I failed to install L4T 32.3.1 on Jetson Nano Devkit, following the instructions from:
How to build NVIDIA Jetson Nano kernel - RidgeRun Developer Connection
All build steps finished OK except the last step:
export CROSS_COMPILE_AARCH64_PATH=$HOME/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu
./nvbuild.sh -o $TEGRA_KERNEL_OUT
because nvbuild exits with error message: missing configuration.
Could not find information about nvbuild and why this step is needed.
The host log:
# L4T BSP Information:
# R32 , REVISION: 3.1
# Target Board Information:
# Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x21 --applet "/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0018 ] Generating RCM messages
[ 0.0031 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/user/nano_32.3.1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0044 ] RCM 0 is saved as rcm_0.rcm
[ 0.0055 ] RCM 1 is saved as rcm_1.rcm
[ 0.0056 ] List of rcm files are saved in rcm_list.xml
[ 0.0056 ]
[ 0.0056 ] Signing RCM messages
[ 0.0148 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0161 ] Assuming zero filled SBK key
[ 0.0251 ]
[ 0.0252 ] Copying signature to RCM mesages
[ 0.0265 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0287 ]
[ 0.0288 ] Boot Rom communication
[ 0.0308 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0323 ] RCM version 0X210001
[ 0.0796 ] Boot Rom communication completed
[ 1.0937 ]
[ 1.0947 ] dump EEPROM info
[ 1.1067 ] tegrarcm --oem platformdetails eeprom /home/user/nano_32.3.1/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1159 ] Applet version 00.01.0000
[ 1.1543 ] Saved platform info in /home/user/nano_32.3.1/Linux_for_Tegra/bootloader/cvm.bin
[ 1.2403 ]
Board ID(3448) version(200)
copying bctfile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/user/nano_32.3.1/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/user/nano_32.3.1/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
Copying nv_boot_control.conf to rootfs
Making system.img...
populating rootfs from /home/user/nano_32.3.1/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 6291456( 6 blks) ==> 28:6291468
1: SKP: 30408704( 29 blks) ==> 6291496:12
2: RAW: 6291456( 6 blks) ==> 6291508:6291468
3: SKP: 91226112( 87 blks) ==> 12582976:12
4: RAW: 1048576( 1 blks) ==> 12582988:1048588
5: SKP: 2097152( 2 blks) ==> 13631576:12
6: RAW: 28311552( 27 blks) ==> 13631588:28311564
7: SKP: 1048576( 1 blks) ==> 41943152:12
8: RAW: 37748736( 36 blks) ==> 41943164:37748748
9: SKP: 1048576( 1 blks) ==> 79691912:12
10: RAW: 62914560( 60 blks) ==> 79691924:62914572
11: SKP: 1048576( 1 blks) ==> 142606496:12
12: RAW: 29360128( 28 blks) ==> 142606508:29360140
13: SKP: 3145728( 3 blks) ==> 171966648:12
14: RAW: 15728640( 15 blks) ==> 171966660:15728652
15: SKP: 1048576( 1 blks) ==> 187695312:12
16: RAW: 28311552( 27 blks) ==> 187695324:28311564
17: SKP: 1048576( 1 blks) ==> 216006888:12
18: RAW: 34603008( 33 blks) ==> 216006900:34603020
19: SKP: 3145728( 3 blks) ==> 250609920:12
20: RAW: 17825792( 17 blks) ==> 250609932:17825804
21: SKP: 2097152( 2 blks) ==> 268435736:12
22: RAW: 44040192( 42 blks) ==> 268435748:44040204
23: SKP: 3145728( 3 blks) ==> 312475952:12
24: RAW: 137363456( 131 blks) ==> 312475964:137363468
25: SKP: 5242880( 5 blks) ==> 449839432:12
26: RAW: 76546048( 73 blks) ==> 449839444:76546060
27: SKP: 2097152( 2 blks) ==> 526385504:12
28: RAW: 159383552( 152 blks) ==> 526385516:159383564
29: SKP: 1048576( 1 blks) ==> 685769080:12
30: RAW: 3145728( 3 blks) ==> 685769092:3145740
31: SKP: 1048576( 1 blks) ==> 688914832:12
32: RAW: 55574528( 53 blks) ==> 688914844:55574540
33: SKP: 3145728( 3 blks) ==> 744489384:12
34: RAW: 42991616( 41 blks) ==> 744489396:42991628
