AGX Orin 64gb upgrade to Jetpack 6.2
I recently acquired a AGX Orin 64GB and it is on jetpack 5.1.2-b104. I have run the ‘sudo apt install nvidia-jetpack’ to try to upgrade it to 6.x but it goes through and says it’s already on latest. Is there a way to force it or something that needs to be updated prior?
Trying not to use the SDK Manager - I have an Orin Nano so could use that as a host I guess but was hoping to just update OTA.
Below are excerpts from this doc page.
I believe you have to use sdkmanager, or one of the *flash.sh methods, to get from Jetpack 5.1.2 to Jetpack 6.2.
Debian Package: If you have JetPack 6 already installed on Jetson AGX Orin Developer Kit or Jetson Orin Nano Developer Kit, you can upgrade to JetPack 6.2 using APT.
Jetpack 6.0-6.2 does a firmware update that is required to run 6.0-6.2.
NVIDIA SDK Manager supports JetPack installation on these Jetson products:
NVIDIA Jetson AGX Orin Developer Kit
A Linux host computer running Ubuntu Linux x64 version 22.04 or 20.04 is required to run NVIDIA SDK Manager.
thanks @whitesscott - I ended up using the SDK manager since I wanted to instal to the NVMe drive I installed - worked well and up and running!
