I found the ORin platform DTS structure a little different than agX Xavier
Is there a specific method ?
Does the Orin platform still need to block this “Does the Orin platform still need to block this”?
I would suggest reference to imx477 to implement your driver.
agx orin r34.1.1
I can’t find the DTS configuration for IMX477 in the following directory
“Linux_for_Tegra/source/hardware/nvidia/platform/t23x”
Doesn’t T23X stand for AgX Orin ?
Yes, should be t234 for Orin.
If you want implement your own device tree that don’t necessary.
You mean I can directly add my own Camera DTS in the following DTSI
“Linux_for_Tegra/source/hardware/nvidia/platform/t23x/concord/kernel-dts/cvb/tegra234-p3737-camera-modules.dtsi”
Another question is, custom kernels compiled byself need to be signed ???
Yes, and no need sign.
Have checking the programing guide and kernel building.
May I ask, my transplanted camera driver and DTS have been loaded normally, why is there no video production
Could be your device tree have problem cause the problem.
my orin version : r34.0.1
The kernel version I compiled was based on R34.1.1
Is this feasible???
I have the same problem. the video node cann’t be generated. Did you succeed?
Me too …
For Orin need change the vi@xxxxx{} to tegra-capture-vi{} also the nvcsi@ could be different.
18 tegra-capture-vi {
19 num-channels = <1>;
20 ports {
21 #address-cells = <1>;
22 #size-cells = <0>;
23 port@0 {
24 reg = <0>;
25 liimx185_vi_in0: endpoint {
26 port-index = <0>;
27 bus-width = <4>;
28 remote-endpoint = <&liimx185_csi_out0>;
29 };
30 };
31 };
32 };
33
34 host1x@13e00000 {
35 nvcsi@15a00000 {
36 num-channels = <1>;
37 #address-cells = <1>;
