4734885597 data:0x00000010
kworker/3:1-1149 [003] .... 137.696001: rtcpu_vinotify_event: tstamp:4734892439 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4734886062 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751904: rtcpu_vinotify_error: tstamp:4735410228 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4735407418 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751908: rtcpu_vinotify_event: tstamp:4735434703 tag:FE channel:0x00 frame:1 vi_tstamp:4735386562 data:0x00000020
kworker/3:1-1149 [003] .... 137.751909: rtcpu_vinotify_event: tstamp:4735434840 tag:FS channel:0x00 frame:1 vi_tstamp:4735406953 data:0x00000010
kworker/3:1-1149 [003] .... 137.751911: rtcpu_vinotify_event: tstamp:4735434997 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4735407418 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751912: rtcpu_vinotify_error: tstamp:4735931580 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4735928775 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751913: rtcpu_vinotify_event: tstamp:4735976540 tag:FE channel:0x00 frame:1 vi_tstamp:4735907919 data:0x00000020
kworker/3:1-1149 [003] .... 137.751915: rtcpu_vinotify_event: tstamp:4735976697 tag:FS channel:0x00 frame:1 vi_tstamp:4735928309 data:0x00000010
kworker/3:1-1149 [003] .... 137.751916: rtcpu_vinotify_event: tstamp:4735976833 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4735928775 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751918: rtos_queue_peek_from_isr_failed: tstamp:4736241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 137.751920: rtcpu_vinotify_error: tstamp:4736452939 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4736450131 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751921: rtcpu_vinotify_event: tstamp:4736519191 tag:FE channel:0x00 frame:1 vi_tstamp:4736429275 data:0x00000020
kworker/3:1-1149 [003] .... 137.751922: rtcpu_vinotify_event: tstamp:4736519329 tag:FS channel:0x00 frame:1 vi_tstamp:4736449666 data:0x00000010
kworker/3:1-1149 [003] .... 137.751923: rtcpu_vinotify_event: tstamp:4736519488 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4736450131 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751925: rtcpu_vinotify_error: tstamp:4736974429 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4736971487 data:0x000003c9
kworker/3:1-1149 [003] .... 137.751926: rtcpu_vinotify_event: tstamp:4736974813 tag:FE channel:0x00 frame:1 vi_tstamp:4736950631 data:0x00000020
kworker/3:1-1149 [003] .... 137.751927: rtcpu_vinotify_event: tstamp:4736974970 tag:FS channel:0x00 frame:1 vi_tstamp:4736971022 data:0x00000010
kworker/3:1-1149 [003] .... 137.751928: rtcpu_vinotify_event: tstamp:4736975106 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4736971487 data:0x000003c9
kworker/3:1-1149 [003] .... 137.807919: rtcpu_vinotify_error: tstamp:4737495689 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4737492844 data:0x000003c9
kworker/3:1-1149 [003] .... 137.807923: rtcpu_vinotify_event: tstamp:4737498221 tag:FE channel:0x00 frame:1 vi_tstamp:4737471987 data:0x00000020
kworker/3:1-1149 [003] .... 137.807925: rtcpu_vinotify_event: tstamp:4737498359 tag:FS channel:0x00 frame:1 vi_tstamp:4737492378 data:0x00000010
kworker/3:1-1149 [003] .... 137.807926: rtcpu_vinotify_event: tstamp:4737498519 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4737492844 data:0x000003c9
kworker/3:1-1149 [003] .... 137.807927: rtcpu_vinotify_error: tstamp:4738017003 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4738014200 data:0x000003c9
kworker/3:1-1149 [003] .... 137.807929: rtcpu_vinotify_event: tstamp:4738038525 tag:FE channel:0x00 frame:1 vi_tstamp:4737993344 data:0x00000020
kworker/3:1-1149 [003] .... 137.807930: rtcpu_vinotify_event: tstamp:4738038698 tag:FS channel:0x00 frame:1 vi_tstamp:4738013734 data:0x00000010
kworker/3:1-1149 [003] .... 137.807931: rtcpu_vinotify_event: tstamp:4738038834 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4738014200 data:0x000003c9
kworker/3:1-1149 [003] .... 137.807932: rtcpu_vinotify_error: tstamp:4738538362 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4738535556 data:0x000003c9
kworker/3:1-1149 [003] .... 137.807933: rtcpu_vinotify_event: tstamp:4738581182 tag:FE channel:0x00 frame:1 vi_tstamp:4738514700 data:0x00000020
kworker/3:1-1149 [003] .... 137.807934: rtcpu_vinotify_event: tstamp:4738581317 tag:FS channel:0x00 frame:1 vi_tstamp:4738535091 data:0x00000010
kworker/3:1-1149 [003] .... 137.807936: rtcpu_vinotify_event: tstamp:4738581474 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4738535556 data:0x000003c9
kworker/3:1-1149 [003] .... 137.863895: rtcpu_vinotify_error: tstamp:4739059766 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4739056913 data:0x000003c9
kworker/3:1-1149 [003] .... 137.863897: rtcpu_vinotify_event: tstamp:4739123844 tag:FE channel:0x00 frame:1 vi_tstamp:4739036056 data:0x00000020
kworker/3:1-1149 [003] .... 137.863899: rtcpu_vinotify_event: tstamp:4739124003 tag:FS channel:0x00 frame:1 vi_tstamp:4739056447 data:0x00000010
kworker/3:1-1149 [003] .... 137.863900: rtcpu_vinotify_event: tstamp:4739124141 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4739056913 data:0x000003c9
kworker/3:1-1149 [003] .... 137.863901: rtcpu_vinotify_error: tstamp:4739581076 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4739578269 data:0x000003c9
kworker/3:1-1149 [003] .... 137.863903: rtcpu_vinotify_event: tstamp:4739666497 tag:FE channel:0x00 frame:1 vi_tstamp:4739557413 data:0x00000020
kworker/3:1-1149 [003] .... 137.863904: rtcpu_vinotify_event: tstamp:4739666635 tag:FS channel:0x00 frame:1 vi_tstamp:4739577803 data:0x00000010
kworker/3:1-1149 [003] .... 137.863905: rtcpu_vinotify_event: tstamp:4739666793 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4739578269 data:0x000003c9
kworker/3:1-1149 [003] .... 137.863906: rtcpu_vinotify_event: tstamp:4740081185 tag:FE channel:0x00 frame:1 vi_tstamp:4740078768 data:0x00000020
kworker/3:1-1149 [003] .... 137.863907: rtcpu_vinotify_error: tstamp:4740102427 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4740099625 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919900: rtcpu_vinotify_event: tstamp:4740588640 tag:FS channel:0x00 frame:1 vi_tstamp:4740099160 data:0x00000010
kworker/3:1-1149 [003] .... 137.919903: rtcpu_vinotify_event: tstamp:4740588782 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4740099625 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919904: rtcpu_vinotify_error: tstamp:4740623798 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4740620982 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919905: rtcpu_vinotify_event: tstamp:4741130621 tag:FE channel:0x00 frame:1 vi_tstamp:4740600126 data:0x00000020
kworker/3:1-1149 [003] .... 137.919906: rtcpu_vinotify_event: tstamp:4741130757 tag:FS channel:0x00 frame:1 vi_tstamp:4740620516 data:0x00000010
kworker/3:1-1149 [003] .... 137.919907: rtcpu_vinotify_event: tstamp:4741130914 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4740620982 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919909: rtcpu_vinotify_event: tstamp:4741131049 tag:FE channel:0x00 frame:1 vi_tstamp:4741121482 data:0x00000020
kworker/3:1-1149 [003] .... 137.919910: rtcpu_vinotify_error: tstamp:4741145128 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4741142338 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919912: rtos_queue_peek_from_isr_failed: tstamp:4741241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 137.919914: rtcpu_vinotify_error: tstamp:4741666505 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4741663695 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919915: rtcpu_vinotify_event: tstamp:4741673540 tag:FS channel:0x00 frame:1 vi_tstamp:4741141872 data:0x00000010
kworker/3:1-1149 [003] .... 137.919916: rtcpu_vinotify_event: tstamp:4741673677 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4741142338 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919918: rtcpu_vinotify_event: tstamp:4741673834 tag:FE channel:0x00 frame:1 vi_tstamp:4741642837 data:0x00000020
kworker/3:1-1149 [003] .... 137.919919: rtcpu_vinotify_event: tstamp:4741673969 tag:FS channel:0x00 frame:1 vi_tstamp:4741663229 data:0x00000010
kworker/3:1-1149 [003] .... 137.919920: rtcpu_vinotify_event: tstamp:4741674124 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4741663695 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919921: rtcpu_vinotify_error: tstamp:4742187855 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4742185051 data:0x000003c9
kworker/3:1-1149 [003] .... 137.919922: rtcpu_vinotify_event: tstamp:4742216254 tag:FE channel:0x00 frame:1 vi_tstamp:4742164194 data:0x00000020
kworker/3:1-1149 [003] .... 137.919923: rtcpu_vinotify_event: tstamp:4742216413 tag:FS channel:0x00 frame:1 vi_tstamp:4742184585 data:0x00000010
kworker/3:1-1149 [003] .... 137.919925: rtcpu_vinotify_event: tstamp:4742216549 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4742185051 data:0x000003c9
kworker/3:1-1149 [003] .... 137.975896: rtcpu_vinotify_event: tstamp:4742709551 tag:FE channel:0x00 frame:1 vi_tstamp:4742685551 data:0x00000020
kworker/3:1-1149 [003] .... 137.975899: rtcpu_vinotify_event: tstamp:4742709692 tag:FS channel:0x00 frame:1 vi_tstamp:4742705942 data:0x00000010
kworker/3:1-1149 [003] .... 137.975900: rtcpu_vinotify_error: tstamp:4742710757 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4742706407 data:0x000003c9
kworker/3:1-1149 [003] .... 137.975901: rtcpu_vinotify_error: tstamp:4743230568 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4743227763 data:0x000003c9
kworker/3:1-1149 [003] .... 137.975903: rtcpu_vinotify_event: tstamp:4743246842 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4742706407 data:0x000003c9
kworker/3:1-1149 [003] .... 137.975904: rtcpu_vinotify_event: tstamp:4743246982 tag:FE channel:0x00 frame:1 vi_tstamp:4743206907 data:0x00000020
kworker/3:1-1149 [003] .... 137.975906: rtcpu_vinotify_event: tstamp:4743247143 tag:FS channel:0x00 frame:1 vi_tstamp:4743227299 data:0x00000010
kworker/3:1-1149 [003] .... 137.975907: rtcpu_vinotify_event: tstamp:4743247281 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4743227763 data:0x000003c9
kworker/3:1-1149 [003] .... 137.975908: rtcpu_vinotify_error: tstamp:4743751925 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4743749120 data:0x000003c9
kworker/3:1-1149 [003] .... 137.975909: rtcpu_vinotify_event: tstamp:4743789453 tag:FE channel:0x00 frame:1 vi_tstamp:4743728264 data:0x00000020
kworker/3:1-1149 [003] .... 137.975910: rtcpu_vinotify_event: tstamp:4743789590 tag:FS channel:0x00 frame:1 vi_tstamp:4743748654 data:0x00000010
kworker/3:1-1149 [003] .... 137.975912: rtcpu_vinotify_event: tstamp:4743789747 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4743749120 data:0x000003c9
kworker/3:1-1149 [003] .... 138.031918: rtcpu_vinotify_error: tstamp:4744273283 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4744270476 data:0x000003c9
kworker/3:1-1149 [003] .... 138.031920: rtcpu_vinotify_event: tstamp:4744332106 tag:FE channel:0x00 frame:1 vi_tstamp:4744249620 data:0x00000020
kworker/3:1-1149 [003] .... 138.031922: rtcpu_vinotify_event: tstamp:4744332265 tag:FS channel:0x00 frame:1 vi_tstamp:4744270011 data:0x00000010
kworker/3:1-1149 [003] .... 138.031923: rtcpu_vinotify_event: tstamp:4744332401 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4744270476 data:0x000003c9
kworker/3:1-1149 [003] .... 138.031924: rtcpu_vinotify_error: tstamp:4744794638 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4744791832 data:0x000003c9
kworker/3:1-1149 [003] .... 138.031925: rtcpu_vinotify_event: tstamp:4744874756 tag:FE channel:0x00 frame:1 vi_tstamp:4744770976 data:0x00000020
kworker/3:1-1149 [003] .... 138.031926: rtcpu_vinotify_event: tstamp:4744874892 tag:FS channel:0x00 frame:1 vi_tstamp:4744791367 data:0x00000010
kworker/3:1-1149 [003] .... 138.031928: rtcpu_vinotify_event: tstamp:4744875049 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4744791832 data:0x000003c9
kworker/3:1-1149 [003] .... 138.031938: rtcpu_vinotify_error: tstamp:4745316129 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4745313189 data:0x000003c9
kworker/3:1-1149 [003] .... 138.031939: rtcpu_vinotify_event: tstamp:4745316513 tag:FE channel:0x00 frame:1 vi_tstamp:4745292332 data:0x00000020
kworker/3:1-1149 [003] .... 138.031940: rtcpu_vinotify_event: tstamp:4745316669 tag:FS channel:0x00 frame:1 vi_tstamp:4745312723 data:0x00000010
kworker/3:1-1149 [003] .... 138.031941: rtcpu_vinotify_event: tstamp:4745316806 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4745313189 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087892: rtcpu_vinotify_error: tstamp:4745837352 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4745834546 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087894: rtcpu_vinotify_event: tstamp:4745851435 tag:FE channel:0x00 frame:1 vi_tstamp:4745813689 data:0x00000020
kworker/3:1-1149 [003] .... 138.087896: rtcpu_vinotify_event: tstamp:4745851573 tag:FS channel:0x00 frame:1 vi_tstamp:4745834080 data:0x00000010
kworker/3:1-1149 [003] .... 138.087897: rtcpu_vinotify_event: tstamp:4745851732 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4745834546 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087898: rtos_queue_peek_from_isr_failed: tstamp:4746241055 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 138.087900: rtcpu_vinotify_error: tstamp:4746358712 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4746355901 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087901: rtcpu_vinotify_event: tstamp:4746393308 tag:FE channel:0x00 frame:1 vi_tstamp:4746335045 data:0x00000020
kworker/3:1-1149 [003] .... 138.087902: rtcpu_vinotify_event: tstamp:4746393466 tag:FS channel:0x00 frame:1 vi_tstamp:4746355436 data:0x00000010
kworker/3:1-1149 [003] .... 138.087903: rtcpu_vinotify_event: tstamp:4746393603 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4746355901 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087904: rtcpu_vinotify_error: tstamp:4746880062 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4746877258 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087905: rtcpu_vinotify_event: tstamp:4746935971 tag:FE channel:0x00 frame:1 vi_tstamp:4746856401 data:0x00000020
kworker/3:1-1149 [003] .... 138.087906: rtcpu_vinotify_event: tstamp:4746936107 tag:FS channel:0x00 frame:1 vi_tstamp:4746876792 data:0x00000010
kworker/3:1-1149 [003] .... 138.087908: rtcpu_vinotify_event: tstamp:4746936264 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4746877258 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087909: rtcpu_vinotify_error: tstamp:4747401422 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4747398614 data:0x000003c9
kworker/3:1-1149 [003] .... 138.087910: rtcpu_vinotify_event: tstamp:4747478616 tag:FE channel:0x00 frame:1 vi_tstamp:4747377758 data:0x00000020
kworker/3:1-1149 [003] .... 138.087911: rtcpu_vinotify_event: tstamp:4747478772 tag:FS channel:0x00 frame:1 vi_tstamp:4747398148 data:0x00000010
kworker/3:1-1149 [003] .... 138.087912: rtcpu_vinotify_event: tstamp:4747478908 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4747398614 data:0x000003c9
kworker/3:1-1149 [003] .... 138.143916: rtcpu_vinotify_error: tstamp:4747922773 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4747919970 data:0x000003c9
kworker/3:1-1149 [003] .... 138.143918: rtcpu_vinotify_event: tstamp:4748021273 tag:FE channel:0x00 frame:1 vi_tstamp:4747899114 data:0x00000020
kworker/3:1-1149 [003] .... 138.143919: rtcpu_vinotify_event: tstamp:4748021409 tag:FS channel:0x00 frame:1 vi_tstamp:4747919505 data:0x00000010
kworker/3:1-1149 [003] .... 138.143921: rtcpu_vinotify_event: tstamp:4748021566 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4747919970 data:0x000003c9
kworker/3:1-1149 [003] .... 138.143922: rtcpu_vinotify_event: tstamp:4748422893 tag:FE channel:0x00 frame:1 vi_tstamp:4748420470 data:0x00000020
kworker/3:1-1149 [003] .... 138.143923: rtcpu_vinotify_error: tstamp:4748444131 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4748441327 data:0x000003c9
kworker/3:1-1149 [003] .... 138.143924: rtcpu_vinotify_event: tstamp:4748943483 tag:FS channel:0x00 frame:1 vi_tstamp:4748440861 data:0x00000010
kworker/3:1-1149 [003] .... 138.143925: rtcpu_vinotify_event: tstamp:4748943620 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4748441327 data:0x000003c9
kworker/3:1-1149 [003] .... 138.143926: rtcpu_vinotify_error: tstamp:4748965517 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4748962683 data:0x000003c9
kworker/3:1-1149 [003] .... 138.199884: rtcpu_vinotify_event: tstamp:4749487423 tag:FE channel:0x00 frame:1 vi_tstamp:4748941827 data:0x00000020
kworker/3:1-1149 [003] .... 138.199886: rtcpu_vinotify_event: tstamp:4749487567 tag:FS channel:0x00 frame:1 vi_tstamp:4748962217 data:0x00000010
kworker/3:1-1149 [003] .... 138.199887: rtcpu_vinotify_event: tstamp:4749487728 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4748962683 data:0x000003c9
kworker/3:1-1149 [003] .... 138.199889: rtcpu_vinotify_event: tstamp:4749487863 tag:FE channel:0x00 frame:1 vi_tstamp:4749463182 data:0x00000020
kworker/3:1-1149 [003] .... 138.199890: rtcpu_vinotify_event: tstamp:4749488017 tag:FS channel:0x00 frame:1 vi_tstamp:4749483574 data:0x00000010
kworker/3:1-1149 [003] .... 138.199891: rtcpu_vinotify_error: tstamp:4749489080 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4749484039 data:0x000003c9
kworker/3:1-1149 [003] .... 138.199893: rtcpu_vinotify_error: tstamp:4750008204 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4750005396 data:0x000003c9
kworker/3:1-1149 [003] .... 138.199894: rtcpu_vinotify_event: tstamp:4750028662 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4749484039 data:0x000003c9
kworker/3:1-1149 [003] .... 138.199895: rtcpu_vinotify_event: tstamp:4750028822 tag:FE channel:0x00 frame:1 vi_tstamp:4749984539 data:0x00000020
kworker/3:1-1149 [003] .... 138.199896: rtcpu_vinotify_event: tstamp:4750028961 tag:FS channel:0x00 frame:1 vi_tstamp:4750004930 data:0x00000010