35: SKP: 2097152( 2 blks) ==> 787481024:12
36: RAW: 102760448( 98 blks) ==> 787481036:102760460
37: SKP: 3145728( 3 blks) ==> 890241496:12
38: RAW: 132120576( 126 blks) ==> 890241508:132120588
39: SKP: 2097152( 2 blks) ==> 1022362096:12
40: RAW: 26214400( 25 blks) ==> 1022362108:26214412
41: SKP: 2097152( 2 blks) ==> 1048576520:12
42: RAW: 115343360( 110 blks) ==> 1048576532:115343372
43: SKP: 7340032( 7 blks) ==> 1163919904:12
44: RAW: 197132288( 188 blks) ==> 1163919916:197132300
45: SKP: 4194304( 4 blks) ==> 1361052216:12
46: RAW: 51380224( 49 blks) ==> 1361052228:51380236
47: SKP: 560988160( 535 blks) ==> 1412432464:12
48: RAW: 4194304( 4 blks) ==> 1412432476:4194316
49: SKP: 29360128( 28 blks) ==> 1416626792:12
50: RAW: 2097152( 2 blks) ==> 1416626804:2097164
51: SKP: 98566144( 94 blks) ==> 1418723968:12
52: RAW: 94371840( 90 blks) ==> 1418723980:94371852
53: SKP: 979369984( 934 blks) ==> 1513095832:12
54: RAW: 1048576( 1 blks) ==> 1513095844:1048588
55: SKP: 267386880( 255 blks) ==> 1514144432:12
56: RAW: 1048576( 1 blks) ==> 1514144444:1048588
57: SKP: 670040064( 639 blks) ==> 1515193032:12
58: RAW: 8388608( 8 blks) ==> 1515193044:8388620
59: SKP: 25165824( 24 blks) ==> 1523581664:12
60: RAW: 9437184( 9 blks) ==> 1523581676:9437196
61: SKP: 91226112( 87 blks) ==> 1533018872:12
62: RAW: 570425344( 544 blks) ==> 1533018884:570425356
63: SKP: 33554432( 32 blks) ==> 2103444240:12
64: RAW: 26214400( 25 blks) ==> 2103444252:26214412
65: SKP: 1383071744( 1319 blks) ==> 2129658664:12
66: RAW: 6291456( 6 blks) ==> 2129658676:6291468
67: SKP: 27262976( 26 blks) ==> 2135950144:12
68: RAW: 9437184( 9 blks) ==> 2135950156:9437196
69: SKP: 91226112( 87 blks) ==> 2145387352:12
70: RAW: 1048576( 1 blks) ==> 2145387364:1048588
71: SKP: 2097152( 2 blks) ==> 2146435952:12
72: RAW: 119537664( 114 blks) ==> 2146435964:119537676
73: SKP: 14680064( 14 blks) ==> 2265973640:12
74: RAW: 8388608( 8 blks) ==> 2265973652:8388620
75: SKP: 1048576( 1 blks) ==> 2274362272:12
76: RAW: 567279616( 541 blks) ==> 2274362284:567279628
77: SKP: 24117248( 23 blks) ==> 2841641912:12
78: RAW: 33554432( 32 blks) ==> 2841641924:33554444
79: SKP: 1241513984( 1184 blks) ==> 2875196368:12
80: RAW: 3145728( 3 blks) ==> 2875196380:3145740
81: SKP: 30408704( 29 blks) ==> 2878342120:12
82: RAW: 9437184( 9 blks) ==> 2878342132:9437196
83: SKP: 91226112( 87 blks) ==> 2887779328:12
84: RAW: 141557760( 135 blks) ==> 2887779340:141557772
85: SKP: 1048576( 1 blks) ==> 3029337112:12
86: RAW: 25165824( 24 blks) ==> 3029337124:25165836
87: SKP: 33554432( 32 blks) ==> 3054502960:12
88: RAW: 22020096( 21 blks) ==> 3054502972:22020108
89: SKP: 1789919232( 1707 blks) ==> 3076523080:12
90: RAW: 5242880( 5 blks) ==> 3076523092:5242892
91: SKP: 28311552( 27 blks) ==> 3081765984:12
92: RAW: 12582912( 12 blks) ==> 3081765996:12582924
93: SKP: 88080384( 84 blks) ==> 3094348920:12
94: RAW: 1048576( 1 blks) ==> 3094348932:1048588
95: SKP: 2097152( 2 blks) ==> 3095397520:12
96: RAW: 281018368( 268 blks) ==> 3095397532:281018380
97: SKP: 1729101824( 1649 blks) ==> 3376415912:12
98: RAW: 7340032( 7 blks) ==> 3376415924:7340044
99: SKP: 26214400( 25 blks) ==> 3383755968:12
100: RAW: 10485760( 10 blks) ==> 3383755980:10485772
101: SKP: 90177536( 86 blks) ==> 3394241752:12
102: RAW: 276824064( 264 blks) ==> 3394241764:276824076
103: SKP: 2097152( 2 blks) ==> 3671065840:12
104: RAW: 303038464( 289 blks) ==> 3671065852:303038476
105: SKP: 22020096( 21 blks) ==> 3974104328:12
106: RAW: 33554432( 32 blks) ==> 3974104340:33554444
107: SKP: 1375731712( 1312 blks) ==> 4007658784:12
-- Total: ---------------------------------------------------
108 CHUNK 15032385536( 14336 blks) ==> 4007658796(3822 blks)
done.
system.img built successfully.
