About mipi 2.5G
i have a camera sensor,when i set output data rate 2.5Gbps,will report error
[ 245.431834] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 84, flags: 0, err_data 4194400
[ 245.478504] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 85, flags: 0, err_data 4194400
[ 245.525388] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 86, flags: 0, err_data 4194400
[ 245.572273] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 87, flags: 0, err_data 4194400
but when i set output data rate 2.2Gbps,can receive normally
why did this situation occur
CPHY or DHPY?
What’s the trace log tell?
DHPY
 kworker/1:0-4197    [001] ....  5556.411246: rtcpu_vinotify_error: tstamp:174110927073 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51189 vi_tstamp:5571549561600 data:0x0000c7f500400060
 kworker/1:0-4197    [001] ....  5556.467372: rtcpu_vinotify_error: tstamp:174112391491 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51190 vi_tstamp:5571551138592 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.467372: rtcpu_vinotify_error: tstamp:174112392103 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51190 vi_tstamp:5571596446272 data:0x0000c7f600400060
 kworker/1:0-4197    [001] ....  5556.522968: rtcpu_vinotify_error: tstamp:174113856842 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51191 vi_tstamp:5571598023296 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.522968: rtcpu_vinotify_error: tstamp:174113857454 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51191 vi_tstamp:5571643330944 data:0x0000c7f700400060
 kworker/1:0-4197    [001] ....  5556.579046: rtcpu_vinotify_error: tstamp:174115322038 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51192 vi_tstamp:5571644908032 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.579046: rtcpu_vinotify_error: tstamp:174115322646 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51192 vi_tstamp:5571690215616 data:0x0000c7f800400060
 kworker/1:0-4197    [001] ....  5556.634890: rtcpu_vinotify_error: tstamp:174116786711 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51193 vi_tstamp:5571691792672 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.634890: rtcpu_vinotify_error: tstamp:174116787323 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51193 vi_tstamp:5571737100320 data:0x0000c7f900400060
 kworker/1:0-4197    [001] ....  5556.635565: rtcpu_vinotify_error: tstamp:174118252211 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51194 vi_tstamp:5571738677344 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.635565: rtcpu_vinotify_error: tstamp:174118252821 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51194 vi_tstamp:5571783984960 data:0x0000c7fa00400060
 kworker/1:0-4197    [001] ....  5556.691443: rtcpu_vinotify_error: tstamp:174119717502 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51195 vi_tstamp:5571785562048 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.691443: rtcpu_vinotify_error: tstamp:174119718113 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51195 vi_tstamp:5571830869664 data:0x0000c7fb00400060
 kworker/1:0-4197    [001] ....  5556.747313: rtcpu_vinotify_error: tstamp:174121182646 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51196 vi_tstamp:5571832446656 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.747313: rtcpu_vinotify_error: tstamp:174121183258 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51196 vi_tstamp:5571877754336 data:0x0000c7fc00400060
 kworker/1:0-4197    [001] ....  5556.803182: rtcpu_vinotify_error: tstamp:174122647816 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51197 vi_tstamp:5571879331392 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.803182: rtcpu_vinotify_error: tstamp:174122648427 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51197 vi_tstamp:5571924639040 data:0x0000c7fd00400060
 kworker/1:0-4197    [001] ....  5556.859057: rtcpu_vinotify_error: tstamp:174124112764 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51198 vi_tstamp:5571926216096 data:0x0000000000000589
 kworker/1:0-4197    [001] ....  5556.859058: rtcpu_vinotify_error: tstamp:174124113372 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:51198 vi_tstamp:5571971523712 data:0x0000c7fe00400060
 kworker/1:0-4197    [001] ....  5556.914907: rtcpu_vinotify_error: tstamp:174125577855 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:51199 vi_tstamp:5571973100768 data:0x0000000000000589
Did you boost the clocks to try?
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
i have already tried this command
but the phenomenon is still the same
do you have any other opinions,or is there any other information you need to know
