I am trying to use an eGPU with Ubuntu on Intel NUC device. My configuration is Intel NUC 11PAHi7 + Ubuntu 22.04.1 LTS + Razer Core X + Nvidia Titan RTX eGPU. I do not seem to be able to get the eGPU running with Ubuntu (or even on Windows). When I try to boot with the eGPU connected to the NUC, the device hangs during boot up. Instead, if I boot up the device to Ubuntu and then connect the eGPU, I see that the nvidia driver module is loaded, but nvidia-smi still says ‘No devices were found’.
I am attaching the output from ‘sudo nvidia-bug-report.sh --safe-mode --extra-system-data’ (this command also hangs the device without --safe-mode). I appreciate any help/suggestions on how to fix this issue!
Thank you,
Krishna.
nvidia-bug-report.log.gz (89.7 KB)
Edit:
If I plugin the display directly to the eGPU, the display is garbled and hangs during boot up.