kworker/3:1-1149 [003] .... 138.199897: rtcpu_vinotify_event: tstamp:4750029118 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4750005396 data:0x000003c9
kworker/3:1-1149 [003] .... 138.199898: rtcpu_vinotify_error: tstamp:4750529611 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4750526753 data:0x000003c9
kworker/3:1-1149 [003] .... 138.199900: rtcpu_vinotify_event: tstamp:4750571267 tag:FE channel:0x00 frame:1 vi_tstamp:4750505896 data:0x00000020
kworker/3:1-1149 [003] .... 138.199901: rtcpu_vinotify_event: tstamp:4750571423 tag:FS channel:0x00 frame:1 vi_tstamp:4750526286 data:0x00000010
kworker/3:1-1149 [003] .... 138.199902: rtcpu_vinotify_event: tstamp:4750571562 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4750526753 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255947: rtcpu_vinotify_event: tstamp:4751051255 tag:FE channel:0x00 frame:1 vi_tstamp:4751027252 data:0x00000020
kworker/3:1-1149 [003] .... 138.255949: rtcpu_vinotify_event: tstamp:4751051400 tag:FS channel:0x00 frame:1 vi_tstamp:4751047643 data:0x00000010
kworker/3:1-1149 [003] .... 138.255950: rtcpu_vinotify_error: tstamp:4751052463 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4751048109 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255952: rtos_queue_peek_from_isr_failed: tstamp:4751241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 138.255953: rtcpu_vinotify_event: tstamp:4751548011 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4751048109 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255954: rtcpu_vinotify_error: tstamp:4751572269 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4751569465 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255955: rtcpu_vinotify_event: tstamp:4752089984 tag:FE channel:0x00 frame:1 vi_tstamp:4751548609 data:0x00000020
kworker/3:1-1149 [003] .... 138.255957: rtcpu_vinotify_event: tstamp:4752090142 tag:FS channel:0x00 frame:1 vi_tstamp:4751568999 data:0x00000010
kworker/3:1-1149 [003] .... 138.255958: rtcpu_vinotify_event: tstamp:4752090281 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4751569465 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255959: rtcpu_vinotify_event: tstamp:4752090477 tag:FE channel:0x00 frame:1 vi_tstamp:4752069965 data:0x00000020
kworker/3:1-1149 [003] .... 138.255960: rtcpu_vinotify_error: tstamp:4752093616 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4752090822 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255961: rtcpu_vinotify_error: tstamp:4752614983 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4752612177 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255962: rtcpu_vinotify_event: tstamp:4752632911 tag:FS channel:0x00 frame:1 vi_tstamp:4752090355 data:0x00000010
kworker/3:1-1149 [003] .... 138.255964: rtcpu_vinotify_event: tstamp:4752633070 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4752090822 data:0x000003c9
kworker/3:1-1149 [003] .... 138.255991: rtcpu_vinotify_event: tstamp:4752633205 tag:FE channel:0x00 frame:1 vi_tstamp:4752591321 data:0x00000020
kworker/3:1-1149 [003] .... 138.255993: rtcpu_vinotify_event: tstamp:4752633358 tag:FS channel:0x00 frame:1 vi_tstamp:4752611712 data:0x00000010
kworker/3:1-1149 [003] .... 138.255994: rtcpu_vinotify_event: tstamp:4752633493 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4752612177 data:0x000003c9
kworker/3:1-1149 [003] .... 138.311881: rtcpu_vinotify_error: tstamp:4753136339 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4753133534 data:0x000003c9
kworker/3:1-1149 [003] .... 138.311883: rtcpu_vinotify_event: tstamp:4753175574 tag:FE channel:0x00 frame:1 vi_tstamp:4753112678 data:0x00000020
kworker/3:1-1149 [003] .... 138.311884: rtcpu_vinotify_event: tstamp:4753175712 tag:FS channel:0x00 frame:1 vi_tstamp:4753133068 data:0x00000010
kworker/3:1-1149 [003] .... 138.311885: rtcpu_vinotify_event: tstamp:4753175871 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4753133534 data:0x000003c9
kworker/3:1-1149 [003] .... 138.311887: rtcpu_vinotify_error: tstamp:4753657830 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4753654891 data:0x000003c9
kworker/3:1-1149 [003] .... 138.311888: rtcpu_vinotify_event: tstamp:4753658214 tag:FE channel:0x00 frame:1 vi_tstamp:4753634034 data:0x00000020
kworker/3:1-1149 [003] .... 138.311889: rtcpu_vinotify_event: tstamp:4753658371 tag:FS channel:0x00 frame:1 vi_tstamp:4753654424 data:0x00000010
kworker/3:1-1149 [003] .... 138.311890: rtcpu_vinotify_event: tstamp:4753658506 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4753654891 data:0x000003c9
kworker/3:1-1149 [003] .... 138.311892: rtcpu_vinotify_error: tstamp:4754179052 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4754176246 data:0x000003c9
kworker/3:1-1149 [003] .... 138.311893: rtcpu_vinotify_event: tstamp:4754206540 tag:FE channel:0x00 frame:1 vi_tstamp:4754155390 data:0x00000020
kworker/3:1-1149 [003] .... 138.311894: rtcpu_vinotify_event: tstamp:4754206679 tag:FS channel:0x00 frame:1 vi_tstamp:4754175781 data:0x00000010
kworker/3:1-1149 [003] .... 138.311895: rtcpu_vinotify_event: tstamp:4754206836 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4754176246 data:0x000003c9
kworker/3:1-1149 [003] .... 138.367912: rtcpu_vinotify_error: tstamp:4754700408 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4754697603 data:0x000003c9
kworker/3:1-1149 [003] .... 138.367914: rtcpu_vinotify_event: tstamp:4754748418 tag:FE channel:0x00 frame:1 vi_tstamp:4754676747 data:0x00000020
kworker/3:1-1149 [003] .... 138.367915: rtcpu_vinotify_event: tstamp:4754748577 tag:FS channel:0x00 frame:1 vi_tstamp:4754697137 data:0x00000010
kworker/3:1-1149 [003] .... 138.367917: rtcpu_vinotify_event: tstamp:4754748716 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4754697603 data:0x000003c9
kworker/3:1-1149 [003] .... 138.367950: rtcpu_vinotify_error: tstamp:4755221766 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4755218959 data:0x000003c9
kworker/3:1-1149 [003] .... 138.367951: rtcpu_vinotify_event: tstamp:4755291067 tag:FE channel:0x00 frame:1 vi_tstamp:4755198103 data:0x00000020
kworker/3:1-1149 [003] .... 138.367952: rtcpu_vinotify_event: tstamp:4755291203 tag:FS channel:0x00 frame:1 vi_tstamp:4755218494 data:0x00000010
kworker/3:1-1149 [003] .... 138.367953: rtcpu_vinotify_event: tstamp:4755291359 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4755218959 data:0x000003c9
kworker/3:1-1149 [003] .... 138.367955: rtcpu_vinotify_error: tstamp:4755743122 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4755740315 data:0x000003c9
kworker/3:1-1149 [003] .... 138.367956: rtcpu_vinotify_event: tstamp:4755833720 tag:FE channel:0x00 frame:1 vi_tstamp:4755719459 data:0x00000020
kworker/3:1-1149 [003] .... 138.367957: rtcpu_vinotify_event: tstamp:4755833874 tag:FS channel:0x00 frame:1 vi_tstamp:4755739850 data:0x00000010
kworker/3:1-1149 [003] .... 138.367958: rtcpu_vinotify_event: tstamp:4755834010 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4755740315 data:0x000003c9
kworker/3:1-1149 [003] .... 138.367960: rtos_queue_peek_from_isr_failed: tstamp:4756241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 138.367961: rtcpu_vinotify_error: tstamp:4756264478 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4756261672 data:0x000003c9
kworker/3:1-1149 [003] .... 138.423941: rtcpu_vinotify_event: tstamp:4756376378 tag:FE channel:0x00 frame:1 vi_tstamp:4756240815 data:0x00000020
kworker/3:1-1149 [003] .... 138.423945: rtcpu_vinotify_event: tstamp:4756376521 tag:FS channel:0x00 frame:1 vi_tstamp:4756261206 data:0x00000010
kworker/3:1-1149 [003] .... 138.423946: rtcpu_vinotify_event: tstamp:4756376680 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4756261672 data:0x000003c9
kworker/3:1-1149 [003] .... 138.423947: rtcpu_vinotify_event: tstamp:4756764589 tag:FE channel:0x00 frame:1 vi_tstamp:4756762172 data:0x00000020
kworker/3:1-1149 [003] .... 138.423949: rtcpu_vinotify_error: tstamp:4756785828 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4756783028 data:0x000003c9
kworker/3:1-1149 [003] .... 138.423950: rtcpu_vinotify_event: tstamp:4757298629 tag:FS channel:0x00 frame:1 vi_tstamp:4756782562 data:0x00000010
kworker/3:1-1149 [003] .... 138.423952: rtcpu_vinotify_event: tstamp:4757298765 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4756783028 data:0x000003c9
kworker/3:1-1149 [003] .... 138.423953: rtcpu_vinotify_event: tstamp:4757298922 tag:FE channel:0x00 frame:1 vi_tstamp:4757283528 data:0x00000020
kworker/3:1-1149 [003] .... 138.423954: rtcpu_vinotify_error: tstamp:4757307178 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4757304384 data:0x000003c9
kworker/3:1-1149 [003] .... 138.423955: rtcpu_vinotify_error: tstamp:4757828550 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4757825740 data:0x000003c9
kworker/3:1-1149 [003] .... 138.423956: rtcpu_vinotify_event: tstamp:4757841614 tag:FS channel:0x00 frame:1 vi_tstamp:4757303919 data:0x00000010
kworker/3:1-1149 [003] .... 138.423957: rtcpu_vinotify_event: tstamp:4757841772 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4757304384 data:0x000003c9
kworker/3:1-1149 [003] .... 138.423959: rtcpu_vinotify_event: tstamp:4757841910 tag:FE channel:0x00 frame:1 vi_tstamp:4757804884 data:0x00000020
kworker/3:1-1149 [003] .... 138.423960: rtcpu_vinotify_event: tstamp:4757842064 tag:FS channel:0x00 frame:1 vi_tstamp:4757825275 data:0x00000010
kworker/3:1-1149 [003] .... 138.423961: rtcpu_vinotify_event: tstamp:4757842200 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4757825740 data:0x000003c9
kworker/3:1-1149 [003] .... 138.479908: rtcpu_vinotify_error: tstamp:4758349901 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4758347097 data:0x000003c9
kworker/3:1-1149 [003] .... 138.479911: rtcpu_vinotify_event: tstamp:4758383436 tag:FE channel:0x00 frame:1 vi_tstamp:4758326241 data:0x00000020
kworker/3:1-1149 [003] .... 138.479912: rtcpu_vinotify_event: tstamp:4758383573 tag:FS channel:0x00 frame:1 vi_tstamp:4758346631 data:0x00000010
kworker/3:1-1149 [003] .... 138.479913: rtcpu_vinotify_event: tstamp:4758383733 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4758347097 data:0x000003c9
kworker/3:1-1149 [003] .... 138.479915: rtcpu_vinotify_error: tstamp:4758871261 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4758868453 data:0x000003c9
kworker/3:1-1149 [003] .... 138.479916: rtcpu_vinotify_event: tstamp:4758926090 tag:FE channel:0x00 frame:1 vi_tstamp:4758847597 data:0x00000020
kworker/3:1-1149 [003] .... 138.479917: rtcpu_vinotify_event: tstamp:4758926247 tag:FS channel:0x00 frame:1 vi_tstamp:4758867988 data:0x00000010
kworker/3:1-1149 [003] .... 138.479918: rtcpu_vinotify_event: tstamp:4758926383 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4758868453 data:0x000003c9
kworker/3:1-1149 [003] .... 138.479919: rtcpu_vinotify_event: tstamp:4759392950 tag:FE channel:0x00 frame:1 vi_tstamp:4759368953 data:0x00000020
kworker/3:1-1149 [003] .... 138.479921: rtcpu_vinotify_event: tstamp:4759393087 tag:FS channel:0x00 frame:1 vi_tstamp:4759389344 data:0x00000010
kworker/3:1-1149 [003] .... 138.479922: rtcpu_vinotify_error: tstamp:4759394149 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4759389810 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535911: rtcpu_vinotify_event: tstamp:4759902975 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4759389810 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535915: rtcpu_vinotify_event: tstamp:4759903120 tag:FE channel:0x00 frame:1 vi_tstamp:4759890310 data:0x00000020
kworker/3:1-1149 [003] .... 138.535916: rtcpu_vinotify_error: tstamp:4759913961 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4759911167 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535918: rtcpu_vinotify_error: tstamp:4760435386 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4760432523 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535919: rtcpu_vinotify_event: tstamp:4760445076 tag:FS channel:0x00 frame:1 vi_tstamp:4759910700 data:0x00000010
kworker/3:1-1149 [003] .... 138.535920: rtcpu_vinotify_event: tstamp:4760445215 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4759911167 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535921: rtcpu_vinotify_event: tstamp:4760445373 tag:FE channel:0x00 frame:1 vi_tstamp:4760411665 data:0x00000020
kworker/3:1-1149 [003] .... 138.535922: rtcpu_vinotify_event: tstamp:4760445508 tag:FS channel:0x00 frame:1 vi_tstamp:4760432057 data:0x00000010
kworker/3:1-1149 [003] .... 138.535950: rtcpu_vinotify_event: tstamp:4760445664 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4760432523 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535951: rtcpu_vinotify_error: tstamp:4760956684 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4760953879 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535952: rtcpu_vinotify_event: tstamp:4760987742 tag:FE channel:0x00 frame:1 vi_tstamp:4760933022 data:0x00000020
kworker/3:1-1149 [003] .... 138.535953: rtcpu_vinotify_event: tstamp:4760987899 tag:FS channel:0x00 frame:1 vi_tstamp:4760953413 data:0x00000010
kworker/3:1-1149 [003] .... 138.535955: rtcpu_vinotify_event: tstamp:4760988035 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4760953879 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535957: rtos_queue_peek_from_isr_failed: tstamp:4761241055 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 138.535958: rtcpu_vinotify_error: tstamp:4761478047 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4761475236 data:0x000003c9
kworker/3:1-1149 [003] .... 138.535959: rtcpu_vinotify_event: tstamp:4761530395 tag:FE channel:0x00 frame:1 vi_tstamp:4761454379 data:0x00000020
kworker/3:1-1149 [003] .... 138.535961: rtcpu_vinotify_event: tstamp:4761530533 tag:FS channel:0x00 frame:1 vi_tstamp:4761474769 data:0x00000010
kworker/3:1-1149 [003] .... 138.535962: rtcpu_vinotify_event: tstamp:4761530692 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4761475236 data:0x000003c9
kworker/3:1-1149 [003] .... 138.591890: rtcpu_vinotify_error: tstamp:4761999536 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4761996591 data:0x000003c9
kworker/3:1-1149 [003] .... 138.591893: rtcpu_vinotify_event: tstamp:4761999923 tag:FE channel:0x00 frame:1 vi_tstamp:4761975735 data:0x00000020
kworker/3:1-1149 [003] .... 138.591894: rtcpu_vinotify_event: tstamp:4762000084 tag:FS channel:0x00 frame:1 vi_tstamp:4761996126 data:0x00000010
kworker/3:1-1149 [003] .... 138.591895: rtcpu_vinotify_event: tstamp:4762000220 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4761996591 data:0x000003c9
kworker/3:1-1149 [003] .... 138.591897: rtcpu_vinotify_event: tstamp:4762506801 tag:FE channel:0x00 frame:1 vi_tstamp:4762497092 data:0x00000020
kworker/3:1-1149 [003] .... 138.591898: rtcpu_vinotify_error: tstamp:4762520743 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4762517948 data:0x000003c9
kworker/3:1-1149 [003] .... 138.591899: rtcpu_vinotify_error: tstamp:4763042113 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4763039305 data:0x000003c9
kworker/3:1-1149 [003] .... 138.591925: rtcpu_vinotify_event: tstamp:4763049724 tag:FS channel:0x00 frame:1 vi_tstamp:4762517482 data:0x00000010
kworker/3:1-1149 [003] .... 138.591926: rtcpu_vinotify_event: tstamp:4763049883 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4762517948 data:0x000003c9
kworker/3:1-1149 [003] .... 138.591927: rtcpu_vinotify_event: tstamp:4763050019 tag:FE channel:0x00 frame:1 vi_tstamp:4763018447 data:0x00000020
kworker/3:1-1149 [003] .... 138.591929: rtcpu_vinotify_event: tstamp:4763050175 tag:FS channel:0x00 frame:1 vi_tstamp:4763038838 data:0x00000010
kworker/3:1-1149 [003] .... 138.591930: rtcpu_vinotify_event: tstamp:4763050310 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4763039305 data:0x000003c9
kworker/3:1-1149 [003] .... 138.647881: rtcpu_vinotify_error: tstamp:4763563468 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4763560660 data:0x000003c9
kworker/3:1-1149 [003] .... 138.647885: rtcpu_vinotify_event: tstamp:4763592386 tag:FE channel:0x00 frame:1 vi_tstamp:4763539804 data:0x00000020
kworker/3:1-1149 [003] .... 138.647886: rtcpu_vinotify_event: tstamp:4763592526 tag:FS channel:0x00 frame:1 vi_tstamp:4763560194 data:0x00000010
kworker/3:1-1149 [003] .... 138.647887: rtcpu_vinotify_event: tstamp:4763592685 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4763560660 data:0x000003c9
kworker/3:1-1149 [003] .... 138.647889: rtcpu_vinotify_error: tstamp:4764084825 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4764082017 data:0x000003c9
kworker/3:1-1149 [003] .... 138.647890: rtcpu_vinotify_event: tstamp:4764135039 tag:FE channel:0x00 frame:1 vi_tstamp:4764061161 data:0x00000020
kworker/3:1-1149 [003] .... 138.647891: rtcpu_vinotify_event: tstamp:4764135194 tag:FS channel:0x00 frame:1 vi_tstamp:4764081551 data:0x00000010
kworker/3:1-1149 [003] .... 138.647893: rtcpu_vinotify_event: tstamp:4764135330 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4764082017 data:0x000003c9
kworker/3:1-1149 [003] .... 138.647894: rtcpu_vinotify_error: tstamp:4764606181 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4764603374 data:0x000003c9
kworker/3:1-1149 [003] .... 138.647895: rtcpu_vinotify_event: tstamp:4764676911 tag:FE channel:0x00 frame:1 vi_tstamp:4764582517 data:0x00000020
kworker/3:1-1149 [003] .... 138.647925: rtcpu_vinotify_event: tstamp:4764677047 tag:FS channel:0x00 frame:1 vi_tstamp:4764602907 data:0x00000010
kworker/3:1-1149 [003] .... 138.647926: rtcpu_vinotify_event: tstamp:4764677204 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4764603374 data:0x000003c9
kworker/3:1-1149 [003] .... 138.703910: rtcpu_vinotify_event: tstamp:4765106293 tag:FE channel:0x00 frame:1 vi_tstamp:4765103873 data:0x00000020
kworker/3:1-1149 [003] .... 138.703914: rtcpu_vinotify_error: tstamp:4765127536 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4765124729 data:0x000003c9
kworker/3:1-1149 [003] .... 138.703916: rtcpu_vinotify_event: tstamp:4765599840 tag:FS channel:0x00 frame:1 vi_tstamp:4765124264 data:0x00000010
kworker/3:1-1149 [003] .... 138.703917: rtcpu_vinotify_event: tstamp:4765599976 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4765124729 data:0x000003c9
