hello I detected It’s not exclusive nVIDIA jetson issue It’s happen too on NVIDIA desktop only in Linux drivers .
Seems not implemented this
// Copyright (c) 2017-2020 The Khronos Group Inc.
// SPDX-License-Identifier: CC-BY-4.0
include::{generated}/meta/{refprefix}VK_EXT_external_memory_host.txt[]
=== Other Extension Metadata
*Last Modified Date*::
2017-11-10
*IP Status*::
No known IP claims.
*Contributors*::
- Jaakko Konttinen, AMD
- David Mao, AMD
- Daniel Rakos, AMD
- Tobias Hector, Imagination Technologies
- Jason Ekstrand, Intel
- James Jones, NVIDIA
This file has been truncated. show original
https://www.khronos.org/registry/vulkan/specs/1.2-extensions/man/html/VK_EXT_external_memory_host.html
Ih the log from pc driver https://developer.nvidia.com/vulkan-driver It’s implemented from 2018 but not implemented for Linux driver.
It would be good to give you support,on Linux too thank you very much.
kayccc
May 17, 2020, 11:17pm
2
Hi _Diablo,
So you did installed the Vulkan 1.2 that we provided at Vulkan Support on Jetson Linux | NVIDIA Developer , and still found this issue, right?
Yes that is even with the new image with the update vulkan 1.2 is not present
Not found this extension for some reason
For now this extension has only been detected in the windows driver on PC from 399.41 but not on Jetson or linux PC driver.
Regards.
Mrc.
Hi _Diablo,
Thanks for reporting this issue.
I will forward this issue to our internal team to do further investigating to see if can have the fix.
Any update on this? I’m also interested in having this (though on Xavier NX). I understand it’s in the desktop Linux driver now but not in L4T yet as far as I can tell.
Any news on this? no Supported tested on Jetson pack 4.5.x with all update
Not returned support this extension by Vulkaninfo .
kayccc
July 28, 2021, 7:56am
9
This feature still not supported yet, internal team will make plan to see if can be supported in future release.
kayccc
January 5, 2022, 1:13am
10
Issue will be fixed at the next JetPack release. Thanks
system
Closed
January 19, 2022, 1:14am
11
