AGX orin boot up fail
hi
我们发现boot过程中概率性无法开机,从串口打印信息来看可能内存分配问题?同时我们发现按下重启按钮时,也概率性出现相同的问题,报错是相同的。麻烦看看可能是什么原因导致的?是否可能是硬件配置引脚错误导致?
Uploading: 20260127114504.png…
Hi cyb1,
How about the failed rate?
It seems the booting failed in MB2, which is relating to DRAM.
Please share the full serial console log as file instead of the image.
boot up fail log.txt (4.6 KB)
AGX Orin所使用的底板是自定义板,jetpack版本是5.2.4版本。
这个概率不稳定,有时三四十次不出现,一旦出现,就算关闭AC电源或拔插核心板都会出现。
Sorry that we don’t have this release.
Could you share the result of cat /etc/nv_tegra_release on your board for further check?
Please also help to clarify if the issue is specific to your custom carrier board.
You can simply put the module to the devkit and check if there’s the similar issue.
In addition, do you have any custom usage for the DRAM strapping pins?
You can refer to Chapter 19. Strapping Pins of Jetson AGX Orin Series Modules Design Guide for details.
nv_tegra_release的结果如下
目前手上尚未有开发套件。
对于strap pins的J58和K58,目前是接到电压转换芯片上(TI公司的TXB0108),这两个引脚想用于RS232功能。
通过实测上电及重启时的引脚状态,均是稳定的0V电平。
为了排除这个问题,我尝试将此电压转换芯片拆除,断开这两个引脚上所有连接关系。重启测试10次未能复现到相同报错问题,可以直接进系统。重新安装上此电压转换芯片后,可复现重启报错问题。
请问这两个strap pins是用于配置什么功能?PDG中未发现有相关说明。
strap pin會決定使用的DRAM config.
這東西如果不穩定會導致使用錯的DRAM config從而造成RAM相關的錯誤
好的,那对于没有buffer的J58和K58来说,在上电及重启过程中,底板必须不能对其有任何状态控制,需要保持悬空对吗
Correct, the carrier board should not interfere with J58 and K58 during power on as mentioned below in chapter 19 of the Jetson AGX Orin Series Design Guide (including AGX Orin Industrial). If your custom board has any pull ups or downs on these pins, they should be removed. If your board has no pull ups or downs, the TXB0108 may be sufficiently loading the pins to affect the strap levels when sampled during boot.
