I am not able to receive valid frames, could you please help track down what is wrong with my code/setup?
I am using Jetpack 5.1.1 with my own driver for the imx728
Clocks are already boosted
v4l2-ctl --device /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'RG12' (12-bit Bayer RGRG/GBGB)
Size: Discrete 3856x2176
Interval: Discrete 0.028s (36.000 fps)
sudo v4l2-ctl -d /dev/video0 --set-fmt-video=width=3856,height=2176,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=300
root@contiorin-desktop:/home/contiorin# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 1664/1664 #P:8
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-2545 [004] .... 234.029279: tegra_channel_open: vi-output, imx728 2-001a
v4l2-ctl-2545 [004] .... 234.054091: tegra_channel_set_power: imx728 2-001a : 0x1
v4l2-ctl-2545 [004] .... 234.054110: camera_common_s_power: status : 0x1
v4l2-ctl-2545 [004] .... 234.054123: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2545 [004] .... 234.054127: csi_s_power: enable : 0x1
v4l2-ctl-2545 [004] .... 234.061270: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2176 fmt c4
v4l2-ctl-2545 [005] .... 234.070331: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-2545 [005] .... 234.072817: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2545 [005] .... 234.072821: csi_s_stream: enable : 0x1
kworker/2:2-217 [002] .... 234.073072: rtcpu_string: tstamp:8075818231 id:0x04010000 str:"VM0 activating."
v4l2-ctl-2545 [005] .... 234.073297: tegra_channel_set_stream: imx728 2-001a : 0x1
kworker/2:2-217 [002] .... 234.129061: rtcpu_vinotify_error: tstamp:8076040650 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:258433278848 data:0x0000000000000001
kworker/2:2-217 [002] .... 234.129064: rtcpu_nvcsi_intr: tstamp:8076257813 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129064: rtcpu_nvcsi_intr: tstamp:8076257813 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129065: rtcpu_vinotify_event: tstamp:8076265965 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258430323136 data:0x399d580010000000
kworker/2:2-217 [002] .... 234.129065: rtcpu_vinotify_event: tstamp:8076266101 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258430329600 data:0x0000000031000001
kworker/2:2-217 [002] .... 234.129066: rtcpu_vinotify_event: tstamp:8076266256 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258430369952 data:0x399d550010000000
kworker/2:2-217 [002] .... 234.129066: rtcpu_vinotify_event: tstamp:8076266389 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258430376512 data:0x0000000031000002
kworker/2:2-217 [002] .... 234.129066: rtcpu_vinotify_event: tstamp:8076266542 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:258433278848 data:0x0000000000000001
kworker/2:2-217 [002] .... 234.129066: rtcpu_nvcsi_intr: tstamp:8076568164 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129066: rtcpu_nvcsi_intr: tstamp:8076568164 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129067: rtcpu_vinotify_event: tstamp:8076942206 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:258460009184 data:0x0000000000000010
kworker/2:2-217 [002] .... 234.129067: rtcpu_vinotify_event: tstamp:8076942364 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:258460009216 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.129067: rtcpu_vinotify_event: tstamp:8076942499 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:258460031680 data:0x0000000000000001
kworker/2:2-217 [002] .... 234.129068: rtcpu_vinotify_event: tstamp:8076942652 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258460033216 data:0x0000000008020001
kworker/2:2-217 [002] .... 234.129068: rtcpu_nvcsi_intr: tstamp:8077191751 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129068: rtcpu_nvcsi_intr: tstamp:8077191751 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129068: rtcpu_nvcsi_intr: tstamp:8077350718 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129068: rtcpu_nvcsi_intr: tstamp:8077350718 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129069: rtcpu_nvcsi_intr: tstamp:8077410331 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129069: rtcpu_nvcsi_intr: tstamp:8077410331 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129069: rtcpu_nvcsi_intr: tstamp:8077459468 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129069: rtcpu_nvcsi_intr: tstamp:8077459468 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.129069: rtcpu_vinotify_error: tstamp:8077671952 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258485476800 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.129070: rtcpu_vinotify_event: tstamp:8077672432 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:258485187104 data:0x00000000087f0002
kworker/2:2-217 [002] .... 234.129070: rtcpu_vinotify_event: tstamp:8077672586 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:258485187744 data:0x0000000000000000
kworker/2:2-217 [002] .... 234.129070: rtcpu_vinotify_event: tstamp:8077672717 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258485190208 data:0x0000000002020001
kworker/2:2-217 [002] .... 234.129070: rtcpu_vinotify_event: tstamp:8077672866 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:258485189088 data:0x0000000008800040
