I’m accelerating some loops in a Fortran main program using PGI
directives. When I add a CONTAINS statement and a trivial
subroutine, I get error messages.
Can anyone advise, please? I’m using v10.6.0 of the compiler.
Cheers,
Alistair.
Here is my code:
PROGRAM test_trivial
IMPLICIT NONE
INTEGER, PARAMETER :: N = 10
INTEGER :: u(N,N),i,j
u = 0
!$acc region \
DO j = 1,N
DO i = 1,N
u(i,j) = u(i,j) + 1
ENDDO
ENDDO
!$acc end region \
#ifdef Use_contains
CONTAINS
SUBROUTINE my_sub()
END SUBROUTINE my_sub
#endif
END PROGRAM test_trivial
Here is the compiler output without the CONTAINS statement:
pgf90 -ta=nvidia,time -Minfo=accel test_trivial.F90
test_trivial:
10, Generating copy(u(1:10,1:10))
Generating compute capability 1.0 binary
Generating compute capability 1.3 binary
11, Loop is parallelizable
12, Loop is parallelizable
Accelerator kernel generated
11, !$acc do parallel, vector(10)
12, !$acc do parallel, vector(10)
CC 1.0 : 6 registers; 24 shared, 20 constant, 0 local memory bytes\
; 100 occupancy
CC 1.3 : 6 registers; 24 shared, 20 constant, 0 local memory bytes\
; 100 occupancy
And here is the output with a CONTAINS statement:
pgf90 -ta=nvidia,time -Minfo=accel -DUse_contains test_trivial.F90
test_trivial:
10, No parallel kernels found, accelerator region ignored
11, Accelerator restriction: scalar variable live-out from loop: i
Accelerator restriction: scalar variable live-out from loop: .dY0002
13, Accelerator restriction: induction variable live-out from loop: j
Accelerator restriction: induction variable live-out from loop: i
14, Accelerator restriction: induction variable live-out from loop: i
Accelerator restriction: induction variable live-out from loop: .dY000\
2
15, Accelerator restriction: induction variable live-out from loop: j
1
