AGX Orin rootfs A/B didn't work correctly
I’s using NRU-230V, based on customized carrier board and AGX ORIN 64G.
What I see (several units, FAB 501 rev G.0 and FAB 502 rev K.0, L4T 36.4.4, ROOTFS_AB=1):
  • After switching to chain B, the unit boots B and nvbootctrl verifies and commits it (“switch boot chain success”). B survives any number of normal reboots.
  • After a full power cycle, it always comes back on chain A. MB2 prints Current Boot-Chain Slot: 0 and BR-BCT Boot-Chain is 1, and status is 0; on a warm reboot it prints Slot: 1 / status is 1.
  • With a USB host connected to the recovery port, the unit goes into recovery mode at power-on instead of booting A. Pressing the power button (reset) then boots chain B normally.
  • After such a failed power-on, the boot ROM reports last_boot_error: 656573201 (0x27228311) when we connect in recovery mode. After clean boots it’s 0.
What I have ruled out:
  • QSPI contents: I read back all A/B partitions in recovery mode. Chains A and B are byte-identical, and the BR-BCT primary copies are committed to chain B.
  • Custinfo, firmware version (fresh L4T 36.4.4 QSPI reflash), module revision, and RAM code.
  • QSPI read timing: I applied NVIDIA’s overlay_mb1bct_36.x (trimmer2-val = 0x04); no change.
  • Chain B’s location: I moved chain B’s boot-ROM images (mb1, psc_bl1, MB1_BCT, MEM_BCT) below 16 MB in QSPI; no change.
  • Questions:
  1. what last_boot_error 0x27228311 means, and why chain B fails only on a cold start while warm and button resets work?
Hello @dennis.hu!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
hello dennis.hu,
please refer to Jetson Linux Release 36.5 | NVIDIA Developer, for checking Additional Files for the [overlay_pcie.tbz2] update.
