Use the following commands to inference:
gst-launch-1.0 filesrc location={Car Image} ! jpegparse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=224 height=224 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test2/dstest2_pgie2_config.txt ! queue ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! jpegenc ! filesink location=result.jpg
dstest2_pgie2_config.txt is here: dstest2_pgie2_config.txt (3.8 KB)
Due to I get the accuracy of model about 91%, so I am confused of my inference result.
Is there any process I miss? Or something of limitation of model?
Thanks your reply.
91% is from NGC model: https://ngc.nvidia.com/catalog/models/nvidia:tlt_vehiclemakenet Methodology and KPI part.
And 35% is correct images divide total images:
Correct images: Images that correct inference from model
Total images: Total numbers of images to be inference
@chris5_lin
According to your comments above, you want to compare https://ngc.nvidia.com/catalog/models/nvidia:tlt_vehiclemakenet (https://ngc.nvidia.com/catalog/models/nvidia:tlt_vehiclemakenet )
So, please follow /opt/nvidia/deepstream/deepstream/samples/configs/tlt_pretrained_models/README to download necessary models and then run below command.
$ deepstream-app -c deepstream_app_source1_trafficcamnet.txt
In dstest2_pgie2_config.txt (3.8 KB), you were using caffe model instead of tlt models. So, you were not testing tlt models at all.
