AGX Orin Crashing on random intervals
• Hardware Platform (Jetson / GPU) : NVIDIA Jeston ORIN
• DeepStream Version : 7.1 & 6
ardware Platform (Jetson / GPU) : Nvidia AGX Orin [64GB Developer kit]
Issue Type(questions, new requirements, bugs) : Bugs
I am trying to run the Yolo Pose detection with Jetpack 6.3 and Deepstream 7.1 but I keep getting this error and the application doesn’t keep running for 30 minutes and keeps crashing on random intervals. Whereas, the application runs fine without any crash in Jetpack 5.1 and Deepstream 6.3.
There are two types of error i am getting randomly
1.
ERROR: Failed to make stream wait on event, cuda err_no:700, err_str:cudaErrorIllegalAddress
libnvosd (1386):(ERROR) : cuGraphicsEGLRegisterImage failed : 700
ERROR: Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
0:06:10.250301857 332222 0xaaaadd1abd80 WARN                 nvinfer gstnvinfer.cpp:1420:gst_nvinfer_input_queue_loop:<pgie> error: Failed to queue input batch for inferencing
ERROR: gst-resource-error-quark: Unable to draw shapes onto video frame by GPU (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvdsosd/gstnvdsosd.c(645): gst_nvds_osd_transform_ip (): /GstPipeline:pipeline0/GstNvDsOsd:nvdsosd
GPUassert: an illegal memory access was encountered /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/src/modules/cuDCFv2/cuDCFFrameTransformTexture.cu 611
!![Exception] GPUassert failed
An exception occurred. GPUassert failed
gstnvtracker: Low-level tracker lib returned error 1
CUDA Runtime error cudaFreeHost(host_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:78
CUDA Runtime error cudaFree(device_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:79
track_keypoints1 {}
2.
0:00:39.962909330 262869 0xaaab1480d980 WARN                 nvinfer gstnvinfer.cpp:1420:gst_nvinfer_input_queue_loop:<pgie> error: Failed to queue input batch for inferencing
ERROR: gst-stream-error-quark: Failed to queue input batch for inferencing (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1420): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline0/GstNvInfer:pgie
[WARN ] 2025-03-12 15:31:23 (cudaErrorIllegalAddress)
[ERROR] 2025-03-12 15:31:23 Error destroying cuda device:
[ERROR] 2025-03-12 15:31:23 Error destroying cuda device:  nN
Same issue is raised in forum : ARUNKRISHNA THAYYILRAVI: forum. https://forums.developer.nvidia.com/t/agx-orin… | NVIDIA-ppt-updates-12032025
How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
  1. Flash Jetson Orin AGX with Jetpack 6.3 and Deepstream 7.1
  2. Build pyds from source (https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/bindings) and install python-gi-dev
  3. Install the pose detection (yolo7 Pose) code using Deepstream from https://github.com/NVIDIA-AI-IOT/deepstream_python_apps
  • Bounding box created using yolo pose being tracked by deep stream [nvDCF]
  1. Launch the application with camera input (USB based )
  2. Application crashes after 20 mins - 1 hour [This is not fixed time]
  3. The Overlay-ed Pose is displayed on screen using gstream
We never provide any yolo7 pose code in deepstream_python_apps. Can you provide the code and configurations you are using?
What kind of USB camera?
How did you make sure that the issue is not related to the opencv overlay code?
Your description is too general to provide enough information. Please follow the instruction
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
