Hello, I am using the docker method on the ubuntu22.04 virtual machine to flash drive orin 6.0.8.1 and the following error is reported during the process. Please give me a solution. Thank you.
[2024-05-15 03:49:53,967 root INFO pdk_flasher.py 209 14760] bypassing inforrom for flashing cmd
[2024-05-15 03:49:53,967 root INFO pdk_flasher.py 379 14760] Pre flash script found! Calling scripts/linux_pre_flash.sh
[2024-05-15 03:49:54,678 root DEBUG utilities.py 395 14760] Spawning child process with args ['/usr/bin/bash', '-E', 'scripts/linux_pre_flash.sh']
[2024-05-15 03:49:54,679 root DEBUG console_logger.py 17 14760] b'NV_WORKSPACE:'
[2024-05-15 03:49:54,733 root DEBUG console_logger.py 17 14760] b'NV_TARGETUSER:'
[2024-05-15 03:49:54,786 root DEBUG console_logger.py 17 14760] b'NV_TARGETPWD:'
[2024-05-15 03:49:54,837 root DEBUG console_logger.py 17 14760] b'NV_EULA_ACCEPTED:'
[2024-05-15 03:49:55,063 root INFO pdk_flasher.py 242 14760] Running flash command: sudo -E /drive/drive-foundation//tools/flashtools/bootburn/bootburn.py -b p3710-10-s05 -B qspi -x /dev/ttyACM1
[2024-05-15 03:49:55,778 root DEBUG console_logger.py 17 14760] b'****** Starting bootburn/bootburn.py ********\r\n'
[2024-05-15 03:49:55,829 root DEBUG console_logger.py 17 14760] b"********* Starting t23x bootburn py ********\r\nBootburn Starting with arguments ['/drive/drive-foundation//tools/flashtools/bootburn/bootburn.py', '-b', 'p3710-10-s05', '-B', 'qspi', '-x', '/dev/ttyACM1']\r\ncwd in setBoardConfigPath :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py\r\n\x1b[01;33m trying hardware folder:\r\n/drive/drive-foundation/platform-config/hardware/nvidia/platform/t23x/automotive/flashing/board_configs\x1b[0m\r\n\r\ncwd in loadBoardGoldenRegsFile :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py\r\nDefault Schema:/drive/drive-foundation/tools/flashtools/bootburn_t23x_py/nv-customer-data-schema.json\r\n\r\nCheck finished successfully\r\nDone parsing command line\r\n\r\n[bootburn]: [GetInfoRom(620)] : Read skuinfo from InfoRom...\r\n[bootburn]: Execute command on Aurix serial port\r\n"
[2024-05-15 03:49:56,094 root DEBUG console_logger.py 17 14760] b'[bootburn]: [CheckFirmwareisAFW(600)] : AFW firmware found\r\n'
[2024-05-15 03:49:57,127 root DEBUG console_logger.py 17 14760] b'[bootburn]: [setTargetConfigt23xInfoRomInfo(720)] : 940-63710-0010-D00\r\n[bootburn]: [setTargetConfigt23xInfoRomInfo(721)] : None\r\n'
[2024-05-15 03:49:57,128 root DEBUG console_logger.py 17 14760] b'[bootburn]: [setTargetConfigt23xInfoRomInfo(728)] : ****** s_InforomSkuVersion D00\r\n[bootburn]: [setTargetConfigt23xInfoRomInfo(729)] : ****** s_InforomProdInfo 940-63710-0010\r\n[bootburn]: [GetTegrasAssocWithAurix(507)] : Setting Tegra-A on hold... \r\n'
[2024-05-15 03:49:57,497 root DEBUG console_logger.py 17 14760] b'[bootburn]: [GetTegrasAssocWithAurix(509)] : Done\r\n'
[2024-05-15 03:49:57,507 root DEBUG console_logger.py 17 14760] b'[bootburn]: [getListTargetsInRecovery(3965)] : Bus 002 Device 004: ID 0955:7045 NVIDIA Corp. VMware Virtual USB Mouse\r\n'
[2024-05-15 03:49:57,508 root DEBUG console_logger.py 17 14760] b'[bootburn]: [GetTegrasAssocWithAurix(534)] : Setting Tegra-A in recovery... \r\n'
[2024-05-15 03:49:58,222 root DEBUG console_logger.py 17 14760] b'[bootburn]: [GetTegrasAssocWithAurix(538)] : Done\r\n'
[2024-05-15 03:49:58,231 root DEBUG console_logger.py 17 14760] b'[bootburn]: [getListTargetsInRecovery(3965)] : Bus 002 Device 004: ID 0955:7045 NVIDIA Corp. VMware Virtual USB Mouse\r\n'
[2024-05-15 03:49:58,232 root DEBUG console_logger.py 17 14760] b'[bootburn]: [GetTegrasAssocWithAurix(552)] : retrying board recovery check...\r\n'
[2024-05-15 03:49:58,909 root DEBUG console_logger.py 17 14760] b'[bootburn]: [getListTargetsInRecovery(3965)] : Bus 002 Device 004: ID 0955:7045 NVIDIA Corp. VMware Virtual USB Mouse\r\n[bootburn]: [GetTegrasAssocWithAurix(552)] : retrying board recovery check...\r\n'
[2024-05-15 03:49:59,416 root DEBUG console_logger.py 17 14760] b'[bootburn]: [getListTargetsInRecovery(3965)] : Bus 002 Device 004: ID 0955:7045 NVIDIA Corp. VMware Virtual USB Mouse\r\n'