kworker/2:2-217 [002] .... 234.129070: rtcpu_vinotify_event: tstamp:8077672997 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258485197760 data:0x0000000001020001
kworker/2:2-217 [002] .... 234.129070: rtcpu_vinotify_event: tstamp:8077673145 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258485476800 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.129071: rtcpu_vinotify_event: tstamp:8077673280 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:258485476800 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.185061: rtcpu_vinotify_event: tstamp:8077990314 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258485505760 data:0x399d580010000000
kworker/2:2-217 [002] .... 234.185063: rtcpu_vinotify_event: tstamp:8077990454 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258485512320 data:0x0000000031000003
kworker/2:2-217 [002] .... 234.185064: rtcpu_vinotify_event: tstamp:8077990611 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:258487756384 data:0x0000000000000010
kworker/2:2-217 [002] .... 234.185065: rtcpu_vinotify_event: tstamp:8077990750 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:258487756384 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.185065: rtcpu_vinotify_event: tstamp:8077990908 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:258487778848 data:0x0000000000000001
kworker/2:2-217 [002] .... 234.185066: rtcpu_vinotify_event: tstamp:8077991043 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258487780384 data:0x0000000008020002
kworker/2:2-217 [002] .... 234.185067: rtcpu_nvcsi_intr: tstamp:8078046567 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185068: rtcpu_nvcsi_intr: tstamp:8078046567 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185069: rtcpu_nvcsi_intr: tstamp:8078160733 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185070: rtcpu_nvcsi_intr: tstamp:8078160733 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185071: rtcpu_nvcsi_intr: tstamp:8078406052 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185071: rtcpu_nvcsi_intr: tstamp:8078406052 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185072: rtcpu_vinotify_error: tstamp:8078538999 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258513224000 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.185073: rtcpu_vinotify_event: tstamp:8078610113 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:258512934304 data:0x00000000087f0002
kworker/2:2-217 [002] .... 234.185074: rtcpu_vinotify_event: tstamp:8078610249 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:258512934880 data:0x0000000000000000
kworker/2:2-217 [002] .... 234.185075: rtcpu_vinotify_event: tstamp:8078611442 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258512937600 data:0x0000000002020002
kworker/2:2-217 [002] .... 234.185076: rtcpu_vinotify_event: tstamp:8078611577 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:258512936224 data:0x0000000008800040
kworker/2:2-217 [002] .... 234.185076: rtcpu_vinotify_event: tstamp:8078611728 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258512944832 data:0x0000000001020002
kworker/2:2-217 [002] .... 234.185077: rtcpu_vinotify_event: tstamp:8078611857 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258513224000 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.185078: rtcpu_vinotify_event: tstamp:8078612009 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:258513224032 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.185078: rtcpu_vinotify_event: tstamp:8078612139 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258513249696 data:0x399d550010000000
kworker/2:2-217 [002] .... 234.185079: rtcpu_vinotify_event: tstamp:8078612289 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:258513256256 data:0x0000000031000004
kworker/2:2-217 [002] .... 234.185080: rtcpu_vinotify_event: tstamp:8078612419 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:258515503520 data:0x0000000000000010
kworker/2:2-217 [002] .... 234.185081: rtcpu_nvcsi_intr: tstamp:8078756863 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185081: rtcpu_nvcsi_intr: tstamp:8078756863 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.185082: rtcpu_vinotify_event: tstamp:8078936887 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:258515503520 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.185083: rtcpu_vinotify_event: tstamp:8078937018 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:258515525952 data:0x0000000000000001
kworker/2:2-217 [002] .... 234.185084: rtcpu_vinotify_event: tstamp:8078937170 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258515527456 data:0x0000000008020003
kworker/2:2-217 [002] .... 234.185084: rtcpu_vinotify_error: tstamp:8079406091 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258540971104 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.241069: rtcpu_nvcsi_intr: tstamp:8079558928 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241072: rtcpu_nvcsi_intr: tstamp:8079558928 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241075: rtcpu_vinotify_event: tstamp:8079613155 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:258540681472 data:0x00000000087f0002
