We did a startup stress test on AGX Orin
Our test has a 10% chance of failing(300 times).
The error goes like this
��NOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0x83c040000 size 0x3fc0000
��DCE: FW Boot Done
��I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:55 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
e[2Je[04De[=3he[2Je[09D
��Unhandled Exception in EL3.
x30 = 0x0000000050000d00
x0 = 0x0000000000000000
x1 = 0x00000000be000011
x2 = 0x0000000000000000
x3 = 0x0000000000000011
x4 = 0x0000000000100000
x5 = 0x000000082d1fe588
x6 = 0x0000000001000000
x7 = 0x0000000001000000
x8 = 0x00180301d3719223
x9 = 0x000000005001c380
x10 = 0x55aaa055071dbd35
x11 = 0x55aa8255ce1abfe1
x12 = 0x0a0341d0000c0102
x13 = 0x0004ff7f00000000
x14 = 0x00000008065bdba8
x15 = 0x00000008065bdb10
x16 = 0x000000082902803c
x17 = 0x00000000307cf10e
x18 = 0x0000000828f3b2f0
x19 = 0x000000005001cec0
x20 = 0x0000000000000000
x21 = 0x0000000000000000
x22 = 0x0000000000000000
x23 = 0x0000000000000000
x24 = 0x0000000000000000
x25 = 0x0000000000000000
x26 = 0x0000000000000000
x27 = 0x0000000000000000
x28 = 0x0000000000000000
x29 = 0x0000000000000000
scr_el3 = 0x000000000003073d
sctlr_el3 = 0x00000000b0cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x0000000080823518
daif = 0x00000000000002c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000600003c9
elr_el3 = 0x0000000828f35280
ttbr0_el3 = 0x0000000050026ac1
esr_el3 = 0x00000000be000011
far_el3 = 0x0000000000000000
spsr_el1 = 0x0000000000000000
elr_el1 = 0x0000000000000000
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000030d00800
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000300000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x0000000000000000
esr_el1 = 0x0000000000000000
ttbr0_el1 = 0x0000000000000000
ttbr1_el1 = 0x0000000000000000
mair_el1 = 0x0000000000000000
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x0000000000000000
tpidr_el0 = 0x0000000080000000
tpidrro_el0 = 0x0000000000000000
par_el1 = 0x0000000000000800
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000005
cntp_cval_el0 = 0x0000000020fb139b
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x0000000828f3b2f0
isr_el1 = 0x0000000000000040
cpuectlr_el1 = 0xa000000b40543000
gicd_ispendr regs (Offsets 0x200 - 0x278)
Offset: value
0000000000000200: 0x0000000000000000
0000000000000204: 0x0000000000000000
0000000000000208: 0x0000000000000000
000000000000020c: 0x0000000000000000
0000000000000210: 0x0000000000000000
0000000000000214: 0x0000000000000000
0000000000000218: 0x0000000000010000
000000000000021c: 0x0000000000020000
0000000000000220: 0x0000000000000000
0000000000000224: 0x0000000000000000
0000000000000228: 0x0000000000000000
000000000000022c: 0x0000000000000000
0000000000000230: 0x0000000000000000
0000000000000234: 0x0000000000000000
0000000000000238: 0x0000000000000000
000000000000023c: 0x0000000000000000
0000000000000240: 0x0000000000000000
0000000000000244: 0x0000000000000000
0000000000000248: 0x0000000000000000
000000000000024c: 0x0000000000000000
0000000000000250: 0x0000000000000000
0000000000000254: 0x0000000000000000
0000000000000258: 0x0000000000000000
000000000000025c: 0x0000000000000000
0000000000000260: 0x0000000000000000
0000000000000264: 0x0000000000000000
0000000000000268: 0x0000000000000000
000000000000026c: 0x0000000000000000
0000000000000270: 0x0000000000000000
0000000000000274: 0x0000000000000000
0000000000000278: 0x0000000000000000
000000000000027c: 0x0000000000000000
The full log is
orin-m-5s-stress-err1.log (34.0 KB)
Is this a known problem?
How can we fix it?