kworker/3:1-1149 [003] .... 138.703918: rtcpu_vinotify_error: tstamp:4765648891 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4765646086 data:0x000003c9
kworker/3:1-1149 [003] .... 138.703919: rtcpu_vinotify_event: tstamp:4766141715 tag:FE channel:0x00 frame:1 vi_tstamp:4765625229 data:0x00000020
kworker/3:1-1149 [003] .... 138.703921: rtcpu_vinotify_event: tstamp:4766141850 tag:FS channel:0x00 frame:1 vi_tstamp:4765645621 data:0x00000010
kworker/3:1-1149 [003] .... 138.703922: rtcpu_vinotify_event: tstamp:4766142007 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4765646086 data:0x000003c9
kworker/3:1-1149 [003] .... 138.703923: rtcpu_vinotify_error: tstamp:4766170250 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4766167442 data:0x000003c9
kworker/3:1-1149 [003] .... 138.703925: rtos_queue_peek_from_isr_failed: tstamp:4766241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 138.703927: rtcpu_vinotify_event: tstamp:4766684517 tag:FE channel:0x00 frame:1 vi_tstamp:4766146586 data:0x00000020
kworker/3:1-1149 [003] .... 138.703928: rtcpu_vinotify_event: tstamp:4766684676 tag:FS channel:0x00 frame:1 vi_tstamp:4766166977 data:0x00000010
kworker/3:1-1149 [003] .... 138.703929: rtcpu_vinotify_event: tstamp:4766684814 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4766167442 data:0x000003c9
kworker/3:1-1149 [003] .... 138.703930: rtcpu_vinotify_event: tstamp:4766684970 tag:FE channel:0x00 frame:1 vi_tstamp:4766667942 data:0x00000020
kworker/3:1-1149 [003] .... 138.703933: rtcpu_vinotify_error: tstamp:4766691593 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4766688798 data:0x000003c9
kworker/3:1-1149 [003] .... 138.759941: rtcpu_vinotify_error: tstamp:4767212963 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4767210155 data:0x000003c9
kworker/3:1-1149 [003] .... 138.759943: rtcpu_vinotify_event: tstamp:4767227409 tag:FS channel:0x00 frame:1 vi_tstamp:4766688333 data:0x00000010
kworker/3:1-1149 [003] .... 138.759945: rtcpu_vinotify_event: tstamp:4767227567 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4766688798 data:0x000003c9
kworker/3:1-1149 [003] .... 138.759946: rtcpu_vinotify_event: tstamp:4767227703 tag:FE channel:0x00 frame:1 vi_tstamp:4767189298 data:0x00000020
kworker/3:1-1149 [003] .... 138.759947: rtcpu_vinotify_event: tstamp:4767227859 tag:FS channel:0x00 frame:1 vi_tstamp:4767209690 data:0x00000010
kworker/3:1-1149 [003] .... 138.759948: rtcpu_vinotify_event: tstamp:4767227995 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4767210155 data:0x000003c9
kworker/3:1-1149 [003] .... 138.759950: rtcpu_vinotify_event: tstamp:4767734650 tag:FE channel:0x00 frame:1 vi_tstamp:4767710655 data:0x00000020
kworker/3:1-1149 [003] .... 138.759951: rtcpu_vinotify_event: tstamp:4767734787 tag:FS channel:0x00 frame:1 vi_tstamp:4767731045 data:0x00000010
kworker/3:1-1149 [003] .... 138.759952: rtcpu_vinotify_error: tstamp:4767735850 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4767731511 data:0x000003c9
kworker/3:1-1149 [003] .... 138.759953: rtcpu_vinotify_error: tstamp:4768255722 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4768252867 data:0x000003c9
kworker/3:1-1149 [003] .... 138.759954: rtcpu_vinotify_event: tstamp:4768258780 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4767731511 data:0x000003c9
kworker/3:1-1149 [003] .... 138.759955: rtcpu_vinotify_event: tstamp:4768258918 tag:FE channel:0x00 frame:1 vi_tstamp:4768232011 data:0x00000020
kworker/3:1-1149 [003] .... 138.759956: rtcpu_vinotify_event: tstamp:4768259075 tag:FS channel:0x00 frame:1 vi_tstamp:4768252402 data:0x00000010
kworker/3:1-1149 [003] .... 138.759958: rtcpu_vinotify_event: tstamp:4768259211 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4768252867 data:0x000003c9
kworker/3:1-1149 [003] .... 138.815870: rtcpu_vinotify_error: tstamp:4768777030 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4768774223 data:0x000003c9
kworker/3:1-1149 [003] .... 138.815872: rtcpu_vinotify_event: tstamp:4768800657 tag:FE channel:0x00 frame:1 vi_tstamp:4768753367 data:0x00000020
kworker/3:1-1149 [003] .... 138.815874: rtcpu_vinotify_event: tstamp:4768800796 tag:FS channel:0x00 frame:1 vi_tstamp:4768773759 data:0x00000010
kworker/3:1-1149 [003] .... 138.815875: rtcpu_vinotify_event: tstamp:4768800954 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4768774223 data:0x000003c9
kworker/3:1-1149 [003] .... 138.815876: rtcpu_vinotify_error: tstamp:4769298388 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4769295580 data:0x000003c9
kworker/3:1-1149 [003] .... 138.815877: rtcpu_vinotify_event: tstamp:4769343310 tag:FE channel:0x00 frame:1 vi_tstamp:4769274724 data:0x00000020
(+Continue) Test1 Trace log
kworker/3:1-1149 [003] .... 138.815878: rtcpu_vinotify_event: tstamp:4769343466 tag:FS channel:0x00 frame:1 vi_tstamp:4769295114 data:0x00000010
kworker/3:1-1149 [003] .... 138.815880: rtcpu_vinotify_event: tstamp:4769343602 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4769295580 data:0x000003c9
kworker/3:1-1149 [003] .... 138.815905: rtcpu_vinotify_error: tstamp:4769819743 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4769816937 data:0x000003c9
kworker/3:1-1149 [003] .... 138.815906: rtcpu_vinotify_event: tstamp:4769885961 tag:FE channel:0x00 frame:1 vi_tstamp:4769796080 data:0x00000020
kworker/3:1-1149 [003] .... 138.815907: rtcpu_vinotify_event: tstamp:4769886098 tag:FS channel:0x00 frame:1 vi_tstamp:4769816471 data:0x00000010
kworker/3:1-1149 [003] .... 138.815909: rtcpu_vinotify_event: tstamp:4769886254 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4769816937 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871877: rtcpu_vinotify_error: tstamp:4770341282 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4770338293 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871879: rtcpu_vinotify_event: tstamp:4770341689 tag:FE channel:0x00 frame:1 vi_tstamp:4770317436 data:0x00000020
kworker/3:1-1149 [003] .... 138.871881: rtcpu_vinotify_event: tstamp:4770341849 tag:FS channel:0x00 frame:1 vi_tstamp:4770337828 data:0x00000010
kworker/3:1-1149 [003] .... 138.871882: rtcpu_vinotify_event: tstamp:4770341985 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4770338293 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871883: rtcpu_vinotify_error: tstamp:4770862454 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4770859650 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871884: rtcpu_vinotify_event: tstamp:4770864984 tag:FE channel:0x00 frame:1 vi_tstamp:4770838793 data:0x00000020
kworker/3:1-1149 [003] .... 138.871885: rtcpu_vinotify_event: tstamp:4770865120 tag:FS channel:0x00 frame:1 vi_tstamp:4770859183 data:0x00000010
kworker/3:1-1149 [003] .... 138.871886: rtcpu_vinotify_event: tstamp:4770865277 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4770859650 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871888: rtos_queue_peek_from_isr_failed: tstamp:4771241054 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 138.871889: rtcpu_vinotify_error: tstamp:4771383812 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4771381005 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871920: rtcpu_vinotify_event: tstamp:4771404528 tag:FE channel:0x00 frame:1 vi_tstamp:4771360149 data:0x00000020
kworker/3:1-1149 [003] .... 138.871922: rtcpu_vinotify_event: tstamp:4771404686 tag:FS channel:0x00 frame:1 vi_tstamp:4771380540 data:0x00000010
kworker/3:1-1149 [003] .... 138.871923: rtcpu_vinotify_event: tstamp:4771404823 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4771381005 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871924: rtcpu_vinotify_error: tstamp:4771905168 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4771902362 data:0x000003c9
kworker/3:1-1149 [003] .... 138.871925: rtcpu_vinotify_event: tstamp:4771947179 tag:FE channel:0x00 frame:1 vi_tstamp:4771881505 data:0x00000020
kworker/3:1-1149 [003] .... 138.871926: rtcpu_vinotify_event: tstamp:4771947318 tag:FS channel:0x00 frame:1 vi_tstamp:4771901896 data:0x00000010
kworker/3:1-1149 [003] .... 138.871928: rtcpu_vinotify_event: tstamp:4771947475 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4771902362 data:0x000003c9
kworker/3:1-1149 [003] .... 138.927896: rtcpu_vinotify_error: tstamp:4772426525 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4772423719 data:0x000003c9
kworker/3:1-1149 [003] .... 138.927898: rtcpu_vinotify_event: tstamp:4772489834 tag:FE channel:0x00 frame:1 vi_tstamp:4772402862 data:0x00000020
kworker/3:1-1149 [003] .... 138.927900: rtcpu_vinotify_event: tstamp:4772489991 tag:FS channel:0x00 frame:1 vi_tstamp:4772423252 data:0x00000010
kworker/3:1-1149 [003] .... 138.927901: rtcpu_vinotify_event: tstamp:4772490129 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4772423719 data:0x000003c9
kworker/3:1-1149 [003] .... 138.927902: rtcpu_vinotify_error: tstamp:4772947881 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4772945074 data:0x000003c9
kworker/3:1-1149 [003] .... 138.927903: rtcpu_vinotify_event: tstamp:4773032488 tag:FE channel:0x00 frame:1 vi_tstamp:4772924218 data:0x00000020
kworker/3:1-1149 [003] .... 138.927904: rtcpu_vinotify_event: tstamp:4773032624 tag:FS channel:0x00 frame:1 vi_tstamp:4772944608 data:0x00000010
kworker/3:1-1149 [003] .... 138.927905: rtcpu_vinotify_event: tstamp:4773032781 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4772945074 data:0x000003c9
kworker/3:1-1149 [003] .... 138.927907: rtcpu_vinotify_event: tstamp:4773447991 tag:FE channel:0x00 frame:1 vi_tstamp:4773445574 data:0x00000020
kworker/3:1-1149 [003] .... 138.927908: rtcpu_vinotify_error: tstamp:4773469235 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4773466431 data:0x000003c9
kworker/3:1-1149 [003] .... 138.983875: rtcpu_vinotify_event: tstamp:4773954630 tag:FS channel:0x00 frame:1 vi_tstamp:4773465965 data:0x00000010
kworker/3:1-1149 [003] .... 138.983879: rtcpu_vinotify_event: tstamp:4773954773 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4773466431 data:0x000003c9
kworker/3:1-1149 [003] .... 138.983881: rtcpu_vinotify_error: tstamp:4773990595 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4773987788 data:0x000003c9
kworker/3:1-1149 [003] .... 138.983882: rtcpu_vinotify_event: tstamp:4774497445 tag:FE channel:0x00 frame:1 vi_tstamp:4773966931 data:0x00000020
kworker/3:1-1149 [003] .... 138.983883: rtcpu_vinotify_event: tstamp:4774497581 tag:FS channel:0x00 frame:1 vi_tstamp:4773987322 data:0x00000010
kworker/3:1-1149 [003] .... 138.983885: rtcpu_vinotify_event: tstamp:4774497738 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4773987788 data:0x000003c9
kworker/3:1-1149 [003] .... 138.983892: rtcpu_vinotify_event: tstamp:4774497873 tag:FE channel:0x00 frame:1 vi_tstamp:4774488287 data:0x00000020
kworker/3:1-1149 [003] .... 138.983893: rtcpu_vinotify_error: tstamp:4774511936 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4774509143 data:0x000003c9
kworker/3:1-1149 [003] .... 138.983894: rtcpu_vinotify_error: tstamp:4775033306 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4775030500 data:0x000003c9
kworker/3:1-1149 [003] .... 138.983895: rtcpu_vinotify_event: tstamp:4775039530 tag:FS channel:0x00 frame:1 vi_tstamp:4774508678 data:0x00000010
kworker/3:1-1149 [003] .... 138.983896: rtcpu_vinotify_event: tstamp:4775039668 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4774509143 data:0x000003c9
kworker/3:1-1149 [003] .... 138.983898: rtcpu_vinotify_event: tstamp:4775039825 tag:FE channel:0x00 frame:1 vi_tstamp:4775009644 data:0x00000020
kworker/3:1-1149 [003] .... 138.983899: rtcpu_vinotify_event: tstamp:4775039961 tag:FS channel:0x00 frame:1 vi_tstamp:4775030034 data:0x00000010
kworker/3:1-1149 [003] .... 138.983925: rtcpu_vinotify_event: tstamp:4775040118 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4775030500 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039896: rtcpu_vinotify_error: tstamp:4775554689 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4775551856 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039899: rtcpu_vinotify_event: tstamp:4775582196 tag:FE channel:0x00 frame:1 vi_tstamp:4775531000 data:0x00000020
kworker/3:1-1149 [003] .... 139.039901: rtcpu_vinotify_event: tstamp:4775582353 tag:FS channel:0x00 frame:1 vi_tstamp:4775551390 data:0x00000010
kworker/3:1-1149 [003] .... 139.039902: rtcpu_vinotify_event: tstamp:4775582492 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4775551856 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039903: rtcpu_vinotify_event: tstamp:4776076353 tag:FE channel:0x00 frame:1 vi_tstamp:4776052356 data:0x00000020
kworker/3:1-1149 [003] .... 139.039905: rtcpu_vinotify_event: tstamp:4776076492 tag:FS channel:0x00 frame:1 vi_tstamp:4776072746 data:0x00000010
kworker/3:1-1149 [003] .... 139.039906: rtcpu_vinotify_error: tstamp:4776077554 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4776073213 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039940: rtos_queue_peek_from_isr_failed: tstamp:4776241051 queue:0x0bcbbbb8
kworker/3:1-1149 [003] .... 139.039941: rtcpu_vinotify_error: tstamp:4776597377 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4776594569 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039943: rtcpu_vinotify_event: tstamp:4776612788 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4776073213 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039944: rtcpu_vinotify_event: tstamp:4776612929 tag:FE channel:0x00 frame:1 vi_tstamp:4776573712 data:0x00000020
kworker/3:1-1149 [003] .... 139.039945: rtcpu_vinotify_event: tstamp:4776613087 tag:FS channel:0x00 frame:1 vi_tstamp:4776594104 data:0x00000010
kworker/3:1-1149 [003] .... 139.039946: rtcpu_vinotify_event: tstamp:4776613223 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4776594569 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039948: rtcpu_vinotify_error: tstamp:4777118725 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4777115925 data:0x000003c9
kworker/3:1-1149 [003] .... 139.039949: rtcpu_vinotify_event: tstamp:4777155448 tag:FE channel:0x00 frame:1 vi_tstamp:4777095069 data:0x00000020
kworker/3:1-1149 [003] .... 139.039950: rtcpu_vinotify_event: tstamp:4777155586 tag:FS channel:0x00 frame:1 vi_tstamp:4777115459 data:0x00000010
kworker/3:1-1149 [003] .... 139.039951: rtcpu_vinotify_event: tstamp:4777155744 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4777115925 data:0x000003c9
kworker/3:1-1149 [003] .... 139.095865: rtcpu_vinotify_error: tstamp:4777640087 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4777637282 data:0x000003c9
kworker/3:1-1149 [003] .... 139.095867: rtcpu_vinotify_event: tstamp:4777698105 tag:FE channel:0x00 frame:1 vi_tstamp:4777616425 data:0x00000020
kworker/3:1-1149 [003] .... 139.095869: rtcpu_vinotify_event: tstamp:4777698262 tag:FS channel:0x00 frame:1 vi_tstamp:4777636816 data:0x00000010
kworker/3:1-1149 [003] .... 139.095899: rtcpu_vinotify_event: tstamp:4777698398 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4777637282 data:0x000003c9
kworker/3:1-1149 [003] .... 139.095900: rtcpu_vinotify_error: tstamp:4778161443 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4778158638 data:0x000003c9
kworker/3:1-1149 [003] .... 139.095901: rtcpu_vinotify_event: tstamp:4778240753 tag:FE channel:0x00 frame:1 vi_tstamp:4778137781 data:0x00000020
kworker/3:1-1149 [003] .... 139.095902: rtcpu_vinotify_event: tstamp:4778240910 tag:FS channel:0x00 frame:1 vi_tstamp:4778158173 data:0x00000010
kworker/3:1-1149 [003] .... 139.095903: rtcpu_vinotify_event: tstamp:4778241067 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4778158638 data:0x000003c9
kworker/3:1-1149 [003] .... 139.095906: rtcpu_vinotify_error: tstamp:4778682935 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4778679994 data:0x000003c9
kworker/3:1-1149 [003] .... 139.095907: rtcpu_vinotify_event: tstamp:4778683318 tag:FE channel:0x00 frame:1 vi_tstamp:4778659138 data:0x00000020
kworker/3:1-1149 [003] .... 139.095908: rtcpu_vinotify_event: tstamp:4778683474 tag:FS channel:0x00 frame:1 vi_tstamp:4778679528 data:0x00000010
kworker/3:1-1149 [003] .... 139.095909: rtcpu_vinotify_event: tstamp:4778683611 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4778679994 data:0x000003c9
root@k-desktop:/home/k#
(Test2) : v4l2-ctl --device /dev/video0 --stream-mmap --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-to=frame.raw --stream-count=10 --verbose
k@k-desktop:~$ sudo su
[sudo] password for k:
root@k-desktop:/home/k# echo 1 > /sys/kernel/debug/tracing/tracing_on
root@k-desktop:/home/k# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
root@k-desktop:/home/k# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
root@k-desktop:/home/k# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
root@k-desktop:/home/k# echo 2 > /sys/kernel/debug/camrtc/log-level
root@k-desktop:/home/k# echo > /sys/kernel/debug/tracing/trace
root@k-desktop:/home/k# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 665/665 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/1:1-1212 [001] .... 198.026322: rtos_queue_peek_from_isr_failed: tstamp:6620140859 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 198.194316: rtos_queue_peek_from_isr_failed: tstamp:6625140860 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 198.250329: rtos_queue_peek_from_isr_failed: tstamp:6627556721 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 227.426258: rtos_queue_peek_from_isr_failed: tstamp:7539834041 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 227.426265: rtcpu_start: tstamp:7539835348
kworker/1:1-1212 [001] .... 227.426267: rtos_queue_send_from_isr_failed: tstamp:7539846322 queue:0x0bcb2e38
kworker/1:1-1212 [001] .... 227.426268: rtos_queue_send_from_isr_failed: tstamp:7539846475 queue:0x0bcb76a0
kworker/1:1-1212 [001] .... 227.426269: rtos_queue_send_from_isr_failed: tstamp:7539846624 queue:0x0bcb9220
kworker/1:1-1212 [001] .... 227.426270: rtos_queue_send_from_isr_failed: tstamp:7539846769 queue:0x0bcb9fe0
kworker/1:1-1212 [001] .... 227.426271: rtos_queue_send_from_isr_failed: tstamp:7539846916 queue:0x0bcbada0
kworker/1:1-1212 [001] .... 227.426272: rtcpu_string: tstamp:7539847344 id:0x04010000 str:"Configuring VI GoS.
