The device boot up failed
Hi sir
the device boot up failed and enter into the UEFI shell, the attachment is the detailed log:
** WARNING: Test Key is used. **
L4TLauncher: Attempting Recovery Boot
Header not seen at either offset 0 or offset 0x1000
Failed to boot recovery:0 partition
UEFI Interactive Shell v2.2
EDK II
UEFI v2.70 (EDK II, 0x00010000)
Mapping table
bootup.txt (34.5 KB)
Hi sunjiandong,
Could your board boot up before?
and how did you flash the board?
Hi KevinFFF,
It can bootup successfully before.
It failed after I flash the kernel and dtb which we modified.
UEFI is driven by dtb.
What did you modify in dtb?
Could you help to clarify the issue through removing each custom modification in dtb?
Hi sir
we use the custom board. And the Jetpack is 5.1.1.
Do you mean the dtb can make the device enter into the UEFI?
No, what I mean is the configuration in device tree would affect the feature in UEFI, which will load dtb for initialization.
