When using the veye327 camera
Has anyone succeeded in building the kernel image and dtb from the source?
I know you need to contact veyeimaging, but has anyone in the forums ever succeeded in building from source someone?
Thank you.
Thank you.
I believe you should be able get more information from google search.
http://wiki.veye.cc/index.php/VEYE_MIPI_290/327_for_Jetson_Nano
I looked at the document and tried to follow it all,
I’m having a problem with the build failing.
Thanks for the answer
Thank you.
At least post the what’s the error message for getting help.
I have followed the contents of both sites.
http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2
http://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson
As a result, I cannot boot as follows.
Thank you.
Can’t tell what happen from this message.
Could you try if ssh can connect to it?
I am not sure why the monitor output is not working.
Thank you.
It’s could be the device tree cause the graphic driver failed to load cause the problem.
Could you provide the dmesg after login by ssh.
Yes, looks like something wrong for the display driver.
Could you modify the /boot/extlinux/extlinux.conf to boot by default dtb to try.
I don’t know how to fix it, can you guide me?
Thank you.
Thank you very much.
Can connect by ssh?
If can connect by ssh modify try to copy the original Image to /boot/ and reboot by command to try.
I can’t access it through ssh.
Thank you.
You need to reflash the original image and try to integrate the veye driver and device tree again.
You can just copy the dtb and Image to Nano and add new boot entry in extlinux.conf do not replace the original context and select to boot to which image by uart during bootloader.
About dtb compile for veye327.
To build dtb, the following site was referenced.
The environment variables for the directory are as follows:
The dtsi file that existed by default in the following directory is compiled as follows.
Linux_for_Tegra/source/public/hardware/nvidia/platform/t210/porg/kernel-dts/porg-plugin-manager
========================= compile ====================================
nanohostpc@nanohostpc-Vostro-470:~/coding/build_nvidia_kernel_201215_2/Linux_for_Tegra/source/public/kernel/kernel-4.9$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT dtbs
make[1]: Entering directory ‘/home/nanohostpc/coding/build_nvidia_kernel_201215_2/outdir’
CHK scripts/mod/devicetable-offsets.h
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-imx274-hdmi.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00-auo-1080p-edp.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-android-devkit.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-imx274-dp-hdmi.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-base-p2595-0000-a00.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-p2595-0000-a00-00.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit_as_TM660M.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a00.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-a02.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-as-p3448-0003.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00-hdmi-dsi.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-hdmi-dsi.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-hdmi-dsi.dtb
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr40.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-sph0645lm4h.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-fe-pi-audio-z-v2.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-adafruit-sph0645lm4h.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-adafruit-sph0645lm4h.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-fe-pi-audio-z-v2.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-fe-pi-audio-z-v2.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-hdr40.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-hdr40.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-adafruit-sph0645lm4h.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-fe-pi-audio-z-v2.dtbo
DTC arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-hdr40.dtbo
cp -u arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-imx274-hdmi.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00-auo-1080p-edp.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-android-devkit.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-imx274-dp-hdmi.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-base-p2595-0000-a00.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-p2595-0000-a00-00.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit_as_TM660M.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a00.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-a02.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-as-p3448-0003.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00-hdmi-dsi.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-hdmi-dsi.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-hdmi-dsi.dtb arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr40.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-sph0645lm4h.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit-fe-pi-audio-z-v2.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-adafruit-sph0645lm4h.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-adafruit-sph0645lm4h.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-fe-pi-audio-z-v2.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-fe-pi-audio-z-v2.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01-hdr40.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-hdr40.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-adafruit-sph0645lm4h.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-fe-pi-audio-z-v2.dtbo arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-hdr40.dtbo arch/arm64/boot/dts/
make[1]: Leaving directory ‘/home/nanohostpc/coding/build_nvidia_kernel_201215_2/outdir’
but,
An error occurs when compiling the dtsi file downloaded from git. (Attach the downloaded dtsi file.)
========================= compile error ======================
ERROR (phandle_references): Reference to non-existent node or label “veye327_single_cam0”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_vi_in0”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_csi_out0”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_csi_in0”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_out0”
ERROR (phandle_references): Reference to non-existent node or label “veye327_cam0”
ERROR (phandle_references): Reference to non-existent node or label “veye327_cam1”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_vi_in1”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_csi_out1”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_dual_out0”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_csi_in1”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_veye327_dual_out1”
ERROR (phandle_references): Reference to non-existent node or label “rbpcv2_cssc132_csi_out1”
ERROR: Input tree has errors, aborting (use -f to force output)
/home/nanohostpc/coding/build_nvidia_kernel_201215_2/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/Makefile:120: recipe for target ‘arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a00.dtb’ failed
make[2]: *** [arch/arm64/boot/dts/ddot/ddot/ddot/ddot/ddot/ddot/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a00.dtb] Error 2
arch/arm64/Makefile:154: recipe for target ‘dtbs’ failed
make[1]: *** [dtbs] Error 2
Makefile:171: recipe for target ‘sub-make’ failed
make: *** [sub-make] Error 2
Can you help me solve this problem?
Thank you.git_cloned_dtsi.zip (2.3 KB)
