• Hardware Platform (Jetson / GPU) Jetson Orin
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 5.0.1
• TensorRT Version 8
• Issue Type( questions, new requirements, bugs) Questions
HI I am trying to use the GPIOs on the Jetson Orin. I found that the python package jetson-gpio is already installed so I tried to use it.
I am able to read correctly the values on the pins but setting the pin in output mode seems not working. Whenever I set an output pin to high nothing happens “electrically”.
I validated that the same script and circuit work fine on my jetson nano.
Is it a known bug on the jetson Orin ?
The weird thing is that the readme of jetson-gpio repo doesn’t state that is supported on jetson orin to be fair but is it really the case? or is there any workaround to make it work? Thank you for your help !