Existing tbcfile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/user/nano_32.3.1/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
copying cfgfile(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/user/nano_32.3.1/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb"
saving flash command in /home/user/nano_32.3.1/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/user/nano_32.3.1/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0016 ] tegrasign --key None --getmode mode.txt
[ 0.0030 ] Assuming zero filled SBK key
[ 0.0048 ]
[ 0.0049 ] Generating RCM messages
[ 0.0073 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0090 ] RCM 0 is saved as rcm_0.rcm
[ 0.0101 ] RCM 1 is saved as rcm_1.rcm
[ 0.0103 ] List of rcm files are saved in rcm_list.xml
[ 0.0107 ]
[ 0.0110 ] Signing RCM messages
[ 0.0156 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0192 ] Assuming zero filled SBK key
[ 0.0251 ]
[ 0.0254 ] Copying signature to RCM mesages
[ 0.0271 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0298 ]
[ 0.0299 ] Parsing partition layout
[ 0.0324 ] tegraparser --pt flash.xml.tmp
[ 0.0347 ]
[ 0.0348 ] Creating list of images to be signed
[ 0.0377 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0548 ]
[ 0.0548 ] Generating signatures
[ 0.0563 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0575 ] Assuming zero filled SBK key
[ 0.1147 ]
[ 0.1148 ] Generating br-bct
[ 0.1253 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.1269 ] Copying Sdram info from 0 to 1 set
[ 0.1293 ] Copying Sdram info from 1 to 2 set
[ 0.1293 ] Copying Sdram info from 2 to 3 set
[ 0.1293 ]
[ 0.1293 ] Updating boot device parameters
[ 0.1306 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.1318 ] Warning: No sdram params
[ 0.1330 ]
[ 0.1331 ] Updating bl info
[ 0.1344 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1369 ]
[ 0.1369 ] Updating secondary storage information into bct
[ 0.1382 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.1396 ]
[ 0.1397 ] Updating Odmdata
[ 0.1410 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 0.1452 ] Warning: No sdram params
[ 0.1453 ]
[ 0.1455 ] Get Signed section of bct
[ 0.1498 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.1514 ]
[ 0.1515 ] Signing BCT
[ 0.1540 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.1554 ] Assuming zero filled SBK key
[ 0.1562 ]
[ 0.1562 ] Updating BCT with signature
[ 0.1575 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.1598 ]
[ 0.1599 ] Copying signatures
[ 0.1614 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.1833 ]
[ 0.1834 ] Updating BFS information on BCT
[ 0.1847 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.1868 ]
[ 0.1871 ] Boot Rom communication
[ 0.1886 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.1899 ] BootRom is not running
[ 0.2320 ]
[ 0.2324 ] Sending BCTs
[ 0.2339 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.2353 ] Applet version 00.01.0000
[ 0.2657 ] Sending bct
[ 0.2665 ] [................................................] 100%
[ 0.4507 ]
[ 0.4550 ] tegrahost --chip 0x21 --align cboot.bin
[ 0.4592 ]
[ 0.4637 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 0.4744 ]
[ 0.4799 ] tegrasign --key None --list cboot.bin_list.xml
[ 0.4823 ] Assuming zero filled SBK key
[ 0.5092 ]
[ 0.5114 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 0.5143 ]
[ 0.5173 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
[ 0.5188 ]
[ 0.5203 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
[ 0.5232 ]
[ 0.5250 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
[ 0.5265 ] Assuming zero filled SBK key
[ 0.5361 ]
[ 0.5382 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
[ 0.5408 ]
[ 0.5418 ] Sending bootloader and pre-requisite binaries
[ 0.5432 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
[ 0.5450 ] Applet version 00.01.0000
[ 0.5667 ] Sending ebt
[ 0.5670 ] [................................................] 100%
[ 0.6783 ] Sending rp1
[ 0.6851 ] [................................................] 100%
[ 0.7596 ]
[ 0.7717 ] tegrarcm --boot recovery
[ 0.7848 ] Applet version 00.01.0000
[ 0.8243 ]
[ 0.8246 ] Retrieving storage infomation
[ 0.8294 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 0.8340 ] Applet is not running on device. Continue with Bootloader
[ 1.4410 ]
[ 1.4491 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 1.4530 ] Cboot version 00.01.0000
[ 1.4669 ] Saved platform info in storage_info.bin
[ 1.4791 ]
[ 1.4795 ] Flashing the device
[ 1.4847 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 1.4883 ] Cboot version 00.01.0000
[ 1.5028 ] Writing partition GPT with gpt.bin
[ 1.5046 ] [................................................] 100%
[ 1.5180 ] Writing partition NVC with nvtboot.bin.encrypt
[ 14.9708 ] [................................................] 100%
[ 14.9983 ] Writing partition PT with flash.xml.bin
[ 24.9933 ] [................................................] 100%
[ 25.0251 ] Writing partition NVC_R with nvtboot.bin.encrypt
[ 25.2759 ] [................................................] 100%
[ 25.3100 ] Writing partition VER_b with qspi_bootblob_ver.txt
[ 35.3700 ] [................................................] 100%
[ 35.4071 ] Writing partition VER with qspi_bootblob_ver.txt
[ 35.6773 ] [................................................] 100%
[ 35.7105 ] Writing partition APP with system.img
[ 35.9838 ] [................................................] 100%
[ 437.2144 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[ 445.8466 ] [................................................] 100%
[ 445.8593 ] Writing partition RP1 with tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt
[ 445.9145 ] [................................................] 100%
[ 445.9465 ] Writing partition EBT with cboot.bin.encrypt
[ 446.0082 ] [................................................] 100%
[ 446.0499 ] Writing partition WB0 with warmboot.bin.encrypt
[ 446.1412 ] [................................................] 100%
[ 446.1576 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[ 446.1949 ] [................................................] 100%
[ 446.2090 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 446.2482 ] [................................................] 100%
[ 446.2632 ] Writing partition DTB with tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt
[ 446.3132 ] [................................................] 100%
[ 446.3320 ] Writing partition LNX with boot.img.encrypt
[ 446.3853 ] [................................................] 100%
[ 446.4136 ] Warning: EKS partition magic header mismatch!
