Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
2.1.0.11669
other
Host Machine Version
other
VMWare (Host Windows), Ubuntu Linux 20.04 Host installed with SDK Manager
I am experiencing flashing errors similar to many other posts here in the Forum. For example Install DRIVE OS with SDK Manager :Failed to bind partitions - DRIVE AGX Orin / DRIVE AGX Orin General - NVIDIA Developer Forums
I followed the steps but wasnt successful.
Following the troubleshooting in the other posts:
- I have connected all cables (original from the DevKit)
- I can successfully connect to /dev/ttyACM0 and ACM1 with minicom,
- I am able to see both devices with lsusb: 0955:7023 and 0955:7045.
- I have more than 180GB free disk space and 16GB Ram
I am getting an error
Failed to bind partitions!
and in the logs
23:04:07.129 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: [ Component Install Finished with Error ]
23:04:07.130 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: [host] [ Disk Avail on Partition : 0.00 B ]
23:04:07.130 - info: NV_DRIVE_FLASH_DRIVE_COMP@DRIVE_AGX_ORIN_DEVKITS: [ NV_DRIVE_FLASH_DRIVE_COMP Install took 17s ]
in ~/.nvsdk/driveinstaller.log I can find the error
[2024-05-21 23:25:04,307 root DEBUG utilities.py 294 3856] [bootburn]: [findTargetBaseBoardName(763)] : baseBoardName found :: p3710-10-a01
[2024-05-21 23:25:04,307 root DEBUG utilities.py 294 3856] [bootburn]: [findBaseBoardName(3574)] : Detected baseboard with default ChipSku :: p3710-10-a01
[2024-05-21 23:25:04,307 root DEBUG utilities.py 294 3856] [bootburn]: [updateFindBoardData(354)] : Connected Board Name details :: baseBoard name - p3710-10-a01
[2024-05-21 23:25:04,307 root DEBUG utilities.py 294 3856] [bootburn]: [GetTegrasAssocWithAurix(507)] : Setting Tegra-A on hold…
[2024-05-21 23:25:04,307 root DEBUG utilities.py 294 3856] [bootburn]: [GetTegrasAssocWithAurix(509)] : Done
[2024-05-21 23:25:04,307 root DEBUG utilities.py 294 3856] [bootburn]: [getListTargetsInRecovery(3642)] : Bus 003 Device 005: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
[2024-05-21 23:25:04,307 root DEBUG utilities.py 294 3856] [bootburn]: [GetTegrasAssocWithAurix(534)] : Setting Tegra-A in recovery…
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] [bootburn]: [GetTegrasAssocWithAurix(538)] : Done
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] [bootburn]: [getListTargetsInRecovery(3642)] : Bus 003 Device 005: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] [bootburn]: [GetTegrasAssocWithAurix(548)] : No valid Tegra-A … must have a primary SOC
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] command line used was:
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] [‘/home/testuser/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/bootburn.py’, ‘–find_board_name’, ‘-x’, ‘/dev/ttyACM1’]
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] e[01;31mCould not put Tegra-A in recoverye[0m
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] [bootburn]: [exit(82)] : Exception in critical section :<class ‘OSError’>
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] e[01;31mException caught in bootburn e[0m
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] Traceback (most recent call last):
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] File “/home/testuser/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn.py”, line 286, in bootburn
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] bootburnLib.CheckRecoveryTargets()
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] File “/home/testuser/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_lib.py”, line 3587, in CheckRecoveryTargets
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] self.aurix.GetTegrasAssocWithAurix(self.targetConfig.s_AurixPort)
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] File “/home/testuser/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_aurix.py”, line 549, in GetTegrasAssocWithAurix
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] AbnormalTermination(“Could not put {} in recovery”.format(name), nverror.NvError_ResourceError)
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] File “/home/testuser/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/flashtools_nverror.py”, line 249, in AbnormalTermination
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] raise OSError(errorCode)
[2024-05-21 23:25:04,308 root DEBUG utilities.py 294 3856] OSError: 15
[2024-05-21 23:25:04,309 root INFO runner.py 37 3856] Failed to bind partitions!
[2024-05-21 23:25:04,309 root DEBUG runner.py 39 3856] Error on line 958
[2024-05-21 23:25:04,309 root DEBUG runner.py 40 3856] Exception info: Exception Type <class ‘module.errors.FailedToBindPartitionsError’>, Traceback <traceback object at 0x7f75a74ce948>
[2024-05-21 23:25:04,309 root INFO runner.py 45 3856] driveinstaller cannot continue! Check the log file for details: /home/testuser/.nvsdkm/driveinstaller.log
At the moment I dont have a native Ubuntu 20.04 Host, so I tried with the VM instead. Could this be an issue?
What other ways to debug this issue could you propose?
Thanks a lot in advance
Best regards
