Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
2.0.0.11405
other
Host Machine Version
other
We are facing the below failure while trying to flash the NEW M.2 NVMe Card in Drive Orin(DRIVE-V6.0.4-P3710-AFW-Aurix-StepB-5.05.03)
[2023-12-22 07:01:58,867 root DEBUG console_logger.py 17 117169] b’ashtools/bootburn_t23x_py/__temp_t234/Tegra-A-c0ea10592ec/flash-images\r\n’
[2023-12-22 07:02:32,317 root DEBUG console_logger.py 17 117169] b’[bootburnTegra-A]: [executeShellCommand(156)] : nvdd: /dev/block/3270000.spi not found, looking by controller instance…\r\nnvdd: Using [/dev/mtd/mtd0]\r\n5681920 bytes copied, 34.750581 sec, 163505.755487 bytes/sec\r\n\r\nEXITCODE=0\r\n\r\n’
[2023-12-22 07:02:32,326 root DEBUG console_logger.py 17 117169] b’[bootburnTegra-A]: [AdbShell(280)] : EXITCODE = 0\r\n[bootburnTegra-A]: [executeShellCommand(149)] : command = /home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/flash/adb -s 8S2TQK27G00000AFU040 shell /tmp/wr_sh.sh rm /tmp/C_2_3_kernel_zerosign.img\r\ncwd = /home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn_t23x_py/__temp_t234/Tegra-A-c0ea10592ec/flash-images\r\n’
[2023-12-22 07:02:32,336 root DEBUG console_logger.py 17 117169] b’[bootburnTegra-A]: [executeShellCommand(156)] : \r\nEXITCODE=0\r\n\r\n[bootburnTegra-A]: [AdbShell(280)] : EXITCODE = 0\r\n[bootburnTegra-A]: [executeShellCommand(149)] : command = /home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/flash/adb -s 8S2TQK27G00000AFU040 shell /tmp/wr_sh.sh /tmp/nvdd --device /dev/block/3270000.spi --startoffset 38797312 --partsize 5681920 --md5sum 32ff3dcac6c57ad54d54a76f383f7e19 --printmd5sum\r\ncwd = /home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn_t23x_py/__temp_t234/Tegra-A-c0ea10592ec/flash-images\r\n’
[2023-12-22 07:02:32,593 root DEBUG console_logger.py 17 117169] b’[bootburnTegra-A]: [executeShellCommand(156)] : nvdd: /dev/block/3270000.spi not found, looking by controller instance…\r\nnvdd: Using [/dev/mtd/mtd0]\r\nrbMd5 : 32ff3dcac6c57ad54d54a76f383f7e19\r\n\r\nEXITCODE=0\r\n\r\n’
[2023-12-22 07:02:32,602 root DEBUG console_logger.py 17 117169] b’[bootburnTegra-A]: [checkMd5(425)] : \x1b[01;32m target md5 = /dev/block/3270000.spi not found, looking by controller instance… matches host side md5 = 32ff3dcac6c57ad54d54a76f383f7e19\x1b[0m\r\n[bootburnTegra-A]: [SendFileUsingADB(608)] : Image written correctly, md5 sum matches\r\ncommand line used was:\r\n['/home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation//tools/flashtools/bootburn/bootburn.py', '-b', 'p3710-10-s05', '-B', 'qspi', '-x', '/dev/ttyACM1', '-D']\r\n\r\n\r\n\x1b[01;31mFlashing Failed Propagated Error\x1b[0m\r\n\r\n[bootburnTegra-A]: [FlashImages(3131)] : **** FlashImages::Exception in flashing ****\r\n[bootburnTegra-A]: [FlashImages(3133)] : exception dictionary - {}\r\n[bootburnTegra-A]: [FlashImages(3142)] : flashExcept return code - 116\r\n[bootburnTegra-A]: [FlashImages(3152)] : **** s_BrickOnTCFFlashingFail is disabled in the configuration ****\r\ncommand line used was:\r\n['/home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation//tools/flashtools/bootburn/bootburn.py', '-b', 'p3710-10-s05', '-B', 'qspi', '-x', '/dev/ttyACM1', '-D']\r\n\r\n\r\n\x1b[01;31mFlashing failed and target was not bricked as per configuration\x1b[0m\r\n\r\n\r\n\r\n\x1b[01;31mException 116 raised in bootburn_active \x1b[0m\r\nTraceback (most recent call last):\r\n File “/home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn.py”, line 156, in bootburn_active\r\n bootburnOrin.Boot_Create_Flash_Coldboot()\r\n File “/home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_orin.py”, line 756, in Boot_Create_Flash_Coldboot\r\n self.FlashImages(self.targetConfig.p_OutDirPath)\r\n File “/home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootbu’
[2023-12-22 07:02:32,607 root DEBUG console_logger.py 17 117169] b’rn_lib.py”, line 3153, in FlashImages\r\n AbnormalTermination(“Flashing failed and target was not bricked as per configuration”, flashExceptRetCode)\r\n File “/home/vijays/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/flashtools_nverror.py”, line 249, in AbnormalTermination\r\n raise OSError(errorCode)\r\nOSError: 116\r\n’
[2023-12-22 07:02:32,663 root DEBUG console_logger.py 17 117169] b’\r\n’
client_loop: send disconnect: Broken pipelasher.py 277 117169] Flashing process exited with error 116