[2024-05-15 03:49:59,417 root DEBUG console_logger.py 17 14760] b'[bootburn]: [GetTegrasAssocWithAurix(552)] : retrying board recovery check...\r\n'
[2024-05-15 03:49:59,925 root DEBUG console_logger.py 17 14760] b'[bootburn]: [getListTargetsInRecovery(3965)] : Bus 002 Device 004: ID 0955:7045 NVIDIA Corp. VMware Virtual USB Mouse\r\n'
[2024-05-15 03:49:59,925 root DEBUG console_logger.py 17 14760] b'[bootburn]: [getListTargetsInRecovery(3965)] : Bus 001 Device 012: ID 0955:7023 NVIDIA Corp. APX\r\n'
[2024-05-15 03:49:59,933 root DEBUG console_logger.py 17 14760] b'p3710-10-s05\r\n'
[2024-05-15 03:49:59,934 root DEBUG console_logger.py 17 14760] b'cwd in setBoardConfigPath :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py\r\n\x1b[01;33m trying hardware folder:\r\n/drive/drive-foundation/platform-config/hardware/nvidia/platform/t23x/automotive/flashing/board_configs\x1b[0m\r\n\r\ncwd in loadBoardGoldenRegsFile :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py\r\nDefault Schema:/drive/drive-foundation/tools/flashtools/bootburn_t23x_py/nv-customer-data-schema.json\r\n\r\n'
[2024-05-15 03:49:59,934 root DEBUG console_logger.py 17 14760] b' *** found bootburn-flags in platform-config.json **** \r\nCheck finished successfully\r\nDone parsing command line\r\n\r\n'
[2024-05-15 03:49:59,935 root DEBUG console_logger.py 17 14760] b' *** found bootburn-flags in platform-config.json **** \r\n'
[2024-05-15 03:49:59,935 root DEBUG console_logger.py 17 14760] b'[bootburn]: [setTargetConfigt23xInfoRomInfo(720)] : 940-63710-0010-D00\r\n[bootburn]: [setTargetConfigt23xInfoRomInfo(721)] : None\r\n[bootburn]: [setTargetConfigt23xInfoRomInfo(728)] : ****** s_InforomSkuVersion D00\r\n'
[2024-05-15 03:49:59,936 root DEBUG console_logger.py 17 14760] b'[bootburn]: [setTargetConfigt23xInfoRomInfo(729)] : ****** s_InforomProdInfo 940-63710-0010\r\n[bootburn]: [validateTargetBoardName(752)] : boardName p3710-10-s05 matches with the connected board\r\n'
[2024-05-15 03:50:00,056 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [GetTargetECID(792)] : Target BR_CID: 0x80012344705DD51F1400000014FF8040\r\n\r\n'
[2024-05-15 03:50:00,057 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [GetTargetECID(793)] : Target ECID: 0x4705DD51F1400000014FF8040\r\n\r\n'
[2024-05-15 03:50:00,057 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [CheckFuseForAuthentication(810)] : Target Authentication State : SHA-2\r\n'
[2024-05-15 03:50:00,058 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [GenAdbSerialNum(558)] : ADB serial number is 8S2TQKFH800000AFV020\r\n'
[2024-05-15 03:50:00,059 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [CheckForDeviceType(908)] : Detected ES production device type\r\n*** in targetConfig, s_BrickOnTCFFlashingFail not found in board_config ***\r\n*** in targetConfig, s_BrickOnFirmwareFlashingFail not found in board_config ***\r\n'
[2024-05-15 03:50:00,061 root DEBUG console_logger.py 17 14760] b'*** in targetConfig, s_BrickOnFirmwareFlashingFail not found in board_config ***\r\n'
[2024-05-15 03:50:00,062 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: creating and flashing coldboot images\r\n[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(746)] : Creating & Flashing images \r\n[bootburnTegra-A]: Creating rcm-flash images\r\n'
[2024-05-15 03:50:00,062 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(749)] : flashingCFG :: /drive/drive-foundation/tools/flashtools/flashing_kernel/flashing_configs/t23x/quickboot_flashing.cfgself.targetConfig.p_OutDirPath :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py/__temp_t234/Tegra-A-d9faf966eae\r\n'
[2024-05-15 03:50:01,004 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1502)] : *****prodInfo :: 940-63710-0010******\r\n'
[2024-05-15 03:50:01,004 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1503)] : *****skuVersion :: D00******\r\n'
[2024-05-15 03:50:01,085 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [GenerateImage(2432)] : Generating Flashing-RCM Images\r\n'
[2024-05-15 03:50:03,025 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(753)] : Generating cold boot flash-images\r\n'