kworker/1:1-1212 [001] .... 227.426300: rtcpu_string: tstamp:7539847542 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/1:1-1212 [001] .... 227.426331: rtcpu_string: tstamp:7539847796 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/1:1-1212 [001] .... 227.426340: rtcpu_string: tstamp:7539848039 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/1:1-1212 [001] .... 227.426348: rtcpu_string: tstamp:7539848271 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/1:1-1212 [001] .... 227.426356: rtcpu_string: tstamp:7539848520 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/1:1-1212 [001] .... 227.426364: rtcpu_string: tstamp:7539848751 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/1:1-1212 [001] .... 227.426373: rtcpu_string: tstamp:7539857192 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/1:1-1212 [001] .... 227.426391: rtcpu_string: tstamp:7539857310 id:0x04010000 str:"on 2.2
kworker/1:1-1212 [001] .... 227.426401: rtos_queue_send_from_isr_failed: tstamp:7539869697 queue:0x0bcb2e38
kworker/1:1-1212 [001] .... 227.426402: rtos_queue_send_from_isr_failed: tstamp:7539869866 queue:0x0bcb76a0
kworker/1:1-1212 [001] .... 227.426403: rtos_queue_send_from_isr_failed: tstamp:7539870020 queue:0x0bcb9220
kworker/1:1-1212 [001] .... 227.426403: rtos_queue_send_from_isr_failed: tstamp:7539870169 queue:0x0bcb9fe0
kworker/1:1-1212 [001] .... 227.426404: rtos_queue_send_from_isr_failed: tstamp:7539870313 queue:0x0bcbada0
kworker/1:1-1212 [001] .... 227.426405: rtcpu_string: tstamp:7539871239 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/1:1-1212 [001] .... 227.482258: rtos_queue_send_from_isr_failed: tstamp:7539958030 queue:0x0bcb2e38
kworker/1:1-1212 [001] .... 227.482263: rtos_queue_send_from_isr_failed: tstamp:7539958181 queue:0x0bcb76a0
kworker/1:1-1212 [001] .... 227.482265: rtos_queue_send_from_isr_failed: tstamp:7539958334 queue:0x0bcb9220
kworker/1:1-1212 [001] .... 227.482266: rtos_queue_send_from_isr_failed: tstamp:7539958482 queue:0x0bcb9fe0
kworker/1:1-1212 [001] .... 227.482267: rtos_queue_send_from_isr_failed: tstamp:7539958629 queue:0x0bcbada0
kworker/1:1-1212 [001] .... 227.482270: rtcpu_vinotify_error: tstamp:7539967106 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:7539964265 data:0x00000001
kworker/1:1-1212 [001] .... 227.482279: rtcpu_vinotify_event: tstamp:7540377236 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9347683360 data:0x10000000
kworker/1:1-1212 [001] .... 227.482281: rtcpu_vinotify_event: tstamp:7540377381 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9347691552 data:0x31000001
kworker/1:1-1212 [001] .... 227.482282: rtcpu_vinotify_event: tstamp:7540377542 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:9347693760 data:0x07020001
kworker/1:1-1212 [001] .... 227.482283: rtcpu_vinotify_event: tstamp:7540377678 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9347727072 data:0x10000000
kworker/1:1-1212 [001] .... 227.482285: rtcpu_vinotify_event: tstamp:7540377835 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9347735328 data:0x31000002
kworker/1:1-1212 [001] .... 227.482286: rtcpu_vinotify_event: tstamp:7540377979 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:7539964265 data:0x00000001
kworker/1:1-1212 [001] .... 227.482287: rtcpu_vinotify_event: tstamp:7540378137 tag:FS channel:0x00 frame:1 vi_tstamp:7540153342 data:0x00000010
kworker/1:1-1212 [001] .... 227.482288: rtcpu_vinotify_event: tstamp:7540378277 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:7540153345 data:0x00000000
kworker/1:1-1212 [001] .... 227.482290: rtcpu_vinotify_event: tstamp:7540378439 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:7540153808 data:0x00000001
kworker/1:1-1212 [001] .... 227.482291: rtcpu_vinotify_event: tstamp:7540378574 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:9356692096 data:0x08020001
kworker/1:1-1212 [001] .... 227.482292: rtcpu_vinotify_event: tstamp:7540678862 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:7540654243 data:0x04370002
kworker/1:1-1212 [001] .... 227.482293: rtcpu_vinotify_event: tstamp:7540679000 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:7540654272 data:0x00000000
kworker/1:1-1212 [001] .... 227.482294: rtcpu_vinotify_event: tstamp:7540679160 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:9372709632 data:0x02020001
kworker/1:1-1212 [001] .... 227.482296: rtcpu_vinotify_event: tstamp:7540679297 tag:FE channel:0x00 frame:1 vi_tstamp:7540654308 data:0x00000020
kworker/1:1-1212 [001] .... 227.482297: rtcpu_vinotify_event: tstamp:7540679453 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:7540654311 data:0x00000000
kworker/1:1-1212 [001] .... 227.482298: rtcpu_vinotify_event: tstamp:7540679588 tag:FS channel:0x00 frame:1 vi_tstamp:7540674699 data:0x00000010
kworker/1:1-1212 [001] .... 227.482299: rtcpu_vinotify_event: tstamp:7541191262 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:7540674702 data:0x00000000
kworker/1:1-1212 [001] .... 227.482301: rtcpu_vinotify_event: tstamp:7541191401 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:7540675164 data:0x00000001
kworker/1:1-1212 [001] .... 227.482302: rtcpu_vinotify_event: tstamp:7541191561 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:9373379328 data:0x08020001
kworker/1:1-1212 [001] .... 227.482303: rtcpu_vinotify_event: tstamp:7541191695 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:7541175600 data:0x04370002
kworker/1:1-1212 [001] .... 227.482304: rtcpu_vinotify_event: tstamp:7541191856 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:7541175627 data:0x00000000
kworker/1:1-1212 [001] .... 227.482306: rtcpu_vinotify_event: tstamp:7541191992 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:9389393088 data:0x02020001
kworker/1:1-1212 [001] .... 227.482307: rtcpu_vinotify_event: tstamp:7541192151 tag:FE channel:0x00 frame:1 vi_tstamp:7541175665 data:0x00000020
kworker/1:1-1212 [001] .... 227.482308: rtcpu_vinotify_event: tstamp:7541192288 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:7541175667 data:0x00000000
kworker/1:1-1212 [001] .... 227.482309: rtcpu_vinotify_error: tstamp:7541199317 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7541196521 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538291: rtcpu_vinotify_error: tstamp:7541720688 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7541717877 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538296: rtcpu_vinotify_event: tstamp:7541733446 tag:FS channel:0x00 frame:1 vi_tstamp:7541196056 data:0x00000010
kworker/1:1-1212 [001] .... 227.538298: rtcpu_vinotify_event: tstamp:7541733587 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7541196521 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538299: rtcpu_vinotify_event: tstamp:7541733748 tag:FE channel:0x00 frame:1 vi_tstamp:7541697021 data:0x00000020
kworker/1:1-1212 [001] .... 227.538300: rtcpu_vinotify_event: tstamp:7541733884 tag:FS channel:0x00 frame:1 vi_tstamp:7541717413 data:0x00000010
kworker/1:1-1212 [001] .... 227.538301: rtcpu_vinotify_event: tstamp:7541734042 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7541717877 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538303: rtcpu_vinotify_error: tstamp:7542242179 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7542239234 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538304: rtcpu_vinotify_event: tstamp:7542242563 tag:FE channel:0x00 frame:1 vi_tstamp:7542218378 data:0x00000020
kworker/1:1-1212 [001] .... 227.538305: rtcpu_vinotify_event: tstamp:7542242720 tag:FS channel:0x00 frame:1 vi_tstamp:7542238769 data:0x00000010
kworker/1:1-1212 [001] .... 227.538306: rtcpu_vinotify_event: tstamp:7542242856 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7542239234 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538307: rtcpu_vinotify_error: tstamp:7542763397 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7542760591 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538308: rtcpu_vinotify_event: tstamp:7542765964 tag:FE channel:0x00 frame:1 vi_tstamp:7542739735 data:0x00000020
kworker/1:1-1212 [001] .... 227.538310: rtcpu_vinotify_event: tstamp:7542766104 tag:FS channel:0x00 frame:1 vi_tstamp:7542760125 data:0x00000010
kworker/1:1-1212 [001] .... 227.538311: rtcpu_vinotify_event: tstamp:7542766275 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7542760591 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538312: rtcpu_vinotify_error: tstamp:7543284750 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7543281947 data:0x000003c9
kworker/1:1-1212 [001] .... 227.538313: rtcpu_vinotify_event: tstamp:7543307001 tag:FE channel:0x00 frame:1 vi_tstamp:7543261091 data:0x00000020
kworker/1:1-1212 [001] .... 227.538314: rtcpu_vinotify_event: tstamp:7543307157 tag:FS channel:0x00 frame:1 vi_tstamp:7543281483 data:0x00000010
kworker/1:1-1212 [001] .... 227.538316: rtcpu_vinotify_event: tstamp:7543307293 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7543281947 data:0x000003c9
kworker/1:1-1212 [001] .... 227.594287: rtcpu_vinotify_error: tstamp:7543806105 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7543803304 data:0x000003c9
kworker/1:1-1212 [001] .... 227.594291: rtcpu_vinotify_event: tstamp:7543849652 tag:FE channel:0x00 frame:1 vi_tstamp:7543782448 data:0x00000020
kworker/1:1-1212 [001] .... 227.594293: rtcpu_vinotify_event: tstamp:7543849787 tag:FS channel:0x00 frame:1 vi_tstamp:7543802839 data:0x00000010
kworker/1:1-1212 [001] .... 227.594294: rtcpu_vinotify_event: tstamp:7543849945 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7543803304 data:0x000003c9
kworker/1:1-1212 [001] .... 227.594296: rtcpu_vinotify_error: tstamp:7544327507 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7544324661 data:0x000003c9
kworker/1:1-1212 [001] .... 227.594297: rtcpu_vinotify_event: tstamp:7544392305 tag:FE channel:0x00 frame:1 vi_tstamp:7544303804 data:0x00000020
kworker/1:1-1212 [001] .... 227.594298: rtcpu_vinotify_event: tstamp:7544392459 tag:FS channel:0x00 frame:1 vi_tstamp:7544324196 data:0x00000010
kworker/1:1-1212 [001] .... 227.594299: rtcpu_vinotify_event: tstamp:7544392595 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7544324661 data:0x000003c9
kworker/1:1-1212 [001] .... 227.594302: rtos_queue_peek_from_isr_failed: tstamp:7544834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 227.594304: rtcpu_vinotify_error: tstamp:7544848812 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7544846017 data:0x000003c9
kworker/1:1-1212 [001] .... 227.594305: rtcpu_vinotify_event: tstamp:7544934959 tag:FE channel:0x00 frame:1 vi_tstamp:7544825161 data:0x00000020
kworker/1:1-1212 [001] .... 227.594306: rtcpu_vinotify_event: tstamp:7544935099 tag:FS channel:0x00 frame:1 vi_tstamp:7544845552 data:0x00000010
kworker/1:1-1212 [001] .... 227.594307: rtcpu_vinotify_event: tstamp:7544935256 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7544846017 data:0x000003c9
kworker/1:1-1212 [001] .... 227.650293: rtcpu_vinotify_event: tstamp:7545348939 tag:FE channel:0x00 frame:1 vi_tstamp:7545346518 data:0x00000020
kworker/1:1-1212 [001] .... 227.650297: rtcpu_vinotify_error: tstamp:7545370181 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7545367374 data:0x000003c9
kworker/1:1-1212 [001] .... 227.650298: rtcpu_vinotify_event: tstamp:7545857101 tag:FS channel:0x00 frame:1 vi_tstamp:7545366909 data:0x00000010
kworker/1:1-1212 [001] .... 227.650300: rtcpu_vinotify_event: tstamp:7545857237 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7545367374 data:0x000003c9
kworker/1:1-1212 [001] .... 227.650301: rtcpu_vinotify_error: tstamp:7545891592 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7545888731 data:0x000003c9
kworker/1:1-1212 [001] .... 227.650303: rtcpu_vinotify_event: tstamp:7546399861 tag:FE channel:0x00 frame:1 vi_tstamp:7545867874 data:0x00000020
kworker/1:1-1212 [001] .... 227.650305: rtcpu_vinotify_event: tstamp:7546399999 tag:FS channel:0x00 frame:1 vi_tstamp:7545888266 data:0x00000010
kworker/1:1-1212 [001] .... 227.650306: rtcpu_vinotify_event: tstamp:7546400159 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7545888731 data:0x000003c9
kworker/1:1-1212 [001] .... 227.650307: rtcpu_vinotify_event: tstamp:7546400294 tag:FE channel:0x00 frame:1 vi_tstamp:7546389231 data:0x00000020
kworker/1:1-1212 [001] .... 227.650309: rtcpu_vinotify_error: tstamp:7546412878 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7546410088 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706261: rtcpu_vinotify_error: tstamp:7546934247 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7546931444 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706264: rtcpu_vinotify_event: tstamp:7546942009 tag:FS channel:0x00 frame:1 vi_tstamp:7546409622 data:0x00000010
kworker/1:1-1212 [001] .... 227.706294: rtcpu_vinotify_event: tstamp:7546942148 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7546410088 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706295: rtcpu_vinotify_event: tstamp:7546942306 tag:FE channel:0x00 frame:1 vi_tstamp:7546910587 data:0x00000020
kworker/1:1-1212 [001] .... 227.706296: rtcpu_vinotify_event: tstamp:7546942442 tag:FS channel:0x00 frame:1 vi_tstamp:7546930978 data:0x00000010
kworker/1:1-1212 [001] .... 227.706298: rtcpu_vinotify_event: tstamp:7546942599 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7546931444 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706299: rtcpu_vinotify_error: tstamp:7547455602 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7547452801 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706300: rtcpu_vinotify_event: tstamp:7547484715 tag:FE channel:0x00 frame:1 vi_tstamp:7547431945 data:0x00000020
kworker/1:1-1212 [001] .... 227.706302: rtcpu_vinotify_event: tstamp:7547484872 tag:FS channel:0x00 frame:1 vi_tstamp:7547452335 data:0x00000010
kworker/1:1-1212 [001] .... 227.706303: rtcpu_vinotify_event: tstamp:7547485025 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7547452801 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706304: rtcpu_vinotify_event: tstamp:7547977294 tag:FE channel:0x00 frame:1 vi_tstamp:7547953301 data:0x00000020
kworker/1:1-1212 [001] .... 227.706305: rtcpu_vinotify_event: tstamp:7547977433 tag:FS channel:0x00 frame:1 vi_tstamp:7547973691 data:0x00000010
kworker/1:1-1212 [001] .... 227.706307: rtcpu_vinotify_error: tstamp:7547978496 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7547974158 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706308: rtcpu_vinotify_error: tstamp:7548498321 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7548495514 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706339: rtcpu_vinotify_event: tstamp:7548515312 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7547974158 data:0x000003c9
kworker/1:1-1212 [001] .... 227.706342: rtcpu_vinotify_event: tstamp:7548515449 tag:FE channel:0x00 frame:1 vi_tstamp:7548474657 data:0x00000020
kworker/1:1-1212 [001] .... 227.706344: rtcpu_vinotify_event: tstamp:7548515606 tag:FS channel:0x00 frame:1 vi_tstamp:7548495048 data:0x00000010
kworker/1:1-1212 [001] .... 227.706345: rtcpu_vinotify_event: tstamp:7548515741 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7548495514 data:0x000003c9
kworker/1:1-1212 [001] .... 227.762277: rtcpu_vinotify_error: tstamp:7549019675 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7549016871 data:0x000003c9
kworker/1:1-1212 [001] .... 227.762280: rtcpu_vinotify_event: tstamp:7549057918 tag:FE channel:0x00 frame:1 vi_tstamp:7548996015 data:0x00000020
kworker/1:1-1212 [001] .... 227.762282: rtcpu_vinotify_event: tstamp:7549058058 tag:FS channel:0x00 frame:1 vi_tstamp:7549016404 data:0x00000010
kworker/1:1-1212 [001] .... 227.762283: rtcpu_vinotify_event: tstamp:7549058216 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7549016871 data:0x000003c9
kworker/1:1-1212 [001] .... 227.762284: rtcpu_vinotify_error: tstamp:7549541029 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7549538227 data:0x000003c9
kworker/1:1-1212 [001] .... 227.762286: rtcpu_vinotify_event: tstamp:7549600571 tag:FE channel:0x00 frame:1 vi_tstamp:7549517371 data:0x00000020
kworker/1:1-1212 [001] .... 227.762287: rtcpu_vinotify_event: tstamp:7549600727 tag:FS channel:0x00 frame:1 vi_tstamp:7549537762 data:0x00000010
kworker/1:1-1212 [001] .... 227.762288: rtcpu_vinotify_event: tstamp:7549600863 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7549538227 data:0x000003c9
kworker/1:1-1212 [001] .... 227.762290: rtos_queue_peek_from_isr_failed: tstamp:7549834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 227.762292: rtcpu_vinotify_error: tstamp:7550062389 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7550059584 data:0x000003c9
kworker/1:1-1212 [001] .... 227.762293: rtcpu_vinotify_event: tstamp:7550143227 tag:FE channel:0x00 frame:1 vi_tstamp:7550038728 data:0x00000020
kworker/1:1-1212 [001] .... 227.762295: rtcpu_vinotify_event: tstamp:7550143368 tag:FS channel:0x00 frame:1 vi_tstamp:7550059118 data:0x00000010
kworker/1:1-1212 [001] .... 227.762296: rtcpu_vinotify_event: tstamp:7550143526 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7550059584 data:0x000003c9
kworker/1:1-1212 [001] .... 227.818253: rtcpu_vinotify_error: tstamp:7550583884 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7550580941 data:0x000003c9
kworker/1:1-1212 [001] .... 227.818255: rtcpu_vinotify_event: tstamp:7550584272 tag:FE channel:0x00 frame:1 vi_tstamp:7550560085 data:0x00000020
kworker/1:1-1212 [001] .... 227.818256: rtcpu_vinotify_event: tstamp:7550584430 tag:FS channel:0x00 frame:1 vi_tstamp:7550580476 data:0x00000010
kworker/1:1-1212 [001] .... 227.818258: rtcpu_vinotify_event: tstamp:7550584568 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7550580941 data:0x000003c9
kworker/1:1-1212 [001] .... 227.818259: rtcpu_vinotify_error: tstamp:7551105099 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7551102297 data:0x000003c9
kworker/1:1-1212 [001] .... 227.818260: rtcpu_vinotify_event: tstamp:7551119907 tag:FE channel:0x00 frame:1 vi_tstamp:7551081441 data:0x00000020
kworker/1:1-1212 [001] .... 227.818262: rtcpu_vinotify_event: tstamp:7551120046 tag:FS channel:0x00 frame:1 vi_tstamp:7551101832 data:0x00000010
kworker/1:1-1212 [001] .... 227.818263: rtcpu_vinotify_event: tstamp:7551120203 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7551102297 data:0x000003c9
kworker/1:1-1212 [001] .... 227.818264: rtcpu_vinotify_error: tstamp:7551626462 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7551623654 data:0x000003c9
kworker/1:1-1212 [001] .... 227.818265: rtcpu_vinotify_event: tstamp:7551662563 tag:FE channel:0x00 frame:1 vi_tstamp:7551602798 data:0x00000020
kworker/1:1-1212 [001] .... 227.818267: rtcpu_vinotify_event: tstamp:7551662717 tag:FS channel:0x00 frame:1 vi_tstamp:7551623188 data:0x00000010
kworker/1:1-1212 [001] .... 227.818268: rtcpu_vinotify_event: tstamp:7551662853 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7551623654 data:0x000003c9
kworker/1:1-1212 [001] .... 227.818269: rtcpu_vinotify_error: tstamp:7552147813 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7552145010 data:0x000003c9
kworker/1:1-1212 [001] .... 227.874265: rtcpu_vinotify_event: tstamp:7552204439 tag:FE channel:0x00 frame:1 vi_tstamp:7552124154 data:0x00000020
kworker/1:1-1212 [001] .... 227.874268: rtcpu_vinotify_event: tstamp:7552204579 tag:FS channel:0x00 frame:1 vi_tstamp:7552144545 data:0x00000010
kworker/1:1-1212 [001] .... 227.874270: rtcpu_vinotify_event: tstamp:7552204736 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7552145010 data:0x000003c9
kworker/1:1-1212 [001] .... 227.874271: rtcpu_vinotify_error: tstamp:7552669173 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7552666367 data:0x000003c9
kworker/1:1-1212 [001] .... 227.874273: rtcpu_vinotify_event: tstamp:7552747095 tag:FE channel:0x00 frame:1 vi_tstamp:7552645511 data:0x00000020
kworker/1:1-1212 [001] .... 227.874274: rtcpu_vinotify_event: tstamp:7552747250 tag:FS channel:0x00 frame:1 vi_tstamp:7552665902 data:0x00000010
kworker/1:1-1212 [001] .... 227.874275: rtcpu_vinotify_event: tstamp:7552747388 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7552666367 data:0x000003c9
kworker/1:1-1212 [001] .... 227.874277: rtcpu_vinotify_error: tstamp:7553190527 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7553187724 data:0x000003c9
kworker/1:1-1212 [001] .... 227.874308: rtcpu_vinotify_event: tstamp:7553289752 tag:FE channel:0x00 frame:1 vi_tstamp:7553166868 data:0x00000020