kworker/2:2-217 [002] .... 234.241076: rtcpu_vinotify_event: tstamp:8079613311 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:258540682048 data:0x0000000000000000
kworker/2:2-217 [002] .... 234.241076: rtcpu_vinotify_event: tstamp:8079613446 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258540684512 data:0x0000000002020003
kworker/2:2-217 [002] .... 234.241077: rtcpu_vinotify_event: tstamp:8079613601 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:258540683456 data:0x0000000008800040
kworker/2:2-217 [002] .... 234.241078: rtcpu_vinotify_event: tstamp:8079613736 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258540692096 data:0x0000000001020003
kworker/2:2-217 [002] .... 234.241078: rtcpu_vinotify_event: tstamp:8079613891 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258540971104 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.241079: rtcpu_vinotify_event: tstamp:8079614028 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:258540971104 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.241080: rtcpu_vinotify_event: tstamp:8079614181 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:258543250656 data:0x0000000000000010
kworker/2:2-217 [002] .... 234.241080: rtcpu_vinotify_event: tstamp:8079614317 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:258543250656 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.241081: rtcpu_vinotify_event: tstamp:8079614470 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:258543273152 data:0x0000000000000001
kworker/2:2-217 [002] .... 234.241081: rtcpu_vinotify_event: tstamp:8079614604 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258543274720 data:0x0000000008020004
kworker/2:2-217 [002] .... 234.241082: rtcpu_nvcsi_intr: tstamp:8080206362 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241082: rtcpu_nvcsi_intr: tstamp:8080206362 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241083: rtcpu_vinotify_event: tstamp:8080265501 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:258568428576 data:0x00000000087f0002
kworker/2:2-217 [002] .... 234.241083: rtcpu_vinotify_event: tstamp:8080265636 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:258568429152 data:0x0000000000000000
kworker/2:2-217 [002] .... 234.241086: rtcpu_vinotify_error: tstamp:8080273185 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258568718272 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.241086: rtcpu_vinotify_error: tstamp:8080345122 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:258571020256 data:0x0000000000000589
kworker/2:2-217 [002] .... 234.241086: rtcpu_vinotify_event: tstamp:8080593657 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258568432768 data:0x0000000002020004
kworker/2:2-217 [002] .... 234.241087: rtcpu_vinotify_event: tstamp:8080593788 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:258568430528 data:0x0000000008800040
kworker/2:2-217 [002] .... 234.241087: rtcpu_vinotify_event: tstamp:8080593938 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:258568440960 data:0x0000000001020004
kworker/2:2-217 [002] .... 234.241088: rtcpu_vinotify_event: tstamp:8080594068 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:258568718272 data:0x0000000000400060
kworker/2:2-217 [002] .... 234.241088: rtcpu_vinotify_event: tstamp:8080594221 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:258568718272 data:0x0000000800000000
kworker/2:2-217 [002] .... 234.241088: rtcpu_vinotify_event: tstamp:8080594348 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:258570997824 data:0x0000000000000010
kworker/2:2-217 [002] .... 234.241090: rtcpu_vinotify_event: tstamp:8080594497 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:258571020256 data:0x0000000000000589
kworker/2:2-217 [002] .... 234.241091: rtcpu_nvcsi_intr: tstamp:8080629797 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241092: rtcpu_nvcsi_intr: tstamp:8080629797 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241092: rtcpu_nvcsi_intr: tstamp:8080673875 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241092: rtcpu_nvcsi_intr: tstamp:8080673875 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241093: rtcpu_nvcsi_intr: tstamp:8080715060 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241093: rtcpu_nvcsi_intr: tstamp:8080715060 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241093: rtcpu_nvcsi_intr: tstamp:8080970493 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241094: rtcpu_nvcsi_intr: tstamp:8080970493 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241094: rtcpu_nvcsi_intr: tstamp:8081091165 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/2:2-217 [002] .... 234.241095: rtcpu_nvcsi_intr: tstamp:8081091165 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
hello daniel.kammerer,
please run a v4l2-compliance test for checking, you may see-also developer guide, Verifying the V4L2 Sensor Driver.
BTW,
according to the tracing logs as below.. this meant the packet payload CRC check has failed.
could you please examine your sensor driver configuration again.
hello JerryChang,
there are 2 fails in the compliance test, are they critical?
