along with my robot actor, I added one simple sphere actor by using these lines:
ball_asset_options = gymapi.AssetOptions()
ball_asset_options.disable_gravity = True
ball_asset_options.fix_base_link = True
ball_asset= self.gym.create_sphere (self.sim, 0.2 , ball_asset_options)
# set ball dof properties
ball_dof_props = self.gym.get_asset_dof_properties(ball_asset)
for i in range(self.num_envs):
# create env instance
env_ptr = self.gym.create_env(
self.sim, lower, upper, num_per_row
robot_actor = self.gym.create_actor(env_ptr, my_robot_asset, my_robot_start_pose, "my_robot", 1)
ball_actor = self.gym.create_actor (env_ptr,ball_asset, robot_start_tip_pose, "ball", 2)
Then the reset() function in the post_physics_step() creates error:
def post_physics_step(self):
self.progress_buf += 1
env_ids = self.reset_buf.nonzero(as_tuple=False).squeeze(-1)
if len(env_ids) > 0:
self.reset(env_ids)
The complete error messages looks like this:
[Error] [carb.gym.plugin] Gym cuda error: an illegal memory access was encountered: …/…/…/source/plugins/carb/gym/impl/Gym/GymPhysXCuda.cu: 981
File “train.py”, line 35, in
train()
File “train.py”, line 26, in train
ppo.run(num_learning_iterations=ppo_iterations, log_interval=cfg_train[“learn”][“save_interval”])
File “/home/user/.local/lib/python3.6/site-packages/rl_pytorch/ppo/ppo.py”, line 100, in run
current_obs = self.vec_env.reset() # .astype(np.float32)
File “/home/user/Downloads/isaacgym/python/rlgpu/tasks/base/vec_task.py”, line 137, in reset
self.task.step(actions)
File “/home/user/Downloads/isaacgym/python/rlgpu/tasks/base/base_task.py”, line 143, in step
self.post_physics_step()
File “/home/user/Downloads/isaacgym/python/rlgpu/tasks/test.py”, line 404, in post_physics_step
self.reset(env_ids)
File “/home/user/Downloads/isaacgym/python/rlgpu/tasks/test.py”, line 350, in reset
self.progress_buf[env_ids] = 0
RuntimeError: CUDA error: an illegal memory access was encountered
