Hello everyone,
I’m having some trouoble using the GPIO of the Jetson Nano.
I’ve tried both python scripts and C++ scripts with absolutely no results.
I’ve found c++ scripts here: https://github.com/menghuanlee/jetsontx2gpio (i know those are for Jetson TX)
and python scripts from /usr/share/doc/jetson-gpio-common/samples
I’m used to work with Raspberry Pi’s GPIO so I know how to use pins, buttons etc.
I’ve recently swapped to Jetson for a project. I installed python 3.6 from pip and directly went for the simplest examples (simple_input.py) but it doesn’t read the value correctly.
Can someone help me? my doubt is: do I need some other configuration? some jumper to be closed or open?
thank you in advance
