Ace Tokkio deployment failing
applying task: check-nvidia-gpu-operator-pods-up
PLAY [all] ************************************************************
TASK [Gathering Facts] ********************************************************
ok: [app-master]
TASK [fail if no pods] ********************************************************
FAILED - RETRYING: [app-master]: fail if no pods (20 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (19 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (18 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (17 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (16 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (15 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (14 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (13 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (12 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (11 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (10 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (9 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (8 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (7 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (6 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (5 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (4 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (3 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (2 retries left).
FAILED - RETRYING: [app-master]: fail if no pods (1 retries left).
fatal: [app-master]: FAILED! => {“api_found”: true, “attempts”: 20, “changed”: false, “resources”: }
PLAY RECAP ************************************************************
app-master : ok=1 changed=0 unreachable=0 failed=1 skipped=0 rescued=0 ignored=0
I had the same issue and for me the problem was that I tried installing the app to Ubuntu Desktop where I had a terminal opened. After closing the terminal installation successfully finished.