Compliance test for tegra-video device /dev/video0:
Driver Info:
Driver name : tegra-video
Card type : vi-output, imx728 2-001a
Bus info : platform:tegra-capture-vi:0
Driver version : 5.10.104
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.10.104
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, imx728 2-001a
Function : V4L2 I/O
Pad 0x01000007 : 0: Sink
Link 0x0200000c: from remote pad 0x1000003 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
Required ioctls:
test MC information (see 'Media Driver Info' above): OK
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second /dev/video0 open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Control ioctls (Input 0):
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 19
Format ioctls (Input 0):
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: v4l2-test-formats.cpp(1280): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls (Input 0):
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls (Input 0):
fail: v4l2-test-buffers.cpp(715): q.create_bufs(node, 1, &fmt) != EINVAL
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
test VIDIOC_EXPBUF: OK
test Requests: OK (Not Supported)
Total for tegra-video device /dev/video0: 45, Succeeded: 43, Failed: 2, Warnings: 0
for me the driver also looks correct, at least I don’t see any error
What parameter could cause a payload CRC to fail?
tegra-capture-vi {
num-channels = <1>;
status = "okay";
ports {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
status = "okay";
liimx728_vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&liimx728_csi_out0>;
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
status = "okay";
channel@0 {
reg = <0>;
status = "okay";
ports {
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
status = "okay";
liimx728_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&liimx728_imx728_out0>;
port@1 {
reg = <1>;
status = "okay";
liimx728_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&liimx728_vi_in0>;
i2c@3180000 {
status = "okay";
imx728_a@1a {
status = "okay";
compatible = "sony,imx728";
reg = <0x1a>;
devnode = "video0";
physical_w = "8.100";
physical_h = "4.572";
sensor_model = "imx728";
mode0 {
status = "okay";
mclk_khz = "25000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "3856";
active_h = "2176";
readout_orientation = "0";
line_length = "3856";
inherent_gain = "1";
/*mclk_multiplier = "2";*/
pix_clk_hz = "302063616";
serdes_pix_clk_hz = "500000000";
gain_factor = "10";
min_gain_val = "0"; /* 0dB */
max_gain_val = "480"; /* 48dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "30000000"; /* 1.5 */
max_framerate = "36000000"; /* 30 */
step_framerate = "1";
default_framerate= "36000000";
exposure_factor = "1000000";
min_exp_time = "34"; /* us */
max_exp_time = "550385"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
status = "okay";
liimx728_imx728_out0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&liimx728_csi_in0>;
tegra-camera-platform {
status = "okay";
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
status = "okay";
module0 {
status = "okay";
badge = "imx728_rear_liimx728";
position = "rear";
orientation = "0";
drivernode0 {
status = "okay";
pcl_id = "v4l2_sensor";
devname = "imx728 30-001a";
proc-device-tree = "/proc/device-tree/i2c@3180000/imx728_a@1a";
you may ignore VIDIOC_G/S_PARM test failure.
however, the test failure of VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF is unexpected.
these are basic buffer operation for VI driver to capture a frame.
FYI,
device tree settings only setup the port bindings, and given specific hardware settings to CSI configuration.
payload CRC failed may due to sensor configuration.
is this camera driver validate with previous Jetpack release versions?
you may see-also Camera Sensor Drivers Porting to examine your sensor driver.
hello JerryChang,
is it not normal? I just tried this example here and see the same fail and receive valid frames
“NVIDIA Jetson Orin - IMX477 J20”
The sensor configuration should be OK. I tried it with another tooling and it worked.
Could it also be due to a bad CSI2 connection between the camera and Orin (e.g. Noise), it is no longer the best connection cable?
No, it is not a port
it might be connection issue, could you please replace a known good connection cable to test again?
hello JerryChang,
sorry for the late reply, it took a bit longer to get a new cable.
With the new cable there are some improvements, the CSIMUX_FRAME error is gone but the CHANSEL_NOMATCH error is still there, do you have another tip for me?
# tracer: nop
# entries-in-buffer/entries-written: 278/278 #P:8
# _-----=> irqs-off
# ||| / delay
v4l2-ctl-2512 [000] .... 149.597773: tegra_channel_open: vi-output, imx728 2-001a
v4l2-ctl-2512 [000] .... 149.621014: tegra_channel_set_power: imx728 2-001a : 0x1
v4l2-ctl-2512 [000] .... 149.621024: camera_common_s_power: status : 0x1
v4l2-ctl-2512 [000] .... 149.621033: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2512 [000] .... 149.621034: csi_s_power: enable : 0x1
v4l2-ctl-2512 [000] .... 149.621554: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2176 fmt c4
v4l2-ctl-2512 [001] .... 149.627553: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-2512 [001] .... 149.629766: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2512 [001] .... 149.629768: csi_s_stream: enable : 0x1
v4l2-ctl-2512 [001] .... 149.630098: tegra_channel_set_stream: imx728 2-001a : 0x1
kworker/4:0-35 [004] .... 149.671483: rtcpu_string: tstamp:5561433400 id:0x04010000 str:"VM0 activating."
