Hi all, I am working on a razer blade stealth with razer core x, inside the razer core i have a nvidia geforce 1060 graphic card. I have set the bios thunderbolt settings for the use of egpu, (it works brillantly back then when i was using windows). And i have switch system76-graphics to hybrid. First pop os won’t boot correctly when the egpu is connected, secondly if i boot without the egpu and i plug it later my second screen and my nvidia will be recognized but my second screen (which is plugged in the egpu) won’t swith on and the graphics performance are verry poor, the nvidia x server shows nothing (no trace of the nvidia card). I have uninstall reinstall system76 power and nvidia graphic (provided with pop os) but nothing has changed. I have read many things and my issu is similar to the one faced by this guy: Razer Blade 15 (2018) / Razer Core V1 / NVidia 1080 TI / POP OS 20.04 | Thunderbolt Linux eGPU . But still no solution that works.
My etc/modprobe.b.system76-power.conf file is maybe the source of the problem after all of what i have read but i don’t know what i should change:
Automatically generated by system76-power
blacklist i2c_nvidia_gpu
alias i2c_nvidia_gpu off
options nvidia NVreg_DynamicPowerManagement=0x02
options nvidia-drm modeset=1
Thank you for your answer, On my /usr/share/X11/xorg.conf.d/10-nvidia.conf i have put: Option “AllowExternalGpus” “true”
and reboot, but still not solved. Anything i have missed ?
I had no problem when using it with windows, the egpu doesn’t work since i have installed linux. Nevertheless i have an other thunderbolt cable i will try and tell you the results
Just tried with an other thunderbolt cable same problem. Impossible to boot with the egpu connected. And when i connect it when booted nvidia x server show nothing and the screen connected to the egpu stay black
sudo systemctl restart display-manager work, it’s a bodge i have to start my computer without the egpu, plug it, and then restart display manager, but at least it works so thank you very much. Don’t you know why the display manager is blocking at the boot when the egpu is plug ?
Hi, I am having this same issue. I have an intel based hp laptop using the razer core with an RTX 2060 and just installed Pop Os 21.04. Pop Os will not boot or will take many minutes to boot with the egpu plugged in. I have to boot without it, plug it in, and type sudo systemctl restart display-manager as you have mentioned. Is there a way to fix this so it works on boot? @generix