kworker/1:1-1212 [001] .... 227.874310: rtcpu_vinotify_event: tstamp:7553289889 tag:FS channel:0x00 frame:1 vi_tstamp:7553187258 data:0x00000010
kworker/1:1-1212 [001] .... 227.874311: rtcpu_vinotify_event: tstamp:7553290046 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7553187724 data:0x000003c9
kworker/1:1-1212 [001] .... 227.874312: rtcpu_vinotify_event: tstamp:7553690642 tag:FE channel:0x00 frame:1 vi_tstamp:7553688224 data:0x00000020
kworker/1:1-1212 [001] .... 227.874314: rtcpu_vinotify_error: tstamp:7553711883 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7553709081 data:0x000003c9
kworker/1:1-1212 [001] .... 227.930326: rtcpu_vinotify_event: tstamp:7554212007 tag:FS channel:0x00 frame:1 vi_tstamp:7553708615 data:0x00000010
kworker/1:1-1212 [001] .... 227.930329: rtcpu_vinotify_event: tstamp:7554212148 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7553709081 data:0x000003c9
kworker/1:1-1212 [001] .... 227.930330: rtcpu_vinotify_event: tstamp:7554212305 tag:FE channel:0x00 frame:1 vi_tstamp:7554209581 data:0x00000020
kworker/1:1-1212 [001] .... 227.930332: rtcpu_vinotify_error: tstamp:7554233237 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7554230437 data:0x000003c9
kworker/1:1-1212 [001] .... 227.930334: rtcpu_vinotify_error: tstamp:7554754600 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7554751793 data:0x000003c9
kworker/1:1-1212 [001] .... 227.930335: rtcpu_vinotify_event: tstamp:7554757271 tag:FS channel:0x00 frame:1 vi_tstamp:7554229971 data:0x00000010
kworker/1:1-1212 [001] .... 227.930336: rtcpu_vinotify_event: tstamp:7554757428 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7554230437 data:0x000003c9
kworker/1:1-1212 [001] .... 227.930338: rtcpu_vinotify_event: tstamp:7554757564 tag:FE channel:0x00 frame:1 vi_tstamp:7554730937 data:0x00000020
kworker/1:1-1212 [001] .... 227.930339: rtcpu_vinotify_event: tstamp:7554757718 tag:FS channel:0x00 frame:1 vi_tstamp:7554751328 data:0x00000010
kworker/1:1-1212 [001] .... 227.930340: rtcpu_vinotify_event: tstamp:7554757853 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7554751793 data:0x000003c9
kworker/1:1-1212 [001] .... 227.930342: rtos_queue_peek_from_isr_failed: tstamp:7554834394 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 227.930344: rtcpu_vinotify_error: tstamp:7555275960 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7555273150 data:0x000003c9
kworker/1:1-1212 [001] .... 227.930345: rtcpu_vinotify_event: tstamp:7555297586 tag:FE channel:0x00 frame:1 vi_tstamp:7555252294 data:0x00000020
kworker/1:1-1212 [001] .... 227.930346: rtcpu_vinotify_event: tstamp:7555297724 tag:FS channel:0x00 frame:1 vi_tstamp:7555272685 data:0x00000010
kworker/1:1-1212 [001] .... 227.930347: rtcpu_vinotify_event: tstamp:7555297883 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7555273150 data:0x000003c9
kworker/1:1-1212 [001] .... 227.986320: rtcpu_vinotify_error: tstamp:7555797371 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7555794507 data:0x000003c9
kworker/1:1-1212 [001] .... 227.986323: rtcpu_vinotify_event: tstamp:7555839461 tag:FE channel:0x00 frame:1 vi_tstamp:7555773651 data:0x00000020
kworker/1:1-1212 [001] .... 227.986324: rtcpu_vinotify_event: tstamp:7555839619 tag:FS channel:0x00 frame:1 vi_tstamp:7555794041 data:0x00000010
kworker/1:1-1212 [001] .... 227.986326: rtcpu_vinotify_event: tstamp:7555839758 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7555794507 data:0x000003c9
kworker/1:1-1212 [001] .... 227.986327: rtcpu_vinotify_event: tstamp:7556319002 tag:FE channel:0x00 frame:1 vi_tstamp:7556295007 data:0x00000020
kworker/1:1-1212 [001] .... 227.986328: rtcpu_vinotify_event: tstamp:7556319140 tag:FS channel:0x00 frame:1 vi_tstamp:7556315398 data:0x00000010
kworker/1:1-1212 [001] .... 227.986330: rtcpu_vinotify_error: tstamp:7556320204 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7556315864 data:0x000003c9
kworker/1:1-1212 [001] .... 227.986331: rtcpu_vinotify_event: tstamp:7556816196 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7556315864 data:0x000003c9
kworker/1:1-1212 [001] .... 227.986332: rtcpu_vinotify_error: tstamp:7556840024 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7556837221 data:0x000003c9
kworker/1:1-1212 [001] .... 227.986333: rtcpu_vinotify_event: tstamp:7557359010 tag:FE channel:0x00 frame:1 vi_tstamp:7556816365 data:0x00000020
kworker/1:1-1212 [001] .... 227.986335: rtcpu_vinotify_event: tstamp:7557360659 tag:FS channel:0x00 frame:1 vi_tstamp:7556836754 data:0x00000010
kworker/1:1-1212 [001] .... 227.986336: rtcpu_vinotify_event: tstamp:7557360799 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7556837221 data:0x000003c9
kworker/1:1-1212 [001] .... 227.986363: rtcpu_vinotify_event: tstamp:7557360955 tag:FE channel:0x00 frame:1 vi_tstamp:7557337721 data:0x00000020
kworker/1:1-1212 [001] .... 227.986365: rtcpu_vinotify_error: tstamp:7557362014 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7557358577 data:0x000003c9
kworker/1:1-1212 [001] .... 228.042291: rtcpu_vinotify_error: tstamp:7557882739 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7557879934 data:0x000003c9
kworker/1:1-1212 [001] .... 228.042296: rtcpu_vinotify_event: tstamp:7557901061 tag:FS channel:0x00 frame:1 vi_tstamp:7557358111 data:0x00000010
kworker/1:1-1212 [001] .... 228.042299: rtcpu_vinotify_event: tstamp:7557901218 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7557358577 data:0x000003c9
kworker/1:1-1212 [001] .... 228.042300: rtcpu_vinotify_event: tstamp:7557901353 tag:FE channel:0x00 frame:1 vi_tstamp:7557859078 data:0x00000020
kworker/1:1-1212 [001] .... 228.042302: rtcpu_vinotify_event: tstamp:7557901506 tag:FS channel:0x00 frame:1 vi_tstamp:7557879468 data:0x00000010
kworker/1:1-1212 [001] .... 228.042303: rtcpu_vinotify_event: tstamp:7557901641 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7557879934 data:0x000003c9
kworker/1:1-1212 [001] .... 228.042304: rtcpu_vinotify_error: tstamp:7558404098 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7558401291 data:0x000003c9
kworker/1:1-1212 [001] .... 228.042306: rtcpu_vinotify_event: tstamp:7558443718 tag:FE channel:0x00 frame:1 vi_tstamp:7558380434 data:0x00000020
kworker/1:1-1212 [001] .... 228.042307: rtcpu_vinotify_event: tstamp:7558443853 tag:FS channel:0x00 frame:1 vi_tstamp:7558400825 data:0x00000010
kworker/1:1-1212 [001] .... 228.042308: rtcpu_vinotify_event: tstamp:7558444010 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7558401291 data:0x000003c9
kworker/1:1-1212 [001] .... 228.042310: rtcpu_vinotify_error: tstamp:7558925595 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7558922647 data:0x000003c9
kworker/1:1-1212 [001] .... 228.042311: rtcpu_vinotify_event: tstamp:7558925977 tag:FE channel:0x00 frame:1 vi_tstamp:7558901791 data:0x00000020
kworker/1:1-1212 [001] .... 228.042312: rtcpu_vinotify_event: tstamp:7558926133 tag:FS channel:0x00 frame:1 vi_tstamp:7558922181 data:0x00000010
kworker/1:1-1212 [001] .... 228.042313: rtcpu_vinotify_event: tstamp:7558926269 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7558922647 data:0x000003c9
kworker/1:1-1212 [001] .... 228.098293: rtcpu_vinotify_error: tstamp:7559446807 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7559444004 data:0x000003c9
kworker/1:1-1212 [001] .... 228.098296: rtcpu_vinotify_event: tstamp:7559474697 tag:FE channel:0x00 frame:1 vi_tstamp:7559423148 data:0x00000020
kworker/1:1-1212 [001] .... 228.098298: rtcpu_vinotify_event: tstamp:7559474835 tag:FS channel:0x00 frame:1 vi_tstamp:7559443537 data:0x00000010
kworker/1:1-1212 [001] .... 228.098299: rtcpu_vinotify_event: tstamp:7559474994 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7559444004 data:0x000003c9
kworker/1:1-1212 [001] .... 228.098302: rtos_queue_peek_from_isr_failed: tstamp:7559834396 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 228.098304: rtcpu_vinotify_error: tstamp:7559968170 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7559965360 data:0x000003c9
kworker/1:1-1212 [001] .... 228.098305: rtcpu_vinotify_event: tstamp:7560017345 tag:FE channel:0x00 frame:1 vi_tstamp:7559944504 data:0x00000020
kworker/1:1-1212 [001] .... 228.098306: rtcpu_vinotify_event: tstamp:7560017502 tag:FS channel:0x00 frame:1 vi_tstamp:7559964895 data:0x00000010
kworker/1:1-1212 [001] .... 228.098307: rtcpu_vinotify_event: tstamp:7560017639 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7559965360 data:0x000003c9
kworker/1:1-1212 [001] .... 228.098309: rtcpu_vinotify_error: tstamp:7560489522 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7560486717 data:0x000003c9
kworker/1:1-1212 [001] .... 228.098310: rtcpu_vinotify_event: tstamp:7560559994 tag:FE channel:0x00 frame:1 vi_tstamp:7560465861 data:0x00000020
kworker/1:1-1212 [001] .... 228.098311: rtcpu_vinotify_event: tstamp:7560560130 tag:FS channel:0x00 frame:1 vi_tstamp:7560486251 data:0x00000010
kworker/1:1-1212 [001] .... 228.098312: rtcpu_vinotify_event: tstamp:7560560290 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7560486717 data:0x000003c9
kworker/1:1-1212 [001] .... 228.154291: rtcpu_vinotify_error: tstamp:7561010880 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7561008074 data:0x000003c9
kworker/1:1-1212 [001] .... 228.154295: rtcpu_vinotify_event: tstamp:7561102655 tag:FE channel:0x00 frame:1 vi_tstamp:7560987217 data:0x00000020
kworker/1:1-1212 [001] .... 228.154296: rtcpu_vinotify_event: tstamp:7561102812 tag:FS channel:0x00 frame:1 vi_tstamp:7561007608 data:0x00000010
kworker/1:1-1212 [001] .... 228.154323: rtcpu_vinotify_event: tstamp:7561102948 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7561008074 data:0x000003c9
kworker/1:1-1212 [001] .... 228.154325: rtcpu_vinotify_error: tstamp:7561532231 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7561529430 data:0x000003c9
kworker/1:1-1212 [001] .... 228.154326: rtcpu_vinotify_event: tstamp:7561645308 tag:FE channel:0x00 frame:1 vi_tstamp:7561508574 data:0x00000020
kworker/1:1-1212 [001] .... 228.154328: rtcpu_vinotify_event: tstamp:7561645444 tag:FS channel:0x00 frame:1 vi_tstamp:7561528965 data:0x00000010
kworker/1:1-1212 [001] .... 228.154329: rtcpu_vinotify_event: tstamp:7561645600 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7561529430 data:0x000003c9
kworker/1:1-1212 [001] .... 228.154330: rtcpu_vinotify_event: tstamp:7562032349 tag:FE channel:0x00 frame:1 vi_tstamp:7562029931 data:0x00000020
kworker/1:1-1212 [001] .... 228.154332: rtcpu_vinotify_error: tstamp:7562053591 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7562050787 data:0x000003c9
kworker/1:1-1212 [001] .... 228.154333: rtcpu_vinotify_event: tstamp:7562567556 tag:FS channel:0x00 frame:1 vi_tstamp:7562050321 data:0x00000010
kworker/1:1-1212 [001] .... 228.154334: rtcpu_vinotify_event: tstamp:7562567694 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7562050787 data:0x000003c9
kworker/1:1-1212 [001] .... 228.154335: rtcpu_vinotify_event: tstamp:7562567848 tag:FE channel:0x00 frame:1 vi_tstamp:7562551287 data:0x00000020
kworker/1:1-1212 [001] .... 228.154337: rtcpu_vinotify_error: tstamp:7562574938 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7562572143 data:0x000003c9
kworker/1:1-1212 [001] .... 228.210297: rtcpu_vinotify_error: tstamp:7563096306 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7563093500 data:0x000003c9
kworker/1:1-1212 [001] .... 228.210301: rtcpu_vinotify_event: tstamp:7563109759 tag:FS channel:0x00 frame:1 vi_tstamp:7562571678 data:0x00000010
kworker/1:1-1212 [001] .... 228.210302: rtcpu_vinotify_event: tstamp:7563109919 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7562572143 data:0x000003c9
kworker/1:1-1212 [001] .... 228.210303: rtcpu_vinotify_event: tstamp:7563110058 tag:FE channel:0x00 frame:1 vi_tstamp:7563072644 data:0x00000020
kworker/1:1-1212 [001] .... 228.210305: rtcpu_vinotify_event: tstamp:7563110213 tag:FS channel:0x00 frame:1 vi_tstamp:7563093035 data:0x00000010
kworker/1:1-1212 [001] .... 228.210306: rtcpu_vinotify_event: tstamp:7563110348 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7563093500 data:0x000003c9
kworker/1:1-1212 [001] .... 228.210307: rtcpu_vinotify_error: tstamp:7563617664 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7563614857 data:0x000003c9
kworker/1:1-1212 [001] .... 228.210309: rtcpu_vinotify_event: tstamp:7563652363 tag:FE channel:0x00 frame:1 vi_tstamp:7563594001 data:0x00000020
kworker/1:1-1212 [001] .... 228.210310: rtcpu_vinotify_event: tstamp:7563652499 tag:FS channel:0x00 frame:1 vi_tstamp:7563614391 data:0x00000010
kworker/1:1-1212 [001] .... 228.210311: rtcpu_vinotify_event: tstamp:7563652656 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7563614857 data:0x000003c9
kworker/1:1-1212 [001] .... 228.210313: rtcpu_vinotify_error: tstamp:7564139015 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7564136213 data:0x000003c9
kworker/1:1-1212 [001] .... 228.210314: rtcpu_vinotify_event: tstamp:7564195019 tag:FE channel:0x00 frame:1 vi_tstamp:7564115357 data:0x00000020
kworker/1:1-1212 [001] .... 228.210315: rtcpu_vinotify_event: tstamp:7564195174 tag:FS channel:0x00 frame:1 vi_tstamp:7564135748 data:0x00000010
kworker/1:1-1212 [001] .... 228.210316: rtcpu_vinotify_event: tstamp:7564195312 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7564136213 data:0x000003c9
kworker/1:1-1212 [001] .... 228.266284: rtcpu_vinotify_event: tstamp:7564660711 tag:FE channel:0x00 frame:1 vi_tstamp:7564636714 data:0x00000020
kworker/1:1-1212 [001] .... 228.266288: rtcpu_vinotify_event: tstamp:7564660851 tag:FS channel:0x00 frame:1 vi_tstamp:7564657104 data:0x00000010
kworker/1:1-1212 [001] .... 228.266290: rtcpu_vinotify_error: tstamp:7564661913 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7564657570 data:0x000003c9
kworker/1:1-1212 [001] .... 228.266292: rtos_queue_peek_from_isr_failed: tstamp:7564834392 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 228.266294: rtcpu_vinotify_event: tstamp:7565171126 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7564657570 data:0x000003c9
kworker/1:1-1212 [001] .... 228.266295: rtcpu_vinotify_event: tstamp:7565171266 tag:FE channel:0x00 frame:1 vi_tstamp:7565158071 data:0x00000020
kworker/1:1-1212 [001] .... 228.266297: rtcpu_vinotify_error: tstamp:7565181721 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7565178927 data:0x000003c9
kworker/1:1-1212 [001] .... 228.266298: rtcpu_vinotify_error: tstamp:7565703128 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7565700284 data:0x000003c9
kworker/1:1-1212 [001] .... 228.266299: rtcpu_vinotify_event: tstamp:7565714002 tag:FS channel:0x00 frame:1 vi_tstamp:7565178461 data:0x00000010
kworker/1:1-1212 [001] .... 228.266301: rtcpu_vinotify_event: tstamp:7565714140 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7565178927 data:0x000003c9
kworker/1:1-1212 [001] .... 228.266302: rtcpu_vinotify_event: tstamp:7565714299 tag:FE channel:0x00 frame:1 vi_tstamp:7565679428 data:0x00000020
kworker/1:1-1212 [001] .... 228.266303: rtcpu_vinotify_event: tstamp:7565714433 tag:FS channel:0x00 frame:1 vi_tstamp:7565699818 data:0x00000010
kworker/1:1-1212 [001] .... 228.266304: rtcpu_vinotify_event: tstamp:7565714590 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7565700284 data:0x000003c9
kworker/1:1-1212 [001] .... 228.322254: rtcpu_vinotify_error: tstamp:7566224446 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7566221640 data:0x000003c9
kworker/1:1-1212 [001] .... 228.322257: rtcpu_vinotify_event: tstamp:7566256664 tag:FE channel:0x00 frame:1 vi_tstamp:7566200784 data:0x00000020
kworker/1:1-1212 [001] .... 228.322258: rtcpu_vinotify_event: tstamp:7566256821 tag:FS channel:0x00 frame:1 vi_tstamp:7566221174 data:0x00000010
kworker/1:1-1212 [001] .... 228.322259: rtcpu_vinotify_event: tstamp:7566256959 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7566221640 data:0x000003c9
kworker/1:1-1212 [001] .... 228.322261: rtcpu_vinotify_error: tstamp:7566745805 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7566742997 data:0x000003c9
kworker/1:1-1212 [001] .... 228.322262: rtcpu_vinotify_event: tstamp:7566799313 tag:FE channel:0x00 frame:1 vi_tstamp:7566722141 data:0x00000020
kworker/1:1-1212 [001] .... 228.322264: rtcpu_vinotify_event: tstamp:7566799450 tag:FS channel:0x00 frame:1 vi_tstamp:7566742531 data:0x00000010
kworker/1:1-1212 [001] .... 228.322265: rtcpu_vinotify_event: tstamp:7566799608 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7566742997 data:0x000003c9
kworker/1:1-1212 [001] .... 228.322266: rtcpu_vinotify_error: tstamp:7567267297 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7567264354 data:0x000003c9
kworker/1:1-1212 [001] .... 228.322267: rtcpu_vinotify_event: tstamp:7567267678 tag:FE channel:0x00 frame:1 vi_tstamp:7567243497 data:0x00000020
kworker/1:1-1212 [001] .... 228.322269: rtcpu_vinotify_event: tstamp:7567267835 tag:FS channel:0x00 frame:1 vi_tstamp:7567263887 data:0x00000010
kworker/1:1-1212 [001] .... 228.322270: rtcpu_vinotify_event: tstamp:7567267971 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7567264354 data:0x000003c9
kworker/1:1-1212 [001] .... 228.322271: rtcpu_vinotify_event: tstamp:7567775724 tag:FE channel:0x00 frame:1 vi_tstamp:7567764854 data:0x00000020
kworker/1:1-1212 [001] .... 228.322273: rtcpu_vinotify_error: tstamp:7567788504 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7567785710 data:0x000003c9
kworker/1:1-1212 [001] .... 228.378263: rtcpu_vinotify_error: tstamp:7568309872 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7568307067 data:0x000003c9
kworker/1:1-1212 [001] .... 228.378266: rtcpu_vinotify_event: tstamp:7568317866 tag:FS channel:0x00 frame:1 vi_tstamp:7567785245 data:0x00000010
kworker/1:1-1212 [001] .... 228.378268: rtcpu_vinotify_event: tstamp:7568318027 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7567785710 data:0x000003c9
kworker/1:1-1212 [001] .... 228.378269: rtcpu_vinotify_event: tstamp:7568318163 tag:FE channel:0x00 frame:1 vi_tstamp:7568286211 data:0x00000020
kworker/1:1-1212 [001] .... 228.378271: rtcpu_vinotify_event: tstamp:7568318320 tag:FS channel:0x00 frame:1 vi_tstamp:7568306601 data:0x00000010
kworker/1:1-1212 [001] .... 228.378272: rtcpu_vinotify_event: tstamp:7568318455 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7568307067 data:0x000003c9
kworker/1:1-1212 [001] .... 228.378273: rtcpu_vinotify_error: tstamp:7568831257 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7568828424 data:0x000003c9
kworker/1:1-1212 [001] .... 228.378275: rtcpu_vinotify_event: tstamp:7568860527 tag:FE channel:0x00 frame:1 vi_tstamp:7568807567 data:0x00000020
kworker/1:1-1212 [001] .... 228.378276: rtcpu_vinotify_event: tstamp:7568860662 tag:FS channel:0x00 frame:1 vi_tstamp:7568827958 data:0x00000010
kworker/1:1-1212 [001] .... 228.378277: rtcpu_vinotify_event: tstamp:7568860818 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7568828424 data:0x000003c9
kworker/1:1-1212 [001] .... 228.378279: rtcpu_vinotify_error: tstamp:7569352581 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7569349780 data:0x000003c9
kworker/1:1-1212 [001] .... 228.378280: rtcpu_vinotify_event: tstamp:7569403180 tag:FE channel:0x00 frame:1 vi_tstamp:7569328924 data:0x00000020
kworker/1:1-1212 [001] .... 228.378281: rtcpu_vinotify_event: tstamp:7569403334 tag:FS channel:0x00 frame:1 vi_tstamp:7569349315 data:0x00000010
kworker/1:1-1212 [001] .... 228.378284: rtcpu_vinotify_event: tstamp:7569403472 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7569349780 data:0x000003c9
kworker/1:1-1212 [001] .... 228.434247: rtos_queue_peek_from_isr_failed: tstamp:7569834398 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 228.434250: rtcpu_vinotify_error: tstamp:7569873949 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7569871137 data:0x000003c9
kworker/1:1-1212 [001] .... 228.434252: rtcpu_vinotify_event: tstamp:7569945834 tag:FE channel:0x00 frame:1 vi_tstamp:7569850281 data:0x00000020
kworker/1:1-1212 [001] .... 228.434253: rtcpu_vinotify_event: tstamp:7569945973 tag:FS channel:0x00 frame:1 vi_tstamp:7569870671 data:0x00000010
kworker/1:1-1212 [001] .... 228.434254: rtcpu_vinotify_event: tstamp:7569946133 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7569871137 data:0x000003c9
kworker/1:1-1212 [001] .... 228.434256: rtcpu_vinotify_event: tstamp:7570374058 tag:FE channel:0x00 frame:1 vi_tstamp:7570371637 data:0x00000020
kworker/1:1-1212 [001] .... 228.434257: rtcpu_vinotify_error: tstamp:7570395296 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7570392493 data:0x000003c9