kworker/4:0-35 [004] .... 149.671486: rtcpu_vinotify_error: tstamp:5561631412 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:177972183648 data:0x0000000000000001
kworker/4:0-35 [004] .... 149.671488: rtcpu_vinotify_event: tstamp:5561877259 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:177969607168 data:0x399d580010000000
kworker/4:0-35 [004] .... 149.671488: rtcpu_vinotify_event: tstamp:5561877396 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:177969613632 data:0x0000000031000001
kworker/4:0-35 [004] .... 149.671489: rtcpu_vinotify_event: tstamp:5561877552 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:177969654016 data:0x399d550010000000
kworker/4:0-35 [004] .... 149.671489: rtcpu_vinotify_event: tstamp:5561877686 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:177969660576 data:0x0000000031000002
kworker/4:0-35 [004] .... 149.671490: rtcpu_vinotify_event: tstamp:5561877841 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:177972183648 data:0x0000000000000001
kworker/4:0-35 [004] .... 149.671491: rtcpu_vinotify_event: tstamp:5562215358 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:177989306528 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.671491: rtcpu_vinotify_event: tstamp:5562215519 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:177989306560 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.671492: rtcpu_vinotify_event: tstamp:5562215654 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:177989328960 data:0x0000000000000001
kworker/4:0-35 [004] .... 149.671492: rtcpu_vinotify_event: tstamp:5562215809 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:177989330528 data:0x0000000008020001
kworker/4:0-35 [004] .... 149.727487: rtcpu_vinotify_event: tstamp:5562962333 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:178014484288 data:0x00000000087f0002
kworker/4:0-35 [004] .... 149.727489: rtcpu_vinotify_event: tstamp:5562962490 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:178014484896 data:0x0000000000000000
kworker/4:0-35 [004] .... 149.727489: rtcpu_vinotify_event: tstamp:5562962623 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178014487360 data:0x0000000002020001
kworker/4:0-35 [004] .... 149.727489: rtcpu_vinotify_event: tstamp:5562962775 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:178014486304 data:0x0000000008800040
kworker/4:0-35 [004] .... 149.727490: rtcpu_vinotify_event: tstamp:5562962906 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178014494880 data:0x0000000001020001
kworker/4:0-35 [004] .... 149.727490: rtcpu_vinotify_event: tstamp:5562963055 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178014773984 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.727491: rtcpu_vinotify_event: tstamp:5562963190 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:178014773984 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.727491: rtcpu_vinotify_event: tstamp:5563297477 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178014800576 data:0x399d580010000000
kworker/4:0-35 [004] .... 149.727492: rtcpu_vinotify_event: tstamp:5563297609 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178014807168 data:0x0000000031000003
kworker/4:0-35 [004] .... 149.727492: rtcpu_vinotify_event: tstamp:5563297762 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178017053536 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.727493: rtcpu_vinotify_event: tstamp:5563297897 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:178017053568 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.727493: rtcpu_vinotify_event: tstamp:5563298049 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:178017076032 data:0x0000000000000001
kworker/4:0-35 [004] .... 149.727493: rtcpu_vinotify_event: tstamp:5563298185 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178017077536 data:0x0000000008020002
kworker/4:0-35 [004] .... 149.727494: rtcpu_vinotify_event: tstamp:5563900673 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:178042231360 data:0x00000000087f0002
kworker/4:0-35 [004] .... 149.727494: rtcpu_vinotify_event: tstamp:5563900809 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:178042231968 data:0x0000000000000000
kworker/4:0-35 [004] .... 149.727495: rtcpu_vinotify_event: tstamp:5563902024 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178042234656 data:0x0000000002020002
kworker/4:0-35 [004] .... 149.727495: rtcpu_vinotify_event: tstamp:5563902159 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:178042233312 data:0x0000000008800040
kworker/4:0-35 [004] .... 149.727495: rtcpu_vinotify_event: tstamp:5563902312 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178042241888 data:0x0000000001020002
kworker/4:0-35 [004] .... 149.727496: rtcpu_vinotify_event: tstamp:5563902443 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178042520992 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.727496: rtcpu_vinotify_event: tstamp:5563902600 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:178042520992 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.727496: rtcpu_vinotify_event: tstamp:5563902732 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178042534272 data:0x399d550010000000
kworker/4:0-35 [004] .... 149.727496: rtcpu_vinotify_event: tstamp:5563902884 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178042540800 data:0x0000000031000004
kworker/4:0-35 [004] .... 149.727497: rtcpu_vinotify_event: tstamp:5563903021 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178044800544 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.727497: rtcpu_vinotify_event: tstamp:5564210516 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:178044800544 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.727497: rtcpu_vinotify_event: tstamp:5564210655 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:178044823008 data:0x0000000000000001
kworker/4:0-35 [004] .... 149.727497: rtcpu_vinotify_event: tstamp:5564210809 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178044824544 data:0x0000000008020003
kworker/4:0-35 [004] .... 149.783482: rtcpu_vinotify_event: tstamp:5564886644 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:178069978336 data:0x00000000087f0002
kworker/4:0-35 [004] .... 149.783483: rtcpu_vinotify_event: tstamp:5564886805 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:178069978944 data:0x0000000000000000
kworker/4:0-35 [004] .... 149.783484: rtcpu_vinotify_event: tstamp:5564886943 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178069981408 data:0x0000000002020003
kworker/4:0-35 [004] .... 149.783484: rtcpu_vinotify_event: tstamp:5564887102 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:178069980320 data:0x0000000008800040
kworker/4:0-35 [004] .... 149.783484: rtcpu_vinotify_event: tstamp:5564887237 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178069988960 data:0x0000000001020003
