Trying to boot the Jetson AGX Orin, it passes MB1 and MB2. Then, it fails on UEFI.
▒▒NOTICE: BL31: v2.6(release):4fa405dbd
NOTICE: BL31: Built : 20:16:55, Aug 10 2022
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.16 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Thu Aug 11 03:23:19 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!
E/TC:00 0 jetson_user_key_pta_init:700 jetson_user_key_pta_init: Failed (f0100006).
E/TC:00 0 call_initcalls:43 Initcall __text_start + 0x000dab50 failed
I/TC: Primary CPU switching to normal world boot
ERROR: Exception reason=0 syndrome=0xbe000411
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xec000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: MISC0 = 0x44020040
ERROR: MISC1 = 0x5554860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x80000000367fed40
ERROR: sdei_dispatch_event returned -1
Unhandled Exception in EL3.
x30 = 0x0000000050010b84
x0 = 0x0000000000000000
x1 = 0x0000000000000000
My carrier board does not have HDMI port or Display Port. I tried to disable the DP in the dtb node display@13800000{status = “disabled”;} and also following the instructions on nvdisp Readme, but it does not work.
To reverse this process, and skip display init and revert to a boot flow
without boot splash/display init on T194 boards, complete the following steps:
Change the TBCFILE= line in p3668.conf.common and p2972-0000.conf.common to
point to uefi_jetson.bin, for example:
TBCFILE=“bootloader/uefi_jetson.bin”;
Remove the UEFIFILE= line from the above files.
Edit flash.sh, and remove the following lines:
if [ “${CHIPID}” = “0x19” ] and [ ${UEFIFILE} != “” ]; then
echo “NVDISP+UEFI in ${TBCFILE} …”
truncate --size=393216 “${TBCFILE}”
cat “${UEFIFILE}” >> “${TBCFILE}”
fi;
Delete nvdisp-init.bin from your BSP Linux_for_Tegra/bootloader directory.
Reflash your board.
Now only UEFI will be run as the CPU-BL and no boot splash BMP will appear
on HDMI.
As Wayne says, the nvdisp-init stuff (P3668.conf.common, p2972-0000.conf.common and any ‘CHIPID = 0x19’ sections in flash.sh) apply ONLY to T194/Xavier boards, not your Orin AGX system. So please don’t modify any files based on the nvdisp-init README for your system - it isn’t used at all. That includes your P3701.conf.common config file - leave it alone.
As to the UEFI RAS error you are seeing, Wayne can work with our UEFI team to diagnose that.
Here is an update: I used the uefi_jetson.bin from edk2-nvidia-r35.1.0.1 the latest release. It looks like the RAS error is not present anymore, however, a new error makes the boot unsuccessful.
Here is the last fragment of the booting process:
PROGRESS CODE: V02020000 I0
PROGRESS CODE: V02020004 I0
PROGRESS CODE: V02020003 I0
XhcCheckUrbResult: STALL_ERROR! Completecode = 6
XhcControlTransfer: error - Device Error, transfer - 2
XHCI: Don't support multi-TT feature for Hub now. (force to disable MTT)
PROGRESS CODE: V02020006 I0
DeviceDiscoveryBindingStart, failed to reset moduleDevice Error
TegraI2cStartRequest: No ACK received
Failed to read eeprom (No Response)
SNP:PHY: PhyDxeInitialization () Failed to reset Phy
DeviceDiscoveryBindingStart, driver returned Device Error to start notification
PROGRESS CODE: V02010000 I0
PROGRESS CODE: V02010004 I0
DeviceDiscoveryBindingStart, driver returned Unsupported to start notification
Jetson UEFI firmware (version 202209.0-a87aded built on 2022-10-07T21:37:20+00:0
0)
Press ESCAPE for boot options **********************************
** WARNING: Test Key is used. **
......PROGRESS CODE: V03051007 I0
InstallFdt: Installing Kernel DTB
Processing "L4T Configuration Settings" DTB overlay
Deleting fragment fragment@0
Processing "Add PCIe C5 dual mode support" DTB overlay
Deleting fragment fragment@1
Deleting fragment fragment@2
Processing "Jetson Concord (40Pin RT5658)" DTB overlay
Deleting fragment fragment@3
Deleting fragment fragment@4
Deleting fragment fragment@5
Deleting fragment fragment@6
Deleting fragment fragment@7
Deleting fragment fragment@8
Deleting fragment fragment@9
Deleting fragment fragment@12
Deleting fragment fragment@13
Deleting fragment fragment@14
Deleting fragment fragment@15
Processing "Add P3737 A03 Overlay Support" DTB overlay
Processing "Add P3737 A04 Overlay Support" DTB overlay
Processing "L4T Rootfs Information" DTB overlay
UpdateRamOopsMemory: RamOopsBase: 0x82C200000, RamOopsSize: 0x200000
PROGRESS CODE: V03051001 I0
[Bds]Booting UEFI eMMC Device
PROGRESS CODE: V03058000 I0
add-symbol-file /dvs/git/dirty/git-master_linux/out/nvidia/bootloader/uefi/Jetson_RELEASE/Build/Jetson/RELEASE_GCC5/AARCH64/Silicon/NVIDIA/Application/L4TLauncher/L4TLaunch0
Loading driver at 0x00822B3E000 EntryPoint=0x00822B487CC L4TLauncher.efi
PROGRESS CODE: V03058001 I0
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
ASSERT [DtPlatformDxe] /home/runner/work/edk2-nvidia/edk2-nvidia/workspace/edk2-nvidia/Silicon/NVIDIA/Library/MceAriLib/MceAriLib.c(385): Cluster < (LibPcdGet32(66U))
Resetting the system in 5 seconds.
I’m attaching the complete boot log OrinBoot.log (93.5 KB)
@WayneWWW can you help me to diagnose the UEFI error?
