jetson-io.py가 production module에서는 작동 안한다는 걸 알게되었습니다.
I found out that jetson-io.py doesn’t work in production module.
Does jetson-gpio also work in production module?
If so, what should I do to configure gpio in the production module?
Thank you.
hello neuezeal,
may I know what’s the actual use-case to configure GPIO for a production module?
This is the purpose of using a hardware device connected through gpio.
I tested audio.
Thank you.
hello neuezeal,
yes, you may still using Jetson-GPIO to configure GPIO pins.
thanks
You mean, Jetson-GPIO can also be used in production modules?
Thank you.
hello neuezeal,
you may refer to standard APIs to control GPIOs from kernel driver side.
for example,
$L4T_Sources/r32.4.3/Linux_for_Tegra/source/public/kernel/kernel-4.9/include/linux/gpio.h
static inline int gpio_get_value(unsigned int gpio)
return __gpio_get_value(gpio);
static inline void gpio_set_value(unsigned int gpio, int value)
__gpio_set_value(gpio, value);
there’s an example of IMX185 camera driver.
please refer to below kernel sources of the sensor driver to call these APIs for setting reset GPIO pin.
for example,
$L4T_Sources/r32.4.3/Linux_for_Tegra/source/public/kernel/nvidia/drivers/media/i2c/imx185.c
if (pw->reset_gpio)
gpio_set_value(pw->reset_gpio, 0);