kworker/4:0-35 [004] .... 149.783484: rtcpu_vinotify_event: tstamp:5564887391 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178070268000 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.783484: rtcpu_vinotify_event: tstamp:5564887529 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:178070268000 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.783485: rtcpu_vinotify_event: tstamp:5564887683 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178072547584 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.783485: rtcpu_vinotify_event: tstamp:5564887819 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:178072547616 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.783485: rtcpu_vinotify_event: tstamp:5564887975 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:178072570080 data:0x0000000000000001
kworker/4:0-35 [004] .... 149.783485: rtcpu_vinotify_event: tstamp:5564888108 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178072571616 data:0x0000000008020004
kworker/4:0-35 [004] .... 149.783485: rtcpu_vinotify_event: tstamp:5565555977 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:178097725376 data:0x00000000087f0002
kworker/4:0-35 [004] .... 149.783486: rtcpu_vinotify_event: tstamp:5565556114 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:178097726016 data:0x0000000000000000
kworker/4:0-35 [004] .... 149.783487: rtcpu_vinotify_error: tstamp:5565635651 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178100317056 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.783487: rtcpu_vinotify_event: tstamp:5565867285 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178097729824 data:0x0000000002020004
kworker/4:0-35 [004] .... 149.783487: rtcpu_vinotify_event: tstamp:5565867417 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:178097727296 data:0x0000000008800040
kworker/4:0-35 [004] .... 149.783487: rtcpu_vinotify_event: tstamp:5565867574 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:178097737696 data:0x0000000001020004
kworker/4:0-35 [004] .... 149.783488: rtcpu_vinotify_event: tstamp:5565867706 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178098015104 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.783488: rtcpu_vinotify_event: tstamp:5565867862 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:178098015104 data:0x0000000800000000
kworker/4:0-35 [004] .... 149.783488: rtcpu_vinotify_event: tstamp:5565868003 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178100294592 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.783488: rtcpu_vinotify_event: tstamp:5565868158 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178100317056 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.839482: rtcpu_vinotify_error: tstamp:5566502754 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178128064096 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.839483: rtcpu_vinotify_event: tstamp:5566543618 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178125762080 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.839484: rtcpu_vinotify_event: tstamp:5566543774 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178128041600 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.839484: rtcpu_vinotify_event: tstamp:5566543908 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178128064096 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.839484: rtcpu_vinotify_error: tstamp:5567369846 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178155811104 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.839484: rtcpu_vinotify_event: tstamp:5567558110 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178153509088 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.839485: rtcpu_vinotify_event: tstamp:5567558243 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178155788640 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.839485: rtcpu_vinotify_event: tstamp:5567558396 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178155811104 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.895486: rtcpu_vinotify_event: tstamp:5568234528 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178181256096 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.895486: rtcpu_vinotify_error: tstamp:5568236913 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178183558112 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.895486: rtcpu_vinotify_event: tstamp:5568237347 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178183535648 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.895487: rtcpu_vinotify_event: tstamp:5568237481 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178183558112 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.895487: rtcpu_vinotify_event: tstamp:5569046119 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178209003104 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.895487: rtcpu_vinotify_error: tstamp:5569104034 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178211305184 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.895488: rtcpu_vinotify_event: tstamp:5569384186 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178211282688 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.895488: rtcpu_vinotify_event: tstamp:5569384340 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178211305184 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.951480: rtcpu_vinotify_error: tstamp:5569971123 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178239052160 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.951481: rtcpu_vinotify_event: tstamp:5570060381 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178236750176 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.951481: rtcpu_vinotify_event: tstamp:5570060536 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178239029728 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.951482: rtcpu_vinotify_event: tstamp:5570060671 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178239052160 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.951482: rtcpu_vinotify_error: tstamp:5570838217 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178266799200 data:0x0000000000000589
kworker/4:0-35 [004] .... 149.951483: rtcpu_vinotify_event: tstamp:5571074727 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178264497152 data:0x0000000000000020
kworker/4:0-35 [004] .... 149.951483: rtcpu_vinotify_event: tstamp:5571074863 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178266776736 data:0x0000000000000010