[ 446.4766 ] Writing partition EKS with eks.img
[ 446.4771 ] [................................................] 100%
[ 446.4858 ] Writing partition BMP with bmp.blob
[ 446.5272 ] [................................................] 100%
[ 446.5397 ] Writing partition RP4 with rp4.blob
[ 446.5865 ] [................................................] 100%
[ 446.6557 ]
[ 446.6574 ] tegradevflash --write BCT P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 446.6587 ] Cboot version 00.01.0000
[ 446.6642 ] Writing partition BCT with P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 446.6650 ] [................................................] 100%
[ 453.3650 ]
[ 453.3654 ] Flashing completed
[ 453.3660 ] Coldbooting the device
[ 453.3757 ] tegradevflash --reboot coldboot
[ 453.3897 ] Cboot version 00.01.0000
[ 453.4171 ]
*** The target t210ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
The system log:
[0036.758] Enabled early print
[0036.761] [L4T TegraBoot] (version 00.00.2018.01-l4t-1463e5a5)
[0036.767] Processing in recovery mode
[0036.770] A02 Bootrom Patch rev = 1023
[0036.774] Power-up reason: pmc por
[0036.777] Established communication link with host
[0037.819] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0037.827] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0037.836] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
[0114.417] Odmdata from BCT: 0x00094000
[0114.421] DebugPort= 0x3
[0114.430] BoardId read from EEPROM/NCT: 3448
[0114.434] BoardID = 3448, SKU = 0x0
[0114.461] NvTbootInit_Porg: Setting GPIO_A6 for HDMI ...
[0114.466] max77620 setting MBLPD bit
[0114.470] No Battery Present
[0114.473] RamCode = 0
[0114.475] Platform has DDR4 type RAM
[0114.478] max77620 disabling SD1 Remote Sense
[0114.482] Setting DDR voltage to 1125mv
[0114.486] Serial Number of Pmic Max77663: 0x610eb
[0114.494] Entering ramdump check
[0114.497] Get RamDumpCarveOut = 0x0
[0114.500] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0114.506] Last reboot was clean, booting normally!
[0114.510] Sdram initialization is successful
[0114.514] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0114.521] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0114.526] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0114.532] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0114.538] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0114.544] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0114.550] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0114.556] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0114.572] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0114.578] Platform-DebugCarveout: 0
[0114.581] Downloaded BCT successfully
[0114.809] Downloaded Bootloader successfully
[0114.876] Downloaded rp1 successfully
[0114.953] MAX77620_GPIO5 configured
[0114.956] CPU power rail is up
[0114.959] CPU clock enabled
[0114.963] Performing RAM repair
[0114.966] Updating A64 Warmreset Address to 0x92c002e9
[0114.972] Enable APE clock/reset
[0114.975] Error in NvTbootGetTOSBinaryLength: 0x11 !
[0114.980] Loading Secure OS image failed.
[0114.983] Set NvDecSticky Bits
[0114.987] GSC2 address ff53fffc value c0edbbcc
[0114.993] GSC MC Settings done
[0114.998] Next binary entry address: 0x92c00258
[0115.002] BoardId: 3448
[0115.005] Overriding pmu board id with proc board id
[0115.009] Display board id is not available
[0115.014] Starting CPU & Halting co-processor
[0117.785]
[0117.786] Debug Init done
[0117.790] Marked DTB cacheable
[0117.793] Bootloader DTB loaded at 0x83000400
[0117.797] DeviceTree Init done
[0117.810] Pinmux applied successfully
[0117.814] gicd_base: 0x50041000
[0117.818] gicc_base: 0x50042000
[0117.821] Interrupts Init done
[0117.825] Using base:0x60005090 & irq:208 for tick-timer
[0117.830] Using base:0x60005098 for delay-timer
[0117.834] platform_init_timer: DONE
[0117.838] Timer(tick) Init done
[0117.842] osc freq = 38400 khz
[0117.846]
[0117.847] Welcome to L4T Cboot
[0117.850]
[0117.851] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0117.856] calling constructors
[0117.859] initializing heap
[0117.862] initializing threads
[0117.865] initializing timers
[0117.867] creating bootstrap completion thread
[0117.872] top of bootstrap2()
[0117.875] CPU: ARM Cortex A57
[0117.878] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0117.882] initializing platform
[0117.890] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0117.894] ID LSB = 0x36, ID-CFI len = 194 bytes
[0117.899] Macronix QSPI chip present
[0117.902] SPI device register
[0117.905] init boot device
[0117.908] allocating memory for boot device(SPI)
[0117.912] registering boot device
[0117.922] sdmmc node status = okay
[0117.925] sdcard instance = 0
[0117.928] sdcard gpio handle 0x56
[0117.931] sdcard gpio pin 0xc9
[0117.934] sdcard gpio flags 0x0
[0117.937] vmmc-supply 0x99
[0117.940] Instance: 0
[0117.942] Allocating memory for context
[0117.946] enabling clock
[0117.948] sd card init
