Agx orin 32G/64G 功耗上限有差异
我们在 JP5.1.4/JP6.2 上测试了agx orin 32G/64G ,发现有些机器的功耗上限是50W,而有些机器是40W,起初我们以为是64G功耗更高,但后来发现有些64G的也只有40W的上限,请问这是怎么回事?
There should be different between 32G and 64G module.
The max power in 32G is 40W; 64G is 50W, you can refer to Jetson Orin Nano Series, Jetson Orin NX Series and Jetson AGX Orin Series — NVIDIA Jetson Linux Developer Guide
Please be sure to set the devcie with max power mode with the nvpmodel command before running the test.