[2024-05-15 03:50:03,974 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1502)] : *****prodInfo :: 940-63710-0010******\r\n'
[2024-05-15 03:50:03,974 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1503)] : *****skuVersion :: D00******\r\n'
[2024-05-15 03:50:04,077 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [GenerateImage(2458)] : Generating Flash Images for chain A, this may take a few minutes\r\n'
[2024-05-15 03:51:00,824 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1502)] : *****prodInfo :: 940-63710-0010******\r\n'
[2024-05-15 03:51:00,826 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1503)] : *****skuVersion :: D00******\r\n'
[2024-05-15 03:51:00,955 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [GenerateImage(2458)] : Generating Flash Images for chain B, this may take a few minutes\r\n'
[2024-05-15 03:52:00,613 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1502)] : *****prodInfo :: 940-63710-0010******\r\n'
[2024-05-15 03:52:00,615 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1503)] : *****skuVersion :: D00******\r\n'
[2024-05-15 03:52:00,684 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [GenerateImage(2458)] : Generating Flash Images for chain C, this may take a few minutes\r\n'
[2024-05-15 03:52:06,150 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(757)] : Booting Flashing Kernel\r\n'
[2024-05-15 03:52:06,151 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [BootRCM_FPGA(664)] : BootRCM_FPGA - rcm-flash\r\n'
[2024-05-15 03:52:07,529 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [CheckOptFuses(577)] : Emc=0x0 Ccplex=0x0 Gpc 0x0 Dla 0x0 Sku 0x90\r\n\r\n'
[2024-05-15 03:52:07,532 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [PreserveTargetSkuInfo(1616)] : Preserving SkuInfo from Target\r\n'
[2024-05-15 03:52:07,824 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1502)] : *****prodInfo :: 940-63710-0010******\r\n'
[2024-05-15 03:52:07,825 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1503)] : *****skuVersion :: D00******\r\n'
[2024-05-15 03:52:08,027 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1502)] : *****prodInfo :: 940-63710-0010******\r\n'
[2024-05-15 03:52:08,027 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [SkuBlobGen(1503)] : *****skuVersion :: D00******\r\n'
[2024-05-15 03:52:08,233 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [getmembctName(476)] : RAMCODE 0\r\n'
[2024-05-15 03:52:08,234 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [getmembctName(489)] : Selected membct_0 for memcfg\r\n'
[2024-05-15 03:52:15,116 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(759)] : Flashing cold boot Images\r\n'
[2024-05-15 03:52:15,117 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [FlashImages(3409)] : \r\n\r\n[bootburnTegra-A]: [FlashImages(3410)] : Flashing-Images starting\r\n\r\n'
[2024-05-15 03:52:15,135 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [CheckUSBServiceInit(232)] : Waiting for USB device. This may take up to 100 seconds...\r\n'
[2024-05-15 03:52:15,156 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [CheckUSBServiceInit(248)] : Starting and finding the ADB device : 8S2TQKFH800000AFV020\r\n'
[2024-05-15 03:52:15,219 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [startADBServer(161)] : Starting ADB server \r\n'
[2024-05-15 03:52:20,273 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [executeShellCommand(163)] : shell command -- timeout 5 /drive/drive-foundation/tools/flashtools/flash/adb -s 8S2TQKFH800000AFV020 wait-for-device failed\r\n'
[2024-05-15 03:52:20,274 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [executeShellCommand(165)] : Output: \r\n'
[2024-05-15 03:52:20,275 root DEBUG console_logger.py 17 14760] b'[bootburnTegra-A]: [executeShellCommand(172)] : Return code: 124\r\n'
[2024-05-15 04:07:29,418 root DEBUG console_logger.py 17 14760] b'[bootburn]: \r\n\x1b[01;31mFlashing timed out -- Exiting\x1b[0m\r\n\r\n'
[2024-05-15 04:07:29,799 root DEBUG console_logger.py 17 14760] b'\r\n'
[2024-05-15 04:07:29,900 root ERROR pdk_flasher.py 280 14760] Flashing process exited with error 5
[2024-05-15 04:07:29,901 root INFO runner.py 37 14760] Error in flashing!