[0117.950] Check card present and stable
[0117.954] Send command 0
[0117.971] Send command 3
[0117.975] Set RCA for the card
[0117.978] Query card specific data by command 9
[0117.984] Parse CSD data
[0117.987] Send command 7
[0117.997] Calling sd device register
[0118.000] Init sdcard
[0118.003] Allocating memory for boot device
[0118.007] Registering user device
[0118.020] of_register: registering tegra_udc to of_hal
[0118.025] of_register: registering inv20628-driver to of_hal
[0118.031] of_register: registering ads1015-driver to of_hal
[0118.036] of_register: registering lp8557-bl-driver to of_hal
[0118.042] of_register: registering bq2419x_charger to of_hal
[0118.048] of_register: registering bq27441_fuel_gauge to of_hal
[0118.059] gpio framework initialized
[0118.062] of_register: registering tca9539_gpio to of_hal
[0118.068] of_register: registering tca9539_gpio to of_hal
[0118.073] of_register: registering i2c_bus_driver to of_hal
[0118.079] of_register: registering i2c_bus_driver to of_hal
[0118.084] of_register: registering i2c_bus_driver to of_hal
[0118.090] pmic framework initialized
[0118.093] of_register: registering max77620_pmic to of_hal
[0118.099] regulator framework initialized
[0118.103] of_register: registering tps65132_bl_driver to of_hal
[0118.109] initializing target
[0118.115] gpio_driver_register: register 'tegra_gpio_driver' driver
[0118.123] board ID = D78, board SKU = 0
[0118.126] Skipping Z3!
[0118.131] fixed regulator driver initialized
[0118.148] initializing OF layer
[0118.152] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0118.169] I2C Bus Init done
[0118.172] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0118.182] I2C Bus Init done
[0118.185] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0118.195] I2C Bus Init done
[0118.198] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0118.208] I2C Bus Init done
[0118.211] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0118.221] I2C Bus Init done
[0118.224] of_children_init: Ops found for compatible string maxim,max77620
[0118.234] max77620_init using irq 118
[0118.239] register 'maxim,max77620' pmic
[0118.243] gpio_driver_register: register 'max77620-gpio' driver
[0118.249] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0118.260] I2C Bus Init done
[0118.263] Applying platform configs
[0118.270] platform-init is not present. Skipping
[0118.275] calling apps_init()
[0118.295] Found 14 GPT partitions in "sd0"
[0118.299] Proceeding to flashing Server
[0118.303] usbdcd_reinit Initialize driver to use already enumerated device
[0118.310] nv3p_priv_usbf_open USB configuration success
[0118.390] Writing GPT partition
[0118.397] Erasing Boot device
[0118.400] device_write_gpt: Erasing boot device spiflash0
[0131.750] Erasing Storage Device
[0131.753] Writing protective mbr
[0131.765] Writing primary GPT
[0131.817] Writing secondary GPT
[0131.845] Found 14 GPT partitions in "sd0"
[0131.858] Writing NVC partition
[0141.885] partition NVC write successful.
[0141.904] Writing PT partition
[0142.164] partition PT write successful.
[0142.186] Writing NVC_R partition
[0152.235] partition NVC_R write successful.
[0152.257] Writing VER_b partition
[0152.540] partition VER_b write successful.
[0152.565] Writing VER partition
[0152.846] partition VER write successful.
[0152.871] Writing APP partition
[0562.744] partition APP write successful.
[0562.753] Writing TBC partition
[0562.805] partition TBC write successful.
[0562.819] Writing RP1 partition
[0562.903] partition RP1 write successful.
[0562.914] Writing EBT partition
[0563.033] partition EBT write successful.
[0563.048] Writing WB0 partition
[0563.091] partition WB0 write successful.
[0563.102] Writing BPF partition
[0563.143] partition BPF write successful.
[0563.154] Writing TOS partition
[0563.209] partition TOS write successful.
[0563.221] Writing DTB partition
[0563.287] partition DTB write successful.
[0563.293] Writing LNX partition
[0563.378] partition LNX write successful.
[0563.385] Writing EKS partition
[0563.429] partition EKS write successful.
[0563.436] Writing BMP partition
[0563.488] partition BMP write successful.
[0563.495] Writing RP4 partition
[0563.558] partition RP4 write successful.
[0563.574] Writing BCT partition
[0570.225] partition BCT write successful.
[0570.293] Change state to cold boot mode
ъ[0000.157] [L4T TegraBoot] (version 00.00.2018.01-l4t-39a9dc3d)
[0000.163] Processing in cold boot mode Bootloader 2
[0000.167] A02 Bootrom Patch rev = 1023
[0000.171] Power-up reason: software reset
[0000.175] No Battery Present
[0000.177] pmic max77620 reset reason
[0000.181] pmic max77620 NVERC : 0x0
[0000.184] RamCode = 0
[0000.186] Platform has DDR4 type RAM
[0000.190] max77620 disabling SD1 Remote Sense
[0000.194] Setting DDR voltage to 1125mv
[0000.198] Serial Number of Pmic Max77663: 0x610eb
[0000.205] Entering ramdump check
[0000.208] Get RamDumpCarveOut = 0x0
[0000.212] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.217] Last reboot was clean, booting normally!
