Nvidia-smi: No devices were found
I’m trying to install my eGPU on my Dell Latitude running ubuntu 20.04 but with no success. I followed this tutorial and some other online ones.
I have attached the report log file.
Any help with debugging and solving that issue?
Many thanks
lspci -nnk | grep -iA2 vga
0000:00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:9a49] (rev 01)
	Subsystem: Dell Device [1028:0a21]
	Kernel driver in use: i915
0000:2d:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:2504] (rev a1)
	Subsystem: ZOTAC International (MCO) Ltd. Device [19da:4630]
	Kernel driver in use: nvidia
nvidia-bug-report.log (4.5 MB)
Please set kernel parameter
nvidia.OpenRmEnableUnsupportedGpus=1
Should I add the parameter to
/etc/default/grub ?
yes.
When I update the grub it says :
/usr/sbin/grub-mkconfig: 12: /etc/default/grub: nvidia.OpenRmEnableUnsupportedGpus=1: not found
Should I write it differently?
Not that way.
https://askubuntu.com/questions/19486/how-do-i-add-a-kernel-boot-parameter
Now I have the parameter added:
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash nvidia.OpenRmEnableUnsupportedGpus=1”
I still however get No devices were found
Please create a new nvidia-bug-report.log
Here it is. Thank you.
nvidia-bug-report.log (5.6 MB)
Oops, my bad, sorry. The parameter should be
nvidia.NVreg_OpenRmEnableUnsupportedGpus=1
Please change and try again.
It is working now. Thank you.
However, my boot stuck at the dell logo when the eGPU is plugged in, but it starts normally when it is unplugged. Any solution to that, please?
I think I need to make my ubuntu not use the Nvidia card for x server?
Please delete /etc/X11/xorg.conf
