Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hello Nvidia Community,
I am getting a flashing error while flashing drive os sdk 6.0.6.
Please have a look at the log for more details. driveinstaller.log (1.1 MB)
Please consider upgrading to latest devzone release i.e DRIVE OS 6.0.8.1
If you want to use DRIVE OS 6.0.6, could you give a try flashing with DRIVE OS 6.0.6 docker container to avoid issues related to host environment.
NvShell>status
Info: Executing cmd: status, argc: 0, args:
Alive : 00:05:57
CPU load Core 0: 5%
CPU load max Core 0: 24%
CPU load Core 1: 0%
CPU load max Core 1: 0%
CPU load Core 2: 0%
CPU load max Core 2: 0%
CPU load Core 3: 0%
CPU load max Core 3: 0%
CPU load Core 4: 0%
CPU load max Core 4: 0%
CPU load Core 5: 0%
CPU load max Core 5: 0%
The flashing error you have encountered is new to us. In the past, we notice, most of the flashing errors are due to host system state and when customer started using dockers to flash, they could flash without any issue. So we encourage customers to use docker.
Now, per attached picture, I see flashing is successful using docker. May I know which DRIVE OS docker you have used to flash?
Were you able to connect to /dev/ttyACM0(Tegra A console) after booting using minicom? What do you see on the screen?
I am assuming, you are trying to use/flash a new devkit. I would actually expect a new devkit to boot without any issue and aurix and tegra consoles are expect to be accessible.
Please use text messages instead of images in the post when you share any log. So that the related error could be searchable by others in community.
Dear @abdul.rehman3,
I see flashing is successful message in last attached picture.
Could you please file a new topic for better tracking of the issue. Please provide below information in the new topic.
Current DRIVE OS version on target (check cat /etc/nvidia/version-ubuntu-rootfs.txt on target
See if Tegra and Aurix is accessible from host using minicom.
Make sure there is two wire connection between host and target as mentioned in Quick start guide. Check if an additional NVIDIA device is visible on host when running lsusb on host when the target in put in recovery mode.
Make sure target is in normal mode before trying to flash.