[0000.221] Sdram initialization is successful
[0000.226] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.232] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.237] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.243] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.249] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.255] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.261] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.267] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.283] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.289] Platform-DebugCarveout: 0
[0000.292] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.298] Non secure mode, and RB not enabled.
[0000.475] Csd NumOfBlocks=62521344
[0000.480] Set High speed to 1
[0000.485] Using GPT Primary to query partitions
[0000.490] Loading Tboot-CPU binary
[0000.500] Verifying TBC in OdmNonSecureSBK mode
[0000.510] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.517] Bootloader downloaded successfully.
[0000.521] Downloaded Tboot-CPU binary to 0xa0000258
[0000.526] MAX77620_GPIO5 configured
[0000.529] CPU power rail is up
[0000.532] CPU clock enabled
[0000.536] Performing RAM repair
[0000.539] Updating A64 Warmreset Address to 0xa00002e9
[0000.544] Loading NvTbootBootloaderDTB
[0000.569] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.634] Bootloader DTB Load Address: 0x83000000
[0000.639] Loading NvTbootKernelDTB
[0000.663] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.728] Kernel DTB Load Address: 0x83100000
[0000.733] Loading cboot binary
[0000.762] Verifying EBT in OdmNonSecureSBK mode
[0000.804] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.811] Bootloader downloaded successfully.
[0000.828] Using BFS PT to query partitions
[0000.832] Next binary entry address: 0x92c00258
[0000.836] BoardId: 3448
[0000.841] Overriding pmu board id with proc board id
[0000.846] Display board id is not available
[0000.874] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.926] /bpmp deleted
[0000.928] SC7EntryFw header found loaded at 0xff700000
[0001.117] OVR2 PMIC
[0001.119] Bpmp FW successfully loaded
[0001.123] WB0 init successfully at 0xff780000
[0001.127] Set NvDecSticky Bits
[0001.131] GSC2 address ff53fffc value c0edbbcc
[0001.137] GSC MC Settings done
[0001.140] TOS Image length 53680
[0001.143] Monitor size 53680
[0001.146] OS size 0
[0001.153] Secure Os AES-CMAC Verification Success!
[0001.158] TOS image cipher info: plaintext
[0001.162] Loading and Validation of Secure OS Successful
[0001.178] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.182] NvTbootPackSdramParams: start.
[0001.187] NvTbootPackSdramParams: done.
[0001.191] Tegraboot started after 85350 us
[0001.195] Basic modules init took 785658 us
[0001.199] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.205] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.210] Storage Device Read Time = 107 ms, Read Size = 2226 KB
[0001.216] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.221] Next stage binary read took 24310 us
[0001.226] Carveout took -35975 us
[0001.229] CPU initialization took 360840 us
[0001.233] Total time taken by TegraBoot 1134833 us
[0001.238] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:39:57, Dec 9 2019
ERROR: Error initializing runtime service trusty_fast
[0001.360] RamCode = 0
[0001.364] LPDDR4 Training: Read DT: Number of tables = 2
[0001.369] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.382] EMC Training Successful
[0001.385] 408000 not found in DVFS table
[0001.392] RamCode = 0
[0001.395] DT Write: emc-table@204000 succeeded
[0001.401] DT Write: emc-table@1600000 succeeded
[0001.405] LPDDR4 Training: Write DT: Number of tables = 2
[0001.448]
[0001.449] Debug Init done
[0001.451] Marked DTB cacheable
[0001.454] Bootloader DTB loaded at 0x83000000
[0001.459] Marked DTB cacheable
[0001.462] Kernel DTB loaded at 0x83100000
[0001.466] DeviceTree Init done
[0001.482] Pinmux applied successfully
[0001.486] gicd_base: 0x50041000
[0001.489] gicc_base: 0x50042000
[0001.492] Interrupts Init done
[0001.497] Using base:0x60005090 & irq:208 for tick-timer
[0001.502] Using base:0x60005098 for delay-timer
[0001.506] platform_init_timer: DONE
[0001.510] Timer(tick) Init done
[0001.513] osc freq = 38400 khz
[0001.518]
[0001.519] Welcome to L4T Cboot
[0001.522]
[0001.523] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0001.528] calling constructors
[0001.531] initializing heap
[0001.533] initializing threads
[0001.536] initializing timers
[0001.539] creating bootstrap completion thread
[0001.544] top of bootstrap2()
[0001.546] CPU: ARM Cortex A57
[0001.549] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.554] initializing platform
[0001.562] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.566] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.571] Macronix QSPI chip present
[0001.574] SPI device register
[0001.577] init boot device
[0001.580] allocating memory for boot device(SPI)
[0001.584] registering boot device
[0001.593] sdmmc node status = okay
[0001.597] sdcard instance = 0
[0001.600] sdcard gpio handle 0x56
[0001.603] sdcard gpio pin 0xc9
[0001.606] sdcard gpio flags 0x0
[0001.609] vmmc-supply 0x99
[0001.611] Instance: 0
[0001.614] Allocating memory for context
[0001.617] enabling clock
[0001.620] sd card init
[0001.622] Check card present and stable
[0001.626] Send command 0
[0001.642] Send command 3
[0001.647] Set RCA for the card
[0001.649] Query card specific data by command 9
[0001.656] Parse CSD data
[0001.658] Send command 7
[0001.669] Calling sd device register
[0001.672] Init sdcard
[0001.674] Allocating memory for boot device
[0001.678] Registering user device
