Access to all the Isaac utilties via the pip installed version
Isaac Sim Version
4.2.0 (pip)
Operating System
Ubuntu 22.04
I have installed isaac sim via the omniverse installer and have access to a lot of entires in the Isaac Utils menu.
If I install isaac sim via the pip method, the only available utils in that dropdown are Block World Generator and The URDF + MJCF importers.
I was hoping to use the Lula Robot Description editor from the pip installed version.
I’m launching isaac sim from an isolated environment using uv:
#!/usr/bin/env -S uv run
# /// script
# dependencies = [
#   "isaacsim==4.2.0.2",
#   "isaacsim-extscache-kit==4.2.0.2",
#   "isaacsim-extscache-kit-sdk==4.2.0.2",
#   "isaacsim-extscache-physics==4.2.0.2",
#   "isaacsim-robot-setup==4.2.0.2",
#   "isaacsim-robot-motion==4.2.0.2"
import os
import subprocess
def main() -> None:
    try:
        os.environ["OMNI_KIT_ACCEPT_EULA"] = "yes"
        subprocess.run(["isaacsim", "omni.isaac.sim.python.kit"], check=True)
    except subprocess.CalledProcessError as e:
        print(f"Command 'isaacsim' failed with exit code {e.returncode}")
    else:
        print("isaacsim command executed successfully!")
if __name__ == "__main__":
    main()
How to I install these extra utilties? I tried installing more of the pypi isaac packages but it didn’t make a difference.
For future reference. I have fixed it by changing the kit I launch.
subprocess.run(["isaacsim", "omni.isaac.sim.kit"], check=True)
This has access to all the utilities.
Be aware that the window will be blank for quite a long time after loading. This is what threw me off the scent the first time around.
