Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I am trying to update our new Orin device to Drive OS 6.0.6, however when flashing I get:
2023-08-17 11:47:14 ERROR : Flashing failed, please contact provider with logs /drive_flashing/log_6ebilca1u0xomkdqpygj5fnv84r3hwzs.txt and /drive/driveinstaller/driveinstaller.log
2023-08-17 11:47:14 ERROR : Traceback (most recent call last):
File “./flash.py”, line 153, in
flash_config(args.board, args.aurixport, args.tegra, args.pct_variant, args.recovery_timeout)
File “./flash.py”, line 143, in flash_config
raise Exception(f’Error {proc.returncode} occurred’)
Exception: Error 140 occurred
Tried on 2 PC both Ubuntu 20.04 (one fresh install) and using both SDK Manager and NGC containers with the original USB-C to USB cable. All the error logs attached are generated with NGC container.
Have seen the other topics on the issue and tried to power reset from minicom but did not help. Version info:
NvShell>version
Info: Executing cmd: version, argc: 0, args:
DRIVE-V6.0.4-P3710-AFW-Aurix-StepB-5.05.03
Command Executed
Any idea what should I try next?
Thank you in advance,
Gabriel
driveinstaller.log (459.5 KB)
log_6ebilca1u0xomkdqpygj5fnv84r3hwzs.txt (2.1 KB)
minicom.log (8.1 KB)
