Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.10816
other
Host Machine Version
other
I am setting up the Linux Host pc and AGX Orin for first time. i am unable to flash on target hardware. I am not sure if connection between host pc and orin is wrong or i am missing some setting on SDK manager.
@deepak.dubey
Have you followed the messages to find /dev/ttyACM1 on your host?
Please provide all logs under ~/.nvsdkm directory on your host system for our analysis.
Dear @deepak.dubey,
Could you share output of lsusb before and after connecting host and target via USB cable? You are expected to see Nvidia devices in lsusb and also /dev/ttyACM*files on host after connecting host and target. Have you followed the DRIVE AGX Orin Quick start guide ?
Dear @deepak.dubey,
Please use text messages instead of images to be able to searchable by others in community.
It seems now you are able to see /dev/ttyACM* files on host. What changes you have made in connection compared to earlier?
Also I see, /dev/ttyACM0 window opened in shared pictures. Was it kept open when flashing board? If so, you need to close all serial connection to target when flashing.
I see below message in logs
08:59:19.496 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: Executing bind cmd make/bind_partitions -b p3710-10-s05 linux
08:59:19.696 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: Binding of partitions failed ! Check log for more details.
08:59:19.699 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: Failed to bind partitions!
08:59:19.699 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: driveinstaller cannot continue! Check the log file for details: /home/cm/.nvsdkm/driveinstaller.log
08:59:19.715 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: [ Component Install Finished with Error ]
08:59:19.715 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: [host] [ 4.41 MB released. Disk Avail: 123.27 GB ]
08:59:19.715 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: [ NV_DRIVE_FLASH_DRIVE_COMP Install took 23s ]
08:59:19.717 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS:
08:59:19.717 - error: command error code: 11
08:59:19.717 - info: Event: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS - error code is: 1011
08:59:19.717 - error: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: command terminated with error
08:59:19.717 - info: Event: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS - error is: command terminated with error
08:59:19.720 - info: Event: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS - install ended - failure
08:59:19.721 - error: Session first failure occurred while Installing. Root cause component: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS. Root cause error code: (1011: Failed to execute commands with GenericInstaller)
Could you share the /home/cm/.nvsdkm/driveinstaller.log as well.
The below messages are seen in your logs.
It may be something to do with the python environment.
Please try if using another host system helps on this.
[2022-12-14 08:59:19,696 root DEBUG utilities.py 294 4102] /usr/bin/env: ‘python’: No such file or directory
If you still have the issue, please provide the host dmesg log and the target flashing kernel log with the below description:
For the host dmesg log, on the x86 host where you are running SDKM, open a terminal window and enter the command “dmesg -T”
For the target flashing kernel logs, in another terminal window on the host you need to open a minicom connection to the Tegra (“sudo minicom -w -D /dev/ttyACM0”), redo the flashing, and copy paste the output to a file.
