Hi Seems not supported and the driver Vulkan driver is stuck 1.1.85 on jetson nano Any plans update in the future?
The vulkaninfo only returned these extensions supported.
Blockquote
VK_EXT_blend_operation_advanced : extension revision 2
VK_EXT_conditional_rendering : extension revision 1
VK_EXT_conservative_rasterization : extension revision 1
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_descriptor_indexing : extension revision 2
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_global_priority : extension revision 2
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_post_depth_coverage : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_sampler_filter_minmax : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_KHR_16bit_storage : extension revision 1
VK_KHR_8bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 3
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_multiview : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 1
VK_KHR_sampler_ycbcr_conversion : extension revision 1
VK_KHR_shader_atomic_int64 : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_float16_int8 : extension revision 1
VK_KHR_shader_float_controls : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 2
VK_NVX_device_generated_commands : extension revision 3
VK_NVX_multiview_per_view_attributes : extension revision 1
VK_NV_dedicated_allocation : extension revision 1
VK_NV_device_diagnostic_checkpoints : extension revision 2
VK_NV_fill_rectangle : extension revision 1
VK_NV_fragment_coverage_to_color : extension revision 1
VK_NV_framebuffer_mixed_samples : extension revision 1
VK_NV_geometry_shader_passthrough : extension revision 1
VK_NV_sample_mask_override_coverage : extension revision 1
VK_NV_shader_subgroup_partitioned : extension revision 1
VK_NV_viewport_array2 : extension revision 1
VK_NV_viewport_swizzle : extension revision 1
