After installed of rtx 3080 mobile 16g , the nvidia-smi cmmand output no device were found
ubuntu 22.04, 6.2.0-37-generic
intell i9 12900h
rtx 3080 mobile 16g
nvidia-bug-report.log.gz (295.9 KB)
[17560.387781] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1482)
[17560.387888] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Please use Software & Updates to switch to the “-open” driver version and set kernel parameter nvidia.NVreg_OpenRmEnableUnsupportedGpus=1
libkmod: ERROR …/libkmod/libkmod-config.c:712 kmod_config_parse: /etc/modprobe.d/nvidia.conf line 1: ignoring bad line starting with ‘nvidia.NVreg_OpenRmEnableUnsupportedGpus=1’
how to set the kernel parameter ?
I just do :
add a confi file,and the file content is :‘nvidia.NVreg_OpenRmEnableUnsupportedGpus=1’
then excute:
update-initramfs -u
i get the error notice:
If you put it into a modeprobe conf file, the syntax is
options nvidia NVreg_OpenRmEnableUnsupportedGpus=1
thank you reply,
i put the parameta to :nvidia-graphics-drivers-kms.conf,
options nvidia-drm modeset=1
then reboot os,
then nvidia-smi , no device were found
and then, re nvidia-bug-report.sh, I notice the log :
[ 8563.861326] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1482)
[ 8563.861463] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
nvidia-bug-report.log.gz (278.7 KB)
Sorry, I didn’t notice you initially used the runfile installer which had to be uninstalled first, so that one is still active. Please switch to nouveau in Software&Updates, then run the runfile installer again with --uninstall option, then switch back to the -open driver in Software&Updates.
thankx, it works,
