Accessing of Jetson AGX Orin Registers using devmem2 tool
Hi Team,
We are trying to access the following register using devmem2 tool in the Jetson AGX Orin module.
Following is the address details, calculated from the TRM manual TRM(Orin-TRM_DP10508002_v1.2p)
Address[0x3D729] : Base address[0x31000] + Offset[0xC729]
But getting below error:
jetson@tegra-ubuntu:~$ sudo devmem2 0x3D729
/dev/mem opened.
Memory mapped at address 0xffff9a6ae000.
Bus error
Can you please help us to check , whether base address or any changes in address .
Ramesh
Have reference to below topic.
Hi Team,
we want to perform the PRBS testing using below register, we are trying to access the register using devmem2 tool in the devkit .
But while reading and writing the registers its not reflecting the changes and always its showing as 0XFFFFFFFF .
please let me know any issue accessing the address
Address[0x3D710] : Base address[0x31000] + Offset[0xC710]
Register: NVCSI_PHY_2_NVCSI_CIL_CPHY_BIST_CONFIG_0_0
jetson@tegra-ubuntu:~$ sudo devmem2 0X3D710
/dev/mem opened.
Memory mapped at address 0xffffba62e000.
Value at address 0x3D710 (0xffffba62e710): 0xFFFFFFFF
jetson@tegra-ubuntu:~$ sudo devmem2 0X3D710 w 0x101
/dev/mem opened.
Memory mapped at address 0xffff98af8000.
Value at address 0x3D710 (0xffff98af8710): 0xFFFFFFFF
Written 0x101; readback 0xFFFFFFFF
Please let us know the if any correction in accessing the address and point the correct address if any thing wrong .
Ramesh
Hi team,
please help to get the base address of below register
After referring the TRM(Orin-TRM_DP10508002_v1.2p) manual
we got few address related to PHY_2 as shown below and tried to access them, but its not working.
uphy2
please help to get the exact base address for the register mentioned above would be helpful.
Ramesh
It’s 0x15a00000, UPHY should be the USB control.
HI Shane,
We have tried with 0x15a00000. When we read it is always 0xFFFFFFFF and after writing different values also it is showing 0xFFFFFFFF
nvidia@tegra-ubuntu:~$ sudo devmem2 0x15A0C710
/dev/mem opened.
Memory mapped at address 0xffffb2897000.
Value at address 0x15A0C710 (0xffffb2897710): 0xFFFFFFFF
jetson@tegra-ubuntu:~$ sudo devmem2 0x15A0C710 w 0x00000009
/dev/mem opened.
Memory mapped at address 0xffff996af000.
Value at address 0x15A0C710 (0xffff996af710): 0xFFFFFFFF
Written 0x9; readback 0xFFFFFFFF
As per the adaptation guide, only UPHY0 can be configured as USB. So our understanding is that the address what you are saying is related to UPHY0. Is it correct?
We are using UPHY2 lane4 for MGBE, so we need to configure the UPHY2 lane4 registers of Tx and Rx lines for PRBS. Can you help on this.
Ramesh
Do you disable the firewall?
