Access Metadata of YOLOv10 model in deepstream
• Hardware Platform (Jetson / GPU) - Jetson Nano 4GB
• DeepStream Version - 6.0.1
• JetPack Version (valid for Jetson only) - 4.6.1
• TensorRT Version - 8.2
• CUDA runtime version - 10.2
• CUDA driver version - 8.2
• Issue Type( questions, new requirements, bugs) - question
• How to reproduce the issue ?
Config file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=1
camera-id=0
camera-height=480
camera-width=640
camera-fps-n=25
camera-fps-d=1
camera-v4l2-dev-node=0
#drop-frame-interval=5
#cudadec-memtype=1
num-sources=1
[streammux]
gpu-id=0
live-source=1
batch-size=1
nvbuf-memory-type=0
enable-padding=0
width=640
height=480
[primary-gie]
enable=1
gie-unique-id=1
gpu-id=0
config-file=config_infer_primary_yolo11.txt
batch-size=1
labelfile-path=labels.txt
plugin-type=0
[osd]
enable=1
gpu-id=0
border-width=2
text-size=14
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Purisa
nvbuf-memory-type=0
display-text=1
display-bbox=1
nvbuf-memory-type=0
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[sink0]
enable=0
type=2
sync=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=4
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
width=1280
height=720
codec=1
rtsp-port=4444
Model file:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=v11_models/yolo11n.pt.onnx
model-engine-file=model_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
batch-size=1
network-mode=0
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-func-name=NvDsInferParseYolo
#parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.25
topk=300
I have been using a repo for YOLO in deepstream Yolo-Deepstream. I have a config file to access the webcam video and then process with YOLOv10-n model and then display the plotted video and then stream the plotted video using RTSP. Everything is working fine, I don’t know how to access the metadata of the detection model like bbox, class and confidence values. The reason i want them is that i want to give real-time alert like alarm for detection of a particular vehicle for a continous of 40 frames.
Note: My intention is to know how to get the metadata of every corresponding frames. If its not possible in jetson nano its fine. I can go with jetson orin nano or other dGPU.
You need to modify our source code. You can refer to the source code below to learn how to get the informations you wanted.
deepstream\sources\apps\sample_apps\deepstream-app\deepstream_app.c
static GstPadProbeReturn
analytics_done_buf_prob (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
