About nvargus-daemon crash issue
Hello, Nvidia
We are now experiencing a nvargus-ademon crash issue, which causes our camera image to freeze. Please help us analyze it! Here is the background:
Hardware model: orinNX P3767
L4T version: 35.6.0
Number of cameras: 6
Camera interface: mipi-csi
Camera software solution: camera driver->nvargus-daemon->gstreamer
Description of the phenomenon:
We took the camera stream when the product was in a static state, and took 6 streams to display on the screen at the same time.
10 devices were running together. After 12 hours, 3 of them had image stuck. After obtaining the log, it was found that the nvargus-daemon of the faulty device was abnormal. The system automatically restarted nvargus-daemon,
but our gstreamer did not restart, so the image was stuck.
Since we don’t have the source code of nvargus-daemon, we can’t investigate further. Please tell me the following:
  1. What is the reason for the crash of nvargus-daemon?
  2. Is this a software problem or a hardware problem?
  3. How to solve this problem?
The logs when crashing is as follows:
192.168.1.230
Jan 11 11:50:10 cart-ai nvargus-daemon[1493]: Module_id 30 Severity 2 : capture reset ioctl failed: 11
Jan 11 11:50:10 cart-ai nvargus-daemon[1493]: Module_id 30 Severity 2 : (fusa) Error: IoctlFailed ioctl failed in:/capture/src/fusaViChannelLinux.cpp 221
Jan 11 11:50:10 cart-ai nvargus-daemon[1493]: CAM: serial no file already exists, skips storing againSCF: Error IoctlFailed: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function abort(), line 717)
Jan 11 11:50:10 cart-ai nvargus-daemon[1493]: Module_id 30 Severity 2 : (fusa) Error: IoctlFailed propagating from:/capture/src/fusaViHandler.cpp 917
Jan 11 11:51:57 cart-ai systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=11/SEGV
Jan 11 11:51:57 cart-ai systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Jan 11 11:51:57 cart-ai systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 1.
Jan 11 11:51:57 cart-ai systemd[1]: Stopped Argus daemon.
Jan 11 11:51:57 cart-ai systemd[1]: Started Argus daemon.
192.168.1.173
Jan 12 02:03:07 cart-ai nvargus-daemon[25522]: CAM: serial no file already exists, skips storing againfree(): invalid pointer
Jan 12 02:03:09 cart-ai systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=6/ABRT
Jan 12 02:03:09 cart-ai systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Jan 12 02:03:09 cart-ai systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 2.
192.168.1.220
Jan 11 11:57:15 cart-ai nvargus-daemon[26800]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 426: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[16].Slope=0.0113056”
Jan 11 11:57:15 cart-ai nvargus-daemon[26800]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 427: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[17].X=1”
Jan 11 11:57:15 cart-ai nvargus-daemon[26800]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 428: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[17].Y=0.0619091”
Jan 11 11:57:15 cart-ai nvargus-daemon[26800]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 429: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[17].Slope=0.0109644”
Jan 12 02:33:54 cart-ai nvargus-daemon[26800]: CAM: serial no file already exists, skips storing again
Jan 12 02:33:56 cart-ai systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=11/SEGV
Jan 12 02:33:56 cart-ai systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Jan 12 02:33:56 cart-ai systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 2.
Jan 12 02:33:56 cart-ai systemd[1]: Stopped Argus daemon.
Jan 12 02:33:56 cart-ai systemd[1]: Started Argus daemon.
192.168.1.135
Jan 11 11:57:17 cart-ai nvargus-daemon[25991]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 426: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[16].Slope=0.0113056”
Jan 11 11:57:17 cart-ai nvargus-daemon[25991]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 427: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[17].X=1”
Jan 11 11:57:17 cart-ai nvargus-daemon[25991]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 428: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[17].Y=0.0619091”
Jan 11 11:57:17 cart-ai nvargus-daemon[25991]: NvCameraIspConfigFileLoad: type = 0xf5 Config file “camera_overrides.isp” Line 429: Error: Invalid isp config attribute: “badPixelCorrection.v5[0].Or2NoiseFunction[17].Slope=0.0109644”
Jan 11 12:43:45 cart-ai nvargus-daemon[25991]: CAM: serial no file already exists, skips storing again
Jan 11 12:43:46 cart-ai systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=11/SEGV
Jan 11 12:43:46 cart-ai systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Jan 11 12:43:46 cart-ai systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 2.
Jan 11 12:43:46 cart-ai systemd[1]: Stopped Argus daemon.
Jan 11 12:43:46 cart-ai systemd[1]: Started Argus daemon.
Apply the libs from below link to verify.
The L4T version we use is: 35.6.0.
Are you sure you can use the following so?
Have you encountered this issue?
OK, here’s for the r35.6
Could you explain this issue?
In addition, this so lib is for Jetson Xavier NX, can it be used on Jetson Orin NX?
They can apply to all Jeston device for stability issue.
In which directory of rootfs are these two so files located? How should I replace them?
Replace the /usr/lib/aarch64-linux-gnu/tegra/libnvargus.so and /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketserver.so by attached files.
