Description
Hello, I used TAO to train a multitask classifier, and then converted it to .etlt (fp32) using tao multitask_classifier export, and exported it to .engine (fp32) using tao convert. Both conversion and export were made in a docker image ( nvcr.io/nvidia/tao/tao-toolkit-tf v3.21.11-tf1.15.5-py3 c607b0237bc5).
I noticed a drop in accuracy when I run inferences using the .engine model, and I can’t find the reason. Some people say it might be the preprocessing used by tao that is different from tensorRT, or it could be an issue during the export / conversion.
When I run evaluation on the tlt model, it is able to reach 90% accuracy, but when it comes to the .engine model, the results seem random.
Environment
TensorRT Version: 8.0.1
Nvidia Driver Version: nvcr.io/nvidia/tao/tao-toolkit-tf v3.21.11-tf1.15.5-py3 c607b0237bc5
CUDA Version: 11.3
Operating System + Version: Ubuntu 20
Python Version (if applicable): 3.9.7
Baremetal or Container (if container which image + tag): nvcr.io/nvidia/tensorrt 21.08-py3 cc8404aefdca
Relevant Files
you’ll find the python script and models bellow :
Thank you in advance,
