I get 294 MB/sn Read, 82 MB/sn Write speed from eMMC of NX. Are these values normal? Anyone please share if you tested this.
Test result attached below. (MODE_15W_6CORE / max clock rate)
Thank you.
Have you try the performance mode?
sudo nvpmodel -m 3
sudo jetson_clocks
Thanks for the reply.
I would like to the remind that the module I use is the Jetson Xavier NX.
(not AGX Xavier)
I use nvpmodel -m 2 for max power mode. Ran these before test in #1:
sudo nvpmodel -m 2
sudo jetson_clocks
Tried with mode 3 result is the same pretty much:
Is this an expected result?
It would be perfect if a reference test shared here.
Can you post your output for sequential perf using iozone.
apt-get update
apt-get install iozone3
Run the following command to get perf for EMMC.
iozone -ecI -+n -L64 -S32 -s64m -r512k -i0 -i1 -l8 -u8 -m -t8 -F /mnt/file1 /mnt/file2 /mnt/file3 /mnt/file4 /mnt/file5 /mnt/file6 /mnt/file7 /mnt/file8
by the way, the numbers you have posted are sequential numbers and are expected perf numbers