kworker/1:1-1212 [001] .... 228.434258: rtcpu_vinotify_event: tstamp:7570867978 tag:FS channel:0x00 frame:1 vi_tstamp:7570392028 data:0x00000010
kworker/1:1-1212 [001] .... 228.434259: rtcpu_vinotify_event: tstamp:7570868114 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7570392493 data:0x000003c9
kworker/1:1-1212 [001] .... 228.434261: rtcpu_vinotify_error: tstamp:7570916655 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7570913850 data:0x000003c9
kworker/1:1-1212 [001] .... 228.434262: rtcpu_vinotify_event: tstamp:7571410635 tag:FE channel:0x00 frame:1 vi_tstamp:7570892994 data:0x00000020
kworker/1:1-1212 [001] .... 228.434263: rtcpu_vinotify_event: tstamp:7571410772 tag:FS channel:0x00 frame:1 vi_tstamp:7570913384 data:0x00000010
kworker/1:1-1212 [001] .... 228.434265: rtcpu_vinotify_event: tstamp:7571410930 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7570913850 data:0x000003c9
kworker/1:1-1212 [001] .... 228.490245: rtcpu_vinotify_error: tstamp:7571438010 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7571435207 data:0x000003c9
kworker/1:1-1212 [001] .... 228.490247: rtcpu_vinotify_event: tstamp:7571953452 tag:FE channel:0x00 frame:1 vi_tstamp:7571414350 data:0x00000020
kworker/1:1-1212 [001] .... 228.490249: rtcpu_vinotify_event: tstamp:7571953613 tag:FS channel:0x00 frame:1 vi_tstamp:7571434741 data:0x00000010
kworker/1:1-1212 [001] .... 228.490250: rtcpu_vinotify_event: tstamp:7571953752 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7571435207 data:0x000003c9
kworker/1:1-1212 [001] .... 228.490252: rtcpu_vinotify_event: tstamp:7571953908 tag:FE channel:0x00 frame:1 vi_tstamp:7571935707 data:0x00000020
kworker/1:1-1212 [001] .... 228.490253: rtcpu_vinotify_error: tstamp:7571959356 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7571956563 data:0x000003c9
kworker/1:1-1212 [001] .... 228.490254: rtcpu_vinotify_error: tstamp:7572480728 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7572477920 data:0x000003c9
kworker/1:1-1212 [001] .... 228.490255: rtcpu_vinotify_event: tstamp:7572495549 tag:FS channel:0x00 frame:1 vi_tstamp:7571956098 data:0x00000010
kworker/1:1-1212 [001] .... 228.490257: rtcpu_vinotify_event: tstamp:7572495706 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7571956563 data:0x000003c9
kworker/1:1-1212 [001] .... 228.490258: rtcpu_vinotify_event: tstamp:7572495841 tag:FE channel:0x00 frame:1 vi_tstamp:7572457063 data:0x00000020
kworker/1:1-1212 [001] .... 228.490259: rtcpu_vinotify_event: tstamp:7572495995 tag:FS channel:0x00 frame:1 vi_tstamp:7572477454 data:0x00000010
kworker/1:1-1212 [001] .... 228.490260: rtcpu_vinotify_event: tstamp:7572496130 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7572477920 data:0x000003c9
kworker/1:1-1212 [001] .... 228.490262: rtcpu_vinotify_event: tstamp:7573002416 tag:FE channel:0x00 frame:1 vi_tstamp:7572978419 data:0x00000020
kworker/1:1-1212 [001] .... 228.490263: rtcpu_vinotify_event: tstamp:7573002554 tag:FS channel:0x00 frame:1 vi_tstamp:7572998811 data:0x00000010
kworker/1:1-1212 [001] .... 228.490264: rtcpu_vinotify_error: tstamp:7573003621 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7572999276 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546296: rtcpu_vinotify_error: tstamp:7573523438 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7573520634 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546299: rtcpu_vinotify_event: tstamp:7573526917 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7572999276 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546301: rtcpu_vinotify_event: tstamp:7573527056 tag:FE channel:0x00 frame:1 vi_tstamp:7573499776 data:0x00000020
kworker/1:1-1212 [001] .... 228.546302: rtcpu_vinotify_event: tstamp:7573527214 tag:FS channel:0x00 frame:1 vi_tstamp:7573520168 data:0x00000010
kworker/1:1-1212 [001] .... 228.546304: rtcpu_vinotify_event: tstamp:7573527350 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7573520634 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546305: rtcpu_vinotify_error: tstamp:7574044794 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7574041990 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546306: rtcpu_vinotify_event: tstamp:7574068796 tag:FE channel:0x00 frame:1 vi_tstamp:7574021133 data:0x00000020
kworker/1:1-1212 [001] .... 228.546308: rtcpu_vinotify_event: tstamp:7574068932 tag:FS channel:0x00 frame:1 vi_tstamp:7574041524 data:0x00000010
kworker/1:1-1212 [001] .... 228.546309: rtcpu_vinotify_event: tstamp:7574069089 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7574041990 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546311: rtcpu_vinotify_error: tstamp:7574566153 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7574563347 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546312: rtcpu_vinotify_event: tstamp:7574611449 tag:FE channel:0x00 frame:1 vi_tstamp:7574542489 data:0x00000020
kworker/1:1-1212 [001] .... 228.546313: rtcpu_vinotify_event: tstamp:7574611605 tag:FS channel:0x00 frame:1 vi_tstamp:7574562881 data:0x00000010
kworker/1:1-1212 [001] .... 228.546314: rtcpu_vinotify_event: tstamp:7574611743 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7574563347 data:0x000003c9
kworker/1:1-1212 [001] .... 228.546316: rtos_queue_peek_from_isr_failed: tstamp:7574834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 228.602291: rtcpu_vinotify_error: tstamp:7575087511 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7575084704 data:0x000003c9
kworker/1:1-1212 [001] .... 228.602303: rtcpu_vinotify_event: tstamp:7575154101 tag:FE channel:0x00 frame:1 vi_tstamp:7575063846 data:0x00000020
kworker/1:1-1212 [001] .... 228.602305: rtcpu_vinotify_event: tstamp:7575154238 tag:FS channel:0x00 frame:1 vi_tstamp:7575084237 data:0x00000010
kworker/1:1-1212 [001] .... 228.602306: rtcpu_vinotify_event: tstamp:7575154398 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7575084704 data:0x000003c9
kworker/1:1-1212 [001] .... 228.602307: rtcpu_vinotify_error: tstamp:7575609044 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7575606060 data:0x000003c9
kworker/1:1-1212 [001] .... 228.602309: rtcpu_vinotify_event: tstamp:7575609429 tag:FE channel:0x00 frame:1 vi_tstamp:7575585203 data:0x00000020
kworker/1:1-1212 [001] .... 228.602310: rtcpu_vinotify_event: tstamp:7575609586 tag:FS channel:0x00 frame:1 vi_tstamp:7575605594 data:0x00000010
kworker/1:1-1212 [001] .... 228.602311: rtcpu_vinotify_event: tstamp:7575609723 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7575606060 data:0x000003c9
kworker/1:1-1212 [001] .... 228.602312: rtcpu_vinotify_error: tstamp:7576130304 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7576127417 data:0x000003c9
kworker/1:1-1212 [001] .... 228.602313: rtcpu_vinotify_event: tstamp:7576133137 tag:FE channel:0x00 frame:1 vi_tstamp:7576106559 data:0x00000020
kworker/1:1-1212 [001] .... 228.602314: rtcpu_vinotify_event: tstamp:7576133273 tag:FS channel:0x00 frame:1 vi_tstamp:7576126951 data:0x00000010
kworker/1:1-1212 [001] .... 228.602315: rtcpu_vinotify_event: tstamp:7576133430 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7576127417 data:0x000003c9
kworker/1:1-1212 [001] .... 228.602316: rtcpu_vinotify_error: tstamp:7576651577 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7576648773 data:0x000003c9
kworker/1:1-1212 [001] .... 228.602317: rtcpu_vinotify_event: tstamp:7576673443 tag:FE channel:0x00 frame:1 vi_tstamp:7576627917 data:0x00000020
kworker/1:1-1212 [001] .... 228.602318: rtcpu_vinotify_event: tstamp:7576673599 tag:FS channel:0x00 frame:1 vi_tstamp:7576648308 data:0x00000010
kworker/1:1-1212 [001] .... 228.602319: rtcpu_vinotify_event: tstamp:7576673735 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7576648773 data:0x000003c9
kworker/1:1-1212 [001] .... 228.658277: rtcpu_vinotify_error: tstamp:7577172938 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7577170130 data:0x000003c9
kworker/1:1-1212 [001] .... 228.658284: rtcpu_vinotify_event: tstamp:7577216096 tag:FE channel:0x00 frame:1 vi_tstamp:7577149273 data:0x00000020
kworker/1:1-1212 [001] .... 228.658286: rtcpu_vinotify_event: tstamp:7577216234 tag:FS channel:0x00 frame:1 vi_tstamp:7577169665 data:0x00000010
kworker/1:1-1212 [001] .... 228.658287: rtcpu_vinotify_event: tstamp:7577216391 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7577170130 data:0x000003c9
kworker/1:1-1212 [001] .... 228.658288: rtcpu_vinotify_error: tstamp:7577694294 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7577691487 data:0x000003c9
kworker/1:1-1212 [001] .... 228.658290: rtcpu_vinotify_event: tstamp:7577758757 tag:FE channel:0x00 frame:1 vi_tstamp:7577670630 data:0x00000020
kworker/1:1-1212 [001] .... 228.658291: rtcpu_vinotify_event: tstamp:7577758913 tag:FS channel:0x00 frame:1 vi_tstamp:7577691021 data:0x00000010
kworker/1:1-1212 [001] .... 228.658292: rtcpu_vinotify_event: tstamp:7577759050 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7577691487 data:0x000003c9
kworker/1:1-1212 [001] .... 228.658293: rtcpu_vinotify_error: tstamp:7578215645 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7578212843 data:0x000003c9
kworker/1:1-1212 [001] .... 228.658295: rtcpu_vinotify_event: tstamp:7578300633 tag:FE channel:0x00 frame:1 vi_tstamp:7578191986 data:0x00000020
kworker/1:1-1212 [001] .... 228.658296: rtcpu_vinotify_event: tstamp:7578300771 tag:FS channel:0x00 frame:1 vi_tstamp:7578212378 data:0x00000010
kworker/1:1-1212 [001] .... 228.658297: rtcpu_vinotify_event: tstamp:7578300929 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7578212843 data:0x000003c9
kworker/1:1-1212 [001] .... 228.714290: rtcpu_vinotify_event: tstamp:7578715759 tag:FE channel:0x00 frame:1 vi_tstamp:7578713343 data:0x00000020
kworker/1:1-1212 [001] .... 228.714296: rtcpu_vinotify_error: tstamp:7578737001 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7578734200 data:0x000003c9
kworker/1:1-1212 [001] .... 228.714297: rtcpu_vinotify_event: tstamp:7579223563 tag:FS channel:0x00 frame:1 vi_tstamp:7578733734 data:0x00000010
kworker/1:1-1212 [001] .... 228.714299: rtcpu_vinotify_event: tstamp:7579223700 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7578734200 data:0x000003c9
kworker/1:1-1212 [001] .... 228.714300: rtcpu_vinotify_error: tstamp:7579258359 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7579255557 data:0x000003c9
kworker/1:1-1212 [001] .... 228.714301: rtcpu_vinotify_event: tstamp:7579765596 tag:FE channel:0x00 frame:1 vi_tstamp:7579234700 data:0x00000020
kworker/1:1-1212 [001] .... 228.714335: rtcpu_vinotify_event: tstamp:7579765732 tag:FS channel:0x00 frame:1 vi_tstamp:7579255091 data:0x00000010
kworker/1:1-1212 [001] .... 228.714336: rtcpu_vinotify_event: tstamp:7579765890 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7579255557 data:0x000003c9
kworker/1:1-1212 [001] .... 228.714337: rtcpu_vinotify_event: tstamp:7579766025 tag:FE channel:0x00 frame:1 vi_tstamp:7579756056 data:0x00000020
kworker/1:1-1212 [001] .... 228.714339: rtcpu_vinotify_error: tstamp:7579779702 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7579776913 data:0x000003c9
kworker/1:1-1212 [001] .... 228.714342: rtos_queue_peek_from_isr_failed: tstamp:7579834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 228.770267: rtcpu_vinotify_error: tstamp:7580301077 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7580298270 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770274: rtcpu_vinotify_event: tstamp:7580308465 tag:FS channel:0x00 frame:1 vi_tstamp:7579776448 data:0x00000010
kworker/1:1-1212 [001] .... 228.770276: rtcpu_vinotify_event: tstamp:7580308604 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7579776913 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770277: rtcpu_vinotify_event: tstamp:7580308761 tag:FE channel:0x00 frame:1 vi_tstamp:7580277413 data:0x00000020
kworker/1:1-1212 [001] .... 228.770278: rtcpu_vinotify_event: tstamp:7580308895 tag:FS channel:0x00 frame:1 vi_tstamp:7580297804 data:0x00000010
(+Continue) Test2 Trace log
kworker/1:1-1212 [001] .... 228.770280: rtcpu_vinotify_event: tstamp:7580309051 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7580298270 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770281: rtcpu_vinotify_error: tstamp:7580822429 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7580819626 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770282: rtcpu_vinotify_event: tstamp:7580851126 tag:FE channel:0x00 frame:1 vi_tstamp:7580798769 data:0x00000020
kworker/1:1-1212 [001] .... 228.770284: rtcpu_vinotify_event: tstamp:7580851282 tag:FS channel:0x00 frame:1 vi_tstamp:7580819161 data:0x00000010
kworker/1:1-1212 [001] .... 228.770285: rtcpu_vinotify_event: tstamp:7580851418 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7580819626 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770286: rtcpu_vinotify_event: tstamp:7581344123 tag:FE channel:0x00 frame:1 vi_tstamp:7581320126 data:0x00000020
kworker/1:1-1212 [001] .... 228.770289: rtcpu_vinotify_event: tstamp:7581344259 tag:FS channel:0x00 frame:1 vi_tstamp:7581340517 data:0x00000010
kworker/1:1-1212 [001] .... 228.770290: rtcpu_vinotify_error: tstamp:7581345321 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7581340982 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770291: rtcpu_vinotify_error: tstamp:7581865142 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7581862339 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770293: rtcpu_vinotify_event: tstamp:7581881723 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7581340982 data:0x000003c9
kworker/1:1-1212 [001] .... 228.770294: rtcpu_vinotify_event: tstamp:7581881861 tag:FE channel:0x00 frame:1 vi_tstamp:7581841483 data:0x00000020
kworker/1:1-1212 [001] .... 228.770328: rtcpu_vinotify_event: tstamp:7581882018 tag:FS channel:0x00 frame:1 vi_tstamp:7581861874 data:0x00000010
kworker/1:1-1212 [001] .... 228.770329: rtcpu_vinotify_event: tstamp:7581882153 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7581862339 data:0x000003c9
kworker/1:1-1212 [001] .... 228.826254: rtcpu_vinotify_error: tstamp:7582386502 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7582383696 data:0x000003c9
kworker/1:1-1212 [001] .... 228.826260: rtcpu_vinotify_event: tstamp:7582424382 tag:FE channel:0x00 frame:1 vi_tstamp:7582362839 data:0x00000020
kworker/1:1-1212 [001] .... 228.826261: rtcpu_vinotify_event: tstamp:7582424518 tag:FS channel:0x00 frame:1 vi_tstamp:7582383231 data:0x00000010
kworker/1:1-1212 [001] .... 228.826262: rtcpu_vinotify_event: tstamp:7582424675 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7582383696 data:0x000003c9
kworker/1:1-1212 [001] .... 228.826262: rtcpu_vinotify_error: tstamp:7582907856 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7582905052 data:0x000003c9
kworker/1:1-1212 [001] .... 228.826263: rtcpu_vinotify_event: tstamp:7582967040 tag:FE channel:0x00 frame:1 vi_tstamp:7582884197 data:0x00000020
kworker/1:1-1212 [001] .... 228.826264: rtcpu_vinotify_event: tstamp:7582967196 tag:FS channel:0x00 frame:1 vi_tstamp:7582904587 data:0x00000010
kworker/1:1-1212 [001] .... 228.826265: rtcpu_vinotify_event: tstamp:7582967332 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7582905052 data:0x000003c9
kworker/1:1-1212 [001] .... 228.826265: rtcpu_vinotify_error: tstamp:7583429216 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7583426409 data:0x000003c9
kworker/1:1-1212 [001] .... 228.826266: rtcpu_vinotify_event: tstamp:7583509692 tag:FE channel:0x00 frame:1 vi_tstamp:7583405552 data:0x00000020
kworker/1:1-1212 [001] .... 228.826267: rtcpu_vinotify_event: tstamp:7583509831 tag:FS channel:0x00 frame:1 vi_tstamp:7583425944 data:0x00000010
kworker/1:1-1212 [001] .... 228.826268: rtcpu_vinotify_event: tstamp:7583509988 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7583426409 data:0x000003c9
kworker/1:1-1212 [001] .... 228.882286: rtcpu_vinotify_error: tstamp:7583950706 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7583947766 data:0x000003c9
kworker/1:1-1212 [001] .... 228.882293: rtcpu_vinotify_event: tstamp:7583951089 tag:FE channel:0x00 frame:1 vi_tstamp:7583926910 data:0x00000020
kworker/1:1-1212 [001] .... 228.882295: rtcpu_vinotify_event: tstamp:7583951249 tag:FS channel:0x00 frame:1 vi_tstamp:7583947300 data:0x00000010
kworker/1:1-1212 [001] .... 228.882296: rtcpu_vinotify_event: tstamp:7583951385 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7583947766 data:0x000003c9
kworker/1:1-1212 [001] .... 228.882297: rtcpu_vinotify_error: tstamp:7584471925 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7584469123 data:0x000003c9
kworker/1:1-1212 [001] .... 228.882298: rtcpu_vinotify_event: tstamp:7584485582 tag:FE channel:0x00 frame:1 vi_tstamp:7584448266 data:0x00000020
kworker/1:1-1212 [001] .... 228.882300: rtcpu_vinotify_event: tstamp:7584485719 tag:FS channel:0x00 frame:1 vi_tstamp:7584468657 data:0x00000010
kworker/1:1-1212 [001] .... 228.882332: rtcpu_vinotify_event: tstamp:7584485875 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7584469123 data:0x000003c9
kworker/1:1-1212 [001] .... 228.882335: rtos_queue_peek_from_isr_failed: tstamp:7584834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 228.882337: rtcpu_vinotify_error: tstamp:7584993320 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7584990479 data:0x000003c9
kworker/1:1-1212 [001] .... 228.882338: rtcpu_vinotify_event: tstamp:7585028267 tag:FE channel:0x00 frame:1 vi_tstamp:7584969622 data:0x00000020
kworker/1:1-1212 [001] .... 228.882340: rtcpu_vinotify_event: tstamp:7585028425 tag:FS channel:0x00 frame:1 vi_tstamp:7584990014 data:0x00000010
kworker/1:1-1212 [001] .... 228.882341: rtcpu_vinotify_event: tstamp:7585028563 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7584990479 data:0x000003c9
kworker/1:1-1212 [001] .... 228.938280: rtcpu_vinotify_error: tstamp:7585514767 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7585511836 data:0x000003c9
kworker/1:1-1212 [001] .... 228.938287: rtcpu_vinotify_event: tstamp:7585570926 tag:FE channel:0x00 frame:1 vi_tstamp:7585490980 data:0x00000020
kworker/1:1-1212 [001] .... 228.938289: rtcpu_vinotify_event: tstamp:7585571064 tag:FS channel:0x00 frame:1 vi_tstamp:7585511371 data:0x00000010
kworker/1:1-1212 [001] .... 228.938290: rtcpu_vinotify_event: tstamp:7585571220 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7585511836 data:0x000003c9
kworker/1:1-1212 [001] .... 228.938291: rtcpu_vinotify_error: tstamp:7586036002 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7586033192 data:0x000003c9
kworker/1:1-1212 [001] .... 228.938293: rtcpu_vinotify_event: tstamp:7586113557 tag:FE channel:0x00 frame:1 vi_tstamp:7586012336 data:0x00000020
kworker/1:1-1212 [001] .... 228.938294: rtcpu_vinotify_event: tstamp:7586113713 tag:FS channel:0x00 frame:1 vi_tstamp:7586032727 data:0x00000010
kworker/1:1-1212 [001] .... 228.938295: rtcpu_vinotify_event: tstamp:7586113849 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7586033192 data:0x000003c9
kworker/1:1-1212 [001] .... 228.938297: rtcpu_vinotify_error: tstamp:7586557354 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7586554549 data:0x000003c9
kworker/1:1-1212 [001] .... 228.938298: rtcpu_vinotify_event: tstamp:7586656212 tag:FE channel:0x00 frame:1 vi_tstamp:7586533693 data:0x00000020
kworker/1:1-1212 [001] .... 228.938299: rtcpu_vinotify_event: tstamp:7586656348 tag:FS channel:0x00 frame:1 vi_tstamp:7586554084 data:0x00000010
kworker/1:1-1212 [001] .... 228.938300: rtcpu_vinotify_event: tstamp:7586656503 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7586554549 data:0x000003c9
kworker/1:1-1212 [001] .... 228.938302: rtcpu_vinotify_event: tstamp:7587057467 tag:FE channel:0x00 frame:1 vi_tstamp:7587055050 data:0x00000020
kworker/1:1-1212 [001] .... 228.938303: rtcpu_vinotify_error: tstamp:7587078752 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7587075906 data:0x000003c9
kworker/1:1-1212 [001] .... 228.994272: rtcpu_vinotify_event: tstamp:7587578469 tag:FS channel:0x00 frame:1 vi_tstamp:7587075441 data:0x00000010
kworker/1:1-1212 [001] .... 228.994277: rtcpu_vinotify_event: tstamp:7587578608 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7587075906 data:0x000003c9
kworker/1:1-1212 [001] .... 228.994279: rtcpu_vinotify_error: tstamp:7587600056 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7587597262 data:0x000003c9
kworker/1:1-1212 [001] .... 228.994280: rtcpu_vinotify_error: tstamp:7588121427 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7588118619 data:0x000003c9
