• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.1
• TensorRT Version: 8.2.5-1+cuda11.4
• NVIDIA GPU Driver Version (valid for GPU only): 510.73.05
• Issue Type( questions, new requirements, bugs): Question/bug
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing):
I’m currently using the example from the Deepstream python apps called deepstream_test1_rtsp_in_rtsp_out.py.
I have modified the script to use a custom YoloR following the instructions in this other repository: GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 6.1 / 6.0.1 / 6.0 configuration for YOLO models
I have also added code from other examples to get the number of fps and send it to the osd.
The issue I’m having is that the inference speed halves when adding a new source. I have several rtsp streams in h264 running at 15 fps, when I run the pipeline with just 1 stream, it runs at 15 fps and the GPU sits at 10-12% utilisation. When I add a second stream, inference speed and GPU utilisation remains the same overall, essentially halving the number of fps for each of the streams. This happens again when doubling the amount of streams. It sits at 15fps and 10-12% utilisation
