About usb port of jetson orin nano on jetpack 5.1.3
Through the article below, I was able to activate USB3.0 in jetpack 5.1.1.
However, dts has changed a lot in jetpack 5.1.3, so I don’t know how to fix it. Can you guide me?
Thank you.
Dts does not change a lot between jp5.1.1 and jp5.1.3… don’t know what you are talking about…
When I changed dtb to dts in jetpack5.1.3, it became as below. What value should I set for phandle when activating usb3-2?
usb3 {
                            lanes {
                                    usb3-0 {
                                            status = "okay";
                                            #phy-cells = <0x00>;
                                            nvidia,function = "xusb";
                                            phandle = <0x2bf>;
                                    usb3-1 {
                                            status = "okay";
                                            phandle = <0x2bc>;
                                    usb3-2 {
                                            status = "disabled";
                                    usb3-3 {
Attach dts
a.zip (54.6 KB)
Thank you.
I’m attaching dmesg from jetpack5.1.3.
dmesg_orin_nano_jp315_for_usb_check.txt (77.4 KB)
Thank you.