kworker/1:1-1212 [001] .... 228.994282: rtcpu_vinotify_event: tstamp:7588123662 tag:FE channel:0x00 frame:1 vi_tstamp:7587576406 data:0x00000020
kworker/1:1-1212 [001] .... 228.994283: rtcpu_vinotify_event: tstamp:7588123800 tag:FS channel:0x00 frame:1 vi_tstamp:7587596798 data:0x00000010
kworker/1:1-1212 [001] .... 228.994284: rtcpu_vinotify_event: tstamp:7588123957 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7587597262 data:0x000003c9
kworker/1:1-1212 [001] .... 228.994286: rtcpu_vinotify_event: tstamp:7588124090 tag:FE channel:0x00 frame:1 vi_tstamp:7588097763 data:0x00000020
kworker/1:1-1212 [001] .... 228.994287: rtcpu_vinotify_event: tstamp:7588124246 tag:FS channel:0x00 frame:1 vi_tstamp:7588118153 data:0x00000010
kworker/1:1-1212 [001] .... 228.994288: rtcpu_vinotify_event: tstamp:7588124381 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7588118619 data:0x000003c9
kworker/1:1-1212 [001] .... 228.994290: rtcpu_vinotify_error: tstamp:7588642782 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7588639975 data:0x000003c9
kworker/1:1-1212 [001] .... 228.994291: rtcpu_vinotify_event: tstamp:7588663222 tag:FE channel:0x00 frame:1 vi_tstamp:7588619119 data:0x00000020
kworker/1:1-1212 [001] .... 228.994292: rtcpu_vinotify_event: tstamp:7588663375 tag:FS channel:0x00 frame:1 vi_tstamp:7588639510 data:0x00000010
kworker/1:1-1212 [001] .... 228.994294: rtcpu_vinotify_event: tstamp:7588663533 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7588639975 data:0x000003c9
kworker/1:1-1212 [001] .... 229.050271: rtcpu_vinotify_error: tstamp:7589164141 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7589161332 data:0x000003c9
kworker/1:1-1212 [001] .... 229.050277: rtcpu_vinotify_event: tstamp:7589205873 tag:FE channel:0x00 frame:1 vi_tstamp:7589140476 data:0x00000020
kworker/1:1-1212 [001] .... 229.050278: rtcpu_vinotify_event: tstamp:7589206030 tag:FS channel:0x00 frame:1 vi_tstamp:7589160867 data:0x00000010
kworker/1:1-1212 [001] .... 229.050279: rtcpu_vinotify_event: tstamp:7589206169 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7589161332 data:0x000003c9
kworker/1:1-1212 [001] .... 229.050279: rtcpu_vinotify_event: tstamp:7589685830 tag:FE channel:0x00 frame:1 vi_tstamp:7589661833 data:0x00000020
kworker/1:1-1212 [001] .... 229.050280: rtcpu_vinotify_event: tstamp:7589685969 tag:FS channel:0x00 frame:1 vi_tstamp:7589682223 data:0x00000010
kworker/1:1-1212 [001] .... 229.050281: rtcpu_vinotify_error: tstamp:7589687030 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7589682689 data:0x000003c9
kworker/1:1-1212 [001] .... 229.050284: rtos_queue_peek_from_isr_failed: tstamp:7589834391 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 229.050285: rtcpu_vinotify_event: tstamp:7590182617 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7589682689 data:0x000003c9
kworker/1:1-1212 [001] .... 229.050286: rtcpu_vinotify_error: tstamp:7590206842 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7590204045 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106269: rtcpu_vinotify_event: tstamp:7590725377 tag:FE channel:0x00 frame:1 vi_tstamp:7590183189 data:0x00000020
kworker/1:1-1212 [001] .... 229.106274: rtcpu_vinotify_event: tstamp:7590725536 tag:FS channel:0x00 frame:1 vi_tstamp:7590203580 data:0x00000010
kworker/1:1-1212 [001] .... 229.106275: rtcpu_vinotify_event: tstamp:7590727157 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7590204045 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106276: rtcpu_vinotify_event: tstamp:7590727315 tag:FE channel:0x00 frame:1 vi_tstamp:7590704546 data:0x00000020
kworker/1:1-1212 [001] .... 229.106278: rtcpu_vinotify_error: tstamp:7590728376 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7590725402 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106279: rtcpu_vinotify_error: tstamp:7591249564 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7591246759 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106279: rtcpu_vinotify_event: tstamp:7591267507 tag:FS channel:0x00 frame:1 vi_tstamp:7590724936 data:0x00000010
kworker/1:1-1212 [001] .... 229.106280: rtcpu_vinotify_event: tstamp:7591267664 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7590725402 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106281: rtcpu_vinotify_event: tstamp:7591267800 tag:FE channel:0x00 frame:1 vi_tstamp:7591225902 data:0x00000020
kworker/1:1-1212 [001] .... 229.106282: rtcpu_vinotify_event: tstamp:7591267953 tag:FS channel:0x00 frame:1 vi_tstamp:7591246294 data:0x00000010
kworker/1:1-1212 [001] .... 229.106282: rtcpu_vinotify_event: tstamp:7591268088 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7591246759 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106283: rtcpu_vinotify_error: tstamp:7591770920 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7591768116 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106284: rtcpu_vinotify_event: tstamp:7591810164 tag:FE channel:0x00 frame:1 vi_tstamp:7591747259 data:0x00000020
kworker/1:1-1212 [001] .... 229.106284: rtcpu_vinotify_event: tstamp:7591810300 tag:FS channel:0x00 frame:1 vi_tstamp:7591767650 data:0x00000010
kworker/1:1-1212 [001] .... 229.106285: rtcpu_vinotify_event: tstamp:7591810457 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7591768116 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106286: rtcpu_vinotify_error: tstamp:7592292416 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7592289473 data:0x000003c9
kworker/1:1-1212 [001] .... 229.106287: rtcpu_vinotify_event: tstamp:7592292800 tag:FE channel:0x00 frame:1 vi_tstamp:7592268616 data:0x00000020
kworker/1:1-1212 [001] .... 229.106287: rtcpu_vinotify_event: tstamp:7592292957 tag:FS channel:0x00 frame:1 vi_tstamp:7592289006 data:0x00000010
kworker/1:1-1212 [001] .... 229.106288: rtcpu_vinotify_event: tstamp:7592293092 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7592289473 data:0x000003c9
kworker/1:1-1212 [001] .... 229.162273: rtcpu_vinotify_error: tstamp:7592813653 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7592810829 data:0x000003c9
kworker/1:1-1212 [001] .... 229.162278: rtcpu_vinotify_event: tstamp:7592841134 tag:FE channel:0x00 frame:1 vi_tstamp:7592789973 data:0x00000020
kworker/1:1-1212 [001] .... 229.162279: rtcpu_vinotify_event: tstamp:7592841270 tag:FS channel:0x00 frame:1 vi_tstamp:7592810363 data:0x00000010
kworker/1:1-1212 [001] .... 229.162280: rtcpu_vinotify_event: tstamp:7592841427 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7592810829 data:0x000003c9
kworker/1:1-1212 [001] .... 229.162282: rtcpu_vinotify_error: tstamp:7593334988 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7593332186 data:0x000003c9
kworker/1:1-1212 [001] .... 229.162283: rtcpu_vinotify_event: tstamp:7593383788 tag:FE channel:0x00 frame:1 vi_tstamp:7593311329 data:0x00000020
kworker/1:1-1212 [001] .... 229.162284: rtcpu_vinotify_event: tstamp:7593383945 tag:FS channel:0x00 frame:1 vi_tstamp:7593331719 data:0x00000010
kworker/1:1-1212 [001] .... 229.162284: rtcpu_vinotify_event: tstamp:7593384081 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7593332186 data:0x000003c9
kworker/1:1-1212 [001] .... 229.162285: rtcpu_vinotify_error: tstamp:7593856349 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7593853542 data:0x000003c9
kworker/1:1-1212 [001] .... 229.162286: rtcpu_vinotify_event: tstamp:7593926436 tag:FE channel:0x00 frame:1 vi_tstamp:7593832685 data:0x00000020
kworker/1:1-1212 [001] .... 229.162287: rtcpu_vinotify_event: tstamp:7593926571 tag:FS channel:0x00 frame:1 vi_tstamp:7593853076 data:0x00000010
kworker/1:1-1212 [001] .... 229.162288: rtcpu_vinotify_event: tstamp:7593926727 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7593853542 data:0x000003c9
kworker/1:1-1212 [001] .... 229.218276: rtcpu_vinotify_error: tstamp:7594377704 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7594374899 data:0x000003c9
kworker/1:1-1212 [001] .... 229.218282: rtcpu_vinotify_event: tstamp:7594468307 tag:FE channel:0x00 frame:1 vi_tstamp:7594354043 data:0x00000020
kworker/1:1-1212 [001] .... 229.218284: rtcpu_vinotify_event: tstamp:7594468463 tag:FS channel:0x00 frame:1 vi_tstamp:7594374433 data:0x00000010
kworker/1:1-1212 [001] .... 229.218285: rtcpu_vinotify_event: tstamp:7594468599 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7594374899 data:0x000003c9
kworker/1:1-1212 [001] .... 229.218289: rtos_queue_peek_from_isr_failed: tstamp:7594834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 229.218290: rtcpu_vinotify_error: tstamp:7594899062 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7594896256 data:0x000003c9
kworker/1:1-1212 [001] .... 229.218292: rtcpu_vinotify_event: tstamp:7595010973 tag:FE channel:0x00 frame:1 vi_tstamp:7594875399 data:0x00000020
kworker/1:1-1212 [001] .... 229.218293: rtcpu_vinotify_event: tstamp:7595011109 tag:FS channel:0x00 frame:1 vi_tstamp:7594895790 data:0x00000010
kworker/1:1-1212 [001] .... 229.218294: rtcpu_vinotify_event: tstamp:7595011267 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7594896256 data:0x000003c9
kworker/1:1-1212 [001] .... 229.218295: rtcpu_vinotify_event: tstamp:7595399180 tag:FE channel:0x00 frame:1 vi_tstamp:7595396756 data:0x00000020
kworker/1:1-1212 [001] .... 229.218297: rtcpu_vinotify_error: tstamp:7595420405 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7595417612 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274304: rtcpu_vinotify_event: tstamp:7595933224 tag:FS channel:0x00 frame:1 vi_tstamp:7595417147 data:0x00000010
kworker/1:1-1212 [001] .... 229.274310: rtcpu_vinotify_event: tstamp:7595933367 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7595417612 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274311: rtcpu_vinotify_event: tstamp:7595933525 tag:FE channel:0x00 frame:1 vi_tstamp:7595918113 data:0x00000020
kworker/1:1-1212 [001] .... 229.274313: rtcpu_vinotify_error: tstamp:7595941763 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7595938969 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274314: rtcpu_vinotify_error: tstamp:7596463133 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7596460325 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274316: rtcpu_vinotify_event: tstamp:7596476156 tag:FS channel:0x00 frame:1 vi_tstamp:7595938503 data:0x00000010
kworker/1:1-1212 [001] .... 229.274317: rtcpu_vinotify_event: tstamp:7596476314 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7595938969 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274318: rtcpu_vinotify_event: tstamp:7596476450 tag:FE channel:0x00 frame:1 vi_tstamp:7596439469 data:0x00000020
kworker/1:1-1212 [001] .... 229.274319: rtcpu_vinotify_event: tstamp:7596476606 tag:FS channel:0x00 frame:1 vi_tstamp:7596459860 data:0x00000010
kworker/1:1-1212 [001] .... 229.274321: rtcpu_vinotify_event: tstamp:7596476742 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7596460325 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274322: rtcpu_vinotify_error: tstamp:7596984540 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7596981682 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274323: rtcpu_vinotify_event: tstamp:7597018814 tag:FE channel:0x00 frame:1 vi_tstamp:7596960826 data:0x00000020
kworker/1:1-1212 [001] .... 229.274349: rtcpu_vinotify_event: tstamp:7597018952 tag:FS channel:0x00 frame:1 vi_tstamp:7596981216 data:0x00000010
kworker/1:1-1212 [001] .... 229.274350: rtcpu_vinotify_event: tstamp:7597019111 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7596981682 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274351: rtcpu_vinotify_error: tstamp:7597505842 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7597503039 data:0x000003c9
kworker/1:1-1212 [001] .... 229.274352: rtcpu_vinotify_event: tstamp:7597561474 tag:FE channel:0x00 frame:1 vi_tstamp:7597482182 data:0x00000020
kworker/1:1-1212 [001] .... 229.274354: rtcpu_vinotify_event: tstamp:7597561629 tag:FS channel:0x00 frame:1 vi_tstamp:7597502573 data:0x00000010
kworker/1:1-1212 [001] .... 229.274355: rtcpu_vinotify_event: tstamp:7597561765 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7597503039 data:0x000003c9
kworker/1:1-1212 [001] .... 229.330274: rtcpu_vinotify_event: tstamp:7598027537 tag:FE channel:0x00 frame:1 vi_tstamp:7598003539 data:0x00000020
kworker/1:1-1212 [001] .... 229.330278: rtcpu_vinotify_event: tstamp:7598027674 tag:FS channel:0x00 frame:1 vi_tstamp:7598023930 data:0x00000010
kworker/1:1-1212 [001] .... 229.330310: rtcpu_vinotify_error: tstamp:7598028736 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7598024395 data:0x000003c9
kworker/1:1-1212 [001] .... 229.330312: rtcpu_vinotify_event: tstamp:7598537533 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7598024395 data:0x000003c9
kworker/1:1-1212 [001] .... 229.330313: rtcpu_vinotify_event: tstamp:7598537668 tag:FE channel:0x00 frame:1 vi_tstamp:7598524896 data:0x00000020
kworker/1:1-1212 [001] .... 229.330314: rtcpu_vinotify_error: tstamp:7598548563 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7598545752 data:0x000003c9
kworker/1:1-1212 [001] .... 229.330315: rtcpu_vinotify_error: tstamp:7599069915 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7599067108 data:0x000003c9
kworker/1:1-1212 [001] .... 229.330317: rtcpu_vinotify_event: tstamp:7599080453 tag:FS channel:0x00 frame:1 vi_tstamp:7598545286 data:0x00000010
kworker/1:1-1212 [001] .... 229.330318: rtcpu_vinotify_event: tstamp:7599080589 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7598545752 data:0x000003c9
kworker/1:1-1212 [001] .... 229.330319: rtcpu_vinotify_event: tstamp:7599080746 tag:FE channel:0x00 frame:1 vi_tstamp:7599046252 data:0x00000020
kworker/1:1-1212 [001] .... 229.330321: rtcpu_vinotify_event: tstamp:7599080885 tag:FS channel:0x00 frame:1 vi_tstamp:7599066643 data:0x00000010
kworker/1:1-1212 [001] .... 229.330322: rtcpu_vinotify_event: tstamp:7599081042 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7599067108 data:0x000003c9
kworker/1:1-1212 [001] .... 229.386312: rtcpu_vinotify_error: tstamp:7599591271 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7599588465 data:0x000003c9
kworker/1:1-1212 [001] .... 229.386316: rtcpu_vinotify_event: tstamp:7599623115 tag:FE channel:0x00 frame:1 vi_tstamp:7599567609 data:0x00000020
kworker/1:1-1212 [001] .... 229.386318: rtcpu_vinotify_event: tstamp:7599623272 tag:FS channel:0x00 frame:1 vi_tstamp:7599588000 data:0x00000010
kworker/1:1-1212 [001] .... 229.386320: rtcpu_vinotify_event: tstamp:7599623408 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7599588465 data:0x000003c9
kworker/1:1-1212 [001] .... 229.386323: rtos_queue_peek_from_isr_failed: tstamp:7599834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 229.386325: rtcpu_vinotify_error: tstamp:7600112628 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7600109822 data:0x000003c9
kworker/1:1-1212 [001] .... 229.386326: rtcpu_vinotify_event: tstamp:7600164984 tag:FE channel:0x00 frame:1 vi_tstamp:7600088966 data:0x00000020
kworker/1:1-1212 [001] .... 229.386327: rtcpu_vinotify_event: tstamp:7600165121 tag:FS channel:0x00 frame:1 vi_tstamp:7600109356 data:0x00000010
kworker/1:1-1212 [001] .... 229.386329: rtcpu_vinotify_event: tstamp:7600165278 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7600109822 data:0x000003c9
kworker/1:1-1212 [001] .... 229.386330: rtcpu_vinotify_error: tstamp:7600634120 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7600631179 data:0x000003c9
kworker/1:1-1212 [001] .... 229.386331: rtcpu_vinotify_event: tstamp:7600634504 tag:FE channel:0x00 frame:1 vi_tstamp:7600610322 data:0x00000020
kworker/1:1-1212 [001] .... 229.386332: rtcpu_vinotify_event: tstamp:7600634661 tag:FS channel:0x00 frame:1 vi_tstamp:7600630713 data:0x00000010
kworker/1:1-1212 [001] .... 229.386334: rtcpu_vinotify_event: tstamp:7600634797 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7600631179 data:0x000003c9
kworker/1:1-1212 [001] .... 229.386335: rtcpu_vinotify_event: tstamp:7601142171 tag:FE channel:0x00 frame:1 vi_tstamp:7601131679 data:0x00000020
kworker/1:1-1212 [001] .... 229.386336: rtcpu_vinotify_error: tstamp:7601155330 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7601152536 data:0x000003c9
kworker/1:1-1212 [001] .... 229.442266: rtcpu_vinotify_error: tstamp:7601676697 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7601673892 data:0x000003c9
kworker/1:1-1212 [001] .... 229.442270: rtcpu_vinotify_event: tstamp:7601684313 tag:FS channel:0x00 frame:1 vi_tstamp:7601152069 data:0x00000010
kworker/1:1-1212 [001] .... 229.442271: rtcpu_vinotify_event: tstamp:7601684474 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7601152536 data:0x000003c9
kworker/1:1-1212 [001] .... 229.442273: rtcpu_vinotify_event: tstamp:7601684612 tag:FE channel:0x00 frame:1 vi_tstamp:7601653035 data:0x00000020
kworker/1:1-1212 [001] .... 229.442274: rtcpu_vinotify_event: tstamp:7601684767 tag:FS channel:0x00 frame:1 vi_tstamp:7601673426 data:0x00000010
kworker/1:1-1212 [001] .... 229.442275: rtcpu_vinotify_event: tstamp:7601684903 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7601673892 data:0x000003c9
kworker/1:1-1212 [001] .... 229.442277: rtcpu_vinotify_error: tstamp:7602198053 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7602195249 data:0x000003c9
kworker/1:1-1212 [001] .... 229.442278: rtcpu_vinotify_event: tstamp:7602226969 tag:FE channel:0x00 frame:1 vi_tstamp:7602174393 data:0x00000020
kworker/1:1-1212 [001] .... 229.442279: rtcpu_vinotify_event: tstamp:7602227105 tag:FS channel:0x00 frame:1 vi_tstamp:7602194783 data:0x00000010
kworker/1:1-1212 [001] .... 229.442280: rtcpu_vinotify_event: tstamp:7602227262 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7602195249 data:0x000003c9
kworker/1:1-1212 [001] .... 229.442282: rtcpu_vinotify_error: tstamp:7602719409 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7602716605 data:0x000003c9
kworker/1:1-1212 [001] .... 229.442283: rtcpu_vinotify_event: tstamp:7602769621 tag:FE channel:0x00 frame:1 vi_tstamp:7602695749 data:0x00000020
kworker/1:1-1212 [001] .... 229.442311: rtcpu_vinotify_event: tstamp:7602769777 tag:FS channel:0x00 frame:1 vi_tstamp:7602716139 data:0x00000010
kworker/1:1-1212 [001] .... 229.442313: rtcpu_vinotify_event: tstamp:7602769915 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7602716605 data:0x000003c9
kworker/1:1-1212 [001] .... 229.498260: rtcpu_vinotify_error: tstamp:7603240767 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7603237962 data:0x000003c9
kworker/1:1-1212 [001] .... 229.498263: rtcpu_vinotify_event: tstamp:7603312279 tag:FE channel:0x00 frame:1 vi_tstamp:7603217106 data:0x00000020
kworker/1:1-1212 [001] .... 229.498265: rtcpu_vinotify_event: tstamp:7603312416 tag:FS channel:0x00 frame:1 vi_tstamp:7603237496 data:0x00000010
kworker/1:1-1212 [001] .... 229.498266: rtcpu_vinotify_event: tstamp:7603312575 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7603237962 data:0x000003c9
kworker/1:1-1212 [001] .... 229.498268: rtcpu_vinotify_event: tstamp:7603740884 tag:FE channel:0x00 frame:1 vi_tstamp:7603738463 data:0x00000020
kworker/1:1-1212 [001] .... 229.498269: rtcpu_vinotify_error: tstamp:7603762113 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7603759319 data:0x000003c9
kworker/1:1-1212 [001] .... 229.498270: rtcpu_vinotify_event: tstamp:7604234477 tag:FS channel:0x00 frame:1 vi_tstamp:7603758852 data:0x00000010
kworker/1:1-1212 [001] .... 229.498272: rtcpu_vinotify_event: tstamp:7604234614 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7603759319 data:0x000003c9
kworker/1:1-1212 [001] .... 229.498273: rtcpu_vinotify_error: tstamp:7604283480 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7604280675 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554283: rtcpu_vinotify_event: tstamp:7604777075 tag:FE channel:0x00 frame:1 vi_tstamp:7604259819 data:0x00000020
kworker/1:1-1212 [001] .... 229.554287: rtcpu_vinotify_event: tstamp:7604777214 tag:FS channel:0x00 frame:1 vi_tstamp:7604280209 data:0x00000010
kworker/1:1-1212 [001] .... 229.554288: rtcpu_vinotify_event: tstamp:7604777371 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7604280675 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554290: rtcpu_vinotify_error: tstamp:7604804837 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7604802032 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554292: rtos_queue_peek_from_isr_failed: tstamp:7604834394 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 229.554294: rtcpu_vinotify_event: tstamp:7605319057 tag:FE channel:0x00 frame:1 vi_tstamp:7604781176 data:0x00000020
