Hello
Has anyone tried setting up High-Precision AD/DA Board work with Jetson Orin Nano Dev Kit 8GB ? Else can you recommend an AD for Jetson Orin nano dev kit please?
My use case is analog to digital conversion.
I see Jetson nano software, not orin. First try using jetson nano code errors and exists at try to ADC.ADS1256_init():
ID Read failed
Thank you for your help !
Could you please mention AD/DA board is connected to which tegra interface/signals.
Hello @Sheetal.G I’m on Jetpack 6, I am using RPi.GPIO library and I cannot find /gpio : cannot ls /sys/class/gpio . Is it something else in Jetpack 6?
(base) sergio@jetson:/sys/class$ sudo su
root@jetson:/sys/class# echo 474 > /sys/class/gpio/export
bash: /sys/class/gpio/export: No such file or directory
root@jetson:/sys/class# ls /sys/class/gpio
ls: cannot access ‘/sys/class/gpio’: No such file or directory
My system:
(base) sergio@jetson:~$ cat /etc/nv_tegra_release
R36 (release), REVISION: 2.0, GCID: 34956989, BOARD: generic, EABI: aarch64, DATE: Thu Nov 30 19:03:58 UTC 2023
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
(base) sergio@jetson:/sys/class$ uname -r
5.15.122-tegra
gpio sysfs is deprecated now. Please use gpiod_tools instead.
- Steps to install gpiod tools
sudo apt update
sudo apt-get install gpiod
Also please help with the info which interface (like I2C1 / SPI) AD/DA board is connected.