[2024-05-15 04:07:29,901 root DEBUG runner.py 39 14760] Error on line 990
[2024-05-15 04:07:29,901 root DEBUG runner.py 40 14760] Exception info: Exception Type <class 'module.errors.FlashingError'>, Traceback <traceback object at 0x7f4ed88559c0>
[2024-05-15 04:07:29,902 root INFO runner.py 42 14760] driveinstaller cannot continue! Check the log file for details: /drive/driveinstaller/driveinstaller.log
[2024-05-15 04:07:29,902 root DEBUG runner.py 62 14760] Cleaning up...
[2024-05-15 04:07:29,902 root DEBUG utilities.py 137 14760] Deleting temporary directories...
[2024-05-15 04:07:29,902 root DEBUG utilities.py 139 14760] Deleting /tmp/pdkinstall-tmp-og3pa4qq-bind
[2024-05-15 04:07:29,903 root DEBUG runner.py 64 14760] Closing the log file.
root@6.0.8.1-0006-build-linux-sdk:/drive# ./flash.py /dev/ttyACM1 p3710
2024-05-15 04:10:31 INFO : Flashing already set for dual bootchain
2024-05-15 04:10:31 INFO : Flash clean already disabled for persistent partitions
2024-05-15 04:10:31 INFO : Initiating pre-flash check
2024-05-15 04:10:31 INFO : Checking Serial Port Connection
2024-05-15 04:10:31 INFO : Serial Port found /dev/ttyACM1
2024-05-15 04:10:31 INFO : Running basic open/close tests on Serial Port Connection
2024-05-15 04:10:31 INFO : Serial Port is open
2024-05-15 04:10:31 INFO : Flushing input and output buffer, discard all content
2024-05-15 04:10:31 INFO : Serial Port is closed
2024-05-15 04:10:31 INFO : Checking available targets
2024-05-15 04:10:31 INFO : Checking Orin board connection
2024-05-15 04:10:31 INFO : Orin board with Device ID -- 0955:7100 found.
2024-05-15 04:10:31 INFO : Orin board with Device ID -- 0955:7045 found.
2024-05-15 04:10:31 INFO : Orin board device path is /dev/bus/usb/001/016
2024-05-15 04:10:31 INFO : Orin board device path is /dev/bus/usb/002/004
2024-05-15 04:10:31 INFO : Pre-flash check complete
2024-05-15 04:10:31 INFO : Flashing DRIVE OS Docker
2024-05-15 04:29:08 INFO : driveinstaller v2.0
2024-05-15 04:29:08 INFO : SDK/PDK Installer and Flasher
2024-05-15 04:29:08 INFO : Run `./driveinstaller --help` for usage information.
2024-05-15 04:29:08 INFO : Initializing board and OS configuration to Autonomous vehicle p3710 Linux Tegra A
2024-05-15 04:29:08 INFO : Manifest version 2.0
2024-05-15 04:29:08 INFO : BOARD SKU : 940-63710-0010-D00
2024-05-15 04:29:08 INFO : Found matching board id p3710-10-s05 in 940-63710-0010-D00 sku
2024-05-15 04:29:08 INFO : Applying additional Bind opts []
2024-05-15 04:29:08 INFO : Executing bind clean cmd make/bind_partitions -b p3710-10-s05 linux clean
2024-05-15 04:29:08 INFO : Executing bind cmd make/bind_partitions -b p3710-10-s05 linux
2024-05-15 04:29:08 INFO : Bind partitions done!
2024-05-15 04:29:08 INFO : Initializing SDK/PDK flasher for configuration
2024-05-15 04:29:08 INFO : Board: p3710
2024-05-15 04:29:08 INFO : Board type: ES
2024-05-15 04:29:08 INFO : Hypervisor config: linux
2024-05-15 04:29:08 INFO : bypassing inforrom for flashing cmd
2024-05-15 04:29:08 INFO : Pre flash script found! Calling scripts/linux_pre_flash.sh
2024-05-15 04:29:08 INFO : Running flash command: sudo -E /drive/drive-foundation//tools/flashtools/bootburn/bootburn.py -b p3710-10-s05 -B qspi -x /dev/ttyACM1
2024-05-15 04:29:08 INFO : This may take a few minutes
2024-05-15 04:29:08 ERROR : Flashing failed, please contact provider with logs /drive_flashing/log_i6x8vsmkla2njpz3t0ubf1q47r5hcgye.txt and /drive/driveinstaller/driveinstaller.log.
