Calculating/Getting register adresses of gpio pins
I am currently using a Jetson AGX Orin devkit with Jetpack 5.1.
At the moment, I control the GPIO Pins of the 40Pin header on the Devkit through the sysfiles with the GPIO numbers.
But I would like to be able to modify the Pin behavior directly through their register addresses.
Which I previously did on a Jetson Xavier NX, but I’m having trouble getting the addresses of the pins.
Before, I converted the default dtsi files via the “pinmux-dts2cfg.py” script to a cfg file.
In this, I could just read the register addresses for each pin and its control register.
pinmux.0x022138e0 = 0x00000001; # CONFIG T7
pinmux.0x02431070 = 0x00000000; # GPIO dap5_din_pt7
(Without actually using/flashing the config)
However, it seems converting dtsi files on AGX Orin is no longer possible/necessary.
In Orin pinmux python giving key error
Python pinmux-dts2cfg.py Error Processing GPIO File
I can calculate the Control register address of a pin with the DRM of the Orin:
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html#mb2-configuration-changes
But I’m not sure how I can get the address of the gpio value.
Any way of easily obtaining those?
If you are designing a custom base board, then it means some adaptation configurations are needed.
Otherwise, your board may not work fine.
For Orin AGX series, you could refer to below document
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=universal%20serial%20bus#jetson-agx-orin-platform-adaptation-and-bring-up
(please be aware that above link is for rel-36.3/jetpack6.0)
This document includes below configuration
  1. pinmux change & GPIO configuration
  2. EEPROM change as most custom boards do not have an EEPROM on it.
  3. Kernel porting
  4. PCIe configuration
  5. USB configuration
  6. MGBE configuration
  7. RGMII configuration
For now I’m just using the Devkit and wish to control the Gpio-Pins on the 40Pin Header directly though their register address, for a lower and more consistent latency.
The linked article has basically the same information as the one I linked.
And I can’t find a way there to get the register address of the value for the gpio pin.
Is there anywhere the registers are stored, like they were in the now obsolete cfg file generated by the python script. Where I could cat for the specific gpio I’m looking for.
Or at least a way to calculate the address similar to the cfg register address of the pin.
Hi jost38,
We would suggest you updating to the latest JP5.1.4(R35.6.0) to verify.
To get the pinmux register for specific pin, you can refer to the Orin TRM document.
And run the following command to get its value.
$ sudo busybox devmem <register>
so I have worked through the TRM.
This is the way I found of calculating the correct registers:
PIN 7 on Orin AGX
Find the Pin in the Pinmux excel sheet through Signalname from DevKitCarrierBoardSpecification
→ PIN7 MCLK05 L57 (Carrier Board Speci)
=> L57 MCLK05 SOC_GPIO33 GPIO3_PQ.06 (Excel Pinmux)
PADCTL:
  1. search for “SOC_GPIO33” in TRM
    ->found in SystemCPomponents->MultipurposeIO->G3 Pad Control Registers
    :PADCTL_G3_SOC_GPIO33_0
    :Offset: 0x70
    :And Bit Description
  2. Find Base adress Block
    From Table 8.4.1.6 Pad Control Grouping find corresponding Base Address Block
    ->G3 Yes PADCTL_A0
  3. FInd Base Adress
    In Table 3.2.2 System Adress Map
    ->PADCTL_A0 0x02430000 0x02430fff SYSTEM
  4. Combine Base and Offset
    0x02430000 + 0x70 = 0x02430070
  5. Bit description
    12 E_SCHMT 0=Disable 1=Enable
    10 GPIO_SF_SEL 0=GPIO 1=SFIO
    8 E_LPDR 0=Disable 1=Enable
    7 E_LPBK 0=Disable 1=Enable
    6 E_INPUT 0=Disable 1=Enable
    5 E_IO_HV 0=Disable 1=Enable
    4 TRISTATE 0=Disable 1=Enable
    3:2 PUPD 0=None 1=PullDown 2=PullUp 3=RSVD
    1:0 PM 0=RSVD0 1=EXTPERIPH4 2=DCB 3=RSVD3
  6. Usage
    Set GPIO: Bit 10 = 0.
    For the output, set Bit 4 = 0 ; Bit 6 = 0.
    For Input, set Bit 4 = 1 ; Bit 6 = 1.
GPIO Control Register
  1. Identify GPIO Port and Number
    Port:Q Pin:6
  2. Find corresponding GPIO controller
    ->From Table in Chapter 8.5.1.2 Features GPIO Controllers and Port Mapping
    GPIO_CTL2 M (8) N (8) EDP VDDIO_EDP
    P (8) Q (8) R (6) G3
  3. Find Base Adress of controller
    ->In
    GPIO_CTL2_GPIO0 0x02230000 0x02230fff SYSTEM
=>IS GPIO_CTL2_GPIO0 CORRECT HERE AND WHY GPIO0 ?
