Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
I was able to successfully flash this Drive AGX Orin device several times before. However, after a power failure in our building it seems to have corrupted something on the Drive AGX Orin device. When I try flash it now, I get this error (I’ll post the full log in another message):
Exception 59 raised in bootburn_active
File “/home/kenneth.chu/nvidia/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn.py”, line 150, in bootburn_active
bootburnLib.UFSDeviceProvision(targetConfig.p_OutDirPath)
File “/home/kenneth.chu/nvidia/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_lib.py”, line 3506, in UFSDeviceProvision
adbObj.ProvisionUFSDevice(p_TempDumpPath)
File “/home/kenneth.chu/nvidia/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_adb.py”, line 1338, in ProvisionUFSDevice
AbnormalTermination(“Provision Failed”, nverror.NvError_FileWriteFailed)
File “/home/kenneth.chu/nvidia/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/flashtools_nverror.py”, line 249, in AbnormalTermination
raise OSError(errorCode)
OSError: 59
[bootburnTegra-A]: [updateFindBoardData(352)] : Connected Board Name details :: : chipSku is - ct00
returning to directory /home/kenneth.chu/nvidia/drive-foundation
Cleaning up …
Cleaning temp dir
Dear @kenneth.chu,
Does that mean, the board is not booting after power failure? Do you see if fans running? Are you able to access Aurix and tegra via serial console? Could you check flashing with sdkmanager as well?
The board is booting after power failure. I can access Aurix and issue the “tegrareset x1” command and it will reset the Orin SoC. The Orin SoC also starts, but get stuck in the boot process and does not respond. I originally saw this and that’s why I wanted to try to reflash the device.
I also tried using sdkmanager to flash the device and it also failed.
Did you attempt to flash the DRIVE OS 6.0.6 Linux SDK instead of QNX? If so, could you please provide the full logs located in the ~/.nvsdkm directory?
@1874077537
Thanks for reaching out. Regarding your flash failure issue, it would be best to create a separate forum topic with your corporate email for further assistance. This will allow our team to provide you with more tailored support and address your issue more effectively.
@kenneth.chu Can you please provide further information about the power failure in your building and what tasks the devkit is performing during the outage?
It seems that the logs do not match the process of flashing DRIVE OS 6.0.6 Linux SDK through SDK Manager. Can you please provide further details on the steps you took leading up to the issue of being unable to flash the unit?
I think I was running a test with Nsight Systems CLI to capture profiling data for our app at the time of power failure.
The log that you attached in the message above is from trying to flash QNX on the devkit after power failure. It failed, so then I tried to flash Linux on the devkit using sdkmanager. The logs from the nvsdkm.tar.gz attached above is from trying to flash Linux using sdkmanager.
The following snippet indicates that the UFS was not functioning properly. Can you confirm if the UFS has been provisioned? If so, would you be able to assist in running the command ‘./bootburn.py -b p3710-10-a01 -U /drive-foundation/tools/flashtools/storage_configs/t23x/ufs-provision-256gb.cfg -D’ on the host and provide the target side log via /dev/ttyACM0? Thank you.
[bootburnTegra-A]: [executeShellCommand(156)] : nvdd: /dev/block/2500000.ufshci:0 not found, looking by controller instance…\r\n:[E]: NvParseDeviceByControllerInstance : 191: Error DeviceNotFound (0x18)\r\n:[E]: NvddGetDeviceInfo : 28: Error DeviceNotFound (0x18)\r\n:[E]: nvdd : 460: Error DeviceNotFound (0x18)\r\n\r\nEXITCODE=24\r\n\r\n[bootburnTegra-A]: [AdbShell(280)] : EXITCODE = 24\r\ncommand line used was:\r\n[‘/home/rnd/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation//tools/flashtools/bootburn/bootburn.py’, ‘-b’, ‘p3710-10-s05’, ‘-B’, ‘qspi’, ‘-x’, ‘/dev/ttyACM1’, ‘–init_persistent_partitions’, ‘-D’]\r\n\r\n\r\n\x1b[01;31mWrite failed on (/dev/block/2500000.ufshci:0)\x1b[0m\r\n\r\n"b’Process Process-1:3:\r\nTraceback (most recent call last):\r\n File “/usr/lib/python3.8/multiprocessing/process.py”, line 315, in _bootstrap\r\n self.run()\r\n File “/usr/lib/python3.8/multiprocessing/process.py”, line 108, in run\r\n self._target(*self._args, **self._kwargs)\r\n File “/home/rnd/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_adb.py”, line 954, in FlashUsingADB\r\n result = self.SendFileUsingADB(partitionInfo, SkipWriteZeroChunk, TempDir, queue)\r\n File “/home/rnd/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_adb.py”, line 493, in SendFileUsingADB\r\n AbnormalTermination(“Write failed on (%s)” % str(partitionInfo.LinuxPartitionName), nverror.NvError_FileWriteFailed)\r\n File “/home/rnd/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/flashtools_nverror.py”, line 249, in AbnormalTermination\r\n raise OSError(errorCode)\r\nOSError: 59\r\n