[0001.692] Enable APE clock
[0001.694] Un-powergate APE partition
[0001.698] of_register: registering tegra_udc to of_hal
[0001.703] of_register: registering inv20628-driver to of_hal
[0001.708] of_register: registering ads1015-driver to of_hal
[0001.714] of_register: registering lp8557-bl-driver to of_hal
[0001.720] of_register: registering bq2419x_charger to of_hal
[0001.725] of_register: registering bq27441_fuel_gauge to of_hal
[0001.737] gpio framework initialized
[0001.740] of_register: registering tca9539_gpio to of_hal
[0001.746] of_register: registering tca9539_gpio to of_hal
[0001.751] of_register: registering i2c_bus_driver to of_hal
[0001.757] of_register: registering i2c_bus_driver to of_hal
[0001.762] of_register: registering i2c_bus_driver to of_hal
[0001.768] pmic framework initialized
[0001.771] of_register: registering max77620_pmic to of_hal
[0001.777] regulator framework initialized
[0001.781] of_register: registering tps65132_bl_driver to of_hal
[0001.787] initializing target
[0001.792] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.800] board ID = D78, board SKU = 0
[0001.804] Skipping Z3!
[0001.809] fixed regulator driver initialized
[0001.826] initializing OF layer
[0001.829] NCK carveout not present
[0001.833] Skipping dts_overrides
[0001.837] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.854] I2C Bus Init done
[0001.856] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.866] I2C Bus Init done
[0001.869] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.879] I2C Bus Init done
[0001.882] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.893] I2C Bus Init done
[0001.895] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.906] I2C Bus Init done
[0001.908] of_children_init: Ops found for compatible string maxim,max77620
[0001.918] max77620_init using irq 118
[0001.923] register 'maxim,max77620' pmic
[0001.928] gpio_driver_register: register 'max77620-gpio' driver
[0001.934] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.944] I2C Bus Init done
[0001.948] NCK carveout not present
[0001.958] Find /i2c@7000c000's alias i2c0
[0001.962] get eeprom at 1-a0, size 256, type 0
[0001.971] Find /i2c@7000c500's alias i2c2
[0001.974] get eeprom at 3-a0, size 256, type 0
[0001.979] get eeprom at 3-ae, size 256, type 0
[0001.983] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.989] I2C slave not started
[0001.992] I2C write failed
[0001.994] Writing offset failed
[0001.997] eeprom_init: EEPROM read failed
[0002.001] pm_ids_update: eeprom init failed
[0002.005] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.035] pm_ids_update: The pm board id is 3448-0000-200
[0002.042] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.050] pm_ids_update: pm id update successful
[0002.054] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.084] pm_ids_update: The pm board id is 3449-0000-200
[0002.091] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.099] pm_ids_update: pm id update successful
[0002.129] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.135] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.144] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.149] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.158] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:0b:ea
[0002.164] Plugin Manager: Parse ODM data 0x00094000
[0002.175] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.196] Find /i2c@7000c000's alias i2c0
[0002.200] get eeprom at 1-a0, size 256, type 0
[0002.209] Find /i2c@7000c500's alias i2c2
[0002.213] get eeprom at 3-a0, size 256, type 0
[0002.217] get eeprom at 3-ae, size 256, type 0
[0002.221] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.227] I2C slave not started
[0002.230] I2C write failed
[0002.232] Writing offset failed
[0002.235] eeprom_init: EEPROM read failed
[0002.239] pm_ids_update: eeprom init failed
[0002.243] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.274] pm_ids_update: The pm board id is 3448-0000-200
[0002.280] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.287] pm_ids_update: pm id update successful
[0002.292] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.322] pm_ids_update: The pm board id is 3449-0000-200
[0002.328] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.335] pm_ids_update: pm id update successful
[0002.366] Add serial number:0421519093312 as DT property
[0002.374] Applying platform configs
[0002.380] platform-init is not present. Skipping
[0002.385] calling apps_init()
[0002.404] Found 14 GPT partitions in "sd0"
[0002.408] Proceeding to Cold Boot
[0002.412] starting app android_boot_app
[0002.415] Device state: unlocked
[0002.419] display console init
[0002.427] could not find regulator
[0002.430] hdmi cable connected
[0002.446] edid read success
[0002.449] width = 640, height = 480, frequency = 25174825
[0002.454] width = 640, height = 480, frequency = 25174825[0002.462] DT entry for leds-pwm not found
[0002.467] width = 640, height = 480, frequency = 25174825
[0002.472] width = 640, height = 480, frequency = 25174825
[0002.477] width = 1680, height = 1050, frequency = 119000000
[0002.483] Best mode Width = 640, Height = 480, freq = 25174825
[0002.490] tmds-config node not found
[0002.494] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.509] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.517] could not find regulator
[0002.520] could not find regulator
[0002.523] could not find regulator
[0002.552] using default cmu settings
[0002.556] dc_hdmi_enable, starting HDMI initialisation
[0002.562] dc_hdmi_enable, HDMI initialisation complete
[0002.567] list and configure display window
[0002.572] display console init completed
[0002.579] subnode volume_up is not found !
