Using GPIO on Jetson Orin Nano
I am interested in using GPIO pins on the Jetson Orin Nano devkit but I am unable to get the Jetson.GPIO library working in Python which is the method previous Jetson boards were using to enable this hardware.
Since the GPIO pin functions are an important capability of the board, is there a document somewhere that provides clear instructions on how to enable these pins when the latest Jetpack is installed?
If not I will assume that the GPIO capability of the board is simply not production-ready and I won’t try to use it at this time.
thanks,
Steve
For all 8 channels you will have to modify the .dtsi.
