yes, the boot kit boots up successfully with the default image.
Increasing “sleep 1” to “sleep 5” did not help, still the same error occurs:
[2020-02-13 16:48:15,093 root DEBUG console_logger.py 17 4283] b'\r\n'
[2020-02-13 16:48:15,131 root DEBUG console_logger.py 17 4283] b'Successfully acquired lock over /var/lock/LCK..bootburn\r\n'
[2020-02-13 16:48:15,131 root DEBUG console_logger.py 17 4283] b'Successfully acquired lock over /var/lock/LCK..ttyUSB3\r\n'
[2020-02-13 16:48:15,163 root DEBUG console_logger.py 17 4283] b'Read skuinfo from InfoRom...\r\n'
[2020-02-13 16:48:18,243 root DEBUG console_logger.py 17 4283] b'Process CMD (5137) still running. Trying to kill after 5 seconds\r\n'
[2020-02-13 16:48:23,839 root DEBUG console_logger.py 17 4283] b'Disabling SIGINT <Ctrl+C> temporarily\r\nSetting Tegra-A on hold... '
[2020-02-13 16:48:34,022 root DEBUG console_logger.py 17 4283] b'Process CMD (5198) still running. Trying to kill after 5 seconds\r\n'
[2020-02-13 16:48:39,526 root DEBUG console_logger.py 17 4283] b'Done\r\nSetting Tegra-B on hold... '
[2020-02-13 16:48:49,703 root DEBUG console_logger.py 17 4283] b'Process CMD (5229) still running. Trying to kill after 5 seconds\r\n'
[2020-02-13 16:48:55,207 root DEBUG console_logger.py 17 4283] b'Done\r\n'
[2020-02-13 16:48:55,300 root DEBUG console_logger.py 17 4283] b'Setting Tegra-A in recovery... '
[2020-02-13 16:49:05,473 root DEBUG console_logger.py 17 4283] b'Process CMD (5269) still running. Trying to kill after 5 seconds\r\n'
[2020-02-13 16:49:21,145 root DEBUG console_logger.py 17 4283] b'Process CMD (5303) still running. Trying to kill after 5 seconds\r\n'
[2020-02-13 16:49:26,650 root DEBUG console_logger.py 17 4283] b'Done\r\n'
[2020-02-13 16:49:26,743 root DEBUG console_logger.py 17 4283] b'Setting Tegra-B in recovery... '
[2020-02-13 16:49:36,937 root DEBUG console_logger.py 17 4283] b'Process CMD (5355) still running. Trying to kill after 5 seconds\r\n'
[2020-02-13 16:49:52,627 root DEBUG console_logger.py 17 4283] b'Process CMD (5386) still running. Trying to kill after 5 seconds\r\n'
[2020-02-13 16:49:58,131 root DEBUG console_logger.py 17 4283] b'Done\r\n'
[2020-02-13 16:49:58,234 root DEBUG console_logger.py 17 4283] b'Enabling SIGINT <Ctrl+C>\r\n'
[2020-02-13 16:49:58,239 root DEBUG console_logger.py 17 4283] b'Failed to get Tegra instance.\r\n'
[2020-02-13 16:49:58,239 root DEBUG console_logger.py 17 4283] b'==> /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/ta_on <==\r\n\r\n==> /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/tb_on <==\r\n\r\n==> /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/tb_off <==\r\n'
[2020-02-13 16:49:58,240 root DEBUG console_logger.py 17 4283] b'\r\n ------------ Stack Trace ------------\r\nstack frame 0 - 297 AbnormalTermination /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh\r\n'
[2020-02-13 16:49:58,241 root DEBUG console_logger.py 17 4283] b'stack frame 1 - 480 GetTegrasAssocWithAurix /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh\r\n'
[2020-02-13 16:49:58,242 root DEBUG console_logger.py 17 4283] b'stack frame 2 - 509 CheckRecoveryTargets /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh\r\n'
[2020-02-13 16:49:58,243 root DEBUG console_logger.py 17 4283] b'stack frame 3 - 946 main /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh\r\n'
[2020-02-13 16:49:58,243 root DEBUG console_logger.py 17 4283] b'-------------------------------------\r\n\r\n'
[2020-02-13 16:49:58,244 root DEBUG console_logger.py 17 4283] b'error-target-instance\r\n'
[2020-02-13 16:49:58,331 root DEBUG console_logger.py 17 4283] b'\r\n'
[2020-02-13 16:49:58,432 root ERROR pdk_flasher.py 168 4283] Flashing process exited with error 15
[2020-02-13 16:49:58,432 root CRITICAL runner.py 37 4283] Error in flashing!
[2020-02-13 16:49:58,432 root DEBUG runner.py 38 4283] Exception info:
File "./pdkinstaller", line 777, in <module>
pdk_flasher.flash()
File "/home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/pdkinstaller/module/pdk_flasher.py", line 171, in flash
raise FlashingError
module.errors.FlashingError: Error in flashing!
[2020-02-13 16:49:58,435 root CRITICAL runner.py 43 4283] pdkinstaller cannot continue! Check the log file for details: /home/schorn/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/pdkinstaller/pdkinstaller.log
[2020-02-13 16:49:58,435 root DEBUG runner.py 60 4283] Cleaning up...
[2020-02-13 16:49:58,435 root DEBUG utilities.py 124 4283] Deleting temporary directories...
[2020-02-13 16:49:58,435 root DEBUG utilities.py 126 4283] Deleting /tmp/pdkinstall-tmp-stqjmc3t-bind
[2020-02-13 16:49:58,435 root DEBUG runner.py 62 4283] Closing the log file.
Message “Process CMD (xxxxx) still running. Trying to kill after 5 seconds” is still there…
