I am using AGX Orin development with JETPACK5.0.1 when I need to use GPIO, I find that there is actually no change when I change the state of the output pin. I am using nvidia jetson-gpio pakage for python:
And by executing the example/test_all_pins.py inside, none of the pins change at all
Is there any solution we can try?
I had a similar problem. I used the following commands and an oscilloscope to detect voltage changes.
echo 316 > /sys/class/gpio/export
cd /sys/class/gpio/PAA.00
echo 1 > value
echo 0 > value
When I used cat value, the value changed. However, the voltage had no change. I was wondering, is this the same issue? Or is there anything I could do to fix this?
Thank you!