kworker/1:1-1212 [001] .... 229.554296: rtcpu_vinotify_event: tstamp:7605319216 tag:FS channel:0x00 frame:1 vi_tstamp:7604801566 data:0x00000010
kworker/1:1-1212 [001] .... 229.554298: rtcpu_vinotify_event: tstamp:7605319355 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7604802032 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554299: rtcpu_vinotify_event: tstamp:7605319512 tag:FE channel:0x00 frame:1 vi_tstamp:7605302532 data:0x00000020
kworker/1:1-1212 [001] .... 229.554300: rtcpu_vinotify_error: tstamp:7605326183 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7605323389 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554302: rtcpu_vinotify_error: tstamp:7605847546 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7605844745 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554303: rtcpu_vinotify_event: tstamp:7605861986 tag:FS channel:0x00 frame:1 vi_tstamp:7605322923 data:0x00000010
kworker/1:1-1212 [001] .... 229.554304: rtcpu_vinotify_event: tstamp:7605862147 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7605323389 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554305: rtcpu_vinotify_event: tstamp:7605862283 tag:FE channel:0x00 frame:1 vi_tstamp:7605823888 data:0x00000020
kworker/1:1-1212 [001] .... 229.554334: rtcpu_vinotify_event: tstamp:7605862438 tag:FS channel:0x00 frame:1 vi_tstamp:7605844280 data:0x00000010
kworker/1:1-1212 [001] .... 229.554336: rtcpu_vinotify_event: tstamp:7605862575 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7605844745 data:0x000003c9
kworker/1:1-1212 [001] .... 229.554337: rtcpu_vinotify_event: tstamp:7606369241 tag:FE channel:0x00 frame:1 vi_tstamp:7606345245 data:0x00000020
kworker/1:1-1212 [001] .... 229.554339: rtcpu_vinotify_event: tstamp:7606369377 tag:FS channel:0x00 frame:1 vi_tstamp:7606365636 data:0x00000010
kworker/1:1-1212 [001] .... 229.554340: rtcpu_vinotify_error: tstamp:7606370440 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7606366102 data:0x000003c9
kworker/1:1-1212 [001] .... 229.610247: rtcpu_vinotify_error: tstamp:7606890305 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7606887458 data:0x000003c9
kworker/1:1-1212 [001] .... 229.610251: rtcpu_vinotify_event: tstamp:7606893363 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7606366102 data:0x000003c9
kworker/1:1-1212 [001] .... 229.610252: rtcpu_vinotify_event: tstamp:7606893502 tag:FE channel:0x00 frame:1 vi_tstamp:7606866601 data:0x00000020
kworker/1:1-1212 [001] .... 229.610279: rtcpu_vinotify_event: tstamp:7606893662 tag:FS channel:0x00 frame:1 vi_tstamp:7606886993 data:0x00000010
kworker/1:1-1212 [001] .... 229.610280: rtcpu_vinotify_event: tstamp:7606893800 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7606887458 data:0x000003c9
kworker/1:1-1212 [001] .... 229.610282: rtcpu_vinotify_error: tstamp:7607411620 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7607408815 data:0x000003c9
kworker/1:1-1212 [001] .... 229.610283: rtcpu_vinotify_event: tstamp:7607435238 tag:FE channel:0x00 frame:1 vi_tstamp:7607387958 data:0x00000020
kworker/1:1-1212 [001] .... 229.610284: rtcpu_vinotify_event: tstamp:7607435375 tag:FS channel:0x00 frame:1 vi_tstamp:7607408349 data:0x00000010
kworker/1:1-1212 [001] .... 229.610285: rtcpu_vinotify_event: tstamp:7607435532 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7607408815 data:0x000003c9
kworker/1:1-1212 [001] .... 229.610287: rtcpu_vinotify_error: tstamp:7607932974 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7607930172 data:0x000003c9
kworker/1:1-1212 [001] .... 229.610288: rtcpu_vinotify_event: tstamp:7607977891 tag:FE channel:0x00 frame:1 vi_tstamp:7607909315 data:0x00000020
kworker/1:1-1212 [001] .... 229.610289: rtcpu_vinotify_event: tstamp:7607978045 tag:FS channel:0x00 frame:1 vi_tstamp:7607929706 data:0x00000010
kworker/1:1-1212 [001] .... 229.610291: rtcpu_vinotify_event: tstamp:7607978181 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7607930172 data:0x000003c9
kworker/1:1-1212 [001] .... 229.666274: rtcpu_vinotify_error: tstamp:7608454338 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7608451528 data:0x000003c9
kworker/1:1-1212 [001] .... 229.666279: rtcpu_vinotify_event: tstamp:7608520545 tag:FE channel:0x00 frame:1 vi_tstamp:7608430672 data:0x00000020
kworker/1:1-1212 [001] .... 229.666280: rtcpu_vinotify_event: tstamp:7608520681 tag:FS channel:0x00 frame:1 vi_tstamp:7608451063 data:0x00000010
kworker/1:1-1212 [001] .... 229.666282: rtcpu_vinotify_event: tstamp:7608520840 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7608451528 data:0x000003c9
kworker/1:1-1212 [001] .... 229.666283: rtcpu_vinotify_error: tstamp:7608975825 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7608972885 data:0x000003c9
kworker/1:1-1212 [001] .... 229.666284: rtcpu_vinotify_event: tstamp:7608976226 tag:FE channel:0x00 frame:1 vi_tstamp:7608952029 data:0x00000020
kworker/1:1-1212 [001] .... 229.666286: rtcpu_vinotify_event: tstamp:7608976382 tag:FS channel:0x00 frame:1 vi_tstamp:7608972419 data:0x00000010
kworker/1:1-1212 [001] .... 229.666287: rtcpu_vinotify_event: tstamp:7608976519 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7608972885 data:0x000003c9
kworker/1:1-1212 [001] .... 229.666288: rtcpu_vinotify_error: tstamp:7609497049 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7609494242 data:0x000003c9
kworker/1:1-1212 [001] .... 229.666289: rtcpu_vinotify_event: tstamp:7609499564 tag:FE channel:0x00 frame:1 vi_tstamp:7609473385 data:0x00000020
kworker/1:1-1212 [001] .... 229.666291: rtcpu_vinotify_event: tstamp:7609499701 tag:FS channel:0x00 frame:1 vi_tstamp:7609493776 data:0x00000010
kworker/1:1-1212 [001] .... 229.666292: rtcpu_vinotify_event: tstamp:7609499858 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7609494242 data:0x000003c9
kworker/1:1-1212 [001] .... 229.666295: rtos_queue_peek_from_isr_failed: tstamp:7609834394 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 229.722267: rtcpu_vinotify_error: tstamp:7610018406 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7610015599 data:0x000003c9
kworker/1:1-1212 [001] .... 229.722270: rtcpu_vinotify_event: tstamp:7610039876 tag:FE channel:0x00 frame:1 vi_tstamp:7609994741 data:0x00000020
kworker/1:1-1212 [001] .... 229.722271: rtcpu_vinotify_event: tstamp:7610040038 tag:FS channel:0x00 frame:1 vi_tstamp:7610015133 data:0x00000010
kworker/1:1-1212 [001] .... 229.722273: rtcpu_vinotify_event: tstamp:7610040177 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7610015599 data:0x000003c9
kworker/1:1-1212 [001] .... 229.722274: rtcpu_vinotify_error: tstamp:7610539759 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7610536955 data:0x000003c9
kworker/1:1-1212 [001] .... 229.722275: rtcpu_vinotify_event: tstamp:7610581754 tag:FE channel:0x00 frame:1 vi_tstamp:7610516098 data:0x00000020
kworker/1:1-1212 [001] .... 229.722277: rtcpu_vinotify_event: tstamp:7610581890 tag:FS channel:0x00 frame:1 vi_tstamp:7610536489 data:0x00000010
kworker/1:1-1212 [001] .... 229.722278: rtcpu_vinotify_event: tstamp:7610582045 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7610536955 data:0x000003c9
kworker/1:1-1212 [001] .... 229.722279: rtcpu_vinotify_error: tstamp:7611061116 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7611058312 data:0x000003c9
kworker/1:1-1212 [001] .... 229.722281: rtcpu_vinotify_event: tstamp:7611124412 tag:FE channel:0x00 frame:1 vi_tstamp:7611037454 data:0x00000020
kworker/1:1-1212 [001] .... 229.722282: rtcpu_vinotify_event: tstamp:7611124566 tag:FS channel:0x00 frame:1 vi_tstamp:7611057846 data:0x00000010
kworker/1:1-1212 [001] .... 229.722283: rtcpu_vinotify_event: tstamp:7611124702 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7611058312 data:0x000003c9
kworker/1:1-1212 [001] .... 229.722284: rtcpu_vinotify_error: tstamp:7611582472 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7611579669 data:0x000003c9
kworker/1:1-1212 [001] .... 229.722286: rtcpu_vinotify_event: tstamp:7611667066 tag:FE channel:0x00 frame:1 vi_tstamp:7611558811 data:0x00000020
kworker/1:1-1212 [001] .... 229.722287: rtcpu_vinotify_event: tstamp:7611667202 tag:FS channel:0x00 frame:1 vi_tstamp:7611579202 data:0x00000010
kworker/1:1-1212 [001] .... 229.722288: rtcpu_vinotify_event: tstamp:7611667359 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7611579669 data:0x000003c9
kworker/1:1-1212 [001] .... 229.778256: rtcpu_vinotify_event: tstamp:7612082586 tag:FE channel:0x00 frame:1 vi_tstamp:7612080168 data:0x00000020
kworker/1:1-1212 [001] .... 229.778259: rtcpu_vinotify_error: tstamp:7612103819 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7612101025 data:0x000003c9
kworker/1:1-1212 [001] .... 229.778261: rtcpu_vinotify_event: tstamp:7612589208 tag:FS channel:0x00 frame:1 vi_tstamp:7612100559 data:0x00000010
kworker/1:1-1212 [001] .... 229.778262: rtcpu_vinotify_event: tstamp:7612589347 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7612101025 data:0x000003c9
kworker/1:1-1212 [001] .... 229.778264: rtcpu_vinotify_error: tstamp:7612625186 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7612622381 data:0x000003c9
kworker/1:1-1212 [001] .... 229.778265: rtcpu_vinotify_event: tstamp:7613131972 tag:FE channel:0x00 frame:1 vi_tstamp:7612601525 data:0x00000020
kworker/1:1-1212 [001] .... 229.778266: rtcpu_vinotify_event: tstamp:7613132110 tag:FS channel:0x00 frame:1 vi_tstamp:7612621916 data:0x00000010
kworker/1:1-1212 [001] .... 229.778268: rtcpu_vinotify_event: tstamp:7613132267 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7612622381 data:0x000003c9
kworker/1:1-1212 [001] .... 229.778269: rtcpu_vinotify_event: tstamp:7613132402 tag:FE channel:0x00 frame:1 vi_tstamp:7613122882 data:0x00000020
kworker/1:1-1212 [001] .... 229.778270: rtcpu_vinotify_error: tstamp:7613146545 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7613143738 data:0x000003c9
kworker/1:1-1212 [001] .... 229.834249: rtcpu_vinotify_error: tstamp:7613667900 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7613665094 data:0x000003c9
kworker/1:1-1212 [001] .... 229.834251: rtcpu_vinotify_event: tstamp:7613674902 tag:FS channel:0x00 frame:1 vi_tstamp:7613143272 data:0x00000010
kworker/1:1-1212 [001] .... 229.834252: rtcpu_vinotify_event: tstamp:7613675040 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7613143738 data:0x000003c9
kworker/1:1-1212 [001] .... 229.834254: rtcpu_vinotify_event: tstamp:7613675199 tag:FE channel:0x00 frame:1 vi_tstamp:7613644238 data:0x00000020
kworker/1:1-1212 [001] .... 229.834255: rtcpu_vinotify_event: tstamp:7613675334 tag:FS channel:0x00 frame:1 vi_tstamp:7613664630 data:0x00000010
kworker/1:1-1212 [001] .... 229.834257: rtcpu_vinotify_event: tstamp:7613675491 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7613665094 data:0x000003c9
kworker/1:1-1212 [001] .... 229.834258: rtcpu_vinotify_error: tstamp:7614189256 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7614186451 data:0x000003c9
kworker/1:1-1212 [001] .... 229.834259: rtcpu_vinotify_event: tstamp:7614216773 tag:FE channel:0x00 frame:1 vi_tstamp:7614165595 data:0x00000020
kworker/1:1-1212 [001] .... 229.834260: rtcpu_vinotify_event: tstamp:7614216929 tag:FS channel:0x00 frame:1 vi_tstamp:7614185986 data:0x00000010
kworker/1:1-1212 [001] .... 229.834262: rtcpu_vinotify_event: tstamp:7614217065 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7614186451 data:0x000003c9
kworker/1:1-1212 [001] .... 229.834263: rtcpu_vinotify_event: tstamp:7614710948 tag:FE channel:0x00 frame:1 vi_tstamp:7614686951 data:0x00000020
kworker/1:1-1212 [001] .... 229.834264: rtcpu_vinotify_event: tstamp:7614711086 tag:FS channel:0x00 frame:1 vi_tstamp:7614707343 data:0x00000010
kworker/1:1-1212 [001] .... 229.834266: rtcpu_vinotify_error: tstamp:7614712148 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7614707808 data:0x000003c9
kworker/1:1-1212 [001] .... 229.834268: rtos_queue_peek_from_isr_failed: tstamp:7614834395 queue:0x0bcbbbb8
kworker/1:1-1212 [001] .... 229.890262: rtcpu_vinotify_error: tstamp:7615231973 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7615229165 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890265: rtcpu_vinotify_event: tstamp:7615248159 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7614707808 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890267: rtcpu_vinotify_event: tstamp:7615248301 tag:FE channel:0x00 frame:1 vi_tstamp:7615208308 data:0x00000020
kworker/1:1-1212 [001] .... 229.890268: rtcpu_vinotify_event: tstamp:7615248460 tag:FS channel:0x00 frame:1 vi_tstamp:7615228699 data:0x00000010
kworker/1:1-1212 [001] .... 229.890270: rtcpu_vinotify_event: tstamp:7615248598 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7615229165 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890271: rtcpu_vinotify_error: tstamp:7615753327 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7615750522 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890272: rtcpu_vinotify_event: tstamp:7615790811 tag:FE channel:0x00 frame:1 vi_tstamp:7615729665 data:0x00000020
kworker/1:1-1212 [001] .... 229.890274: rtcpu_vinotify_event: tstamp:7615790947 tag:FS channel:0x00 frame:1 vi_tstamp:7615750056 data:0x00000010
kworker/1:1-1212 [001] .... 229.890275: rtcpu_vinotify_event: tstamp:7615791104 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7615750522 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890276: rtcpu_vinotify_error: tstamp:7616274680 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7616271877 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890277: rtcpu_vinotify_event: tstamp:7616332680 tag:FE channel:0x00 frame:1 vi_tstamp:7616251021 data:0x00000020
kworker/1:1-1212 [001] .... 229.890279: rtcpu_vinotify_event: tstamp:7616332835 tag:FS channel:0x00 frame:1 vi_tstamp:7616271413 data:0x00000010
kworker/1:1-1212 [001] .... 229.890280: rtcpu_vinotify_event: tstamp:7616332970 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7616271877 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890281: rtcpu_vinotify_error: tstamp:7616796078 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7616793234 data:0x000003c9
kworker/1:1-1212 [001] .... 229.890284: rtcpu_vinotify_event: tstamp:7616875335 tag:FE channel:0x00 frame:1 vi_tstamp:7616772378 data:0x00000020
kworker/1:1-1212 [001] .... 229.890285: rtcpu_vinotify_event: tstamp:7616875471 tag:FS channel:0x00 frame:1 vi_tstamp:7616792769 data:0x00000010
kworker/1:1-1212 [001] .... 229.890286: rtcpu_vinotify_event: tstamp:7616875628 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7616793234 data:0x000003c9
kworker/1:1-1212 [001] .... 229.946258: rtcpu_vinotify_error: tstamp:7617317533 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7617314591 data:0x000003c9
kworker/1:1-1212 [001] .... 229.946261: rtcpu_vinotify_event: tstamp:7617317925 tag:FE channel:0x00 frame:1 vi_tstamp:7617293734 data:0x00000020
kworker/1:1-1212 [001] .... 229.946263: rtcpu_vinotify_event: tstamp:7617318084 tag:FS channel:0x00 frame:1 vi_tstamp:7617314126 data:0x00000010
kworker/1:1-1212 [001] .... 229.946264: rtcpu_vinotify_event: tstamp:7617318223 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7617314591 data:0x000003c9
kworker/1:1-1212 [001] .... 229.946266: rtcpu_vinotify_error: tstamp:7617838753 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7617835948 data:0x000003c9
kworker/1:1-1212 [001] .... 229.946267: rtcpu_vinotify_event: tstamp:7617852013 tag:FE channel:0x00 frame:1 vi_tstamp:7617815091 data:0x00000020
kworker/1:1-1212 [001] .... 229.946268: rtcpu_vinotify_event: tstamp:7617852166 tag:FS channel:0x00 frame:1 vi_tstamp:7617835482 data:0x00000010
kworker/1:1-1212 [001] .... 229.946270: rtcpu_vinotify_event: tstamp:7617852322 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7617835948 data:0x000003c9
kworker/1:1-1212 [001] .... 229.946271: rtcpu_vinotify_error: tstamp:7618360163 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7618357305 data:0x000003c9
kworker/1:1-1212 [001] .... 229.946272: rtcpu_vinotify_event: tstamp:7618394663 tag:FE channel:0x00 frame:1 vi_tstamp:7618336448 data:0x00000020
kworker/1:1-1212 [001] .... 229.946273: rtcpu_vinotify_event: tstamp:7618394819 tag:FS channel:0x00 frame:1 vi_tstamp:7618356839 data:0x00000010
kworker/1:1-1212 [001] .... 229.946275: rtcpu_vinotify_event: tstamp:7618394955 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:7618357305 data:0x000003c9
root@k-desktop:/home/k#
Did you try embedded_metadata_height as 2, 3, 4
Yes, I have just tried all of that but still get the same errors…
OK, maybe the port-index in device tree incorrect as HW connection.
I am using the Xavier NX Dev Kit and connected my device through CSI 0, 2 lanes.
My device is a HDMI to MIPI/CSI chip.
- Input = HDMI RGB888 (so, I set - dynamic_pixel_bit_depth = “24”)
- Output = YUV422 8bit (so, I set - csi_pixel_bit_depth = “16”;)
Here is my device tree file.
Can you take a look and give me some advice please?
#include <dt-bindings/media/camera.h>
#define CAM0_PWDN TEGRA194_MAIN_GPIO(P, 4)
#define CAM1_PWDN TEGRA194_MAIN_GPIO(P, 5)
#define CAM_I2C_MUX TEGRA194_AON_GPIO(CC, 3)
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_lt6911uxc_vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_lt6911uxc_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_lt6911uxc_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_lt6911uxc_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_lt6911uxc_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&rbpcv2_lt6911uxc_vi_in0>;
cam_i2cmux{
compatible = "i2c-mux-gpio";
#size-cells = <0>;
i2c-parent = <&cam_i2c>;
mux-gpios = <&tegra_aon_gpio CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
i2c@0 {
reg = <0>;
#size-cells = <0>;
rbpcv2_lt6911uxc_a@2b {
compatible = "nvidia,lt6911uxc";
reg = <0x2b>;
reset-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
//avdd-reg = "vana";
//iovdd-reg = "vif";
//dvdd-reg = "vdig";
//vcmvdd-reg = "vvcm";
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "lt6911uxc";
//set_mode_delay_ms = "150";
use_sensor_mode_id = "false";
status = "okay";
mode0 {
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "yes";
cil_settletime = "0";
dpcm_enable = "false";
active_w = "1920";
active_h = "1080";
mode_type = "yuv";
readout_orientation = "0";
csi_pixel_bit_depth = "16";
dynamic_pixel_bit_depth = "24";
pixel_phase = "yuyv";
line_length = "2200";
// mclk_multiplier = "6";
pix_clk_hz = "148500000";
inherent_gain = "1";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "60000000"; /* 60.0 fps */
step_framerate = "1";
default_framerate = "60000000"; /* 60.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "16667"; /* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_lt6911uxc_out0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_lt6911uxc_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
//status = "okay";
badge = "jakku_front_LT6911UXC";
position = "front";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "lt6911uxc 9-002b";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/rbpcv2_lt6911uxc_a@2b";
Maybe connect to another port to try.
Okay I will try that and let you know.
Otherwise, will this be problem?
If I execute v4l2-compliance
command, I get two errors.
I think I can ignore this error '... ret && node -> has_frmintervals'
However, about the duplicate format 56595559 (YUYV) error, does this can be a problem?
I have some output and let you know.
I tried the another port as you said and modified some DTS files.
And I tried to capture the image and save it as .rgb file as below.
(Before I saved it as jpeg but get the result.)
v4l2-ctl --device /dev/video1 --set-fmt-video=width=1920,height=1080,pixelformat=YUYV --stream-mmap --stream-count=5 --stream-to=video.rgb
and I converted the .rgb file as .png file as below.
ffmpeg -s 1920x1080 -pix_fmt rgb565le -i video.rgb -f image2 -pix_fmt rgb video.png
As a result, I can get some image like this.
As you can see it is not a complete image.
Do you have any idea about this image?
Will there be a problem during converting YUV to RGB to PNG?
Thanks,
It could be the YUYV order cause it. Have try UYVY or any others.
Okay,
I think I have four options : uyvy vyuy yuyv yvyu.
Do I only change 'pixel_phase = " ";'
in the device tree file?
Any other things I have to change? like csi_pixel_bit_depth
, or mode_type
You can use tools like 7-yuv to read the video.rgb and change the order configure to check the result.
I will try by using 7-yuv tool.
Thank you for your help.