kworker/4:0-35 [004] .... 149.951483: rtcpu_vinotify_event: tstamp:5571075022 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178266799200 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.007604: rtcpu_vinotify_error: tstamp:5571705322 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178294546176 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.007607: rtcpu_vinotify_event: tstamp:5571751000 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178292244192 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.007607: rtcpu_vinotify_event: tstamp:5571751154 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178294523744 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.007607: rtcpu_vinotify_event: tstamp:5571751289 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178294546176 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.007608: rtcpu_vinotify_error: tstamp:5572572403 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178322293216 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.007608: rtcpu_vinotify_event: tstamp:5572765350 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178319991232 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.007608: rtcpu_vinotify_event: tstamp:5572765485 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178322270784 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.007609: rtcpu_vinotify_event: tstamp:5572765642 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178322293216 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.007609: rtcpu_vinotify_event: tstamp:5573367377 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178347738208 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.063485: rtcpu_vinotify_error: tstamp:5573439498 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178350040288 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.063487: rtcpu_vinotify_event: tstamp:5573678417 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178350017760 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.063488: rtcpu_vinotify_event: tstamp:5573678551 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178350040288 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.063488: rtcpu_vinotify_error: tstamp:5574306599 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178377787264 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.063488: rtcpu_vinotify_event: tstamp:5574354773 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178375485280 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.063488: rtcpu_vinotify_event: tstamp:5574354907 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178377764800 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.063489: rtcpu_vinotify_event: tstamp:5574355061 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178377787264 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.063489: rtcpu_vinotify_error: tstamp:5575173688 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178405534304 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.119610: rtcpu_vinotify_event: tstamp:5575369318 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178403232256 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.119612: rtcpu_vinotify_event: tstamp:5575369476 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178405511840 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.119612: rtcpu_vinotify_event: tstamp:5575369611 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178405534304 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.119613: rtcpu_vinotify_error: tstamp:5576040782 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178433281312 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.119613: rtcpu_vinotify_event: tstamp:5576045702 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178430979296 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.119614: rtcpu_vinotify_event: tstamp:5576045843 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178433258848 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.119614: rtcpu_vinotify_event: tstamp:5576045997 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178433281312 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.119615: rtcpu_vinotify_error: tstamp:5576907884 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178461028320 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.175480: rtcpu_vinotify_event: tstamp:5577060225 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178458726304 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.175481: rtcpu_vinotify_event: tstamp:5577060379 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178461005856 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.175482: rtcpu_vinotify_event: tstamp:5577060511 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178461028320 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.175482: rtcpu_vinotify_event: tstamp:5577736494 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178486473344 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.175483: rtcpu_vinotify_event: tstamp:5577774080 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178488752864 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.175484: rtcpu_vinotify_error: tstamp:5577774972 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178488775392 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.175484: rtcpu_vinotify_event: tstamp:5578108541 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178488775392 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.175484: rtcpu_vinotify_error: tstamp:5578642063 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178516522368 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.231487: rtcpu_vinotify_event: tstamp:5578784785 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178514220352 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.231488: rtcpu_vinotify_event: tstamp:5578784939 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178516499904 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.231489: rtcpu_vinotify_event: tstamp:5578785074 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178516522368 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.231489: rtcpu_vinotify_event: tstamp:5579460925 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178541967360 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.231491: rtcpu_vinotify_error: tstamp:5579509168 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178544269408 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.231491: rtcpu_vinotify_event: tstamp:5579799141 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178544246944 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.231492: rtcpu_vinotify_event: tstamp:5579799292 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178544269408 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.231492: rtcpu_vinotify_error: tstamp:5580376280 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178572016416 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.287672: rtcpu_vinotify_event: tstamp:5580475363 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178569714432 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.287673: rtcpu_vinotify_event: tstamp:5580475515 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178571993984 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.287673: rtcpu_vinotify_event: tstamp:5580475646 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178572016416 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.287675: rtcpu_vinotify_error: tstamp:5581243348 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178599763456 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.287675: rtcpu_vinotify_event: tstamp:5581489782 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178597461408 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.287676: rtcpu_vinotify_event: tstamp:5581489913 