  1. Find Adresses of the Registers with Port(q) and Pin(6)
    ->In 8.5.6 GPIO Control Registers
GPIO_Q_ENABLE_CONFIG_06_0 Offset: 0x126c0
GPIO_Q_DEBOUNCE_THRESHOLD_06_0 Offset: 0x126c4
GPIO_Q_INPUT_06_0 Offset: 0x126c8
GPIO_Q_OUTPUT_CONTROL_06_0 Offset: 0x126cc
GPIO_Q_OUTPUT_VALUE_06_0 Offset: 0x126d0
GPIO_Q_INTERRUPT_CLEAR_06_0 Offset: 0x126d4
(GPIO_Q_INTERRUPT_STATUS_G6_0 Offset: 0x12718)
=> as seen the other Offsets als always constant from the first and a fixed value can be added
  1. Combine Base and Offset Address
    0x02230000 + 0x126c0 = 0x022426c0 for ENABLE_CONFIG of pin pq.06 ?
  2. Bit description
    ENABLE_CONFIG:
    7 TIMESTAMPING_FUNCTION 0=Disable 1=Enable
    6 INTERRUPT_FUNCTION 0=Disable 1=Enable
    5 DEBOUNCE_FUNCTION 0=Disable 1=Enable
    4 TRIGGER_LEVEL When NO TRIGGER: this field is irrelevant
    When LEVEL: 0 = Trigger on level Low. 1 = Trigger on Level High
    When SINGLE EDGE: 0 = Trigger on Falling Edge. 1 = Trigger on Raising Edge
    When BOTH EDGES: this field is irrelevant
    3:2 TRIGGER_TYPE 0=NO_TRIGGER 1=LEVEL 2=SINGLE_EDGE 3=DOUBLE_EDGE
    1 IN_OUT 0=In 1=Out
    0 GPIO_ENABLE 0=Disable 1=Enable
    DEBOUNCE_THRESHOLD:
    7:0 DEBOUNCE_THRESHOLD 0=No Debounce 1~N-1=Debouncing interval of 1 msec to (N-1) msec.
    INPUT:
    0 GPIO_IN This field holds the GPIO Input value sampled after the specified Debouncing interval
    OUTPUT_CONTROL:
    0 GPIO_OUT_CONTROL 0=DRIVEN 1=FLOATED
    OUTPUT_VALUE:
    0 GPIO_OUT_VAL This field holds the GPIO output value to be driven
    INTERRUPT_CLEAR
    0 GPIO_INTERRUPT_CLEAR 0=DON’T CLEAR 1=CLEAR.
    (INTERRUPT_STATUS:)
    (7:0 GPIO_INTERRUPT_STATUS 0=Interrupt not set 1=Interrupt set)
However, I am unsure as to which the correct Base address of the GPIO controller would be.
Is it GPIO_CTL2_GPIO0 and why is it the one with the zero at the end?
Are the adresses for the pin pq.06 correct?
PADCTL = 0x02430070
GPIO_CTL = 0x022426c0 (for enable config)
This is regarding the Jetson Orin AGX.
For the Jetson Xavier Nx I’m unable to locate the System Address Map for the GPIO controller in the Xavier NX TRM.
With is present in the Orin Series TRM in Chapter 8.5.3.1 System Address Map (AMAP).
Can you also assist me in locating that for the jetson Xavier series.
Correct!
Please open another topic for Xavier since the current topic is in AGX Orin category.
Thank you for the confirmation.
Can you still explain why GPIO_CTL2_GPIOzero is the correct base address?
Respectively if it is always GPIO_CTLx_GPIO0 (GPIOzero) and what the other GPIO_CTLx_GPIOy meaning/purpose is.
Correct is for PADCTL register of PQ.06
Please refer to the above info from TRM that all control registers use the same base address of GPIO_CTL as following.
So, please use 0x02200000(GPIO_CTL) + 0x126c0(GPIO_Q_ENABLE_CONFIG_06_0) = 0x022126c0 for ENABLE_CONFIG of PQ.06
Please try to control it and check if the pin state would be changed.
Ah ok, thank you.
I confirmed that it works with busybox and can control/read the pin.
I just realized that PIN16 of the 40Pin expansion header is part of the AON Group, with it being GPIO3_PBB.0.
And for them the TRM mentions:
All AON, i.e. GPIO_, Control Registers share the same base address under the name AON_GPIO_0,
where = AA, BB, CC, DD, EE, and GG.
Basically the same as for the Non AON Control Registers.
However, I am unable to find the base Address of the AON GPIO Control Register (AON_GPIO_0) in the Address Map of the TRM, as mentioned right below:
For the base address of Non-AON GPIO Control Registers (GPIO_CTL) and AON GPIO Control Registers (AON_GPIO_0), please refer to the System Address Map in this TRM.
As there seems to no AON_GPIO_0 mentioned in the System Address map.
But I found in a git repo (jetGpio) the base Address of AON_GPIO_0 to be 0x0c2f0000.
Which worked for reading the values of a pin when added with its offset.
But I am not able to find that information in the TRM.