[0002.583] subnode back is not found !
[0002.586] subnode volume_down is not found !
[0002.591] subnode menu is not found !
[0002.594] Gpio keyboard init success
[0002.638] found decompressor handler: lz4-legacy
[0002.652] decompressing blob (type 1)...
[0002.686] load_bmp_blob: panelresolution=480 type=0
[0002.737] decompressor handler not found
[0002.741] load_firmware_blob: Firmware blob loaded, entries=2
[0002.747] -------> se_aes_verify_sbk_clear: 747
[0002.751] se_aes_verify_sbk_clear: Error
[0002.755] bl_battery_charging: connected to external power supply
[0002.763] xusb is supported
[0002.769] error while finding nvidia,portmap
[0003.273] xusb blob version 0 size 124416
[0003.277] firmware size 124416
[0003.282] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.289] xhci0: 64 bytes context size, 32-bit DMA
[0003.329] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.349] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.999] uhub0: 9 ports with 9 removable, self powered
[0004.999] failed to get HID devices
[0005.002] failed to init xhci or no usb device attached
[0005.013] device_query_partition_size: failed to open partition sd0:MSC !
[0005.020] MSC Partition not found
[0005.026] device_query_partition_size: failed to open partition sd0:USP !
[0005.033] USP partition read failed!
[0005.036] blob_init: blob-partition USP header read failed
[0005.042] android_boot Unable to update recovery partition
[0005.047] kfs_getpartname: name = LNX
[0005.051] Loading kernel from LNX
[0005.149] load kernel from storage
[0005.160] decompressor handler not found
[0005.218] Successfully loaded kernel and ramdisk images
[0005.224] load_bmp_blob: panelresolution=480 type=0
[0005.298] display bmp image done
[0005.301] NCK carveout not present
[0005.304] Skipping dts_overrides
[0005.307] NCK carveout not present
[0005.317] Find /i2c@7000c000's alias i2c0
[0005.321] get eeprom at 1-a0, size 256, type 0
[0005.330] Find /i2c@7000c500's alias i2c2
[0005.334] get eeprom at 3-a0, size 256, type 0
[0005.338] get eeprom at 3-ae, size 256, type 0
[0005.343] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.348] I2C slave not started
[0005.351] I2C write failed
[0005.354] Writing offset failed
[0005.357] eeprom_init: EEPROM read failed
[0005.361] pm_ids_update: eeprom init failed
[0005.365] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.395] pm_ids_update: The pm board id is 3448-0000-200
[0005.401] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.409] pm_ids_update: pm id update successful
[0005.414] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.444] pm_ids_update: The pm board id is 3449-0000-200
[0005.450] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0005.458] pm_ids_update: pm id update successful
[0005.489] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.495] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.503] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.509] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.518] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:0b:ea
[0005.524] Plugin Manager: Parse ODM data 0x00094000
[0005.534] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.549] Add serial number:0421519093312 as DT property
[0005.558] "bpmp" doesn't exist, creating
[0005.563] Updated bpmp info to DTB
[0005.568] Updated initrd info to DTB
[0005.572] "proc-board" doesn't exist, creating
[0005.577] Updated board info to DTB
[0005.581] "pmu-board" doesn't exist, creating
[0005.586] Updated board info to DTB
[0005.589] "display-board" doesn't exist, creating
[0005.595] Updated board info to DTB
[0005.598] "reset" doesn't exist, creating
[0005.603] Updated reset info to DTB
[0005.606] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1
[0005.645] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.658] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.671] Updated bootarg info to DTB
[0005.674] Adding uuid 00000001644226c91800000006ff0480 to DT
[0005.680] Adding eks info 0 to DT
[0005.686] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.692] Updated memory info to DTB
[0005.698] Updated system-lp0-disable info to DTB
[0005.706] set vdd_core voltage to 1075 mv
[0005.710] setting 'vdd-core' regulator to 1075000 micro volts
[0005.729] Found secure-pmc; disable BPMP
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Card did not respond to voltage select!
starting USB...
USB0: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
USB error: all controllers failed lowlevel init
Warning: eth_rtl8169 MAC addresses don't match:
Address in SROM is 00:e0:4c:68:05:05
Address in environment is 00:04:4b:e5:0b:ea
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.0.102 (526 ms)
*** Warning: no boot file name; using 'C0A80066.img'
Using eth_rtl8169 device
TFTP from server 192.168.0.1; our IP address is 192.168.0.102
Filename 'C0A80066.img'.
Load address: 0x80080000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-00-04-4b-e5-0b-ea
Filename 'pxelinux.cfg/01-00-04-4b-e5-0b-ea'.
Load address: 0x90100000
Loading: T T 7