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178599740960 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.287676: rtcpu_vinotify_event: tstamp:5581490065 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178599763456 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.287677: rtcpu_vinotify_error: tstamp:5582110431 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178627510464 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.287677: rtcpu_vinotify_event: tstamp:5582110868 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178625208448 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.287677: rtcpu_vinotify_event: tstamp:5582111018 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178627488000 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.287678: rtcpu_vinotify_event: tstamp:5582111149 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178627510464 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.343490: rtcpu_vinotify_event: tstamp:5582909847 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178652955488 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.343493: rtcpu_vinotify_error: tstamp:5582977540 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178655257472 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.343493: rtcpu_vinotify_event: tstamp:5583247950 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178655235008 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.343494: rtcpu_vinotify_event: tstamp:5583248103 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178655257472 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.343494: rtcpu_vinotify_error: tstamp:5583844632 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178683004544 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.343494: rtcpu_vinotify_event: tstamp:5583924305 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178680702464 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.343495: rtcpu_vinotify_event: tstamp:5583924458 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178682982016 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.343495: rtcpu_vinotify_event: tstamp:5583924589 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178683004544 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.399606: rtcpu_vinotify_error: tstamp:5584711731 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178710751488 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.399608: rtcpu_vinotify_event: tstamp:5584938535 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178708449504 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.399609: rtcpu_vinotify_event: tstamp:5584938669 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178710729088 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.399609: rtcpu_vinotify_event: tstamp:5584938824 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178710751488 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.399609: rtcpu_vinotify_error: tstamp:5585578820 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178738498560 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.399610: rtcpu_vinotify_event: tstamp:5585614899 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178736196512 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.399610: rtcpu_vinotify_event: tstamp:5585615048 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178738476064 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.399611: rtcpu_vinotify_event: tstamp:5585615179 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178738498560 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.455490: rtcpu_vinotify_error: tstamp:5586445914 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178766245568 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.455492: rtcpu_vinotify_event: tstamp:5586629253 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178763943552 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.455493: rtcpu_vinotify_event: tstamp:5586629388 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178766223104 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.455493: rtcpu_vinotify_event: tstamp:5586629542 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178766245568 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.455493: rtcpu_vinotify_event: tstamp:5587240883 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178791690592 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.455495: rtcpu_vinotify_error: tstamp:5587313015 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178793992576 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.511663: rtcpu_vinotify_event: tstamp:5587575833 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178793970144 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.511664: rtcpu_vinotify_event: tstamp:5587575965 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178793992576 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.511666: rtcpu_vinotify_error: tstamp:5588180101 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178821739616 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.511666: rtcpu_vinotify_event: tstamp:5588252062 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178819437600 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.511667: rtcpu_vinotify_event: tstamp:5588252194 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178821717120 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.511667: rtcpu_vinotify_event: tstamp:5588252347 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178821739616 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.511667: rtcpu_vinotify_error: tstamp:5589047194 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178849486592 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.567549: rtcpu_vinotify_event: tstamp:5589266521 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178847184608 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.567551: rtcpu_vinotify_event: tstamp:5589266674 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178849464160 data:0x0000000000000010
kworker/4:0-35 [004] .... 150.567551: rtcpu_vinotify_event: tstamp:5589266805 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178849486592 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.567553: rtcpu_vinotify_error: tstamp:5589914297 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:178877233664 data:0x0000000000000589
kworker/4:0-35 [004] .... 150.567553: rtcpu_vinotify_event: tstamp:5589942811 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:178874931616 data:0x0000000000000020
kworker/4:0-35 [004] .... 150.567554: rtcpu_vinotify_event: tstamp:5589942950 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:178877211200 data:0x0000000000000010
got it working now.
I looked at the wrong trace message
the relevant message was
“CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:178014486304 data:0x0000000008800040”
40 = PIXEL_RUNAWAY means VI receives more lines than expected
after increasing the height of the sensor resolution in the dtsi and mode_tbls.h it works
